Windows Vista System Security Center will not start
Discussion in 'Legacy Windows' started by larsonjean, 2014/03/05.
  1. 2014/03/05
    larsonjean
    larsonjean Well-Known Member Thread Starter
    Hi,
    A couple of days ago I noticed that I was niot able to access the internet so I decided to try "Diagnose Connection Problems. I tried the suggestions but to no avail.
    I then tried to Restore System files and settings and I got this message:
    "X No restore points have been created on your computer's system disk.
    I then tried to "open System Protection" and received this message:
    The System Restore wizard is already running. The program will now exit. "
    (It was not running.)
    Windows Security Center windows tells me: Security Center can't turn on Windows Firewall. As I look at the Security Center, the firewall is off and if I try to turn it on it won't turn on. It also said Automatic updating is off and when I try to turn it on it says, "Securityy Center can't change your automatic updating settings. Malware protection is on and I have run Malware Bytes several times whit one or two PUP files which I have deleted.
    I was able to finally run SFC and it created a CBS.log file which I finally found out how to open. It has about 126 pages of text so I don't think I should attach it.
    My question is, if possible, could I get my computer working without reformatting it. I have moved most of my documents to this laptop but I would much rather use my Windows Vista Desktop with my large monitor.
    Is there a place that I should start checking? I don't think I have been hit by a virus as I'm usually careful but one never knows.
    I would really appreciate some help with this as I have been trying to fix this problems for about 5 days.
    Thank you.
    I also ran "Error Checking" but this was no help either.
    Jeanne
  2. 2014/03/05
    Virus or Malware comes to mind here. What are you running for security?
    larsonjean
    Microsoft security essentials.
  5. 2014/03/05
    That is for a Virus only. Will not find any Malware/Spyware. You need special programs to do that. One that is really good at what it does for that in Malware Bytes. There is a FREE and a paid version. The FREE version does a good job.
    Usually a Virus or Malware will cause the problems you are having.
    You can download Malware Bytes to a thumb drive and try running it on the PC or else, try booting the PC in Safe Mode with Networking and see if it will let you get on line.
  6. 2014/03/05
    larsonjean
    I was able to run Malwarebytes and I received this message:
    The scan completed successfully. No malicious items were detected.
    I did run this earlier but I forgot to mention it.
    Thanks.
  7. 2014/03/05
    Whiskeyman Inactive Alumni
  8. 2014/03/05
    larsonjean
    OK, thank you so much. I will post in the Malware section.
    Jeanne
  9. 2014/03/05
    Full scan or Quick Scan? Did you update it before you ran it? They have at least 1 and sometimes 4 or 5 updates every day. I agree with Whiskeyman on posting in the Malware Section. Broni is good at what he does.
  10. 2014/03/06
    larsonjean
    Yes,I ran full scan but could not update it because I could not get on the internet.
    I posted as you advised to the Malware Forum and Broni is going to try to help me. I posted in the Malware section with the same title so maybe we will be able to close this issue out in this Forum. Right?. Thank you.
