[XP SP3 - Workgroup computers they can`t see each other]
Discussion in 'Networking (Hardware & Software)' started by Sucram, 2008/09/01.
  1. 2008/09/01
    Sucram
    Sucram Inactive Thread Starter
    I have 2 computers both P4 , Intel MB 850 , Intel PRO 100 , XP-PRO ( english ) SP3 , fresh clean installation .
    Computers are cable connected trough Siemmens SL2-141 Router - Hub ( latest firmware ) .
    In Workgroup computers they don`t see each other !!!
    They can access each other trough RUN : \\IP . Files transfer etc. very good .
    PLEASE HELP !!!
  2. 2008/09/01
    mflynn
    mflynn Inactive
    Hi Sucram
    First! Are both of these computers in same Workgroup?
    What is the name of the Workgroup and name of both computers?
    Do the below on pc1
    Drag mouse to highlight the ipconfig line below then rt click and copy
    ipconfig /all > "%USERPROFILE% "\Desktop\pc1ipcfg.txt
    Next
    Start-Run
    type
    cmd
    click OK to open CMD prompt
    Left click in CMD prompt and rt click and paste then hit enter.
    close cmd prompt.
    There is now a pc1ipcfg.txt file on desktop. Open copy the contents and paste back to this thread.
    Now do the exact same on pc2 with the below line and paste back here also.
    ipconfig /all > "%USERPROFILE% "\Desktop\pc2ipcfg.txt
    Mike
    Sucram
    pc1config.txt
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : mmarcus
    Node Type . . . . . . . . . . . . : Unknown
    Ethernet adapter Local Area Connection:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connection
    Physical Address. . . . . . . . . : 00-07-E9-E3-DB-68
    Dhcp Enabled. . . . . . . . . . . : No
    IP Address. . . . . . . . . . . . : 10.0.0.1
    Subnet Mask . . . . . . . . . . . : 255.0.0.0
    Default Gateway . . . . . . . . . : 10.0.0.138
    DNS Servers . . . . . . . . . . . : 10.0.0.138
    Pc2config.txt
    Host Name . . . . . . . . . . . . : rmarcus
    Description . . . . . . . . . . . : Intel(R) PRO/100 VM Network Connection
    Physical Address. . . . . . . . . : 00-03-47-C3-4F-60
    IP Address. . . . . . . . . . . . : 10.0.0.2
    Both on "workgroup "
    mmarcus
    rmarcus
  5. 2008/09/01
    Sucram
    Thanks Arie & Mike
  6. 2008/09/01
    mflynn
    mflynn Inactive
    Get properties on "Local Area Connection" confirm both "File and printer sharing" and "Client for Microsoft networks" are installed.
    Besides the defalt XP Shared folder create a MMarcus Folder on MMarcus and rt click and share it. Do same on RMarcus.
    Now dbl click My Network places-View Workgroup computers.
    If you do not have "View Workgroup computers" then click Entire Network-Microsoft windows network-Workgroup.
    Do you see the computers and shares?
    Ok so lets see what does work.
    On mmarcus
    ping mmarcus > "%USERPROFILE% "\Desktop\mmarcusping.txt
    ping 10.0.0.1 >> "%USERPROFILE% "\Desktop\mmarcusping.txt
    ping 10.0.0.138 >> "%USERPROFILE% "\Desktop\mmarcusping.txt
    ping yahoo.com >> "%USERPROFILE% "\Desktop\mmarcusping.txt
    On rmarcus
    ping tester1 > "%USERPROFILE% "\Desktop\rmarcusping.txt
    ping 10.0.0.2 >> "%USERPROFILE% "\Desktop\rmarcusping.txt
    ping 10.0.0.138 >> "%USERPROFILE% "\Desktop\rmarcusping.txt
    ping yahoo.com >> "%USERPROFILE% "\Desktop\rmarcusping.txt
    Get me the above info, you can paste all 4 lines at once if you want.
    Mike
  7. 2008/09/01
    Sucram
    Hi Mike .
    First I want to thank You for Your attention .
    All protocols are present & enabled on both computers .
    I have created sugested folders NO CHANGE !
    Ping statistics for 10.0.0.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
    Pinging 10.0.0.138 with 32 bytes of data:
    Reply from 10.0.0.138: bytes=32 time=2ms TTL=64
    Reply from 10.0.0.138: bytes=32 time=1ms TTL=64
    Reply from 10.0.0.138: bytes=32 time<1ms TTL=64
    Ping statistics for 10.0.0.138:
    Minimum = 0ms, Maximum = 2ms, Average = 1ms
    Pinging yahoo.com [68.180.206.184] with 32 bytes of data:
    Reply from 68.180.206.184: bytes=32 time=241ms TTL=52
    Reply from 68.180.206.184: bytes=32 time=240ms TTL=52
    Reply from 68.180.206.184: bytes=32 time=243ms TTL=52
    Ping statistics for 68.180.206.184:
    Minimum = 240ms, Maximum = 243ms, Average = 241ms
    Ping request could not find host tester1. Please check the name and try again.
    Pinging 10.0.0.2 with 32 bytes of data:
    Reply from 10.0.0.2: bytes=32 time<1ms TTL=128
    Ping statistics for 10.0.0.2:
    Minimum = 1ms, Maximum = 1ms, Average = 1ms
    Reply from 68.180.206.184: bytes=32 time=244ms TTL=52
    Reply from 68.180.206.184: bytes=32 time=242ms TTL=52
    Minimum = 241ms, Maximum = 244ms, Average = 242ms
  8. 2008/09/01
    mflynn
    mflynn Inactive
    OK that all looks good!
    Next:
    Start run
    type
    services.msc
    click OK or hit enter
    Look under Name for
    "Computer Browser" make sure it says Started and Automatic.
    "Workstation" make sure it says Started and Automatic.
    "Server" make sure it says Started and Automatic.
    "Network Location Awareness" make sure it says Started and Automatic.
    Reboot retest!
    Mike
  9. 2008/09/02
    ReggieB
    ReggieB Inactive Alumni
    This looks like a NetBIOS name resolution problem. So checking things like the computer browser service are working are just the right things to do.
    However, also go into the connection properties, and from there the TCP/IP properties. Select the Advanced option. On the next set of screens, go to the WINS tab. Make sure the NetBIOS setting is at either Default or "Enable NetBIOS over TCP/IP ".
  10. 2008/09/03
    Sucram
    All 4 services were started & auto
    I`ve replaced the router with a simple HUB , no change , something went wrong and I cannot find what .
    It was working few month ago and I did not made any hardware changes the only major change is SP3 ??!!!
  11. 2008/09/03
    Sucram
    It is on default . I`ve tried also NETBIOS over TCP/IP no change
  12. 2008/09/03
    mflynn
    mflynn Inactive
    Hi Surcam
    You did confirm all in my post #8?
    Ok make note of all the IP, Gateway and DNS settings in case the below clears them.
    Drag mouse with left button down the lines below across then paste each line below 1 at a time to an open CMD prompt and hit enter, ignore any errors for now.
    netsh interface ip delete arpcache
    ipconfig /flushdns
    ipconfig /release *
    ipconfig /renew *
    ipconfig /registerdns
    nbtstat -RR
    netsh winsock show catalog > "%USERPROFILE% "\Desktop\lsp.txt
    netsh winsock reset catalog
    netsh winsock show catalog >> "%USERPROFILE% "\Desktop\lsp.txt
    netsh int ip reset > "%USERPROFILE% "\Desktop\tcpreset.txt
    Reboot see new icons on desktop, paste contents of lsp and tcp.txt back to thread.
    Recheck network IP GW DNS settings and reset if needed.
    If still no joy!
    Download Dial-A-Fix (DAF)
    http://wiki.djlizard.net/Dial-a-fix#...C_and_articles
    Have XP CD available in case DAF needs a file.
    Check all boxes on the screen (clear any restrictions if it shows any)
    Then click GO!
    When the entire page is finished click the HammerHead at bottom to go to the second DAF page.
    Here do the below
    Repair Permissions
    Watch for any File not found or other errors and make note as this may lead to the fix!
    Reboot retest!
    Get back to us.
    Mike
  13. 2008/09/03
    Sucram
    No change
    Winsock Catalog Provider Entry
    Entry Type: Base Service Provider
    Description: MSAFD Tcpip [TCP/IP]
    Provider ID: {E70F1AA0-AB8B-11CF-8CA3-00805F48A192}
    Provider Path: %SystemRoot%\system32\mswsock.dll
    Catalog Entry ID: 1001
    Version: 2
    Address Family: 2
    Max Address Length: 16
    Min Address Length: 16
    Socket Type: 1
    Protocol: 6
    Protocol Chain Length: 1
    Description: MSAFD Tcpip [UDP/IP]
    Catalog Entry ID: 1002
    Version: 2
    Address Family: 2
    Socket Type: 2
    Protocol: 17
    Description: MSAFD Tcpip [RAW/IP]
    Catalog Entry ID: 1003
    Version: 2
    Address Family: 2
    Socket Type: 3
    Protocol: 0
    Description: RSVP UDP Service Provider
    Provider ID: {9D60A9E0-337A-11D0-BD88-0000C082E69A}
    Provider Path: %SystemRoot%\system32\rsvpsp.dll
    Catalog Entry ID: 1004
    Version: 6
    Address Family: 2
    Socket Type: 2
    Protocol: 17
    Description: RSVP TCP Service Provider
    Catalog Entry ID: 1005
    Version: 6
    Address Family: 2
    Socket Type: 1
    Protocol: 6
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{B29DBA91-5B15-4B8F-8103-8AD7E8C2671B}] SEQPACKET 7
    Provider ID: {8D5F1830-C273-11CF-95C8-00805F48A192}
    Catalog Entry ID: 1055
    Version: 2
    Address Family: 17
    Max Address Length: 20
    Min Address Length: 20
    Socket Type: 5
    Protocol: -7
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{B29DBA91-5B15-4B8F-8103-8AD7E8C2671B}] DATAGRAM 7
    Catalog Entry ID: 1056
    Version: 2
    Address Family: 17
    Socket Type: 2
    Protocol: -7
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{F7C80344-2933-4A96-B200-0D87236EAFFF}] SEQPACKET 6
    Catalog Entry ID: 1057
    Version: 2
    Address Family: 17
    Socket Type: 5
    Protocol: -6
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{F7C80344-2933-4A96-B200-0D87236EAFFF}] DATAGRAM 6
    Catalog Entry ID: 1058
    Version: 2
    Address Family: 17
    Socket Type: 2
    Protocol: -6
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{D111523A-47F0-4905-849E-57190D97ECD8}] SEQPACKET 5
    Catalog Entry ID: 1059
    Version: 2
    Address Family: 17
    Socket Type: 5
    Protocol: -5
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{D111523A-47F0-4905-849E-57190D97ECD8}] DATAGRAM 5
    Catalog Entry ID: 1060
    Version: 2
    Address Family: 17
    Socket Type: 2
    Protocol: -5
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{3004E843-7DDB-4A2A-A3DA-ED5895B79B3A}] SEQPACKET 4
    Catalog Entry ID: 1061
    Version: 2
    Address Family: 17
    Socket Type: 5
    Protocol: -4
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{3004E843-7DDB-4A2A-A3DA-ED5895B79B3A}] DATAGRAM 4
    Catalog Entry ID: 1062
    Version: 2
    Address Family: 17
    Socket Type: 2
    Protocol: -4
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{A269C336-93E2-40A3-ACB4-98212FDB6A60}] SEQPACKET 0
    Catalog Entry ID: 1063
    Version: 2
    Address Family: 17
    Socket Type: 5
    Protocol: -2147483648
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{A269C336-93E2-40A3-ACB4-98212FDB6A60}] DATAGRAM 0
    Catalog Entry ID: 1064
    Version: 2
    Address Family: 17
    Socket Type: 2
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{2FEAFCC7-C6D2-418A-BE54-0189B6D8AE6B}] SEQPACKET 1
    Catalog Entry ID: 1065
    Version: 2
    Address Family: 17
    Socket Type: 5
    Protocol: -1
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{2FEAFCC7-C6D2-418A-BE54-0189B6D8AE6B}] DATAGRAM 1
    Catalog Entry ID: 1066
    Version: 2
    Address Family: 17
    Socket Type: 2
    Protocol: -1
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{DE850C1C-2E55-4F58-9331-BBB8C9EE9E82}] SEQPACKET 2
    Catalog Entry ID: 1067
    Version: 2
    Address Family: 17
    Socket Type: 5
    Protocol: -2
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{DE850C1C-2E55-4F58-9331-BBB8C9EE9E82}] DATAGRAM 2
    Catalog Entry ID: 1068
    Version: 2
    Address Family: 17
    Socket Type: 2
    Protocol: -2
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{741471DB-D6EC-4061-8422-8432C93CBA28}] SEQPACKET 3
    Catalog Entry ID: 1069
    Version: 2
    Address Family: 17
    Socket Type: 5
    Protocol: -3
    Description: MSAFD NetBIOS [\Device\NetBT_Tcpip_{741471DB-D6EC-4061-8422-8432C93CBA28}] DATAGRAM 3
    Catalog Entry ID: 1070
    Version: 2
    Address Family: 17
    Socket Type: 2
    Protocol: -3
    Name Space Provider Entry
    Description: Tcpip
    Provider ID: {22059D40-7E9E-11CF-AE5A-00AA00A7112B}
    Name Space: 12
    Active: 1
    Version: 0
    Description: NTDS
    Provider ID: {3B2637EE-E580-11CF-A555-00C04FD8D4AC}
    Name Space: 32
    Active: 1
    Version: 0
    Description: Network Location Awareness (NLA) Namespace
    Provider ID: {6642243A-3BA8-4AA6-BAA5-2E0BD71FDD83}
    Name Space: 15
    Active: 1
    Version: 0
    Version: 2
    Address Family: 2
    Socket Type: 1
    Protocol: 6
    Version: 2
    Address Family: 2
    Socket Type: 2
    Protocol: 17
    Version: 2
    Address Family: 2
    Socket Type: 3
    Protocol: 0
    Version: 2
    Address Family: 17
    Socket Type: 5
    Protocol: -7
    Version: 2
    Address Family: 17
    Socket Type: 2
    Protocol: -7
    Catalog Entry ID: 1006
    Version: 2
    Address Family: 17
    Socket Type: 5
    Protocol: -6
    Catalog Entry ID: 1007
    Version: 2
    Address Family: 17
    Socket Type: 2
    Protocol: -6
    Catalog Entry ID: 1008
    Version: 2
    Address Family: 17
    Socket Type: 5
    Protocol: -5
    Catalog Entry ID: 1009
    Version: 2
    Address Family: 17
    Socket Type: 2
    Protocol: -5
    Catalog Entry ID: 1010
    Version: 2
    Address Family: 17
    Socket Type: 5
    Protocol: -4
    Catalog Entry ID: 1011
    Version: 2
    Address Family: 17
    Socket Type: 2
    Protocol: -4
    Catalog Entry ID: 1012
    Version: 2
    Address Family: 17
    Socket Type: 5
    Catalog Entry ID: 1013
    Version: 2
    Address Family: 17
    Socket Type: 2
    Catalog Entry ID: 1014
    Version: 2
    Address Family: 17
    Socket Type: 5
    Protocol: -1
    Catalog Entry ID: 1015
    Version: 2
    Address Family: 17
    Socket Type: 2
    Protocol: -1
    Catalog Entry ID: 1016
    Version: 2
    Address Family: 17
    Socket Type: 5
    Protocol: -2
    Catalog Entry ID: 1017
    Version: 2
    Address Family: 17
    Socket Type: 2
    Protocol: -2
    Catalog Entry ID: 1018
    Version: 2
    Address Family: 17
    Socket Type: 5
    Protocol: -3
    Catalog Entry ID: 1019
    Version: 2
    Address Family: 17
    Socket Type: 2
    Protocol: -3
    Catalog Entry ID: 1020
    Version: 6
    Address Family: 2
    Socket Type: 2
    Protocol: 17
    Catalog Entry ID: 1021
    Version: 6
    Address Family: 2
    Socket Type: 1
    Protocol: 6
    Description: Tcpip
    Name Space: 12
    Active: 1
    Version: 0
    Description: NTDS
    Name Space: 32
    Active: 1
    Version: 0
    Name Space: 15
    Active: 1
    Version: 0
    One or more essential parameters were not entered.
    Verify the required parameters, and reenter them.
    The syntax supplied for this command is not valid. Check help for the correct syntax.
    Usage: reset [name=]<string>
    Parameters:
    Tag Value
    name - The name of a file to which to append information
    regarding what settings were reset.
    Remarks: Resets TCP/IP and related components to a clean state.
    Examples:
    reset resetlog.txt
  14. 2008/09/03
    mflynn
    mflynn Inactive
    Hi Sucram
    You did confirm all in my post #8? Yes!
    This line did not execute need to paste it again
    And if it does there will be a tcpreset.txt on Desktop to paste back!
    Also did you do the Dial-a-Fix?
    Mike
  15. 2008/09/03
    Sucram
    Hi Mike and Thanks again !!!
    This line syntax may be misspelled :
    Parameters:
    Tag Value
    Examples:
    reset resetlog.txt
    The Dial-a-Fix run OK. on rmarcus 10.0.0.1 nothing changed .
    On mmarcus ( My main comp. )10.0.0.2 it goes to the " GO " scren but when I click GO it does not run .
    I`ve noticed another thing :
    When I click " View Workgroup Computers " on one computer it show itself only .
    When I click on the other it came with the msg. : " MSHOME is not accessible You may have not PERMISSION ....call Network admin. ...... "
    Always the first clicked show itself .
    I`ve runed " INTEL PRO SET " diagnostic SEND - RECIVE no failure .
    Also Maped Drives are ok. on both comp.s
    Michael .
  16. 2008/09/03
    mflynn
    mflynn Inactive
    Hi Sucram
    No the line is correct I tested it here. Must be an issue on your computer.
    1. On the computer that will run DAF go to second page (Hammer) and run
    Reset Networking interfaces
    That will do the same as the line that will not work (unless you have other problems).
    2. Not good that DAF will not run on the one computer as I have never seen it not run at all and I have ran it on some really messed up computers.
    3. Confirm that you are using the same workgroup MSHOME on both computers.
    4. Make sure you are using the same account on both computers for the time being and if you do not have a password set one.
    If you are using Sucram to log into one computer create an identical account on the other computer with the exact same password.
    Mike
  17. 2008/09/05
    Sucram
    Hi Mike
    I`m sorry I was wrong using the DAF ( it was after midnight and I did not followed exactly Your`s instuctions ).
    It runs OK on both comp.s !!!
    I would like to restart from scratch
    Attached ( mmarcus master comp. )SECREPAIR.LOG there are some warnings do I need to fix them and how ?
    09 05 2008 10:13:50
    The text is too long I`ll paste the warnigs only :
    Configure machine\system\currentcontrolset\services\samss\security.
    Warning 2: The system cannot find the file specified.
    Error enumerating info for machine\system\currentcontrolset\services\scarddrv.
    Configure c:\ntbootdd.sys.
    Error setting security on c:\ntbootdd.sys.
    Configure c:\windows\inf\atiintaa.inf.
    Error setting security on c:\windows\inf\atiintaa.inf.
    Configure c:\windows\inf\avmisd64.inf.
    Error setting security on c:\windows\inf\avmisd64.inf.
    Configure c:\windows\inf\is_wow64.inf.
    Error setting security on c:\windows\inf\is_wow64.inf.
    Configure c:\windows\inf\usermig.inf.
    Error setting security on c:\windows\inf\usermig.inf.
    Configure c:\windows\inf\wkstamig.inf.
    Error setting security on c:\windows\inf\wkstamig.inf.
    Configure c:\windows\speech.
    Error setting security on c:\windows\speech.
    Configure c:\windows\system32\decem.dll.
    Error setting security on c:\windows\system32\decem.dll.
    Configure c:\windows\system32\html64.iec.
    Error setting security on c:\windows\system32\html64.iec.
    Configure c:\windows\system32\kdcsvc.dll.
    Error setting security on c:\windows\system32\kdcsvc.dll.
    Configure c:\windows\system32\migisol.exe.
    Error setting security on c:\windows\system32\migisol.exe.
    Configure c:\windows\system32\msenc64.dll.
    Error setting security on c:\windows\system32\msenc64.dll.
    Configure c:\windows\system32\mtstocom.exe.
    Error setting security on c:\windows\system32\mtstocom.exe.
    Configure c:\windows\system32\w95upgnt.dll.
    Error setting security on c:\windows\system32\w95upgnt.dll.
  18. 2008/09/05
    mflynn
    mflynn Inactive
    Hi Michael
    OK!
    We will deal with only 1 Computer at a time!
    Do not mention the other computer or try to run the below on it at the same time.
    Also please answer my requests in detail like the below questions, which I have asked more than once already.
    1. Confirm that you are using the same workgroup MSHOME on both computers.
    2. Make sure you are using the same account on both computers for the time being and if you do not have a password set one.
    If you are using Account Sucram or Michael to log into one computer create an identical account on the other computer with the exact same password.
    3. You did confirm all in my post #8? Yes!
    The above 3 items you need to answer for me even tho they apply to both computers.
    Not being able to browse while able to access by "RUN : \\IP . Files transfer" and to map drives is not a critical problem but we will fix that anyways later.
    Apparently you have several issues as evidenced by your last post so pick one computer and forget the other until I ask you to move to it!
    Fist check for Malware!
    Begin do in order presented! And give me back details on what happens at each step.
    1.=======================================
    D/L Xclean_Micro http://www.xblock.com/download/xclean_micro.exe
    No install, run it delete all it finds decline to reboot on each item found, until the program finishes then reboot.
    Xclean may run minimized and will pop up a window if it finds anything. If it finds nothing it will exit.
    Please make a note of what it found if any as this might indicate a deeper Malware diag.
    2.========================================
    Get the below install and update then run FULL scan post log
    http://www.malwarebytes.org/mbam.php
    If it found much the reboot to Safe Mode and run it again then paste s new log for this run when back to normal mode!
    Next Cleanup!
    3.========================================
    D/L install and run ATF-Cleaner clear all except passwords in all browsers you have. Run repeatedly until no more found.
    http://www.majorgeeks.com/ATF_Cleaner_d4949.html
    D/L and install CCleaner: Clean temps and registry. Run both (temp and registry) repeatedly until no more found.
    http://www.ccleaner.com/download/builds get Slim version
    4.=======================================
    Reboot and do the below.
    To look deeply at you system:
    D/L RSIT http://images.malwareremoval.com/random/RSIT.exe
    Run it post both logs here.
    Mike
  19. 2008/09/05
    Sucram
    Hi Mike
    I agree
    We`ll deal with 1 computer at a time the comp. is : description : "Master" ,full name : "mmarcus" workgroup : "MSHOME" .
    1. Same workgroup is used on both computers : "MSHOME" .
    2. Same account on both computers : "sucram" , both with same password .
    3. I`ve confirmed Your post #8 in My post #10 : " all 4 services were and are started and auto" .
    I`ll start the procedure and post You the logs .
    My Time Region is GMT + 2 what is Your`s ?
    Tanks ,
    Michael .
  20. 2008/09/05
    mflynn
    mflynn Inactive
    Time is - 4 Eastern time, now is 2 PM.
    The last post looks complex but is not. Just do 1 step at a time should take about a hour (because of the XClean and MalwareBytes antimalware).
    Mike
  21. 2008/09/05
    mflynn
    mflynn Inactive
    See last post for corrected time! Kinda busy distracted!
    I can't think and chew gum at same time!:D
    Mike
