Solved Wow.dll popup and errors
Discussion in 'Malware and Virus Removal Archive' started by Talynne, 2013/06/29.
  1. 2013/07/03
    [​IMG] Update Adobe Reader
    You can download it from http://www.adobe.com/products/acrobat/readstep2.html
    After installing the latest Adobe Reader, uninstall all previous versions (if present).
    Note. If you already have Adobe Photoshop® Album Starter Edition installed or do not wish to have it installed UNcheck the box which says Also Download Adobe Photoshop® Album Starter Edition.
    Alternatively, you can uninstall Adobe Reader (33.5 MB) and install one of two free alternatives:
    - Foxit PDF Reader(3.5MB) from HERE.
    It's a much smaller file to download and uses a lot less resources than Adobe Reader.
    Note: When installing FoxitReader, make sure to UN-check any pre-checked toolbar, or any other garbage.
    - PDF-XChange Viewer: http://www.tracker-software.com/product/pdf-xchange-viewer
    [​IMG] 1. Update your Java version here: http://www.java.com/en/download/installed.jsp
    2. Now, we need to remove old Java version and its remnants...
    Download JavaRa to your desktop and unzip it.
    • Run JavaRa.exe (Vista and 7 users! Right click on JavaRa.exe, click Run As Administrator), pick the language of your choice and click Select. Then click Remove Older Versions.
    • Accept any prompts.
    • Do NOT post JavaRa log.
    Your computer is clean [​IMG]
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [emptyjava]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure Windows Updates are current.
    4. If any trojans, rootkits or bootkits were listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    5. Check if your browser plugins are up to date.
    Firefox - https://www.mozilla.org/en-US/plugincheck/
    other browsers: https://browsercheck.qualys.com/ (click on "Launch a quick scan now" link)
    7. Run Malwarebytes "Quick scan" once in a while to assure safety of your computer.
    8. Run Temporary File Cleaner (TFC) weekly.
    9. Download and install Secunia Personal Software Inspector (PSI): http://secunia.com/vulnerability_scanning/personal/. The Secunia PSI is a FREE security tool designed to detect vulnerable and out-dated programs and plug-ins which expose your PC to attacks. Run it weekly.
    10. (optional) If you want to keep all your programs up to date, download and install FileHippo Update Checker.
    11. (Windows XP only) Run defrag at your convenience.
    12. When installing\updating ANY program, make sure you always select "Custom " installation, so you can UN-check any possible "drive-by-install" (foistware), like toolbars etc., which may try to install along with the legitimate program. Do NOT click "Next" button without looking at any given page.
    13. Read:
    How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    Simple and easy ways to keep your computer safe and secure on the Internet: http://www.bleepingcomputer.com/tutorials/keep-your-computer-safe-online/
    14. Please, let me know, how your computer is doing.
  2. 2013/07/06
    Talynne
    Talynne Inactive Thread Starter
    Updated Adobe and Java; removed prior versions. Tools removed and final OTL log:
    All processes killed
    Error: Unable to interpret <Code: > in the current context!
    ========== OTL ==========
    [EMPTYTEMP]
    User: All Users
    User: Craig Ballard
    ->Temporary Internet Files folder emptied: 276081422 bytes
    ->Java cache emptied: 37893 bytes
    ->Google Chrome cache emptied: 0 bytes
    ->Flash cache emptied: 2415 bytes
    User: Default
    User: Default User
    User: Public
    %systemroot%\System32 (64bit) .tmp files removed: 0 bytes
    Windows Temp folder emptied: 89794218 bytes
    %systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 33170 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 349.00 mb
    [EMPTYFLASH]
    User: All Users
    User: Craig Ballard
    User: Default
    User: Default User
    User: Public
    [EMPTYJAVA]
    User: All Users
    User: Craig Ballard
    ->Java cache emptied: 0 bytes
    User: Default
    User: Default User
    User: Public
    Total Java Files Cleaned = 0.00 mb
    Restore point Set: OTL Restore Point
    OTL by OldTimer - Version 3.2.69.0 log created on 07052013_215118
    PendingFileRenameOperations files...
    Talynne
    Windows updates are current. Browser plug-ins are current. WOT and PSI installed. Other tips/directions read and noted. Computer's running fine... think we're good and can mark this as resolved?
  5. 2013/07/06
    Absolutely.
    Way to go!! [​IMG]
    Good luck and stay safe :)
