Resolved virtual memory low
Discussion in 'Windows XP' started by Trisha, 2010/09/24.
  1. 2010/09/24
    Trisha
    Trisha Inactive Thread Starter
    Hi folks I am hoping you can help me, I have been getting a virtual memory low message over the past 2 days when I switch on my laptop and as I am not a technically minded gal do not know what to do?!
    I have McAfee security program, Processor type is 1.60GHz Intel(R)Celeron(R)M, amount of Ram 1.12GB My C Drive total size is 21.2GB free space 8.14GB My virtual memory has custom size selected and shows initial size 288MB maximum 576 - does this info help?
    Would appreciate assistance with this as my laptop is now soooooo slowwwww!
  2. 2010/09/24
    wildfire
    wildfire Getting Old
    Remove the custom settings and let windows manage virtual memory, does that help?
    Trisha
    Thanks Wildfire for your message, do I check the box system managed size under virtual
  5. 2010/09/24
    Trisha
    memory which currently has custom as checked?
  6. 2010/09/24
    wildfire
    Yep, that's the one...
    Your system will probably still be slow but it should get rid of the memory low errors...
    Post back to confirm and we'll take a look at why your systems crawling.
  7. 2010/09/24
    Trisha
    Thanks for that I confirm have now done as requested, my restart took about 3 minutes to log on?
  8. 2010/09/24
    wildfire
    With no errors?
    If yes, can I advise you toward malware and virus removal.
    2 Reasons,
    1 - Malware is a common reason for slow computers and startup.
    2 - The logs you supply to Broni will help me see what is slowing your computer even if it is not malware.
    I'll be looking in on that thread but please be patient, Broni is a busy fella right now, follow the instructions below to the letter for a speedier response.
    Please read this and post requested logs in the Malware and virus removal board.
    NOTES:
    When posting the logs ensure word wrap is switched off (in notepad Uncheck Format->Word Wrap) as this makes them difficult to read.
    Be aware that only Malware analysts will advise and they are often busy. Your post will be taken on a first come first served basis but it may take a while before you receive a reply.
    Include a link to this thread if you can.
  9. 2010/09/24
    Trisha
    Thanks for that, I have saved log files to Desktop but can you tell me how I post them to malware & virus removal board?
  10. 2010/09/24
    wildfire
    Copy (ctrl-.C) and paste (ctrl-V) just post them as normal...
    1) Open DDS.LOG in notepad, ctrl-A (Select all), ctrl-c (copy), switch to your browser with new post, ctr-v (Paste).
    Post that then repeat for attach.txt
    I'll follow up your post with a link so don't worry about that.
  11. 2010/09/24
    Try another startup. Can also be a one time occurrence because a larger pagefile had to be created (on a slow hard drive).
  12. 2010/09/24
    Trisha
    Sorry Wildfire but I am having problems with posting! have got log files saved in Notepad, presume I need to open a new thread under malware and virus removal but cannot see how to paste contents of Notepad to new thread? sorry to be such a thicky?
  13. 2010/09/24
    Run chkdsk /f on your disk.
    I would also recommend that you set a custom size for pagefile where minimum = maximum & equal to about twice the RAM in your system, in your case make it around 2.5 GB.
    Pagefile can also suffer from fragmentation & the inbuilt defrag tool doesn't do anything about it. Download & install PageDefrag. It runs at boot & defragments paging files, event log files, and Registry hives (SAM, SYSTEM, SYSTEM.ALT, SECURITY, SOFTWARE, .DEFAULT), as well as shows how many fragments those files are in.
  14. 2010/09/24
    wildfire
    @rsinfo, customised pagefile settings is a partial cause of the original issue, we'll look at them later. For now XP's memory manager should be adequate ;)
    @Arie, Good Idea, I never thought of that but I've a feeling it won't be that simple.
    @Trisha, OK. Let's forget the logs for now. You're computer is getting on a bit, can you follow the instructions (using SIW) to complete your full system details specifically what OS (Home or Pro) and service pack you have.
  15. 2010/09/24
    Trisha
    OK guys have updated my system details as far as I am able - hope it makes sense, as I have stated I am not a technical gal!
  16. 2010/09/24
    Trisha
    Since we have started this thread I have not received any further low memory messages and my computer does seem faster!!
  17. 2010/09/24
    wildfire
    Still looking for XP Home/pro and Service Pack level (you didn't use SIW did you ;))
    Good to know your system is responding quicker though
