Resolved DO NOT Run as Admin
Discussion in 'Windows 7' started by gw1500se, 2015/09/26.
  1. 2015/09/27
    SpywareDr
  2. 2015/09/27
    gw1500se
    gw1500se Well-Known Member Thread Starter
    If that is the case why does it NOT require admin rights when NOT in compatibility mode?
    SpywareDr
  5. 2015/09/27
    lj50 Lifetime Subscription
    Do you have the navigation path to that registry key?
  6. 2015/09/27
    SpywareDr
  7. 2015/09/27
    gw1500se
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers\
    C:\Games\Trains and Trucks Tycoon\Trains and Trucks Tycoon.exe WINXPSP3
  8. 2015/09/27
    gw1500se
    SpywareDr
    1) I was responding to lj50's question.
    2) I understand what you want to do. According to what I've seen so far on the 'net, it looks like the only way I might be able to figure how to run it without admin rights would require access to a computer running Windows 7, a copy of the program, some debug/hacking tools and some free time.
  10. 2015/09/28
    Doc and gw1500se. My apologies I didn't read the article my oversight.
  11. 2015/09/28
    gw1500se
    Probably not worth the effort. I guess just mark this thread as Unresolvable.
  12. 2015/09/28
    What folder is the app installed in? If it's in the Program Files (x86) folder you might try installing it to a user friendly folder that you create like C:\Tycoon
    It'd be interesting to know why you want this changed... If I were sitting there, I'd simply be happy that it worked on the newer OS.
  13. 2015/09/28
    gw1500se
    It is in c:\Games\Trains and Trucks Tycoon
    I agree it is mostly academic but don't like something running with admin rights that is not necessary. However, as I said if this is normal operation for something running in compatibility mode (which seems odd to begin with), it is not worth pursuing, at least in this case.
  14. 2015/09/28
    H_KEY_CURRENT_USER\Software\Microsoft\WindowsNT\CurremtVersion\AppCompatFlags\Layers. In the right pane key SIGN.MEDIA=A930B SETUP.EXE REG_SZ value of WINXPSP3. The HKLM navigational path has in the right pane key C:\Users\Username\Downloads\sp41377.exe REG_SZ and a value of WINXPSP2 and another key SIGN.IE=0646798 sp54714.exe REG_SZ with a value of WINXPSP2. My MS Flight Simulator 2002 runs fine in compatibility mode without any prompting for a need to run with administrative rights. My first install failed I couldn't get it to run. I uninstalled and reinstalled FS 2002. The reinstall works fine. I even got my MS Sidewinder Force Feedback 2 Joy Stick to install work, and even calibrated it. My apologies if you tried this already try uninstalling and reinstalling the game.
  15. 2015/09/29
    gw1500se
    Thanks and yes I have uninstalled and reinstalled. As I said this is just not worth any more effort.
  16. 2015/09/29
    I tried. I hope you figure it out.
