BSOD after system setting idle for 8 hours
Discussion in 'Windows XP' started by MitchellCooley, 2008/05/13.
  1. 2008/05/22
    MitchellCooley Inactive Thread Starter
    Mike, I'll take care of the cleanups now but will wait until I get home from work to do the upgrade. Gotta head out to work in about two hours.
    I'll post when I get started and when I finish.
    Mitch
  2. 2008/05/23
    Mike,
    SP3 installed without a hitch.
    I had to test it. Started Spybot S&D. It crashed.:(
    Oh well.
    Mitch
    mflynn
    mflynn Inactive
    Morning Mitch
    Time for a different route.
    Locate the Via and NIC updates you downloaded earlier so you will have them for later.
    Then uninstall from Add/Remove the Via software and the NIC software if any in Add/Remove.
    Then in Device mgr uninstall the NIC it will reinstall on reboot. I say this because Spybot runs OK in safe mode non network so it may be something to do with that.
    If there are issues then you may need to reinstall using the above software.
    Mike
  5. 2008/05/23
    ok. I get back to you shortly.
    Mitch
  6. 2008/05/23
    Success!!!!
    Mike,
    I must pay homage to you somehow. I tried it twice and no crashes. Jim will be quite pleased.
    With the generic video drivers though the scroll is a slow refresh...who cares, it's not crashing:D
    Mike, forget what I just said. I was reading posts on WindowsBBS, then decided to give Spybot one more try.........It crashed again.
    This is so frustrating
    Mitch
  7. 2008/05/23
    Mitch
    Never say die :) at least not when Mike's got his teeth into it.
  8. 2008/05/23
    Thanks Pete. I picked a bad time to stop smoking:)
    Mitch
  9. 2008/05/23
    mflynn
    mflynn Inactive
    OK Great but lets not stop here we need to do some finalizing!
    Go to system properties and turn off System Restore to clear old possibly bad restore data. Reboot once run Ccleaner and Atf-cleaner then reacitvate System Restore and do a fresh restore point.
    Then run the Erunt and create a registry backup.
    OK are you still running under msconfig clean boot! If so reverse that back to normal.
    The issue was probably fixed by the NIC procedure so reinstall the VIA updates.
    Reboot once again and test. If it works your Video should now be back to normal and also if it works the issue was in fact the NIC Driver.
    Mike
  10. 2008/05/23
    mflynn
    mflynn Inactive
    Opps you wer both posting while I was composing!
    Yuck!
    Did you do anything at all since you said it ran an when it failed again!
    Mike
  11. 2008/05/23
    The only thing I did was go to WindowsBBS and browse posts. I don't remember if I closed IE7 beforehand or not.
    Mitch
  12. 2008/05/23
    mflynn
    mflynn Inactive
    Make a mental note of post #88 as that is what we need to do when it is finished.
    Close all browser connections.
    Go to Local Area Connection properties, click Disable. This will kill the network and internet.
    To put this back later do the same but click Enable.
    Now run Spybot again to see if it runs OK now.
    Mike
  13. 2008/05/23
    Mike,
    Spybot appears to load just fine with the NIC disabled. I tried it three times just to be sure.
    Mitch
  14. 2008/05/23
    mflynn
    mflynn Inactive
    All Righty!!
    We have pinpointed the Gremlin!
    OK tell me the brand and model of the NIC! Is it an onboard NIC or a PCI card?
    And go ahead with the VIA reinstall! The Erunt, and reverse the msconfig clean boot.
    And try one more spbot test.
    Reboot with NIC enabled and do no internet do not update or anything.
    Find out if it runs more than once as long as network or internet has not been accesses. Which may be what happened when you thought it was fixed.
    Mike
    Mike
  15. 2008/05/23
    NIC is on board. Information here is from Everest (probably more than you wanted but.....
    Will report back after testing.
    Mitch
    --------[ Windows Network ]---------------------------------------------------------------------------------------------
    [ VIA PCI 10/100Mb Fast Ethernet Adapter ]
    Network Adapter Properties:
    Network Adapter VIA PCI 10/100Mb Fast Ethernet Adapter
    Interface Type Ethernet
    Hardware Address 00-30-18-B1-37-43
    Connection Name Local Area Connection 1
    Connection Speed 100 Mbps
    Network Adapter Manufacturer:
    Company Name VNT Technologies, Inc.
    Product Information http://www.vntek.com/en/products
    Driver Download http://www.vntek.com/en/resources/download-center/drivers.jsp
    --------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
    B00 D00 F00: VIA UniChrome KM266 Pro / KM400(A) / KN400(A) Chipset - System Controller
    Offset 00: 06 11 05 32 06 00 30 22 00 00 00 06 00 08 00 00
    Offset 10: 08 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00
    Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 06 11 05 32
    Offset 30: 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
    Offset 40: 00 19 88 80 82 44 01 00 08 99 88 80 82 44 00 00
    Offset 50: 08 80 00 CA 60 85 20 20 EE 00 10 10 20 20 20 20
    Offset 60: 40 FA 00 20 A6 99 C0 11 44 6D 54 D0 81 43 00 00
    Offset 70: A2 C8 00 01 C1 0F 50 00 01 00 00 00 00 00 12 02
    Offset 80: 02 C0 35 00 07 0A 00 1F 00 00 00 00 00 00 00 00
    Offset 90: 00 00 00 00 30 0F 01 00 00 00 00 00 00 00 00 00
    Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 21 98 00 00
    Offset B0: 7F 9B 01 96 68 00 00 02 88 00 00 01 00 09 FD 08
    Offset C0: 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
    Offset D0: 17 A3 69 EA 07 1C F1 19 72 FF 00 00 61 72 75 00
    Offset E0: 41 EE 66 00 20 FF 80 00 A6 87 EE 00 02 96 33 40
    Offset F0: 00 00 40 A0 84 00 84 00 00 03 F0 08 00 04 00 00
    B00 D12 F00: VIA 10/100 Fast Ethernet Adapter
    Offset 00: 06 11 65 30 07 00 10 02 74 00 00 02 08 20 00 00
    Offset 10: 01 E4 00 00 00 10 00 EA 00 00 00 00 00 00 00 00
    Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 06 11 02 01
    Offset 30: 00 00 00 00 40 00 00 00 00 00 00 00 0A 01 03 08
    Offset 40: 01 00 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
    Offset 50: 00 00 80 04 00 00 00 00 00 00 00 00 65 30 00 03
    Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  16. 2008/05/23
    mflynn
    mflynn Inactive
    OK we need a model number!
    Tell me what the properties on the NIC in device manager says.
    Then go into the BIOs and see what info it has as far as neme etc.
    Get that to me.
    But here is the plan when we are sure we have the correct model.
    We are going to uninsatall the NIC from Device Mgr.
    Then reboot not allow it to get back into windows hit the f2 or Del to go into the BIOS and disable the onboard NIC.
    Then boot to Safe mode run a CCleaner registry clean to clean out the settings for the NIC.
    boot to normal mode with it still disabled run cclean again
    then reboot back to BIOS renable the onboard NIC
    then let it reinstall on boot (will need the drivers).
    Mike
  17. 2008/05/23
    mflynn
    mflynn Inactive
  18. 2008/05/23
    Sorry for the jumble of info.
    Ran Spybot right after reboot. Started fine. Closed it. Started again - crash.
    Properties in Devmgr does not show a model number. I guess I'm stupid...point me in the right direction
    VIA PCI 10/100Mb Fast Ethernet Adapter #2
    Manufac: Via Technologies
    Mitch
  19. 2008/05/23
    mflynn
    mflynn Inactive
    No not stupid it may not have a good description but a generic.
    So run the 2 programs above and see what they say.
    Mike
  20. 2008/05/23
    VIA VT6102 Rhine II Fast Ethernet Adapter
  21. 2008/05/23
    mflynn
    mflynn Inactive
