Windows Vista Windows Booting Problem
Discussion in 'Legacy Windows' started by Supermaine, 2013/03/13.
  1. 2013/03/19
    Do you know the manufacturer of your motherboard? I would look at updating your BIOS to the latest version if you haven't done that already.
    When you don't change the boot order in the BIOS and Vista doesn't load do you get an error message or just a black screen?
  2. 2013/03/19
    Supermaine
    Supermaine Inactive Thread Starter
    The manufacturer is Phoenix. I don't know any specifics beyond that, or if there is a certain brand I have. But I do know that I haven't updated the BIOS since I purchased the computer, and this was back in maybe 08 or 09. How would I go about updating it?
    Yes, it gives me an error message. It actually gives me different ones at various times. As I said, it's given me the Windows Boot Manager screen a couple of times. Sometimes I get the screen that says insert the system disc, this one is the most frequent. Sometimes I get a screen that says something along the lines of windows didn't shut down properly (although it did). Sometimes I will get a port 01 message screen. And sometimes I will get a NVIDIA Boot Agent screen.
    So really, the error messages are hit and miss, I never know which one is going to pop up. However, the BIOS fix seems to work every time, regardless of the previous error.
    You have the Acer Aspire X1200 correct? When You go into the BIOS can you tell me the version that is installed? Its possible that you may already have the latest version installed but I need to verify that you have the older version installed before you download the newer version.
    Here is the download page for the latest BIOS for your motherboard, Updates and Drivers for Acer products. The latest BIOS that is available is from 2009. Assuming you have the older version from 2008 installed all you would have to do is download the .zip folder from the download link and run the .exe file to flash your BIOS.
  5. 2013/03/20
    Supermaine
    Yes, I just checked. I have the version from 08/14/2008. R01-A4.
    I'll go ahead and download/install the updated R01.B0 version now.
  6. 2013/03/20
    Supermaine
    I installed the update as you said to do and then rebooted the computer. Of course, it worked fine the first time. Then each additional time, I still have to enter the BIOS.
    The part that is frustrating me is the fact that when I go into the BIOS I don't have to change anything. It's already in the correct boot order. All I do is re-select what is already selected. I literally make zero changes, yet it works every single time.
    Any clue on what the next step would be? I could try to write each error out if you think that would be helpful.
  7. 2013/03/20
    Do you mean that rebooting the system causes it to enter the BIOS screen without having you press any key?
    If so, I'd try another keyboard.
  8. 2013/03/20
    So updating the BIOS and replacing the CMOS battery didn't help at all. Well just as another troubleshooting step, make sure there are no other peripheral devices plugged in that could be interfering with the machine starting up. Unplug all other peripheral devices from the machine if you have any installed and just leave the power cable, mouse, keyboard and monitor plugged into the machine and see if that helps.
    If there is no change then I think we may be looking at a hard drive problem such as a corrupted boot sector or some corrupted system files.
    Using your System Repair Disk, boot up the machine with it and on the Install Windows Vista screen click on Repair your computer. Then in the System Recovery Options window, click on Command Prompt.
    When the Command Prompt window opens type the following commands and press enter after entering each one:
    BootRec.exe /fixmbr
    BootRec.exe /fixboot
    BootRec.exe /RebuildBcd
    Close the Command Prompt and reboot the computer when finished. See if that makes any difference.
  9. 2013/03/20
    Supermaine
    In response to Arie:
    Yes I have to enter the BIOS myself. If not, error messages will pop up.
    In response to Evan Omo:
    Okay I will try that now.
    If it helps, I attached the pictures of the steps I have to take each time.
    As you can see, when first entering the BIOS everything is already perfect. Second step, I change the First Boot Device to any other one one.Then the third step, I change it right back to Hard Disk. Lastly, I save to CMOS and exit.
  10. 2013/03/20
    Supermaine
    Alright lol, time to update you on what happened.
    I inserted the system disc, and went to the command prompt. The first two commands worked perfectly. The third one said "The requested system device could not be found" (I took a pic of that screen in case you need to see it)
    I went ahead and restarted, and the windows boot manager screen came back up. This is the same problem I had before I posted this question. I had to restart and go back into system repair and try to repair the computer. After trying about five times it finally repaired correctly and now I'm here. I'm not sure if I'll have to run startup repair each time I want to boot back into windows, but that's how it was before, so I wouldn't be surprised. I guess I'm right back where I started lol.
  11. 2013/03/20
    Supermaine
    There's never just one error. There's been four or five that show up at any given time. I never know which one I'll get. Earlier I described most of them. Here's the paragraph:
    As far as checking out my drive, is there a way to know the manufacturer? I can't recall.
  13. 2013/03/20
    Try Speccy
  14. 2013/03/20
    Supermaine
    Thank you. And sorry I'm a little slow. I don't know what I need to look for on the Western Digital site. Here's all the information I got from the Speccy program.
    WDC WD32 00AAJS-22B4A SCSI Disk Device
    Manufacturer Western Digital
    Business Unit/Brand Desktop/WD Caviar
    RPM/Buffer Size or Attribute 7200 RPM with 8 MB cache
    Interface/Connector SATA 3 Gb/s with 22-pin SATA connector/SATA 1.5 Gb/s with 22-pin SATA connector (Mobile)
    Interface Fibre
    Capacity 298GB
    Real size 320,072,933,376 bytes
    RAID Type None
  15. 2013/03/20
  16. 2013/03/20
    Supermaine
    Run the extended test on the hard drive.
  18. 2013/03/21
    Supermaine
    Okay so I ran the extended test.
    It said: "The test found bad sectors that may be repairable"
    And it gave me the option to click Repair, so I did.
    It then said: "Error was detected while repairing bad sectors. Please contact WD technical support for help. "
  19. 2013/03/21
    You will need to check if the warranty on the drive has expired. I don't know about WD warranty, it might be 5 years, if you are unlucky, it will be 1 year. They won't replace the drive unless it is under warranty. Look up the warranty details for your model on the WD website.
    In the meantime, back up your data and investigate how you can get the "system" transferred over to the new drive.
  20. 2013/03/21
    Supermaine
    So basically I need a hard drive?
    When I booted up today I got a new error message. It said something along the lines of pxe-61: Media test failure, check cable.
  21. 2013/03/21
    Yeah that's what it looks like. I would back up your data as soon as possible and be looking at buying a new hard drive. But as Matt said check first to see if your hard drive is still under warranty.
