Resolved IE has stopped working
Discussion in 'Internet Explorer & Microsoft Edge' started by BOBBO, 2017/05/22.
  1. 2017/06/03
    See: Dump Data collection tool and instructions
    It shouldn't open IE, but rather WE
  2. 2017/06/03
    BOBBO
    BOBBO Geek Member Thread Starter
    Finally! Here's the dump log:
    Opened log file 'c:debuglog.txt'
    Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
    Loading Dump File [C:\CrashDumps\iexplore.exe.5528.dmp]
    User Mini Dump File: Only registers, stack and portions of memory are available
    Symbol search path is: SRV*c:\symbols*Symbol information
    Executable search path is: C:\Windows;C:\Windows\system32;C:\Windows\system32\drivers
    Windows 7 Version 7601 (Service Pack 1) MP (4 procs) Free x86 compatible
    Product: WinNt, suite: SingleUserTS Personal
    Machine Name:
    Debug session time: Sat Jun 3 09:57:43.000 2017 (UTC - 7:00)
    System Uptime: not available
    Process Uptime: 0 days 0:00:04.000
    This dump file has a breakpoint exception stored in it.
    The stored exception information can be accessed via .ecxr.
    eax=00000000 ebx=002ff104 ecx=002ff7d0 edx=002ff7a9 esi=00000002 edi=00000000
    eip=77b8016d esp=002ff0b4 ebp=002ff150 iopl=0 nv up ei pl zr na pe nc
    cs=0023 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00000246
    ntdll!ZwWaitForMultipleObjects+0x15:
    77b8016d 83c404 add esp,4
    0:000> !analyze -v;r;kv;lmtn;.logclose;q
    * Exception Analysis *
    *** ERROR: Symbol file could not be found. Defaulted to export symbols for ole32.dll -
    *** ERROR: Symbol file could not be found. Defaulted to export symbols for IPSEng32.dll -
    *** ERROR: Module load completed but symbols could not be loaded for cmdshim32.dll
    GetPageUrlData failed, server returned HTTP status 404
    URL requested: http://watson.microsoft.com/StageOn...0_0/bbbbbbb4/80000003/003a0d06.htm?Retriage=1
    FAULTING_IP:
    +5550c
    003a0d06 cc int 3
    EXCEPTION_RECORD: ffffffff -- (.exr 0xffffffffffffffff)
    ExceptionAddress: 003a0d06
    ExceptionCode: 80000003 (Break instruction exception)
    ExceptionFlags: 00000000
    NumberParameters: 1
    Parameter[0]: 00000000
    DEFAULT_BUCKET_ID: STATUS_BREAKPOINT
    PROCESS_NAME: iexplore.exe
    ERROR_CODE: (NTSTATUS) 0x80000003 - {EXCEPTION} Breakpoint A breakpoint has been reached.
    EXCEPTION_CODE: (HRESULT) 0x80000003 (2147483651) - One or more arguments are invalid
    EXCEPTION_PARAMETER1: 00000000
    MOD_LIST: <ANALYSIS/>
    NTGLOBALFLAG: 0
    APPLICATION_VERIFIER_FLAGS: 0
    FAULTING_THREAD: 00001760
    PRIMARY_PROBLEM_CLASS: STATUS_BREAKPOINT
    BUGCHECK_STR: APPLICATION_FAULT_STATUS_BREAKPOINT
    LAST_CONTROL_TRANSFER: from 73f38fbc to 003a0d06
    STACK_TEXT:
    WARNING: Frame IP not in any known module. Following frames may be wrong.
    002ff734 73f38fbc 002ff7a9 002ff7d0 002ff7b0 0x3a0d06
    002ff7c4 75b92e66 00000000 00000000 00000000 guard32!Exported+0x5550c
    002ff7e4 77681ca6 77681d04 00000000 00000000 KERNELBASE!LoadLibraryExA+0x26
    002ff808 0114301d 002ff814 00000000 002ffa98 msvcrt!rand_s+0x55
    002ff818 0114261e 00300000 00000020 00000080 iexplore!AddBottomUpRandomization+0x20
    002ffa98 01141108 01140000 00000000 006612c0 iexplore!wWinMain+0x45
    002ffb2c 7589336a 7efde000 002ffb78 77b99902 iexplore!_imp_load__WaitForInputIdle+0x26c
    002ffb38 77b99902 7efde000 72bdb8f2 00000000 kernel32!BaseThreadInitThunk+0xe
    002ffb78 77b998d5 01141e40 7efde000 00000000 ntdll!__RtlUserThreadStart+0x70
    002ffb90 00000000 01141e40 7efde000 00000000 ntdll!_RtlUserThreadStart+0x1b
    STACK_COMMAND: ~0s; .ecxr ; kb
    FOLLOWUP_IP:
    guard32!Exported+5550c
    73f38fbc 8945dc mov dword ptr [ebp-24h],eax
    SYMBOL_STACK_INDEX: 1
    SYMBOL_NAME: guard32!Exported+5550c
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: guard32
    IMAGE_NAME: guard32.dll
    DEBUG_FLR_IMAGE_TIMESTAMP: 58fbd232
    FAILURE_BUCKET_ID: STATUS_BREAKPOINT_80000003_guard32.dll!Exported
    BUCKET_ID: APPLICATION_FAULT_STATUS_BREAKPOINT_guard32!Exported+5550c
    WATSON_STAGEONE_URL: http://watson.microsoft.com/StageOn...0_0/bbbbbbb4/80000003/003a0d06.htm?Retriage=1
    Followup: MachineOwner
    002ff0b4 75b9171a 00000002 002ff104 00000001 ntdll!ZwWaitForMultipleObjects+0x15 (FPO: [5,0,0])
    002ff150 758919fc 002ff104 002ff178 00000000 KERNELBASE!WaitForMultipleObjectsEx+0x100 (FPO: [Non-Fpo])
    002ff198 758941d8 00000002 7efde000 00000000 kernel32!WaitForMultipleObjectsExImplementation+0xe0 (FPO: [Non-Fpo])
    002ff1b4 758b80bc 00000002 002ff1e8 00000000 kernel32!WaitForMultipleObjects+0x18 (FPO: [Non-Fpo])
    002ff220 758b7f7b 002ff300 00000001 00000001 kernel32!WerpReportFaultInternal+0x186 (FPO: [Non-Fpo])
    002ff234 758b7870 002ff300 00000001 002ff2d0 kernel32!WerpReportFault+0x70 (FPO: [Non-Fpo])
    002ff244 758b77ef 002ff300 00000001 e6bf6429 kernel32!BasepReportFault+0x20 (FPO: [Non-Fpo])
    002ff2d0 77bd5be7 00000000 77bd5ac4 00000000 kernel32!UnhandledExceptionFilter+0x1af (FPO: [Non-Fpo])
    002ff2d8 77bd5ac4 00000000 002ffb78 77b8c620 ntdll!__RtlUserThreadStart+0x62 (FPO: [SEH])
    002ff2ec 77bd5951 00000000 00000000 00000000 ntdll!_EH4_CallFilterFunc+0x12 (FPO: [Uses EBP] [0,0,4])
    002ff314 77bc3529 fffffffe 002ffb68 002ff450 ntdll!_except_handler4+0x8e (FPO: [Non-Fpo])
    002ff338 77bc34fb 002ff400 002ffb68 002ff450 ntdll!ExecuteHandler2+0x26 (FPO: [Uses EBP] [5,3,1])
    002ff35c 77bc349c 002ff400 002ffb68 002ff450 ntdll!ExecuteHandler+0x24 (FPO: [5,0,3])
    002ff3e8 77b70143 002ff400 002ff450 002ff400 ntdll!RtlDispatchException+0x127 (FPO: [Non-Fpo])
    002ff3e8 003a0d06 002ff400 002ff450 002ff400 ntdll!KiUserExceptionDispatcher+0xf (FPO: [2,0,0]) (CONTEXT @ 002ff450)
    002ff7e4 77681ca6 77681d04 00000000 00000000 KERNELBASE!LoadLibraryExA+0x26 (FPO: [Non-Fpo])
    002ff808 0114301d 002ff814 00000000 002ffa98 msvcrt!rand_s+0x55 (FPO: [Non-Fpo])
    002ff818 0114261e 00300000 00000020 00000080 iexplore!AddBottomUpRandomization+0x20 (FPO: [Non-Fpo])
    002ffa98 01141108 01140000 00000000 006612c0 iexplore!wWinMain+0x45 (FPO: [Non-Fpo])
    002ffb2c 7589336a 7efde000 002ffb78 77b99902 iexplore!_imp_load__WaitForInputIdle+0x26c (FPO: [Non-Fpo])
    002ffb38 77b99902 7efde000 72bdb8f2 00000000 kernel32!BaseThreadInitThunk+0xe (FPO: [Non-Fpo])
    002ffb78 77b998d5 01141e40 7efde000 00000000 ntdll!__RtlUserThreadStart+0x70 (FPO: [Non-Fpo])
    002ffb90 00000000 01141e40 7efde000 00000000 ntdll!_RtlUserThreadStart+0x1b (FPO: [Non-Fpo])
    start end module name
    01140000 01208000 iexplore iexplore.exe Sat Apr 15 23:28:55 2017 (58F30F27)
    6d9a0000 6dc47000 IPSEng32 IPSEng32.dll Sat May 20 13:29:44 2017 (5920A738)
    6dd60000 6def1000 GdiPlus GdiPlus.dll Tue Mar 14 08:17:54 2017 (58C809A2)
    73ed0000 73ed7000 fltLib fltLib.dll Mon Jul 13 18:05:55 2009 (4A5BD9F3)
    73ee0000 73f97000 guard32 guard32.dll Sat Apr 22 14:59:14 2017 (58FBD232)
    74040000 74049000 version version.dll Mon Jul 13 18:11:07 2009 (4A5BDB2B)
    74050000 74053000 api_ms_win_core_synch_l1_2_0 api-ms-win-core-synch-l1-2-0.DLL Fri Jan 13 22:08:37 2017 (5879C065)
    744f0000 7452b000 IseGuard32 IseGuard32.dll Wed Mar 29 20:06:17 2017 (58DC7629)
    75010000 75041000 cmdshim32 cmdshim32.dll Sat Apr 22 14:58:56 2017 (58FBD220)
    753f0000 753fc000 CRYPTBASE CRYPTBASE.dll Thu Apr 27 17:07:20 2017 (590287B8)
    75400000 75460000 sspicli sspicli.dll Thu Apr 27 17:32:51 2017 (59028DB3)
    75460000 75466000 nsi nsi.dll Mon Jul 13 18:09:45 2009 (4A5BDAD9)
    75470000 75560000 rpcrt4 rpcrt4.dll Thu Apr 27 17:32:51 2017 (59028DB3)
    755f0000 75625000 ws2_32 ws2_32.dll Wed May 11 08:19:40 2016 (57334D8C)
    75630000 75865000 iertutil iertutil.dll Sun Apr 16 00:53:01 2017 (58F322DD)
    75870000 75874000 api_ms_win_downlevel_version_l1_1_0 api-ms-win-downlevel-version-l1-1-0.dll Sun Jan 13 13:11:07 2013 (50F322EB)
    75880000 75990000 kernel32 kernel32.dll Thu Apr 27 17:35:36 2017 (59028E58)
    75b80000 75bc7000 KERNELBASE KERNELBASE.dll Thu Apr 27 17:35:37 2017 (59028E59)
    75bd0000 7681c000 shell32 shell32.dll Mon Aug 29 08:12:52 2016 (57C450F4)
    76820000 76acb000 wininet wininet.dll Sat Apr 15 23:37:37 2017 (58F31131)
    76ad0000 76ae9000 sechost sechost.dll Mon May 25 10:59:00 2015 (556362E4)
    76c20000 76d7d000 ole32 ole32.dll Mon Apr 17 08:12:37 2017 (58F4DB65)
    76e40000 76e45000 api_ms_win_downlevel_advapi32_l1_1_0 api-ms-win-downlevel-advapi32-l1-1-0.dll Sun Jan 13 13:16:42 2013 (50F3243A)
    76eb0000 76f4d000 usp10 usp10.dll Fri Feb 10 08:17:55 2017 (589DE7B3)
    76f50000 76fa7000 shlwapi shlwapi.dll Sat Nov 20 04:06:58 2010 (4CE7B9E2)
    76fc0000 77050000 gdi32 gdi32.dll Fri Apr 07 08:22:12 2017 (58E7AEA4)
    77050000 7711d000 msctf msctf.dll Tue Oct 11 08:19:32 2016 (57FD0304)
    77120000 77125000 psapi psapi.dll Mon Jul 13 18:09:34 2009 (4A5BDACE)
    77140000 771a0000 imm32 imm32.dll Sat Nov 20 04:08:51 2010 (4CE7BA53)
    77240000 77243000 normaliz normaliz.dll Mon Jul 13 18:09:40 2009 (4A5BDAD4)
    77250000 7725b000 profapi profapi.dll Mon Jul 13 16:12:01 2009 (4A5BBF41)
    77310000 77314000 api_ms_win_downlevel_shlwapi_l1_1_0 api-ms-win-downlevel-shlwapi-l1-1-0.dll Sun Jan 13 13:17:03 2013 (50F3244F)
    77320000 7732a000 lpk lpk.dll Fri Mar 10 08:20:40 2017 (58C2D258)
    77330000 77334000 api_ms_win_downlevel_user32_l1_1_0 api-ms-win-downlevel-user32-l1-1-0.dll Sun Jan 13 13:11:21 2013 (50F322F9)
    77340000 77357000 userenv userenv.dll Sat Nov 20 04:08:08 2010 (4CE7BA28)
    77360000 77401000 advapi32 advapi32.dll Thu Apr 27 17:32:42 2017 (59028DAA)
    77410000 77510000 user32 user32.dll Thu Nov 10 08:19:40 2016 (58249E1C)
    77660000 7770c000 msvcrt msvcrt.dll Thu Dec 15 23:45:38 2011 (4EEAF722)
    77b30000 77b33000 api_ms_win_downlevel_normaliz_l1_1_0 api-ms-win-downlevel-normaliz-l1-1-0.dll Sun Jan 13 13:17:02 2013 (50F3244E)
    77b60000 77ce0000 ntdll ntdll.dll Thu Apr 27 17:32:51 2017 (59028DB3)
    Closing open log file c:debuglog.txt
    guard32.dll is part of Comodo Firewall. I would make sure you update it to make sure you have the latest version.
  5. 2017/06/04
    BOBBO
    I check frequently, I just checked again now and ran the update operation, apparently successfully. Is COMODO interfering with IE starting? Is the updating of it going to help fixing IE?
    EDIT: COMODO version 10.0 is loaded on my wife's laptop. Some on-line searching leads me to wonder if version 10 may not be compatible with Windows 7. Is that the problem?
    I still get the "Failed to connect to a windows service" warning each time I boot up.
  6. 2017/06/04
    COMODO ver.10 is compatible with Win7. No problem over there.
    Why don't you just uninstall it & check if your problem disappears.
  7. 2017/06/05
    BOBBO
    I uninstalled COMODO, rebooted, and IE still "has stopped working." OK for me to download and install COMODO now?
  8. 2017/06/05
    lj50 Lifetime Subscription
    How old is your router?
  9. 2017/06/05
    BOBBO
    I'd estimate it's 4 years old. This problem with IE not working is very recent, and my default browser (SeaMonkey) and other programs work OK.
  10. 2017/06/05
    BOBBO
    Interesting new development: Last night I discovered that the COMODO free firewall version installed in my desktop computer (details are in my signature below, same as the laptop this thread is concerned with) was version 8.2.0.4978, way out of date. For months, every time I'd update it the process would indicate updates are available, I'd click on Update, the process would proceed and end with a notice that the last update had been 14 months ago. Never any change in version. So last night I downloaded and installed the current version, 10.0.1.6223. Everything worked fine until a few minutes ago when I tried to run IE and it wouldn't open! Same problem as on the laptop, but no warning or error message like what appears on the laptop.
    There more and more appears to be a connection between COMODO's free firewall version 10 and Internet Explorer not running. What is it and what's the fix?
  11. 2017/06/05
    Mine was a lot older when it started doing the same thing yours is doing.
  12. 2017/06/05
    Why not disable Comodo and start Defender in W7 and see what happens? There may be a conflict in Comodo AV.
  13. 2017/06/05
    BOBBO
    Disabled COMODO in both my desktop and my wife's laptop. IE still doesn't start in either one, although in the laptop an "IE has stopped working" error message opens, but not in the desktop.
    By the way, my COMODO is the free firewall, not the AV. Both are the very latest version and updated today.
  14. 2017/06/06
    I would uninstall Comodo and just use Windows native firewall....
  15. 2017/06/06
    BOBBO
    It worked!! COMODO 10 has a nice uninstall utility and it cleaned out the Firewall easily. It also told me I had to uninstall Internet Security Essentials to complete the entire project, and after a restart I did that, too. When I clicked on the IE icon, the program opened right away and functioned as it's supposed to. Then I enabled the Windows Firewall. I did all that first on my desktop, then went through the same procedure on my wife's laptop. Now everything seems back to normal on both machines.
    The odd thing is, I'd uninstalled COMODO from the laptop before and it hadn't fixed the IE problem. The difference? I didn't know about ISE also needing to be uninstalled and that delayed achieving final success.
    Thanks to everyone who offered their help. I do appreciate it. I'll now mark the thread Solved.
  16. 2017/06/06
    Great to see you have sorted out the problem/s ;) It proves the point that 3rd. party software does not always work happily with the OS. Sometimes no matter how well it has worked in the past - they can hiccup.:oops:o_O
  17. 2017/06/06
    Just make sure that your Windows firewall is working.
  18. 2017/06/14
    Glad you got it solved. I've never been a fan of 3rd party FW or AV software post Windows XP ;)
