Resolved xp home install freezes same place everytime
Discussion in 'Windows XP' started by gghartman, 2010/12/05.
  1. 2010/12/11
    markmadras
    markmadras Banned
    I do recall a keyboard causing a major problem with the boot sequence, I should have thought of that earlier:rolleyes:
    Glad to hear you got it sorted:)
  2. 2010/12/11
    gghartman
    its a new multi-media keyboard and honestly i cant say ive ever seen that happen. ive seen keyboard usb ones that have had coffee or pop spilled on them and it caused the desktop to go crazy but not this. i suppose if the signal is bad its accessing a memory address and freezes. still want to test a little more to make sure its not the speakers but so far its good. we will see in the morning when i fire it up again.
    thanks man for your assistance.
    gghartman
    nope problem is back once again. this **** machine is going to be stripped and then i am going to use my shotgun and blow it into pieces.
  5. 2010/12/14
    markmadras
    markmadras Banned
    Just one last idea. Are you using SATA or IDE hard drives? If you have been using SATA you need to have the drivers, SATA drivers are not included in Windows XP.
  6. 2010/12/14
    gghartman
    good thought but no this is ide
  7. 2010/12/14
    gghartman
    honestly it makes no sense was working just fine for 3 months then pow.
  8. 2010/12/14
    markmadras
    markmadras Banned
    Going back to post 22 when you had it working did you get the chipset drivers installed?
  9. 2010/12/14
    gghartman
    oh yeah either i have the driver cd or i download all the drivers while im rebuilding the machine so yes chipset is always installed on every dell i work with.
  10. 2010/12/15
    markmadras
    markmadras Banned
    All I can conclude is some fault on the mobo:(, what else could it be?
    Time for target practice;)
