IE 8 does not open!
Discussion in 'Internet Explorer & Microsoft Edge' started by novintan, 2010/11/22.
  1. 2010/11/22
    novintan
    novintan Inactive Thread Starter
    when double click on shortcut internet explorer cannot runing!
    Internet option is not open double click!
    With unistall and reinstall the Internet Explorer problem is not resolved!
    Try the steps in this article: Internet Explorer does not start or stops responding" http://support.microsoft.com/kb/926449
    To open Internet Options do this if Internet Explorer does not open:
    a. Click start
    b. And click Run.
    c. Type "inetcpl.cpl" without the quotes and click Ok
    d. And try the steps in the above article.
    Not Worked!!
    Help me
  2. 2010/11/22
    markmadras
    markmadras Banned
    You followed the guide Step 1 which did not work, did you then follow instructions in Step 3, if not please try it.
    What version of Windows do you have.
    Did you switch off all security software when downloading and installing IE8.
    Have you just upgraded from IE7 or has IE8 been running OK and just failed.
    novintan
    -I did all steps but the problem is not resolved.
    -Windows XP SP3
    -Was performed once before but was having difficulty.
  5. 2010/11/22
    markmadras
    markmadras Banned
    You did not answer this question.
    Are you saying that you did have IE8 installed, but it did not work very well?
    Please click on the link below and follow the instructions. This will show you how to enter your systems details.
    http://www.windowsbbs.com/adding_system_specifications.html
    After you have filled in all your details do not forget to click on save changes, at the bottom of the page, If you don't do this your system details will not show under your member name in any of your posts.
  6. 2010/11/22
    novintan
    When installing I got off the Security.
    Already installed and worked but then trouble started.
  7. 2010/11/22
    markmadras
    markmadras Banned
    If you click on Start and then programs and click on Internet explorer in the programs list, will it open that way?
    If that doesn't work try this. Click Start and type iexplore.exe -extoff and hit Enter, then try to open IE8.
    If one of these solutions works then just reply telling me which one.
    If neither worked then I suspect you may have a virus or a malware infection, please follow the link below to have your PC checked for any infections.
    Please make sure you follow the instructions and do not miss anything or you may not receive the help you need.
    http://www.windowsbbs.com/malware-virus-removal/announcements.html
    You have not entered your system details as requested in post 4.
    I have already had to repeat two questions to get an answer, please try to answer all questions. If you come to a question you do not understand please say so, do not ignore it ;)
