Windows Vista Very slow laptop
Discussion in 'Legacy Windows' started by PAUL SHILLAM, 2012/04/12.
  1. 2012/04/21
    PAUL SHILLAM Lifetime Subscription
    PAUL SHILLAM Well-Known Member Thread Starter
    I have now run the diags on the HDD with no problems found.
    I still have the problem of when the laptop is first switched on it will occasionaly freeze for anything up to six minutes and then it will come back to life. After it has been switched on for an hour or so it is ok.
  2. 2012/04/21
    SpywareDr
    Yes it boots up fine, but then it does boot up fine in windows vista, jut freezes every now and then until it's been up for an hour or two.
  5. 2012/04/21
    Have you tried following the instructions to disable all startup programs from post #11?
    Was there any change in your computers behavior?
  6. 2012/04/22
    The laptop does not appear to be slow anymore it's just the intermittent hangs when it is first switched on, ie cold. Disabling the startup programs doesn't alow me to use the pc in the way that causes the hangs. I normaly now only get one hang in a session. If I switch it off for an hour and then on it doesn't hang. Only get the problem when it has been off all night.
  7. 2012/04/22
    SpywareDr
  8. 2012/04/23
    I have run "Whats my computer doing?" and it shows Sidebar and DWM.Exe using the processor but it also shows MobileBroadband.exe using the HDD. Whilst I was watching what was running I had one of my hangs for six minutes with just these three progs' showing so I have disable MobileBroadband from starting up as I think it's odd that it showed it was using the HDD all the time. I await to see if theres any change.
  9. 2012/04/23
    SpywareDr
  10. 2012/04/26
    2 days without a hang since disabling mobilebroadband.exe, seems faster as well.
  11. 2012/04/26
    dnmacleod
    dnmacleod Well-Known Member
    Looks like you might have found out what was causing your issues Paul.
    I used to use mobile broadband some time ago - provided by T-Mobile and I have to say that it wasn't as easy to use as the brochure made out it to be. I had problems with the dongle overheating and also the sporadic nature of the conneciton. I also had serious problems with the software provided. In the end I got rid of it and simply created an ordinary connection and set up the dongle as a simple modem. That was how I got round it.
    Install the driver and nothing else. Then set up an ordinary connection. Its far from being a brilliant setup but it does get the job done (eventually) when there are no alternatives.
  12. 2012/04/26
    SpywareDr
    Good to hear you potentially found the problem. Thanks for posting back. :)
  13. 2012/04/26
    Thanks for the update. :)
  14. 2012/04/28
    Oh dear it just hung for several minutes whilst trying to open a document in email.
  15. 2012/04/28
    SpywareDr
  16. 2012/04/28
    dnmacleod
    Have you uninstalled the mobile broadband program or just disabled it?
    I'd also agree with SpywareDr and bin Mcafee.
  17. 2012/04/29
    Yeah see if uninstalling Mcafee and installing Microsoft Security Essentials makes any difference since you haven't specified if you have done that yet.
  18. 2012/05/10
    I tried uninstalling McaFee and installing windows security essentials but it's made no difference. The odd thing is I only get the intermittent hangs when it is first switched on in the morning, sometimes one sometimes two hangs, after it's been on for about an hour I get no further hangs.
  19. 2012/05/10
    SpywareDr
  20. 2012/05/10
    This is getting too complicated for me and as it's my wifes laptop and she says each time I try something it makes it worse, I think I'll give up.
    Thanks for all your help anyway.
