Active Zeus infection strikes again...
Discussion in 'Malware and Virus Removal Archive' started by SxRacer108, 2010/02/17.
  1. 2010/03/01
    Please download JavaRa to your desktop and unzip it to its own folder
    • Accept any prompts.
    • Open JavaRa.exe again and select Search For Updates.
    • Select Update Using Sun Java's Website then click Search and click on the Open Webpage button. Download and install the latest Java Runtime Environment (JRE) version for your computer.
    Unless you installed Viewpoint Manager knowledgeably...
    Go Start>Control Panel>Add\Remove (Programs and Features in Vista), and...
    Uninstall any of the following programs associated with Viewpoint:
    * Viewpoint Manager
    * Viewpoint Media Player
    * Viewpoint Toolbar
    This program does not do anything bad such as deliver ads or spy on you, but it is considered foistware ( "drive-by-install ") as it is installed without your consent through programs like AOl, AIM, Compuserve, etc.
    When done....
    Your computer is clean :)
    1. Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
