XP Says It's Busy Installing Hardware
Discussion in 'Windows XP' started by Roger NE, 2010/01/24.
  1. 2010/01/24
    Roger NE
    Roger NE Inactive Thread Starter
    Whenever I try installing any new Hardware, using the Add Hardware Wizard, after a few seconds a message comes up saying something like "Windows is busy installing hardware, wait until that task is completed then try again "
    This means you can't even plug in a Memory Stick, as presumably the automatic hardware finder can't tell it's there.
    What can I do?!
  2. 2010/01/24
    wildfire
    wildfire Getting Old
    Look in device manager (start->run->devmgmt.msc) and look for any problem hardware (Question Marks/Exclamation Marks)
    If you find any then right click and uninstall, then restartt your system.
    Roger,
    If this is your main system then it would be helpful if you add your system details to your profile. Please click on the link and follow those instructions it could save some time when resolving this or further issues.
    Roger NE
    Everything looks fine in Device Manager, already checked that
    No, this is my daughter's IBM Laptop . . . . plus I haven't put my details as I have 4 PCs that I use here, all different ages and operating systems
  5. 2010/01/24
    wildfire
    No problem,
    Have you tried system restore to a point before this started happening?
    Only other suggestion I have is to strip the computer to bare minimum (remove all USB/PCMCIA devices etc), start up in safe mode and uninstall all H/W from device manager (obviously make sure you have drivers available).
    If you post model number and any details of currently and previous attached hardware of the laptop in this thread it may help.
  6. 2010/01/24
    Roger NE
    Many thanks for the suggestions . . . but I've tried a System Restore but it made no difference
    And the problem is that being a laptop I can't get inside to physically remove any hardware . . and nothing extra has been added, it's as it came from the factory
    The Laptop is with my daughter at the moment, so can't post details of model etc . . .
    But I was hoping someone may have had a similar problem and could suggest something to try if I get it back from her (in all other respects it's working fine)
    I've never seen this problem EVER on any machine, of it thinking it's still in the middle of installing some Hardware !
  7. 2010/01/24
    wildfire
    OK
    I never asked you to, USB/PCMCIA are external devices
    You've already mentioned a memory stick, so at least one device has been tried ;)
    Let's leave it for now then untill you have this information.
  8. 2010/01/24
    Roger NE
    Yes but it has hardware devices inside, like graphics, sound card, a modem, a wireless transceiver, etc etc . . none of which I can physically remove!
    Nothing else (external) has been installed, just tried to use a memory stick, which as I say, it won't even recognise as it says it's busy installing hardware !
    Hope someone has come across this before and can help
  9. 2010/01/24
    wildfire
    Again, I never asked you to.
    So there's a chance it's the memory stick and not the laptop that's at fault?
    Try the stick in another system and try other USB devices in the IBM laptop, please let us know the results.
  10. 2010/01/24
    Roger NE
    No it's not a faulty stick . . . plus I've tried other memory sticks
    Even without anything plugged in, if you run the Add Hardware Wizard, and ask it to Search for new hardware, the dialogue box opens that says it can't as it's in the middle of installing hardware.
  11. 2010/01/24
    surferdude2
    surferdude2 Inactive
    Try Safe Mode and perhaps it will be able to complete.
    If not, try uninstalling all usb controllers from Device manager and let Windows reinstall them.
