Wireless networking 802.11 A B G or N what is your opinion
Discussion in 'Networking (Hardware & Software)' started by jacrabbit, 2010/06/06.
  1. 2010/06/06
    jacrabbit
    jacrabbit Inactive Thread Starter
    I recently bought 2 new laptops, both Win 7, both have capabilities to run all versions except A? ie: B/G/N
    I also recently bought a B/G/N compatible modem router, the laptops will use the N version, I was using a B/G compatible modem router in this case the laptops use the G version
    The thing is I don't find much difference in speed, but at the other end when using skype for video conferencing; the B/G seems to be better over all than the N.
    Could this be something to do with my ISP speed?
    So I am curious to hear from others as to their experience with the N version
    regards Jac
  2. 2010/06/06
    N mode is great if all clients connected to the N access point are N mode adapters.
    The downside to N mode is that if a client (adapter) is not N mode the access point drops down to G or B for ALL connected clients, even if other clients are N mode clients.
    jacrabbit
    Tony,
    I remember someone saying that if the ISP speed was not up to speed then there was no point using a 108 G card, so stick with your 54? does this apply inregards to the N version? if my download speed is not capable would I not be better off sticking with the G version?
    Jac
  5. 2010/06/16
    Neither apply. B mode (11 mb/sec) is faster than most ISPs. The transfer rates will be noticed when transferring on your LAN.
  6. 2010/06/16
    jacrabbit
    Ok, Thanks Mate, makes the mind a bit clearer
    Jac
