XP out of control
Discussion in 'Malware and Virus Removal Archive' started by aa3648, 2009/12/15.
  1. 2009/12/15
    aa3648
    aa3648 Inactive Thread Starter
    Hi,
    My Dell E510 desktop with XP sp3 installed gets out of my control. The hard drive light remains on continuously and the computer does not respond to my inputs. Occasionally it will release control to the launched program for a very short period of time. This may last up to a half hour.
    The Task Manager indicates CPU usage ranging between 1% and 20% during this period. Listed processes appear to be utilizing the CPU for short periods of time.
    HiJackThis lists 5 programs and 14 processes asrunning.
    I have launched a scan from Windows Security Essentials and the response was that viruses did not exist.
    I do not have the problem when the computer is booted in the safe mode.
  2. 2009/12/15
    Which suggests it is a driver problem - however ....
    Please read this as indicated at the head of the forum and post the logs requested in this thread.
    aa3648
    Hi,
    Thank you PeteC for your response to my inquiry.
    Below are the logs provided by a DDS Snanning Tool as requested in the above reply.
  5. 2009/12/19
    Those logs must be invisible :)
  6. 2009/12/20
    aa3648
    Hi,
    Prior to sending the reply I checked and found the both logs on pages 2 and 3
    of the reply.
    I will try again in this reply.
  7. 2009/12/20
    Are you pasting those logs, or....?
