WinAntiVirus Pro 2007 help. HJT and ComboFix logs included
Discussion in 'Malware and Virus Removal Archive' started by MinnesotaMike, 2007/08/13.
  1. 2007/08/18
    Geri Lifetime Subscription
    Geri Inactive Alumni
    Hi MinnesotaMike
    Yes it's strange, if you get infected it will pop up all the time.
    You might turn off then turn back on your system restore and make a new restore point. Delete everything in your Prefetch folder (This will rebuild itself any way) and delete anything in your AVG quarantine folder if there is anything.
    Was glad to try and help. If things get worse let us know and I'll have noahdfear come take a look.
    Geri
  2. 2007/08/18
    MinnesotaMike
    MinnesotaMike Geek Member Thread Starter
    Geri,
    Thanks, will do.
    Mike
    noahdfear
    noahdfear Inactive
    Mike, if you clear out the prefetch folder, do not delete the layout.ini file. It will slow down boot time. Best bet is to use ATF Cleaner by Atribune to clean out temp files, prefetch and cookies.
  5. 2007/08/18
    MinnesotaMike
    noahdfear,
    Thanks, I'll download and clean things out.
    Mike
