System Spec link
Discussion in 'Site Comments & Suggestions' started by tallin, 2013/04/04.
  1. 2013/04/04
    tallin
    tallin Well-Known Member Thread Starter
  2. 2013/04/04
    User CP near the top left side of the page. Then on the left of the next page, 2nd one down. System Specs.
    tallin
    I am talking about the direct link as in my first post here that does not work today, however it worked yesterday....thanks, but with respect, your way is almost going around the world to get there.:)
    Not my System Specs, the link to encourage others to post them....
    best regards,
  5. 2013/04/04
    I have no idea where your link is supposed to go. What did you click on to get that link?
  6. 2013/04/04
    tallin
    Arie's advice to post it when OP's don't post theirs. He often posts that link in his replies. He will no doubt correct it as it has become corrupted.
    kind regards,
  7. 2013/04/04
    Ok. Didn't know where it was supposed to go to. Have a great day. :D
  8. 2013/04/04
    tallin
  9. 2013/04/04
    I knew what it was when you posted what you did.
  10. 2013/04/04
    The problem is that you copied an invalid link i.e. you copied the text, not the link:
    http://www.windowsbbs.com/adding_sys...fications.html
    instead of
    http://www.windowsbbs.com/adding_system_specifications.html
  11. 2013/04/04
    tallin
    Thanks, I have made a note of my mistake -
    regards,
