Resolved Stop 0X0000009F The DRIVER_POWER_STATE_FAILURE
Discussion in 'Windows 7' started by Ancient, 2016/08/09.
  1. 2016/08/09
    Ancient
    Ancient New Member Thread Starter
    Hi Guys
    I would greatly appreciate assistance with the above error.
    I have installed the latest wfi and chipset drivers from the manufacturer (hp laptop )
    I can upload more, but do not know where to go from here.
    I found the dump files here :
    c$\Windows\System32\config\systemprofile\AppData\Local\CrashDumps
    I have ran a dump analyser and see this:
    Loading Dump File [\\Ox18593\c$\Windows\System32\config\systemprofile\AppData\Local\CrashDumps\wlanext.exe.2172.dmp]
    User Mini Dump File: Only registers, stack and portions of memory are available
    WARNING: Whitespace at start of path element
    Symbol search path is: .symfix
    Executable search path is:
    Windows 7 Version 7601 (Service Pack 1) MP (4 procs) Free x86 compatible
    Product: WinNt, suite: SingleUserTS
    Machine Name:
    Debug session time: Fri Aug 5 15:01:15.000 2016 (UTC + 1:00)
    System Uptime: not available
    Process Uptime: 0 days 0:00:59.000
    Loading unloaded module list
    This dump file has an exception of interest stored in it.
    The stored exception information can be accessed via .ecxr.
    (87c.898): Access violation - code c0000005 (first/second chance not available)
    eax=00000000 ebx=007bf010 ecx=00000400 edx=00000000 esi=00000002 edi=00000000
    eip=77066bf4 esp=007befc0 ebp=007bf05c iopl=0 nv up ei pl zr na pe nc
    cs=001b ss=0023 ds=0023 es=0023 fs=003b gs=0000 efl=00000246
    *** ERROR: Symbol file could not be found. Defaulted to export symbols for ntdll.dll -
    ntdll!KiFastSystemCallRet:
    77066bf4 c3 ret
    This is from another different dump file :
    Machine Name:
    Debug session time: Fri Aug 5 15:01:30.000 2016 (UTC + 1:00)
    Process Uptime: 0 days 0:01:13.000
    (b0c.ca0): Access violation - code c0000005 (first/second chance not available)
    eax=00000000 ebx=069bf104 ecx=00000400 edx=00000000 esi=00000002 edi=00000000
    eip=77066bf4 esp=069bf0b4 ebp=069bf150 iopl=0 nv up ei pl zr na pe nc
    77066bf4 c3 ret
  2. 2016/08/09
    Hi Ancient, Welcome to Windowsbbs! :)
    I would first try Performing a clean boot in Windows and see if the blue screens continue to occur.
    If the machine has another BSOD then Follow these instructions to post a Dump Data Log.
    If you do not have a dump, ensure that your machine is configured to write out a dump by following the directions from microsoft.
    Also please enter your System Details. It helps us in answering your questions.
    Ancient
    Hi Evan
    Apologies for the late reply, the unit is currently away for repair.
    I will re -post if the issue re-occurs.
    Many Thanks.
  5. 2016/09/19
    Ok then. Thanks for the update. :)
