XP Crash, need help with Debug Log
Discussion in 'Windows XP' started by MitchellCooley, 2007/07/21.
  1. 2007/07/21
    MitchellCooley Inactive Thread Starter
    I came home from work. Reading email. Sygate told me AVG was trying to contact update service. I said remember and ok, system crashed. When system restarted it asked to send error report. Then I got a web site which said there may be a problem with BIOS or RAM. Installed new RAM more than a week ago and all has been fine. AMI BIOS is dated 1999. Never have flashed a bios. Don't want to *****(sorry) mess this up. Debug log as follows:
    Opened log file 'c:\debuglog.txt'
    Microsoft (R) Windows Debugger Version 6.7.0005.1
    Loading Dump File [C:\WINDOWS\Minidump\Mini072107-01.dmp]
    Executable search path is: C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS\system32\drivers
    Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS Personal
    Built by: 2600.xpsp_sp2_gdr.070227-2254
    Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a620
    Debug session time: Sat Jul 21 08:45:58.532 2007 (GMT-5)
    System Uptime: 2 days 14:51:46.153
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    BugCheck 100000D0, {8, 2, 0, 805494ec}
    Probably caused by : HTTP.sys ( HTTP!UlIsLowNPPCondition+2e )
    Followup: MachineOwner
    kd> !analyze -v;r;kv;lmtn;.logclose;q
    DRIVER_CORRUPTED_MMPOOL (d0)
    Arguments:
    Arg1: 00000008, memory referenced
    Arg2: 00000002, IRQL
    Arg3: 00000000, value 0 = read operation, 1 = write operation
    Arg4: 805494ec, address which referenced memory
    interrupt request level (IRQL) that is too high. This is
    caused by drivers that have corrupted the system pool. Run the driver
    verifier against any new (or suspect) drivers, and if that doesn't turn up
    the culprit, then use gflags to enable special pool. You can also set
    HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\ProtectNonPagedPool
    to a DWORD 1 value and reboot. Then the system will unmap freed nonpaged pool,
    preventing drivers (although not DMA-hardware) from corrupting the pool.
    Debugging Details:
    READ_ADDRESS: GetUlongFromAddress: unable to read from 8055ee48
    00000008
    CURRENT_IRQL: 2
    FAULTING_IP:
    nt!MiAllocatePoolPages+58
    805494ec 3918 cmp dword ptr [eax],ebx
    CUSTOMER_CRASH_COUNT: 1
    DEFAULT_BUCKET_ID: INTEL_CPU_MICROCODE_ZERO
    BUGCHECK_STR: 0xD0
    PROCESS_NAME: System
    LAST_CONTROL_TRANSFER: from 8054ade1 to 805494ec
    STACK_TEXT:
    f023ac48 8054ade1 00000000 00020000 00000000 nt!MiAllocatePoolPages+0x58
    f023acb0 804eb37f 00000000 00020000 42416c55 nt!ExAllocatePoolWithTag+0x10b
    f023accc efc0c444 00000000 00020000 42416c55 nt!ExAllocatePoolWithTagPriority+0x58
    f023ad50 efc105a2 efc1ad20 81ab25e8 00000000 HTTP!UlIsLowNPPCondition+0x2e
    f023ad88 efc31a09 efc3183a efc1cda0 00000000 HTTP!UlpTimeoutCheckExpiry+0x48
    f023ad8c efc3183a efc1cda0 00000000 82a3fba0 HTTP!UlpTimeoutMonitorWorker+0x5
    f023adac 8057d0f1 00000001 00000000 00000000 HTTP!UlpThreadPoolWorker+0x1c0
    f023addc 804f827a efc3167a 81ab25e8 00000000 nt!PspSystemThreadStartup+0x34
    00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    efc0c444 85c0 test eax,eax
    SYMBOL_STACK_INDEX: 3
    SYMBOL_NAME: HTTP!UlIsLowNPPCondition+2e
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: HTTP
    IMAGE_NAME: HTTP.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 441a03c5
    FAILURE_BUCKET_ID: 0xD0_HTTP!UlIsLowNPPCondition+2e
    eax=00000008 ebx=00000020 ecx=814be000 edx=00000001 esi=00000000 edi=8055a3d8
    eip=805494ec esp=f023ac0c ebp=f023ac48 iopl=0 nv up ei ng nz ac pe cy
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010297
    nt!MiAllocatePoolPages+0x58:
    805494ec 3918 cmp dword ptr [eax],ebx ds:0023:00000008=????????
    f023ac48 8054ade1 00000000 00020000 00000000 nt!MiAllocatePoolPages+0x58 (FPO: [Non-Fpo])
    f023acb0 804eb37f 00000000 00020000 42416c55 nt!ExAllocatePoolWithTag+0x10b (FPO: [Non-Fpo])
    f023accc efc0c444 00000000 00020000 42416c55 nt!ExAllocatePoolWithTagPriority+0x58 (FPO: [Non-Fpo])
    f023ad50 efc105a2 efc1ad20 81ab25e8 00000000 HTTP!UlIsLowNPPCondition+0x2e (FPO: [Non-Fpo])
    f023ad88 efc31a09 efc3183a efc1cda0 00000000 HTTP!UlpTimeoutCheckExpiry+0x48 (FPO: [Non-Fpo])
    f023ad8c efc3183a efc1cda0 00000000 82a3fba0 HTTP!UlpTimeoutMonitorWorker+0x5 (FPO: [1,0,0])
    f023adac 8057d0f1 00000001 00000000 00000000 HTTP!UlpThreadPoolWorker+0x1c0 (FPO: [Non-Fpo])
    f023addc 804f827a efc3167a 81ab25e8 00000000 nt!PspSystemThreadStartup+0x34 (FPO: [Non-Fpo])
    start end module name
    804d7000 806eb500 nt ntoskrnl.exe Wed Feb 28 03:10:41 2007 (45E54711)
    806ec000 80705c00 hal hal.dll Wed Aug 04 00:59:18 2004 (41107B36)
    bf800000 bf9c2180 win32k win32k.sys Thu Mar 08 07:47:34 2007 (45F013F6)
    bf9c3000 bf9d4580 dxg dxg.sys Wed Aug 04 01:00:51 2004 (41107B93)
    bf9d5000 bfa0b000 ati2dvag ati2dvag.dll Wed Aug 04 02:56:47 2004 (411096BF)
    bfa0b000 bfa43000 ati2cqag ati2cqag.dll Wed Aug 04 02:56:45 2004 (411096BD)
    bfa43000 bfb17980 ati3d1ag ati3d1ag.dll Wed Aug 04 02:56:48 2004 (411096C0)
    ef659000 ef683180 kmixer kmixer.sys Wed Jun 14 03:47:45 2006 (448FCD31)
    efbff000 efc3f280 HTTP HTTP.sys Thu Mar 16 19:33:09 2006 (441A03C5)
    efea6000 efeb5900 Cdfs Cdfs.SYS Wed Aug 04 01:14:09 2004 (41107EB1)
    eff64000 eff78400 wdmaud wdmaud.sys Wed Jun 14 04:00:44 2006 (448FD03C)
    f01d1000 f0222480 srv srv.sys Mon Aug 14 05:34:39 2006 (44E051BF)
    f029b000 f02c7400 mrxdav mrxdav.sys Wed Aug 04 01:00:49 2004 (41107B91)
    f0394000 f0396120 wg5n wg5n.sys Wed Oct 13 18:56:33 2004 (416DC0B1)
    f03a4000 f03a6120 wg4n wg4n.sys Wed Oct 13 18:56:32 2004 (416DC0B0)
    f03ac000 f03ae120 wg3n wg3n.sys Wed Oct 13 18:56:30 2004 (416DC0AE)
    f03d4000 f03d7280 ndisuio ndisuio.sys Wed Aug 04 01:03:10 2004 (41107C1E)
    f03e0000 f03f7480 dump_atapi dump_atapi.sys Wed Aug 04 00:59:41 2004 (41107B4D)
    f03f8000 f041b000 Fastfat Fastfat.SYS Wed Aug 04 01:14:15 2004 (41107EB7)
    f041b000 f04e36c0 avg7core avg7core.sys Fri Jun 15 04:13:22 2007 (46725832)
    f04e4000 f0552a00 mrxsmb mrxsmb.sys Fri May 05 04:41:42 2006 (445B1DD6)
    f0627000 f0651a00 rdbss rdbss.sys Fri May 05 04:47:55 2006 (445B1F4B)
    f06af000 f06d0d00 afd afd.sys Wed Aug 04 01:14:13 2004 (41107EB5)
    f06e2000 f0709c00 netbt netbt.sys Wed Aug 04 01:14:36 2004 (41107ECC)
    f074e000 f076ef00 ipnat ipnat.sys Wed Sep 29 17:28:36 2004 (415B3714)
    f086c000 f0874880 Fips Fips.SYS Fri Aug 17 20:31:49 2001 (3B7DC585)
    f1466000 f14bdd80 tcpip tcpip.sys Thu Apr 20 06:51:47 2006 (444775D3)
    f14ea000 f14fc400 ipsec ipsec.sys Wed Aug 04 01:14:27 2004 (41107EC3)
    f167f000 f1685780 USBSTOR USBSTOR.SYS Wed Aug 04 01:08:44 2004 (41107D6C)
    f63a6000 f63ae700 netbios netbios.sys Wed Aug 04 01:03:19 2004 (41107C27)
    f63b6000 f63be700 wanarp wanarp.sys Wed Aug 04 01:04:57 2004 (41107C89)
    f6604000 f6608500 watchdog watchdog.sys Wed Aug 04 01:07:32 2004 (41107D24)
    f6682000 f668b000 wpsdrvnt wpsdrvnt.sys Fri Oct 15 20:18:45 2004 (417076F5)
    f6cfc000 f6cfe280 rasacd rasacd.sys Fri Aug 17 15:55:39 2001 (3B7D84CB)
    f6f6c000 f6f7f900 parport parport.sys Wed Aug 04 00:59:04 2004 (41107B28)
    f6f9f000 f6ff7e80 update update.sys Mon Apr 23 05:32:54 2007 (462C8B56)
    f70e9000 f70fc780 VIDEOPRT VIDEOPRT.SYS Wed Aug 04 01:07:04 2004 (41107D08)
    f7121000 f71e8000 ati2mtag ati2mtag.sys Fri May 28 15:26:05 2004 (40B7A05D)
    f71e8000 f720b980 portcls portcls.sys Wed Aug 04 01:15:47 2004 (41107F13)
    f720c000 f721e000 cwrwdm cwrwdm.sys Thu Feb 26 15:20:22 2004 (403E6316)
    f721e000 f7240680 ks ks.sys Wed Aug 04 01:15:20 2004 (41107EF8)
    f726a000 f728ce80 USBPORT USBPORT.SYS Wed Aug 04 01:08:34 2004 (41107D62)
    f72aa000 f72bae00 psched psched.sys Wed Aug 04 01:04:16 2004 (41107C60)
    f72bb000 f72d1680 ndiswan ndiswan.sys Wed Aug 04 01:14:30 2004 (41107EC6)
    f72f2000 f72fbf00 termdd termdd.sys Wed Aug 04 00:58:52 2004 (41107B1C)
    f7322000 f7330b80 drmk drmk.sys Wed Aug 04 01:07:54 2004 (41107D3A)
    f7352000 f7360080 redbook redbook.sys Wed Aug 04 00:59:34 2004 (41107B46)
    f7362000 f736e180 cdrom cdrom.sys Wed Aug 04 00:59:52 2004 (41107B58)
    f74bd000 f74bf900 Dxapi Dxapi.sys Fri Aug 17 15:53:19 2001 (3B7D843F)
    f74c5000 f74c7120 wg6n wg6n.sys Wed Oct 13 18:56:34 2004 (416DC0B2)
    f74fd000 f7517580 Mup Mup.sys Wed Aug 04 01:15:20 2004 (41107EF8)
    f7518000 f7535000 Teefer Teefer.sys Fri Oct 15 20:17:00 2004 (4170768C)
    f7535000 f7561a80 NDIS NDIS.sys Wed Aug 04 01:14:27 2004 (41107EC3)
    f7562000 f75ee400 Ntfs Ntfs.sys Fri Feb 09 05:10:31 2007 (45CC56A7)
    f75ef000 f7605780 KSecDD KSecDD.sys Wed Aug 04 00:59:45 2004 (41107B51)
    f7606000 f7625780 fltmgr fltmgr.sys Mon Aug 21 04:14:57 2006 (44E97991)
    f7626000 f763d800 SCSIPORT SCSIPORT.SYS Wed Aug 04 00:59:39 2004 (41107B4B)
    f763e000 f7655480 atapi atapi.sys Wed Aug 04 00:59:41 2004 (41107B4D)
    f7656000 f7674880 ftdisk ftdisk.sys Fri Aug 17 15:52:41 2001 (3B7D8419)
    f7675000 f7685a80 pci pci.sys Wed Aug 04 01:07:45 2004 (41107D31)
    f76a7000 f76afc00 isapnp isapnp.sys Fri Aug 17 15:58:01 2001 (3B7D8559)
    f76b7000 f76c1500 MountMgr MountMgr.sys Wed Aug 04 00:58:29 2004 (41107B05)
    f76c7000 f76d3c80 VolSnap VolSnap.sys Wed Aug 04 01:00:14 2004 (41107B6E)
    f76d7000 f76dfe00 disk disk.sys Wed Aug 04 00:59:53 2004 (41107B59)
    f76e7000 f76f3200 CLASSPNP CLASSPNP.SYS Wed Aug 04 01:14:26 2004 (41107EC2)
    f76f7000 f7701700 alim1541 alim1541.sys Wed Aug 04 01:07:40 2004 (41107D2C)
    f7727000 f7735d80 sysaudio sysaudio.sys Wed Aug 04 01:15:54 2004 (41107F1A)
    f7737000 f7743e00 i8042prt i8042prt.sys Wed Aug 04 01:14:36 2004 (41107ECC)
    f77b7000 f77c3880 rasl2tp rasl2tp.sys Wed Aug 04 01:14:21 2004 (41107EBD)
    f77c7000 f77d1200 raspppoe raspppoe.sys Wed Aug 04 01:05:06 2004 (41107C92)
    f77d7000 f77e2d00 raspptp raspptp.sys Wed Aug 04 01:14:26 2004 (41107EC2)
    f77f7000 f77ff900 msgpc msgpc.sys Wed Aug 04 01:04:11 2004 (41107C5B)
    f7827000 f782fd80 AN983 AN983.sys Thu Oct 25 01:42:09 2001 (3BD7B441)
    f7847000 f7856d80 serial serial.sys Wed Aug 04 01:15:51 2004 (41107F17)
    f7857000 f7860480 NDProxy NDProxy.SYS Fri Aug 17 15:55:30 2001 (3B7D84C2)
    f7867000 f7871380 imapi imapi.sys Wed Aug 04 01:00:12 2004 (41107B6C)
    f78c7000 f78d5100 usbhub usbhub.sys Wed Aug 04 01:08:40 2004 (41107D68)
    f7927000 f792d200 PCIIDEX PCIIDEX.SYS Wed Aug 04 00:59:40 2004 (41107B4C)
    f792f000 f7933900 PartMgr PartMgr.sys Fri Aug 17 20:32:23 2001 (3B7DC5A7)
    f797f000 f7985000 kbdclass kbdclass.sys Wed Aug 04 00:58:32 2004 (41107B08)
    f798f000 f7994a00 mouclass mouclass.sys Wed Aug 04 00:58:32 2004 (41107B08)
    f79a7000 f79a8000 fdc fdc.sys unavailable (00000000)
    f79d7000 f79ddc80 avg7rsxp avg7rsxp.sys Tue Jan 30 09:08:42 2007 (45BF5F7A)
    f79df000 f79e4000 flpydisk flpydisk.sys Wed Aug 04 00:59:24 2004 (41107B3C)
    f7a47000 f7a4c200 vga vga.sys Wed Aug 04 01:07:06 2004 (41107D0A)
    f7a4f000 f7a53a80 Msfs Msfs.SYS Wed Aug 04 01:00:37 2004 (41107B85)
    f7a77000 f7a7e880 Npfs Npfs.SYS Wed Aug 04 01:00:38 2004 (41107B86)
    f7a97000 f7a9b880 TDI TDI.SYS Wed Aug 04 01:07:47 2004 (41107D33)
    f7a9f000 f7aa3580 ptilink ptilink.sys Fri Aug 17 15:49:53 2001 (3B7D8371)
    f7aa7000 f7aab080 raspti raspti.sys Fri Aug 17 15:55:32 2001 (3B7D84C4)
    f7aaf000 f7ab3280 usbohci usbohci.sys Wed Aug 04 01:08:34 2004 (41107D62)
    f7ab7000 f7aba000 BOOTVID BOOTVID.dll Fri Aug 17 15:49:09 2001 (3B7D8345)
    f7abb000 f7abee00 vburner vburner.sys Thu Jul 05 00:23:58 2007 (468C806E)
    f7b4b000 f7b4d980 gameenum gameenum.sys Wed Aug 04 01:08:20 2004 (41107D54)
    f7b5f000 f7b61580 ndistapi ndistapi.sys Fri Aug 17 15:55:29 2001 (3B7D84C1)
    f7b7b000 f7b7ec80 mssmbios mssmbios.sys Wed Aug 04 01:07:47 2004 (41107D33)
    f7b83000 f7b86c80 serenum serenum.sys Wed Aug 04 00:59:06 2004 (41107B2A)
    f7ba7000 f7ba8b80 kdcom kdcom.dll Fri Aug 17 15:49:10 2001 (3B7D8346)
    f7ba9000 f7baa480 aliide aliide.sys Fri Aug 17 15:51:54 2001 (3B7D83EA)
    f7bab000 f7bac100 WMILIB WMILIB.SYS Fri Aug 17 16:07:23 2001 (3B7D878B)
    f7bcb000 f7bcc080 avg7rsw avg7rsw.sys Tue Jul 26 07:10:51 2005 (42E6284B)
    f7bcf000 f7bd0100 swenum swenum.sys Wed Aug 04 00:58:41 2004 (41107B11)
    f7bdf000 f7be0280 USBD USBD.SYS Fri Aug 17 16:02:58 2001 (3B7D8682)
    f7bf5000 f7bf6360 avgtdi avgtdi.sys Thu Aug 25 04:59:58 2005 (430D969E)
    f7bf9000 f7bfa100 dump_WMILIB dump_WMILIB.SYS Fri Aug 17 16:07:23 2001 (3B7D878B)
    f7c09000 f7c0af00 Fs_Rec Fs_Rec.SYS Fri Aug 17 15:49:37 2001 (3B7D8361)
    f7c0b000 f7c0c080 Beep Beep.SYS Fri Aug 17 15:47:33 2001 (3B7D82E5)
    f7c0f000 f7c10080 mnmdd mnmdd.SYS Fri Aug 17 15:57:28 2001 (3B7D8538)
    f7c11000 f7c12080 RDPCDD RDPCDD.sys Fri Aug 17 15:46:56 2001 (3B7D82C0)
    f7c35000 f7c36a80 ParVdm ParVdm.SYS Fri Aug 17 15:49:49 2001 (3B7D836D)
    f7c9b000 f7c9bc00 audstub audstub.sys Fri Aug 17 15:59:40 2001 (3B7D85BC)
    f7cd4000 f7cd4b80 Null Null.SYS Fri Aug 17 15:47:39 2001 (3B7D82EB)
    f7cd5000 f7cd5f80 avgclean avgclean.sys Mon Aug 21 17:55:15 2006 (44EA39D3)
    f7d2d000 f7d2dd00 dxgthk dxgthk.sys Fri Aug 17 15:53:12 2001 (3B7D8438)
    Unloaded modules:
    ef659000 ef684000 kmixer.sys
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    ef724000 ef74f000 kmixer.sys
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    f7c47000 f7c49000 kerneld.wnt
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    f7be1000 f7be3000 kerneld.wnt
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    ef9f1000 efa1c000 kmixer.sys
    Checksum: 00000000
    efbac000 efbd7000 kmixer.sys
    Checksum: 00000000
    eff16000 eff41000 kmixer.sys
    Checksum: 00000000
    eff41000 eff64000 aec.sys
    Checksum: 00000000
    f7ced000 f7cee000 drmkaud.sys
    Checksum: 00000000
    f0089000 f0096000 DMusic.sys
    Checksum: 00000000
    f082c000 f083a000 swmidi.sys
    Checksum: 00000000
    f7bc1000 f7bc3000 splitter.sys
    Checksum: 00000000
    f7a3f000 f7a44000 Cdaudio.SYS
    Checksum: 00000000
    f6d00000 f6d03000 Sfloppy.SYS
    Checksum: 00000000
    Closing open log file c:\debuglog.txt
  2. 2007/07/22
    did I post this in the wrong place or did I just pick a bad day?
    Neither :)
    Interpretation of dump data is a complex business requiring expert knowledge and unfortunately we have no regular poster on the Board with that knowledge. The one guy who is able to analyse these logs has not been seen for some time and has not responded to a PM for help in another thread. All we can do is to make observations - if the cause is obvious recommendations can be made. My reference source for Stop Errors has no info on 0x000000D0: DRIVER_CORRUPTED_MMPOOL.
    Is this a one off or continuing BSOD? Is the computer still running?
    I would suggest checking out that memory using Windows Memory Diagnostic Tool or memtest for a start.
  5. 2007/07/22
    Sorry for my impatience. This is an old computer and would hate to think I would have to spend money I don't have to get a new one or fix this one.
    Now to my problem: This is a one time occurance. Hasn't happened before or since.
    Will check my memory to be on the safe side. Motherboard (amptron 3726(m)t) calls for pc100 but installed three sticks of PC133 ram a few weeks ago.
    Thanks for the reply, Pete.
    Mitch
  6. 2007/07/23
    Hello Mitch, we meet again :)
    It is somewhat dangerous to read too much into one dump log. It may have occurred by some reason that will only occur once. We might all spend a lot of time chasing phantoms.
    Only worry if it starts to become an ongoing occurrence.
    Is this install of Windows starting to get old? If you install Windows and never install any programs or go on the internet it should still work a hundred years from now. If you add and remove programs, pick up internet junk (mostly unknowingly), Windows starts to get "tired" and eventually will need to be freshly installed. I say this because, looking at the dump, there are quite a few modules loaded. Check what is loading at startup (the programs running in the Notification Tray near the clock, and maybe some running invisibly in the background), these fill your memory/RAM, they can try to connect to internet when you are not expecting it.
    You might want an antivirus updater running in the background, but not a printer software updater program :rolleyes: I disable updaters and run them myself manually.
    You can see the basic startup programs by going to Start -> Run and entering msconfig -> Startup tab (if they are not running, say, as services). You can usually disable startup programs you see in the Notification Tray by going to their menu Tools -> Options.
    It sounds like you are interested in keeping Windows going well (some people format and reinstall regularly...me, I try to see how long an install will last). It may be a matter of keeping an eye on what is happening in the background.
    Edit:
    If the old (PC100) module is still installed try removing it and just running the PC133. It would help if the PC133 modules were "matching ".
    Don't throw a lot of money at trying to fix a hardware problem when it turns out to be a software problem (maybe my point in this post).
  7. 2007/07/23
    Mitch - and Matt
    I recently started using CodeStuff Starter for controlling startups rather than Mike Lin's Startup Control Panel or msconfig. Give it a whirl - it's very clear and simple to understand - which suits me fine :)
  8. 2007/07/23
    Matt, thanks for the advice. I will heed it. BTW, only PC133 installed. Three sticks 128MB.
    Pete, thanks for the link. Downloaded and installed.
    Mitch
  9. 2007/07/24
    Thanks Pete, keep that one up your sleeve. My new ISP has bamboozled me and I have lost all my regular download usage for the coming month :eek:
    Thinking about it, I have Startup Control Panel in my utilities, but have never actually used it. I use Hijack This to see what is loading, but I investigate those that I am not familiar with and then disable them within their main program or find a way to uninstall them...for minor pests I use msconfig.
