Solved WinAntiSpyware and a Dialer removal
Discussion in 'Malware and Virus Removal Archive' started by Stratman50th, 2008/09/21.
  1. 2008/09/21
    Stratman50th
    Stratman50th Inactive Thread Starter
    [Resolved] WinAntiSpyware and a Dialer removal
    I'll try and put everything in here that was requested.
    Approx. two weeks ago we got the WinAntiSpyware pop up window. The window was closed without going to the site since I had heard of this one before. We also had a bunch of add windows opening up by themselves. Typical gambling save money, etc. All of these were confined to my daughters profile. I was using Spybot Tea Timer resident as well as the firewall and antivirus software that came free with our Earthlink account. I don't know what application it really is since Earthlink puts their name on it.
    All updates were set for automatic and loaded several times a week. Same with Spybot S&D. I did notice that Earthlink wasn't loading resident any longer on her profile. I don't know how long it's been like that.
    I logged into safe mode and ran the Earthlink full scan, then the Spybot S&D. I already had Addaware but hadn't used it in awhile. I updated and ran it too.
    WinAntispyware was found, along with what was identified as a dialer. I apologize that I didn't write it down. I think it started with di, but I can't be sure as supposedly it was removed. According to all the utilities I used, the system was clean. I logged back in and the windows were still coming up in my daughter's profile.
    I went back into safe mode /networking and downloaded AVG8 and tried to install it but it said there was another anti virus app running. I attempted to uninstall Earthlink from add remove programs and it failed with a MS error report. I ran reg cleaner and removed Earthlink and tried to install AVG again. It failed to complete the install however the Toolbar did get installed somehow. It kept popping up and disappearing. I checked the services and found that ieexplorer was starting and AVG toolbar was shutting it down, so I assumed the dialer or whatever it is was still trying to pop those links up. and avg was shutting them down. It would come about every 15 seconds more or less. This is getting really long so I'll try and be brief. I cleaned AVG out of the registry and tried to reinstall. After several attempts it went in. I ran it and it scanned in command line and found and fixed a problem:
    C:\WINDOWS\system32\qqKNOnn4.exe Trojan horse Downloader.Tiny.H Object was moved to Virus Vault.
    Things appeared to be working fairly well so I rebooted and went back to my normal profile (everything had been done in safe mode so far). I noticed a couple of strange things which I posted in another thread. The admin profile was viewable, it is normally hidden. There was no networking/internet available in my profile. Even though there was what appeared to be a normal list of services in task manager, no networking was loaded because "services could not load in safe mode ". This was my profile, not admin. That was the original problem I posted on here.
    One more thing, I removed my daughters profile and deleted the directory. Firefox is our browser. We do not use ie5.
    Here is the hijack this log that I was advised to post:
    Scan saved at 8:41:24 AM, on 9/21/2008
    MSIE: Internet Explorer v6.00 SP3 (6.00.2900.5512)
    C:\Program Files\AVG\AVG8\avgrsx.exe
    C:\WINDOWS\system32\hkcmd.exe
    C:\WINDOWS\system32\igfxpers.exe
    C:\WINDOWS\stsystra.exe
    C:\Program Files\CyberLink\PowerDVD\DVDLauncher.exe
    C:\Program Files\Roxio\Easy Media Creator 8\Drag to Disc\DrgToDsc.exe
    C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
    C:\Program Files\Creative\MediaSource\Detector\CTDetect.exe
    C:\Program Files\Linksys EasyLink Advisor\LinksysAgent.exe
    C:\Program Files\Mozilla Firefox\firefox.exe
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.dell.com
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.dell.com
    O2 - BHO: EarthLink BHO Guard - {00000000-0000-0000-0000-000000000002} - C:\Program Files\EarthLink\Toolbar\EScamBlk.dll
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
    O2 - BHO: EarthLink ScamBlocker V3 - {15F4D456-5BAA-4076-8486-EECB38CD3E57} - C:\Program Files\EarthLink\Toolbar\EScamBlk.dll
    O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll (file missing)
    O2 - BHO: EarthLink PopUp Blocker V2 - {512ACF1B-64D9-4928-B382-A80556F28DB4} - C:\Program Files\EarthLink\Toolbar\ElnkPuB.dll
    O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O2 - BHO: Earthlink Protection BHO - {9579D574-D4D8-4335-9560-FE8641A013BD} - C:\Program Files\EarthLink\Toolbar\ProtctIE.dll
    O2 - BHO: (no name) - {A057A204-BACC-4D26-9990-79A187E2698E} - (no file)
    O2 - BHO: Uninstall Legacy Earthlink Toolbar - {E713904C-DF05-4C79-BBAD-02DB923253BE} - C:\Program Files\EarthLink\Toolbar\uninsttb.dll
    O3 - Toolbar: EarthLink Toolbar - {C7768536-96F8-4001-B1A2-90EE21279187} - C:\Program Files\EarthLink\Toolbar\Toolbar.dll
    O4 - HKLM\..\Run: [igfxtray] C:\WINDOWS\system32\igfxtray.exe
    O4 - HKLM\..\Run: [igfxhkcmd] C:\WINDOWS\system32\hkcmd.exe
    O4 - HKLM\..\Run: [igfxpers] C:\WINDOWS\system32\igfxpers.exe
    O4 - HKLM\..\Run: [SigmatelSysTrayApp] stsystra.exe
    O4 - HKLM\..\Run: [DVDLauncher] "C:\Program Files\CyberLink\PowerDVD\DVDLauncher.exe "
    O4 - HKLM\..\Run: [ISUSPM Startup] "C:\Program Files\Common Files\InstallShield\UpdateService\isuspm.exe" -startup
    O4 - HKLM\..\Run: [ISUSScheduler] "C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe" -start
    O4 - HKLM\..\Run: [RoxioDragToDisc] "C:\Program Files\Roxio\Easy Media Creator 8\Drag to Disc\DrgToDsc.exe "
    O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
    O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
    O4 - HKCU\..\Run: [Creative Detector] C:\Program Files\Creative\MediaSource\Detector\CTDetect.exe /R
    O4 - HKCU\..\Run: [EasyLinkAdvisor] "C:\Program Files\Linksys EasyLink Advisor\LinksysAgent.exe" /startup
    O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
    O4 - Global Startup: Adobe Reader Speed Launch.lnk.disabled
    O8 - Extra context menu item: EarthLink Google Search - res://C:\Program Files\EarthLink\Toolbar\SearchUI.dll/search.html
    O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\j2re1.4.2_03\bin\npjpi142_03.dll
    O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\j2re1.4.2_03\bin\npjpi142_03.dll
    O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\system32\Shdocvw.dll
    O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} - http://download.mcafee.com/molbin/shared/mcinsctl/4,0,0,101/mcinsctl.cab
    O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1137525022796
    O20 - AppInit_DLLs: avgrsstx.dll
    O23 - Service: AuthFw - Authentium - C:\Program Files\Authentium\Firewall SDK\AuthFw.exe
    O23 - Service: AVG8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
    O23 - Service: Creative Service for CDROM Access - Creative Technology Ltd - C:\WINDOWS\system32\CTsvcCDA.EXE
    O23 - Service: DvpApi (dvpapi) - Authentium, Inc. - C:\Program Files\Common Files\Authentium\AntiVirus\dvpapi.exe
    O23 - Service: EarthLinkSafeConnectAgent - Unknown owner - C:\Program Files\EarthLink\EarthLink Protection Control Center\Sana\Bin\SanaAgent.exe (file missing)
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe
    O23 - Service: Intel NCS NetService (NetSvc) - Intel(R) Corporation - C:\Program Files\Intel\PROSetWired\NCS\Sync\NetSvc.exe
    O23 - Service: LiveShare P2P Server (RoxLiveShare) - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxLiveShare.exe
    O23 - Service: RoxMediaDB - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxMediaDB.exe
    O23 - Service: RoxUpnpRenderer (RoxUPnPRenderer) - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\SharedCom\RoxUpnpRenderer.exe
    O23 - Service: RoxUpnpServer - Sonic Solutions - C:\Program Files\Roxio\Easy Media Creator 8\Digital Home\RoxUpnpServer.exe
    O23 - Service: Roxio Hard Drive Watcher (RoxWatch) - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxWatch.exe
    End of file - 6741 bytes
    Sorry if this was longer than it was supposed to be, but the instructions said to list the problem and everything you've done up to this point.
  2. 2008/09/21
    Geri Lifetime Subscription
    Geri Inactive Alumni
    Hi Stratman50th
    Thanks for the info, it does help.
    Lets run a tool and then get another log.
    Please do these in the order given.
    Download Malwarebytes' Anti-Malware (MBAM) from here or here and save the file to your desktop.
    Double click mbam-setup.exe to install the application.
    • Make sure a checkmark is placed next to Update Malwarebytes' Anti-Malware and Launch Malwarebytes' Anti-Malware, then click Finish.
    • If an update is found, it will download and install the latest version.
    • Once the program has loaded, select 'Perform Quick Scan', then click Scan.
    • The scan may take some time to finish,so please be patient.
    • When the scan is complete, click OK, then Show Results to view the results.
    • Make sure that everything is checked, and click Remove Selected.
    • When disinfection is completed, a log will open in Notepad and you may be prompted to Restart. (See Note below)
    • The log is automatically saved by MBAM and can be viewed by clicking the Logs tab in MBAM.
    • Post the entire report in your next reply along with a fresh HijackThis log.
    Note: If MBAM encounters a file that is difficult to remove, you will be presented with 1 of 2 prompts. Click OK to either and let MBAM proceed with the disinfection process. If asked to restart the computer, please do so immediately.
    Now a log from this.
    • Download RSIT by random/random and save it to your desktop.
    • Double click RSIT.exe to start the tool and click Continue at the disclaimer.
    • When the scan completes it will open a log named log.txt maximized, and a log named info.txt minimized.
    • Please post the contents of the log.txt here in your next reply.
    Please post the MBAM log and the log.txt from RSIT.
    Geri
    Geri,
    Stratman50th
    Thanks for your response Geri. I'll take care of it as soon as I get home this evening. This all started as a result of this thread I posted first just to give you all a little more background:
    http://www.windowsbbs.com/windows-xp/77115-safe-mode-likes-hang-around.html
    I have admin rights on my profile, but should I do the downloads and run the scans in safe mode under the admin profile?
    I'll post the results of the scans as soon as I get them. Thanks again for all the help!
  5. 2008/09/22
    Hi
    Normal mode would be best, if possible.
    If not run MBAM in safe mode then try to boot into normal mode and run it again.
    Geri
    Geri,
    Stratman50th
    Malwarebytes Log:
    Malwarebytes' Anti-Malware 1.28
    Database version: 1194
    Windows 5.1.2600 Service Pack 3
    9/22/2008 7:47:58 PM
    mbam-log-2008-09-22 (19-47-58).txt
    Scan type: Quick Scan
    Objects scanned: 70035
    Time elapsed: 14 minute(s), 54 second(s)
    Memory Processes Infected: 0
    Memory Modules Infected: 0
    Registry Keys Infected: 0
    Registry Values Infected: 0
    Folders Infected: 0
    Files Infected: 3
    (No malicious items detected)
    Folders Infected:
    Files Infected:
    C:\Documents and Settings\Lori.D4478691\Local Settings\Temp\5T4YwS8D.exe (Trojan.Agent) -> Quarantined and deleted successfully.
    C:\WINDOWS\system32\5W3qdc2O.exe.a_a (Trojan.Agent) -> Quarantined and deleted successfully.
    C:\WINDOWS\system32\qqKNOnn4.exe.a_a (Trojan.Agent) -> Quarantined and deleted successfully.
    Hyjack This:
    Scan saved at 7:52:43 PM, on 9/22/2008
    C:\WINDOWS\system32\csrss.exe
    C:\WINDOWS\system32\wbem\wmiprvse.exe
    End of file - 6793 bytes
  7. 2008/09/22
    Stratman50th
    RSIT:
    Logfile of random's system information tool 1.02 (written by random/random)
    Run by Don at 2008-09-22 19:54:21
    Microsoft Windows XP Professional Service Pack 3
    System drive C: has 110 GB (74%) free of 149 GB
    Total RAM: 1014 MB (47% free)
    Scan saved at 7:54:34 PM, on 9/22/2008
    C:\Documents and Settings\Don\Desktop\RSIT.exe
    C:\Program Files\Trend Micro\HijackThis\Don.exe
    End of file - 6834 bytes
    ======Scheduled tasks folder======
    C:\WINDOWS\tasks\At1.job
    C:\WINDOWS\tasks\At10.job
    C:\WINDOWS\tasks\At11.job
    C:\WINDOWS\tasks\At12.job
    C:\WINDOWS\tasks\At13.job
    C:\WINDOWS\tasks\At14.job
    C:\WINDOWS\tasks\At15.job
    C:\WINDOWS\tasks\At16.job
    C:\WINDOWS\tasks\At17.job
    C:\WINDOWS\tasks\At18.job
    C:\WINDOWS\tasks\At19.job
    C:\WINDOWS\tasks\At2.job
    C:\WINDOWS\tasks\At20.job
    C:\WINDOWS\tasks\At21.job
    C:\WINDOWS\tasks\At22.job
    C:\WINDOWS\tasks\At23.job
    C:\WINDOWS\tasks\At24.job
    C:\WINDOWS\tasks\At25.job
    C:\WINDOWS\tasks\At26.job
    C:\WINDOWS\tasks\At27.job
    C:\WINDOWS\tasks\At28.job
    C:\WINDOWS\tasks\At29.job
    C:\WINDOWS\tasks\At3.job
    C:\WINDOWS\tasks\At30.job
    C:\WINDOWS\tasks\At31.job
    C:\WINDOWS\tasks\At32.job
    C:\WINDOWS\tasks\At33.job
    C:\WINDOWS\tasks\At34.job
    C:\WINDOWS\tasks\At35.job
    C:\WINDOWS\tasks\At36.job
    C:\WINDOWS\tasks\At37.job
    C:\WINDOWS\tasks\At38.job
    C:\WINDOWS\tasks\At39.job
    C:\WINDOWS\tasks\At4.job
    C:\WINDOWS\tasks\At40.job
    C:\WINDOWS\tasks\At41.job
    C:\WINDOWS\tasks\At42.job
    C:\WINDOWS\tasks\At43.job
    C:\WINDOWS\tasks\At44.job
    C:\WINDOWS\tasks\At45.job
    C:\WINDOWS\tasks\At46.job
    C:\WINDOWS\tasks\At47.job
    C:\WINDOWS\tasks\At48.job
    C:\WINDOWS\tasks\At5.job
    C:\WINDOWS\tasks\At6.job
    C:\WINDOWS\tasks\At7.job
    C:\WINDOWS\tasks\At8.job
    C:\WINDOWS\tasks\At9.job
    ======Registry dump======
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{00000000-0000-0000-0000-000000000002}]
    ElnkBhoGuard Class - C:\Program Files\EarthLink\Toolbar\EScamBlk.dll [2007-07-19 247272]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{06849E9F-C8D7-4D59-B87D-784B7D6BE0B3}]
    Adobe PDF Reader Link Helper - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll [2006-12-18 59032]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{15F4D456-5BAA-4076-8486-EECB38CD3E57}]
    ElnkScamBHO Class - C:\Program Files\EarthLink\Toolbar\EScamBlk.dll [2007-07-19 247272]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}]
    AVG Safe Search - C:\Program Files\AVG\AVG8\avgssie.dll []
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{512ACF1B-64D9-4928-B382-A80556F28DB4}]
    ElnkPubBHO Class - C:\Program Files\EarthLink\Toolbar\ElnkPuB.dll [2007-07-19 255464]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{53707962-6F74-2D53-2644-206D7942484F}]
    Spybot-S&D IE Protection - C:\PROGRA~1\SPYBOT~1\SDHelper.dll [2008-07-30 1562448]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{9579D574-D4D8-4335-9560-FE8641A013BD}]
    ElnkProtectionBHO Class - C:\Program Files\EarthLink\Toolbar\ProtctIE.dll [2007-07-19 415208]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{A057A204-BACC-4D26-9990-79A187E2698E}]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{E713904C-DF05-4C79-BBAD-02DB923253BE}]
    ElnkLegacyUninstBHO Class - C:\Program Files\EarthLink\Toolbar\uninsttb.dll [2007-07-19 280040]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar]
    {C7768536-96F8-4001-B1A2-90EE21279187} - EarthLink Toolbar - C:\Program Files\EarthLink\Toolbar\Toolbar.dll [2007-07-19 878056]
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run]
    "igfxtray "=C:\WINDOWS\system32\igfxtray.exe [2005-07-20 94208]
    "igfxhkcmd "=C:\WINDOWS\system32\hkcmd.exe [2005-07-20 77824]
    "igfxpers "=C:\WINDOWS\system32\igfxpers.exe [2005-07-20 114688]
    "SigmatelSysTrayApp "=C:\WINDOWS\stsystra.exe [2005-03-23 339968]
    "DVDLauncher "=C:\Program Files\CyberLink\PowerDVD\DVDLauncher.exe [2005-02-23 53248]
    "ISUSPM Startup "=C:\Program Files\Common Files\InstallShield\UpdateService\isuspm.exe [2005-06-10 249856]
    "ISUSScheduler "=C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe [2005-06-10 81920]
    "RoxioDragToDisc "=C:\Program Files\Roxio\Easy Media Creator 8\Drag to Disc\DrgToDsc.exe [2005-10-20 1687552]
    "AVG8_TRAY "=C:\PROGRA~1\AVG\AVG8\avgtray.exe [2008-09-16 1235736]
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run]
    "SpybotSD TeaTimer "=C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe [2008-08-18 1832272]
    "Creative Detector "=C:\Program Files\Creative\MediaSource\Detector\CTDetect.exe [2004-12-02 102400]
    "EasyLinkAdvisor "=C:\Program Files\Linksys EasyLink Advisor\LinksysAgent.exe [2006-04-02 389120]
    C:\Documents and Settings\All Users\Start Menu\Programs\Startup
    Adobe Reader Speed Launch.lnk - C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
    Adobe Reader Speed Launch.lnk.disabled - C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows]
    "AppInit_DLLS "= "avgrsstx.dll "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\igfxcui]
    C:\WINDOWS\system32\igfxdev.dll [2005-07-20 135168]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\WgaLogon]
    C:\WINDOWS\system32\WgaLogon.dll [2006-06-19 702768]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad]
    WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll [2006-10-18 133632]
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System]
    "dontdisplaylastusername "=0
    "legalnoticecaption "=
    "legalnoticetext "=
    "shutdownwithoutlogon "=1
    "undockwithoutlogon "=1
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\explorer]
    "NoDriveTypeAutoRun "=145
    [HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\standardprofile\authorizedapplications\list]
    "C:\WINDOWS\system32\sessmgr.exe "= "C:\WINDOWS\system32\sessmgr.exe:*:Disabled:mad:xpsp2res.dll,-22019 "
    "C:\Program Files\NET6\net6vpn.exe "= "C:\Program Files\NET6\net6vpn.exe:*:Enabled:Citrix Secure Access Agent "
    "C:\Program Files\Roxio\Easy Media Creator 8\Digital Home\RoxUpnpServer.exe "= "C:\Program Files\Roxio\Easy Media Creator 8\Digital Home\RoxUpnpServer.exe:*:Enabled:Roxio Upnp Service "
    "C:\Program Files\HP\HP Officejet Pro K550 Series\Toolbox\HPWUTBX.exe "= "C:\Program Files\HP\HP Officejet Pro K550 Series\Toolbox\HPWUTBX.exe:*:Enabled:Toolbox for HP Printing System for Windows "
    "C:\Program Files\Roxio\Easy Media Creator 8\VideoUI\VideoWave8.exe "= "C:\Program Files\Roxio\Easy Media Creator 8\VideoUI\VideoWave8.exe:*:Enabled:VideoWave 8 "
    "%windir%\Network Diagnostic\xpnetdiag.exe "= "%windir%\Network Diagnostic\xpnetdiag.exe:*:Enabled:mad:xpsp3res.dll,-20000 "
    "%windir%\system32\sessmgr.exe "= "%windir%\system32\sessmgr.exe:*:enabled:mad:xpsp2res.dll,-22019 "
    "C:\Program Files\AVG\AVG8\avgnsx.exe "= "C:\Program Files\AVG\AVG8\avgnsx.exe:*:Disabled:avgnsx.exe "
    "C:\Program Files\AVG\AVG8\avgupd.exe "= "C:\Program Files\AVG\AVG8\avgupd.exe:*:Disabled:avgupd.exe "
    "C:\Program Files\MySpace\IM\MySpaceIM.exe "= "C:\Program Files\MySpace\IM\MySpaceIM.exe:*:Disabled:MySpaceIM "
    [HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\domainprofile\authorizedapplications\list]
    "C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe "= "C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe:*:Enabled:AOL "
    "C:\Program Files\Common Files\AOL\ACS\AOLDial.exe "= "C:\Program Files\Common Files\AOL\ACS\AOLDial.exe:*:Enabled:AOL "
    "C:\Program Files\America Online 9.0\waol.exe "= "C:\Program Files\America Online 9.0\waol.exe:*:Enabled:AOL "
    ======List of files/folders created in the last 1 months======
    2008-09-22 19:54:21 ----D---- C:\rsit
    2008-09-22 19:30:23 ----D---- C:\Documents and Settings\Don\Application Data\Malwarebytes
    2008-09-22 19:30:19 ----D---- C:\Program Files\Malwarebytes' Anti-Malware
    2008-09-22 19:30:19 ----D---- C:\Documents and Settings\All Users\Application Data\Malwarebytes
    2008-09-21 08:40:52 ----D---- C:\Program Files\Trend Micro
    2008-09-20 20:52:47 ----D---- C:\WINDOWS\pss
    2008-09-20 18:26:04 ----HD---- C:\$AVG8.VAULT$
    2008-09-20 16:45:57 ----D---- C:\Program Files\RegCleaner
    2008-09-18 18:33:20 ----D---- C:\Documents and Settings\Don\Application Data\ScamBlocker
    2008-09-18 18:28:56 ----D---- C:\Program Files\Common Files\EarthLink
    2008-09-18 17:16:57 ----D---- C:\Documents and Settings\Don\Application Data\aAvgApi
    2008-09-18 17:16:56 ----D---- C:\Documents and Settings\Don\Application Data\AVGTOOLBAR
    2008-09-18 16:34:35 ----D---- C:\Program Files\AVG
    2008-09-18 16:34:29 ----D---- C:\Program Files\McAfee
    2008-09-18 16:34:07 ----D---- C:\Program Files\Common Files\EarthLink Protection Control Center
    2008-09-18 16:34:05 ----D---- C:\Program Files\Common Files\ADS
    2008-09-18 16:34:03 ----D---- C:\Documents and Settings\Don\Application Data\InstallShield
    2008-09-18 16:30:11 ----D---- C:\Documents and Settings\All Users\Application Data\avg8
    2008-09-17 19:00:01 ----D---- C:\Program Files\Common Files\ADS(2)
    2008-09-16 19:37:36 ----A---- C:\WINDOWS\system32\avgrsstx.dll
    2008-09-10 07:47:10 ----HDC---- C:\WINDOWS\$NtUninstallKB938464$
    2008-09-10 07:46:32 ----HDC---- C:\WINDOWS\$NtUninstallKB954154_WM11$
    2008-09-09 18:14:10 ----SHD---- C:\WINDOWS\CSC
    2008-09-08 18:07:51 ----A---- C:\WINDOWS\webica.ini
    2008-09-08 18:01:09 ----D---- C:\Program Files\Citrix
    2008-09-06 22:44:17 ----A---- C:\WINDOWS\system32\5W3qdc2O.exe
    2008-09-01 22:54:16 ----HDC---- C:\WINDOWS\$NtUninstallKB951978$
    2008-08-29 17:21:19 ----D---- C:\WINDOWS\Prefetch
    2008-08-29 17:17:47 ----HDC---- C:\WINDOWS\$NtUninstallKB953838$
    2008-08-29 17:17:41 ----HDC---- C:\WINDOWS\$NtUninstallKB952954$
    2008-08-29 17:17:34 ----HDC---- C:\WINDOWS\$NtUninstallKB952287$
    2008-08-29 17:17:27 ----HDC---- C:\WINDOWS\$NtUninstallKB951748$
    2008-08-29 17:17:21 ----HDC---- C:\WINDOWS\$NtUninstallKB951698$
    2008-08-29 17:17:15 ----HDC---- C:\WINDOWS\$NtUninstallKB951376-v2$
    2008-08-29 17:17:09 ----HDC---- C:\WINDOWS\$NtUninstallKB951376$
    2008-08-29 17:17:01 ----HDC---- C:\WINDOWS\$NtUninstallKB951066$
    2008-08-29 17:16:55 ----HDC---- C:\WINDOWS\$NtUninstallKB950974$
    2008-08-29 17:16:49 ----HDC---- C:\WINDOWS\$NtUninstallKB950762$
    2008-08-29 17:16:41 ----HDC---- C:\WINDOWS\$NtUninstallKB950759$
    2008-08-29 17:16:33 ----HDC---- C:\WINDOWS\$NtUninstallKB946648$
    2008-08-29 17:12:47 ----D---- C:\WINDOWS\system32\en-us
    2008-08-29 17:12:46 ----D---- C:\WINDOWS\system32\scripting
    2008-08-29 17:12:46 ----D---- C:\WINDOWS\l2schemas
    2008-08-29 17:12:45 ----D---- C:\WINDOWS\system32\en
    2008-08-29 17:12:45 ----D---- C:\WINDOWS\system32\bits
    2008-08-29 17:10:49 ----D---- C:\WINDOWS\ServicePackFiles
    2008-08-29 17:08:50 ----D---- C:\WINDOWS\network diagnostic
    2008-08-29 17:04:35 ----HDC---- C:\WINDOWS\$NtServicePackUninstall$
    2008-08-27 06:49:18 ----N---- C:\WINDOWS\system32\xmllite.dll
    2008-08-27 06:49:15 ----N---- C:\WINDOWS\system32\wmphoto.dll
    2008-08-27 06:49:13 ----N---- C:\WINDOWS\system32\wlanapi.dll
    2008-08-27 06:49:12 ----N---- C:\WINDOWS\system32\windowscodecsext.dll
    2008-08-27 06:49:12 ----N---- C:\WINDOWS\system32\windowscodecs.dll
    2008-08-27 06:49:04 ----N---- C:\WINDOWS\system32\tspkg.dll
    2008-08-27 06:49:04 ----N---- C:\WINDOWS\system32\tsgqec.dll
    2008-08-27 06:48:56 ----N---- C:\WINDOWS\system32\spupdwxp.exe
    2008-08-27 06:48:55 ----A---- C:\WINDOWS\system32\spdwnwxp.exe
    2008-08-27 06:48:54 ----N---- C:\WINDOWS\system32\slserv.exe
    2008-08-27 06:48:54 ----N---- C:\WINDOWS\system32\slrundll.exe
    2008-08-27 06:48:54 ----N---- C:\WINDOWS\slrundll.exe
    2008-08-27 06:48:53 ----N---- C:\WINDOWS\system32\slgen.dll
    2008-08-27 06:48:53 ----N---- C:\WINDOWS\system32\slextspk.dll
    2008-08-27 06:48:53 ----N---- C:\WINDOWS\system32\slcoinst.dll
    2008-08-27 06:48:49 ----N---- C:\WINDOWS\system32\setupn.exe
    2008-08-27 06:48:46 ----N---- C:\WINDOWS\system32\s3gnb.dll
    2008-08-27 06:48:45 ----N---- C:\WINDOWS\system32\rhttpaa.dll
    2008-08-27 06:48:44 ----N---- C:\WINDOWS\system32\rasqec.dll
    2008-08-27 06:48:42 ----N---- C:\WINDOWS\system32\qutil.dll
    2008-08-27 06:48:41 ----N---- C:\WINDOWS\system32\qcliprov.dll
    2008-08-27 06:48:41 ----N---- C:\WINDOWS\system32\qagentrt.dll
    2008-08-27 06:48:41 ----N---- C:\WINDOWS\system32\qagent.dll
    2008-08-27 06:48:40 ----N---- C:\WINDOWS\system32\photometadatahandler.dll
    2008-08-27 06:48:37 ----N---- C:\WINDOWS\system32\onex.dll
    2008-08-27 06:48:27 ----N---- C:\WINDOWS\system32\napstat.exe
    2008-08-27 06:48:27 ----N---- C:\WINDOWS\system32\napmontr.dll
    2008-08-27 06:48:27 ----N---- C:\WINDOWS\system32\napipsec.dll
    2008-08-27 06:48:27 ----N---- C:\WINDOWS\system32\mtxparhd.dll
    2008-08-27 06:48:26 ----N---- C:\WINDOWS\system32\msxml6r.dll
    2008-08-27 06:48:26 ----N---- C:\WINDOWS\system32\msxml6.dll
    2008-08-27 06:48:25 ----N---- C:\WINDOWS\system32\msshavmsg.dll
    2008-08-27 06:48:25 ----N---- C:\WINDOWS\system32\mssha.dll
    2008-08-27 06:48:10 ----N---- C:\WINDOWS\system32\mmcperf.exe
    2008-08-27 06:48:09 ----N---- C:\WINDOWS\system32\mmcfxcommon.dll
    2008-08-27 06:48:09 ----N---- C:\WINDOWS\system32\mmcex.dll
    2008-08-27 06:48:08 ----N---- C:\WINDOWS\system32\microsoft.managementconsole.dll
    2008-08-27 06:48:02 ----N---- C:\WINDOWS\system32\mdmxsdk.dll
    2008-08-27 06:47:49 ----N---- C:\WINDOWS\system32\l2gpstore.dll
    2008-08-27 06:47:49 ----N---- C:\WINDOWS\system32\kmsvc.dll
    2008-08-27 06:47:48 ----N---- C:\WINDOWS\system32\kbdpash.dll
    2008-08-27 06:47:48 ----N---- C:\WINDOWS\system32\kbdnepr.dll
    2008-08-27 06:47:48 ----N---- C:\WINDOWS\system32\kbdiultn.dll
    2008-08-27 06:47:48 ----N---- C:\WINDOWS\system32\kbdbhc.dll
    2008-08-27 06:47:39 ----N---- C:\WINDOWS\system32\smtpapi.dll
    2008-08-27 06:47:38 ----N---- C:\WINDOWS\system32\rwnh.dll
    2008-08-27 06:47:35 ----N---- C:\WINDOWS\system32\comsdupd.exe
    2008-08-27 06:47:31 ----N---- C:\WINDOWS\system32\hsfcisp2.dll
    2008-08-27 06:47:25 ----N---- C:\WINDOWS\system32\faxpatch.exe
    2008-08-27 06:47:25 ----A---- C:\WINDOWS\002914_.tmp
    2008-08-27 06:47:23 ----N---- C:\WINDOWS\system32\eapsvc.dll
    2008-08-27 06:47:23 ----N---- C:\WINDOWS\system32\eapqec.dll
    2008-08-27 06:47:23 ----N---- C:\WINDOWS\system32\eappprxy.dll
    2008-08-27 06:47:23 ----N---- C:\WINDOWS\system32\eapphost.dll
    2008-08-27 06:47:23 ----N---- C:\WINDOWS\system32\eappgnui.dll
    2008-08-27 06:47:23 ----N---- C:\WINDOWS\system32\eappcfg.dll
    2008-08-27 06:47:23 ----N---- C:\WINDOWS\system32\eapp3hst.dll
    2008-08-27 06:47:23 ----N---- C:\WINDOWS\system32\eapolqec.dll
    2008-08-27 06:47:20 ----N---- C:\WINDOWS\system32\dot3ui.dll
    2008-08-27 06:47:20 ----N---- C:\WINDOWS\system32\dot3svc.dll
    2008-08-27 06:47:20 ----N---- C:\WINDOWS\system32\dot3msm.dll
    2008-08-27 06:47:20 ----N---- C:\WINDOWS\system32\dot3gpclnt.dll
    2008-08-27 06:47:20 ----N---- C:\WINDOWS\system32\dot3dlg.dll
    2008-08-27 06:47:20 ----N---- C:\WINDOWS\system32\dot3cfg.dll
    2008-08-27 06:47:20 ----N---- C:\WINDOWS\system32\dot3api.dll
    2008-08-27 06:47:18 ----N---- C:\WINDOWS\system32\dimsroam.dll
    2008-08-27 06:47:18 ----N---- C:\WINDOWS\system32\dimsntfy.dll
    2008-08-27 06:47:17 ----N---- C:\WINDOWS\system32\dhcpqec.dll
    2008-08-27 06:47:15 ----N---- C:\WINDOWS\system32\credssp.dll
    2008-08-27 06:47:10 ----N---- C:\WINDOWS\system32\bitsprx4.dll
    2008-08-27 06:47:10 ----N---- C:\WINDOWS\system32\azroles.dll
    2008-08-27 06:47:09 ----N---- C:\WINDOWS\system32\ativvaxx.dll
    2008-08-27 06:47:09 ----N---- C:\WINDOWS\system32\ativtmxx.dll
    2008-08-27 06:47:08 ----N---- C:\WINDOWS\system32\ati3duag.dll
    2008-08-27 06:47:08 ----N---- C:\WINDOWS\system32\ati3d1ag.dll
    2008-08-27 06:47:08 ----N---- C:\WINDOWS\system32\ati2dvag.dll
    2008-08-27 06:47:08 ----N---- C:\WINDOWS\system32\ati2dvaa.dll
    2008-08-27 06:47:07 ----N---- C:\WINDOWS\system32\ati2cqag.dll
    2008-08-27 06:47:03 ----N---- C:\WINDOWS\system32\aaclient.dll
    ======List of files/folders modified in the last 1 months======
    2008-09-22 19:54:27 ----D---- C:\WINDOWS\Temp
    2008-09-22 19:47:58 ----D---- C:\WINDOWS\system32
    2008-09-22 19:37:29 ----D---- C:\Program Files\Mozilla Firefox
    2008-09-22 19:34:47 ----D---- C:\WINDOWS\system32\CatRoot2
    2008-09-22 19:31:49 ----D---- C:\WINDOWS\system32\drivers
    2008-09-22 19:26:53 ----D---- C:\WINDOWS
    2008-09-20 17:03:48 ----D---- C:\Program Files\EarthLink
    2008-09-20 17:00:27 ----SHD---- C:\WINDOWS\Installer
    2008-09-20 17:00:27 ----HD---- C:\Config.Msi
    2008-09-20 17:00:26 ----D---- C:\WINDOWS\WinSxS
    2008-09-20 17:00:26 ----D---- C:\Program Files\Common Files\Microsoft Shared
    2008-09-20 16:59:47 ----SD---- C:\Documents and Settings\Don\Application Data\Microsoft
    2008-09-20 14:18:11 ----A---- C:\WINDOWS\win.ini
    2008-09-18 21:53:23 ----D---- C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy
    2008-09-18 19:29:58 ----D---- C:\Documents and Settings
    2008-09-18 19:28:53 ----A---- C:\WINDOWS\wininit.ini
    2008-09-18 18:51:06 ----D---- C:\Documents and Settings\Don\Application Data\Mozilla
    2008-09-18 17:59:38 ----D---- C:\Katie
    2008-09-18 16:38:02 ----D---- C:\WINDOWS\system32\config
    2008-09-18 16:37:03 ----D---- C:\WINDOWS\system32\wbem
    2008-09-18 16:36:59 ----D---- C:\WINDOWS\Registration
    2008-09-18 16:33:58 ----HD---- C:\Program Files\InstallShield Installation Information
    2008-09-17 18:27:19 ----RSD---- C:\WINDOWS\assembly
    2008-09-17 04:53:00 ----SHD---- C:\System Volume Information
    2008-09-17 04:53:00 ----D---- C:\WINDOWS\system32\Restore
    2008-09-14 11:50:32 ----D---- C:\Documents and Settings\Don\Application Data\Canon
    2008-09-11 16:53:25 ----D---- C:\WINDOWS\Debug
    2008-09-10 07:47:12 ----HD---- C:\WINDOWS\inf
    2008-09-09 19:59:15 ----D---- C:\WINDOWS\security
    2008-09-08 18:04:41 ----D---- C:\Documents and Settings\Don\Application Data\ICAClient
    2008-09-06 22:44:17 ----SD---- C:\WINDOWS\Tasks
    2008-09-03 07:39:53 ----RSHD---- C:\WINDOWS\system32\dllcache
    2008-09-02 18:19:45 ----D---- C:\Family Photos
    2008-09-02 16:36:25 ----D---- C:\WINDOWS\Help
    2008-09-01 20:50:53 ----HD---- C:\WINDOWS\$hf_mig$
    2008-08-29 22:24:22 ----D---- C:\Program Files\Spybot - Search & Destroy
    2008-08-29 17:24:22 ----A---- C:\WINDOWS\system32\PerfStringBackup.INI
    2008-08-29 17:20:58 ----D---- C:\WINDOWS\system32\Setup
    2008-08-29 17:20:58 ----D---- C:\WINDOWS\AppPatch
    2008-08-29 17:20:56 ----RSD---- C:\WINDOWS\Fonts
    2008-08-29 17:17:51 ----D---- C:\WINDOWS\system32\CatRoot
    2008-08-29 17:16:35 ----D---- C:\Program Files\Messenger
    2008-08-29 17:12:59 ----D---- C:\WINDOWS\system32\inetsrv
    2008-08-29 17:12:59 ----D---- C:\WINDOWS\ime
    2008-08-29 17:12:47 ----D---- C:\WINDOWS\system32\usmt
    2008-08-29 17:12:46 ----D---- C:\Program Files\Internet Explorer
    2008-08-29 17:12:45 ----D---- C:\WINDOWS\PeerNet
    2008-08-29 17:12:45 ----D---- C:\Program Files\Movie Maker
    2008-08-29 17:10:40 ----D---- C:\WINDOWS\system32\npp
    2008-08-29 17:10:40 ----D---- C:\WINDOWS\mui
    2008-08-29 17:10:38 ----D---- C:\WINDOWS\msagent
    2008-08-29 17:10:37 ----D---- C:\WINDOWS\srchasst
    2008-08-29 17:10:36 ----D---- C:\Program Files\NetMeeting
    2008-08-29 17:10:35 ----D---- C:\WINDOWS\system32\Com
    2008-08-29 17:10:33 ----D---- C:\Program Files\Windows NT
    2008-08-29 17:10:33 ----D---- C:\Program Files\Windows Media Player
    2008-08-29 17:10:33 ----D---- C:\Program Files\Outlook Express
    2008-08-29 17:10:30 ----D---- C:\Program Files\Common Files\System
    2008-08-29 17:10:17 ----D---- C:\WINDOWS\system32\oobe
    2008-08-29 17:10:15 ----D---- C:\WINDOWS\system
    2008-08-29 17:07:50 ----D---- C:\WINDOWS\system32\ReinstallBackups
    2008-08-29 17:04:33 ----D---- C:\WINDOWS\ehome
    2008-08-26 16:28:12 ----A---- C:\WINDOWS\system32\MRT.exe
    ======List of drivers (R=Running, S=Stopped, 0=Boot, 1=System, 2=Auto, 3=Demand, 4=Disabled)======
    R1 AvgLdx86;AVG AVI Loader Driver x86; C:\WINDOWS\System32\Drivers\avgldx86.sys [2008-09-16 97928]
    R1 AvgMfx86;AVG On-access Scanner Minifilter Driver x86; C:\WINDOWS\System32\Drivers\avgmfx86.sys [2008-09-16 26824]
    R1 cdudf_xp;cdudf_xp; C:\WINDOWS\system32\drivers\cdudf_xp.sys [2005-10-20 311680]
    R1 intelppm;Intel Processor Driver; C:\WINDOWS\system32\DRIVERS\intelppm.sys [2008-04-13 36352]
    R1 kbdhid;Keyboard HID Driver; C:\WINDOWS\system32\DRIVERS\kbdhid.sys [2008-04-13 14592]
    R1 pwd_2k;pwd_2k; C:\WINDOWS\system32\drivers\pwd_2k.sys [2005-10-20 119168]
    R1 RxFilter;RxFilter; C:\WINDOWS\system32\DRIVERS\RxFilter.sys [2005-10-21 50176]
    R3 Arp1394;1394 ARP Client Protocol; C:\WINDOWS\system32\DRIVERS\arp1394.sys [2008-04-13 60800]
    R3 dvd_2K;dvd_2K; C:\WINDOWS\system32\drivers\dvd_2K.sys [2005-10-20 27264]
    R3 E100B;Intel(R) PRO Network Connection Driver; C:\WINDOWS\system32\DRIVERS\e100b325.sys [2004-10-14 155648]
    R3 HDAudBus;Microsoft UAA Bus Driver for High Definition Audio; C:\WINDOWS\system32\DRIVERS\HDAudBus.sys [2008-04-13 144384]
    R3 HidUsb;Microsoft HID Class Driver; C:\WINDOWS\system32\DRIVERS\hidusb.sys [2008-04-13 10368]
    R3 ialm;ialm; C:\WINDOWS\system32\DRIVERS\ialmnt5.sys [2005-07-20 1049180]
    R3 mouhid;Mouse HID Driver; C:\WINDOWS\system32\DRIVERS\mouhid.sys [2001-08-17 12160]
    R3 NIC1394;1394 Net Driver; C:\WINDOWS\system32\DRIVERS\nic1394.sys [2008-04-13 61824]
    R3 STHDA;High Definition Audio Driver (WDM) - SigmaTel CODEC; C:\WINDOWS\system32\drivers\sthda.sys [2005-06-15 180864]
    R3 usbehci;Microsoft USB 2.0 Enhanced Host Controller Miniport Driver; C:\WINDOWS\system32\DRIVERS\usbehci.sys [2008-04-13 30208]
    R3 usbhub;Microsoft USB Standard Hub Driver; C:\WINDOWS\system32\DRIVERS\usbhub.sys [2008-04-13 59520]
    R3 usbprint;Microsoft USB PRINTER Class; C:\WINDOWS\system32\DRIVERS\usbprint.sys [2008-04-13 25856]
    R3 usbscan;USB Scanner Driver; C:\WINDOWS\system32\DRIVERS\usbscan.sys [2008-04-13 15104]
    R3 usbuhci;Microsoft USB Universal Host Controller Miniport Driver; C:\WINDOWS\system32\DRIVERS\usbuhci.sys [2008-04-13 20608]
    S2 ASCTRM;ASCTRM; C:\WINDOWS\system32\drivers\ASCTRM.sys [2006-01-14 8552]
    S2 CSS DVP;Dynamic Virus Protection; C:\WINDOWS\system32\DRIVERS\css-dvp.sys [2007-02-12 837056]
    S2 GRTdiMon;GR TDI Mon; C:\WINDOWS\System32\Drivers\GRTdiMon.sys [2007-04-11 42496]
    S3 61883;61883 Unit Device; C:\WINDOWS\system32\DRIVERS\61883.sys [2008-04-13 48128]
    S3 ADSFilter;ADSFilter - (EarthLink Filter Driver); C:\WINDOWS\system32\drivers\ADSFilter.sys [2007-08-03 57456]
    S3 ADSMonitor;ADSMonitor - (EarthLink Monitor Driver); C:\WINDOWS\system32\drivers\ADSMonitor.sys [2007-08-03 38384]
    S3 Avc;AVC Device; C:\WINDOWS\system32\DRIVERS\avc.sys [2008-04-13 38912]
    S3 CCDECODE;Closed Caption Decoder; C:\WINDOWS\system32\DRIVERS\CCDECODE.sys [2008-04-13 17024]
    S3 EarthLinkSafeConnectDriver;EarthLinkSafeConnectDriver; \??\C:\Program Files\EarthLink\EarthLink Protection Control Center\Sana\Driver\platform_XP\SafeConnectDriver.sys []
    S3 EarthLinkSafeConnectFilter;EarthLinkSafeConnectFilter; \??\C:\Program Files\EarthLink\EarthLink Protection Control Center\Sana\Driver\platform_XP\SafeConnectFilter.sys []
    S3 EarthLinkSafeConnectShim;EarthLinkSafeConnectShim; \??\C:\Program Files\EarthLink\EarthLink Protection Control Center\Sana\Driver\platform_XP\SafeConnectShim.sys []
    S3 GoProto;GoProto Protocol Driver; C:\WINDOWS\system32\DRIVERS\goprot51.sys [2007-05-19 29184]
    S3 mmc_2K;mmc_2K; C:\WINDOWS\system32\drivers\mmc_2K.sys [2005-10-20 27136]
    S3 MSDV;Microsoft DV Camera and VCR; C:\WINDOWS\system32\DRIVERS\msdv.sys [2008-04-13 51200]
    S3 MSTEE;Microsoft Streaming Tee/Sink-to-Sink Converter; C:\WINDOWS\system32\drivers\MSTEE.sys [2008-04-13 5504]
    S3 NABTSFEC;NABTS/FEC VBI Codec; C:\WINDOWS\system32\DRIVERS\NABTSFEC.sys [2008-04-13 85248]
    S3 NdisIP;Microsoft TV/Video Connection; C:\WINDOWS\system32\DRIVERS\NdisIP.sys [2008-04-13 10880]
    S3 Net6IM;Net6; C:\WINDOWS\system32\DRIVERS\net6im51.sys []
    S3 nv;nv; C:\WINDOWS\system32\DRIVERS\nv4_mini.sys [2004-08-04 1897408]
    S3 SLIP;BDA Slip De-Framer; C:\WINDOWS\system32\DRIVERS\SLIP.sys [2008-04-13 11136]
    S3 streamip;BDA IPSink; C:\WINDOWS\system32\DRIVERS\StreamIP.sys [2008-04-13 15232]
    S3 usbccgp;Microsoft USB Generic Parent Driver; C:\WINDOWS\system32\DRIVERS\usbccgp.sys [2008-04-13 32128]
    S3 USBSTOR;USB Mass Storage Driver; C:\WINDOWS\system32\DRIVERS\USBSTOR.SYS [2008-04-13 26368]
    S3 wanatw;WAN Miniport (ATW); C:\WINDOWS\system32\DRIVERS\wanatw4.sys []
    S3 WSTCODEC;World Standard Teletext Codec; C:\WINDOWS\system32\DRIVERS\WSTCODEC.SYS [2008-04-13 19200]
    S3 WudfPf;Windows Driver Foundation - User-mode Driver Framework Platform Driver; C:\WINDOWS\system32\DRIVERS\WudfPf.sys [2006-09-28 77568]
    S3 WudfRd;Windows Driver Foundation - User-mode Driver Framework Reflector; C:\WINDOWS\system32\DRIVERS\wudfrd.sys [2006-09-28 82944]
    S4 agp440;Intel AGP Bus Filter; C:\WINDOWS\system32\DRIVERS\agp440.sys [2008-04-13 42368]
    S4 agpCPQ;Compaq AGP Bus Filter; C:\WINDOWS\system32\DRIVERS\agpCPQ.sys [2008-04-13 44928]
    S4 alim1541;ALI AGP Bus Filter; C:\WINDOWS\system32\DRIVERS\alim1541.sys [2008-04-13 42752]
    S4 amdagp;AMD AGP Bus Filter Driver; C:\WINDOWS\system32\DRIVERS\amdagp.sys [2008-04-13 43008]
    S4 cbidf;cbidf; C:\WINDOWS\system32\DRIVERS\cbidf2k.sys [2001-08-17 13952]
    S4 IntelIde;IntelIde; C:\WINDOWS\system32\DRIVERS\intelide.sys [2008-04-13 5504]
    S4 sisagp;SIS AGP Bus Filter; C:\WINDOWS\system32\DRIVERS\sisagp.sys [2008-04-13 40960]
    S4 viaagp;VIA AGP Bus Filter; C:\WINDOWS\system32\DRIVERS\viaagp.sys [2008-04-13 42240]
    ======List of services (R=Running, S=Stopped, 0=Boot, 1=System, 2=Auto, 3=Demand, 4=Disabled)======
    S2 avg8wd;AVG8 WatchDog; C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe [2008-09-16 231704]
    S2 Creative Service for CDROM Access;Creative Service for CDROM Access; C:\WINDOWS\system32\CTsvcCDA.EXE [1999-12-12 44032]
    S2 dvpapi;DvpApi; C:\Program Files\Common Files\Authentium\AntiVirus\dvpapi.exe [2007-02-12 177672]
    S2 Fax;Fax; C:\WINDOWS\system32\fxssvc.exe [2008-04-13 267776]
    S2 RoxLiveShare;LiveShare P2P Server; C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxLiveShare.exe [2005-10-21 229376]
    S2 RoxUpnpServer;RoxUpnpServer; C:\Program Files\Roxio\Easy Media Creator 8\Digital Home\RoxUpnpServer.exe [2005-10-21 405504]
    S2 RoxWatch;Roxio Hard Drive Watcher; C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxWatch.exe [2005-10-21 155648]
    S3 aspnet_state;ASP.NET State Service; C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_state.exe [2007-10-24 33800]
    S3 AuthFw;AuthFw; C:\Program Files\Authentium\Firewall SDK\AuthFw.exe [2007-04-05 495616]
    S3 clr_optimization_v2.0.50727_32;.NET Runtime Optimization Service v2.0.50727_X86; C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe [2007-10-24 70144]
    S3 EarthLinkSafeConnectAgent;EarthLinkSafeConnectAgent; C:\Program Files\EarthLink\EarthLink Protection Control Center\Sana\Bin\SanaAgent.exe EarthLinkSafeConnectAgent []
    S3 IDriverT;InstallDriver Table Manager; C:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe [2004-10-22 73728]
    S3 NetSvc;Intel NCS NetService; C:\Program Files\Intel\PROSetWired\NCS\Sync\NetSvc.exe [2004-11-19 147456]
    S3 RoxMediaDB;RoxMediaDB; C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxMediaDB.exe [2005-10-21 864256]
    S3 RoxUPnPRenderer;RoxUpnpRenderer; C:\Program Files\Common Files\Roxio Shared\SharedCom\RoxUpnpRenderer.exe [2005-10-21 45056]
    S3 WMPNetworkSvc;Windows Media Player Network Sharing Service; C:\Program Files\Windows Media Player\WMPNetwk.exe [2006-10-18 913408]
    S3 WudfSvc;Windows Driver Foundation - User-mode Driver Framework; C:\WINDOWS\system32\svchost.exe [2008-04-13 14336]
    S4 ADSService;ADSService; C:\Program Files\Common Files\ADS\ADSService.exe [2007-08-03 116200]
    S4 ELNKUpdateService;ELNK Update Service; C:\Program Files\EarthLink\EarthLink Protection Control Center\bin\UpdateService.exe []
    S4 ProtectionService;ProtectionService; C:\Program Files\EarthLink\EarthLink Protection Control Center\bin\ProtectionService.exe []
    -----------------EOF---------------
  8. 2008/09/22
    Hi
    Ok first you have two Anti Virus programs, if you are just using one as a scanner only then that is OK, make sure only one is running real time protection.
    Authentium AntiVirus
    AVG8
    Please do this next.
    Download ComboFix from Here to your Desktop.
    It's best to disable realtime protection applications as they sometimes interfere with the tool.
    Check this link for any applicable programs you may have.
    • Close all open programs and windows
    • Double click combofix.exe and follow the prompts.
    • Vista users right click Combofix.exe and select Run As Administrator.
    • When finished, it shall produce a log for you. Post the Combofix log
    Note: Do not mouseclick combofix's window while its running. That may cause it to stall
    Note - ComboFix may reset a number of Internet Explorer's settings, including making it the default browser.
    Note - Combofix makes some changes when run to prevent autorun/autoplay of ALL CDs, floppies and USB devices, to assist with malware removal & increase security. If this is an issue or makes it difficult for you to use those devices, please ask how to reset it.
    Please post the Combofix log.
    Geri
    Geri,
    #7
  9. 2008/09/23
    Stratman50th
    ComboFix Log:
    ComboFix 08-09-22.06 - Don 2008-09-23 16:28:59.1 - NTFSx86 NETWORK
    Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.670 [GMT -4:00]
    Running from: C:\Documents and Settings\Don\Desktop\ComboFix.exe
    * Created a new restore point
    WARNING -THIS MACHINE DOES NOT HAVE THE RECOVERY CONSOLE INSTALLED !!
    ((((((((((((((((((((((((( Files Created from 2008-08-23 to 2008-09-23 )))))))))))))))))))))))))))))))
    2008-09-22 19:54 . 2008-09-22 19:54 <DIR> d-------- C:\rsit
    2008-09-22 19:30 . 2008-09-22 19:31 <DIR> d-------- C:\Program Files\Malwarebytes' Anti-Malware
    2008-09-22 19:30 . 2008-09-22 19:30 <DIR> d-------- C:\Documents and Settings\Don\Application Data\Malwarebytes
    2008-09-22 19:30 . 2008-09-22 19:30 <DIR> d-------- C:\Documents and Settings\All Users\Application Data\Malwarebytes
    2008-09-22 19:30 . 2008-09-10 00:04 38,528 --a------ C:\WINDOWS\system32\drivers\mbamswissarmy.sys
    2008-09-22 19:30 . 2008-09-10 00:03 17,200 --a------ C:\WINDOWS\system32\drivers\mbam.sys
    2008-09-21 08:40 . 2008-09-21 08:40 <DIR> d-------- C:\Program Files\Trend Micro
    2008-09-20 18:26 . 2008-09-20 18:26 <DIR> d--h----- C:\$AVG8.VAULT$
    2008-09-20 16:45 . 2008-09-20 16:58 <DIR> d-------- C:\Program Files\RegCleaner
    2008-09-18 19:29 . 2008-09-20 17:00 262,144 --a------ C:\Documents and Settings\Katie's
    2008-09-18 19:00 . 2008-09-18 19:00 <DIR> d-------- C:\Documents and Settings\NetworkService\Application Data\ScamBlocker
    2008-09-18 19:00 . 2008-09-18 19:00 <DIR> d-------- C:\Documents and Settings\NetworkService\Application Data\EarthLink
    2008-09-18 18:33 . 2008-09-18 18:33 <DIR> d-------- C:\Documents and Settings\Don\Application Data\ScamBlocker
    2008-09-18 18:28 . 2008-09-18 18:29 <DIR> d-------- C:\Program Files\Common Files\EarthLink
    2008-09-18 17:16 . 2008-09-18 17:19 <DIR> d-------- C:\Documents and Settings\Don\Application Data\AVGTOOLBAR
    2008-09-18 17:16 . 2008-09-18 17:16 <DIR> d-------- C:\Documents and Settings\Don\Application Data\aAvgApi
    2008-09-18 17:01 . 2008-09-18 17:01 <DIR> d-------- C:\Documents and Settings\NetworkService\Application Data\aAvgApi
    2008-09-18 16:34 . 2008-09-20 17:13 <DIR> d-------- C:\WINDOWS\system32\drivers\Avg
    2008-09-18 16:34 . 2008-09-18 18:06 <DIR> d-------- C:\Program Files\McAfee
    2008-09-18 16:34 . 2008-09-18 16:34 <DIR> d-------- C:\Program Files\Common Files\EarthLink Protection Control Center
    2008-09-18 16:34 . 2008-09-18 16:40 <DIR> d-------- C:\Program Files\Common Files\ADS
    2008-09-18 16:34 . 2008-09-18 16:34 <DIR> d-------- C:\Program Files\AVG
    2008-09-18 16:34 . 2008-09-18 16:34 <DIR> d-------- C:\Documents and Settings\LocalService\Application Data\InstallShield
    2008-09-18 16:34 . 2008-09-18 16:34 <DIR> d-------- C:\Documents and Settings\Don\Application Data\InstallShield
    2008-09-18 16:30 . 2008-09-20 17:13 <DIR> d-------- C:\Documents and Settings\All Users\Application Data\avg8
    2008-09-17 20:08 . 2008-09-17 20:14 8,192 --a------ C:\Documents and Settings\TEMP\NTUSER(2).DAT
    2008-09-17 19:00 . 2008-09-18 16:33 <DIR> d-------- C:\Program Files\Common Files\ADS(2)
    2008-09-17 18:29 . 2008-09-17 18:29 <DIR> d-------- C:\Documents and Settings\Administrator\Application Data\EarthLink
    2008-09-16 22:44 . 2008-09-16 22:44 163,840 --ah----- C:\AFCache.dat
    2008-09-16 19:37 . 2008-09-16 19:37 97,928 --a------ C:\WINDOWS\system32\drivers\avgldx86.sys
    2008-09-16 19:37 . 2008-09-16 19:37 12,936 --a------ C:\WINDOWS\system32\drivers\avgrkx86.sys
    2008-09-16 19:37 . 2008-09-16 19:37 10,520 --a------ C:\WINDOWS\system32\avgrsstx.dll
    2008-09-09 18:32 . 2008-09-09 18:32 <DIR> d-------- C:\Documents and Settings\Administrator\Application Data\Lavasoft
    2008-09-09 17:03 . 2008-09-09 17:03 <DIR> d-------- C:\Documents and Settings\Administrator\Application Data\Talkback
    2008-09-08 18:07 . 2008-09-08 18:07 0 --a------ C:\WINDOWS\webica.ini
    2008-09-08 18:01 . 2008-09-08 18:01 <DIR> d-------- C:\Program Files\Citrix
    2008-09-06 22:44 . 2008-09-20 14:29 39,426 --a------ C:\WINDOWS\system32\5W3qdc2O.exe
    2008-08-29 17:12 . 2008-08-29 17:12 <DIR> d-------- C:\WINDOWS\system32\scripting
    2008-08-29 17:12 . 2008-08-29 17:12 <DIR> d-------- C:\WINDOWS\system32\en
    2008-08-29 17:12 . 2008-08-29 17:12 <DIR> d-------- C:\WINDOWS\system32\bits
    2008-08-29 17:12 . 2008-08-29 17:12 <DIR> d-------- C:\WINDOWS\l2schemas
    2008-08-29 17:10 . 2008-08-29 17:10 <DIR> d-------- C:\WINDOWS\ServicePackFiles
    2008-08-28 16:23 . 2008-08-28 16:23 35,262 --a------ C:\WINDOWS\Katie's.acl
    2008-08-27 06:48 . 2008-04-13 20:12 1,737,856 --------- C:\WINDOWS\system32\mtxparhd.dll
    2008-08-27 06:47 . 2008-04-13 20:11 1,888,992 --------- C:\WINDOWS\system32\ati3duag.dll
    2008-09-20 21:03 --------- d-----w C:\Program Files\EarthLink
    2008-09-19 01:53 --------- d-----w C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy
    2008-09-18 20:33 --------- d--h--w C:\Program Files\InstallShield Installation Information
    2008-09-14 15:51 --------- d-----w C:\Documents and Settings\Don\Application Data\Canon
    2008-09-10 01:24 4,184 --sha-w C:\WINDOWS\system32\KGyGaAvL.sys
    2008-09-08 22:04 --------- d-----w C:\Documents and Settings\Don\Application Data\ICAClient
    2008-08-30 02:24 --------- d-----w C:\Program Files\Spybot - Search & Destroy
    2008-07-19 02:10 94,920 ----a-w C:\WINDOWS\system32\dllcache\cdm.dll
    2008-07-19 02:10 94,920 ----a-w C:\WINDOWS\system32\cdm.dll
    2008-07-19 02:10 53,448 ----a-w C:\WINDOWS\system32\wuauclt.exe
    2008-07-19 02:10 53,448 ----a-w C:\WINDOWS\system32\dllcache\wuauclt.exe
    2008-07-19 02:10 45,768 ----a-w C:\WINDOWS\system32\wups2.dll
    2008-07-19 02:10 36,552 ----a-w C:\WINDOWS\system32\wups.dll
    2008-07-19 02:10 36,552 ----a-w C:\WINDOWS\system32\dllcache\wups.dll
    2008-07-19 02:09 563,912 ----a-w C:\WINDOWS\system32\wuapi.dll
    2008-07-19 02:09 563,912 ----a-w C:\WINDOWS\system32\dllcache\wuapi.dll
    2008-07-19 02:09 325,832 ----a-w C:\WINDOWS\system32\wucltui.dll
    2008-07-19 02:09 325,832 ----a-w C:\WINDOWS\system32\dllcache\wucltui.dll
    2008-07-19 02:09 205,000 ----a-w C:\WINDOWS\system32\wuweb.dll
    2008-07-19 02:09 205,000 ----a-w C:\WINDOWS\system32\dllcache\wuweb.dll
    2008-07-19 02:09 1,811,656 ----a-w C:\WINDOWS\system32\wuaueng.dll
    2008-07-19 02:09 1,811,656 ----a-w C:\WINDOWS\system32\dllcache\wuaueng.dll
    2008-07-07 20:26 253,952 ----a-w C:\WINDOWS\system32\es.dll
    2008-07-07 20:26 253,952 ------w C:\WINDOWS\system32\dllcache\es.dll
    2008-06-26 08:15 619,520 ------w C:\WINDOWS\system32\dllcache\urlmon.dll
    2008-06-26 08:15 1,499,136 ------w C:\WINDOWS\system32\dllcache\shdocvw.dll
    2008-06-24 22:12 295,936 ------w C:\WINDOWS\system32\wmpeffects.dll
    2008-06-24 16:43 74,240 ----a-w C:\WINDOWS\system32\mscms.dll
    2008-06-24 16:43 74,240 ------w C:\WINDOWS\system32\dllcache\mscms.dll
    2008-06-23 15:09 666,112 ----a-w C:\WINDOWS\system32\wininet.dll
    2008-06-23 15:09 666,112 ------w C:\WINDOWS\system32\dllcache\wininet.dll
    2008-06-23 15:09 3,067,392 ------w C:\WINDOWS\system32\dllcache\mshtml.dll
    2006-06-22 10:49 13,386 ----a-w C:\Program Files\mozilla firefox\plugins\atgpcdec.dll
    2006-06-22 10:49 92,234 ----a-w C:\Program Files\mozilla firefox\plugins\atgpcext.dll
    "SpybotSD TeaTimer "= "C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe" [2008-08-18 1832272]
    "Creative Detector "= "C:\Program Files\Creative\MediaSource\Detector\CTDetect.exe" [2004-12-02 102400]
    "EasyLinkAdvisor "= "C:\Program Files\Linksys EasyLink Advisor\LinksysAgent.exe" [2006-04-02 389120]
    "igfxtray "= "C:\WINDOWS\system32\igfxtray.exe" [2005-07-20 94208]
    "igfxhkcmd "= "C:\WINDOWS\system32\hkcmd.exe" [2005-07-20 77824]
    "igfxpers "= "C:\WINDOWS\system32\igfxpers.exe" [2005-07-20 114688]
    "DVDLauncher "= "C:\Program Files\CyberLink\PowerDVD\DVDLauncher.exe" [2005-02-23 53248]
    "ISUSPM Startup "= "C:\Program Files\Common Files\InstallShield\UpdateService\isuspm.exe" [2005-06-10 249856]
    "ISUSScheduler "= "C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe" [2005-06-10 81920]
    "RoxioDragToDisc "= "C:\Program Files\Roxio\Easy Media Creator 8\Drag to Disc\DrgToDsc.exe" [2005-10-20 1687552]
    "AVG8_TRAY "= "C:\PROGRA~1\AVG\AVG8\avgtray.exe" [2008-09-16 1235736]
    "SigmatelSysTrayApp "= "stsystra.exe" [2005-03-23 C:\WINDOWS\stsystra.exe]
    C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
    Adobe Reader Speed Launch.lnk - C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe [2008-04-23 29696]
    Adobe Reader Speed Launch.lnk.disabled [2008-03-09 1757]
    [HKEY_USERS\.default\software\microsoft\windows\currentversion\policies\explorer]
    "EditLevel "= 0 (0x0)
    "NoClose "= 0 (0x0)
    "NoCommonGroups "= 0 (0x0)
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\windows]
    "AppInit_DLLs "=avgrsstx.dll
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ati0cexx.sys]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ati1jlxx.sys]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ati2jlxx.sys]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ati6uxxx.sys]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ati7xbxx.sys]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ati8fhxx.sys]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeAntiVirus]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeFirewall]
    "C:\\WINDOWS\\system32\\sessmgr.exe "=
    "C:\\Program Files\\Roxio\\Easy Media Creator 8\\Digital Home\\RoxUpnpServer.exe "=
    "C:\\Program Files\\HP\\HP Officejet Pro K550 Series\\Toolbox\\HPWUTBX.exe "=
    "C:\\Program Files\\Roxio\\Easy Media Creator 8\\VideoUI\\VideoWave8.exe "=
    "%windir%\\Network Diagnostic\\xpnetdiag.exe "=
    "C:\\Program Files\\AVG\\AVG8\\avgupd.exe "=
    R0 AvgRkx86;avgrkx86.sys;C:\WINDOWS\system32\Drivers\avgrkx86.sys [2008-09-16 12936]
    R0 GRFILTER;CS NDIS Driver;C:\WINDOWS\system32\drivers\GRFILTER.sys [2007-04-11 22528]
    R1 AvgLdx86;AVG AVI Loader Driver x86;C:\WINDOWS\system32\Drivers\avgldx86.sys [2008-09-16 97928]
    S2 avg8wd;AVG8 WatchDog;C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe [2008-09-16 231704]
    S2 GRTdiMon;GR TDI Mon;C:\WINDOWS\system32\Drivers\GRTdiMon.sys [2007-04-11 42496]
    S3 ADSFilter;ADSFilter - (EarthLink Filter Driver);C:\WINDOWS\system32\drivers\ADSFilter.sys [2007-08-03 57456]
    S3 ADSMonitor;ADSMonitor - (EarthLink Monitor Driver);C:\WINDOWS\system32\drivers\ADSMonitor.sys [2007-08-03 38384]
    S3 AuthFw;AuthFw;C:\Program Files\Authentium\Firewall SDK\AuthFw.exe [2007-04-05 495616]
    S3 EarthLinkSafeConnectDriver;EarthLinkSafeConnectDriver;C:\Program Files\EarthLink\EarthLink Protection Control Center\Sana\Driver\platform_XP\SafeConnectDriver.sys [ ]
    S3 EarthLinkSafeConnectFilter;EarthLinkSafeConnectFilter;C:\Program Files\EarthLink\EarthLink Protection Control Center\Sana\Driver\platform_XP\SafeConnectFilter.sys [ ]
    S3 EarthLinkSafeConnectShim;EarthLinkSafeConnectShim;C:\Program Files\EarthLink\EarthLink Protection Control Center\Sana\Driver\platform_XP\SafeConnectShim.sys [ ]
    S3 Net6IM;Net6;C:\WINDOWS\system32\DRIVERS\net6im51.sys [ ]
    *Newly Created Service* - PROCEXP90
    FireFox -: Profile - C:\Documents and Settings\Don\Application Data\Mozilla\Firefox\Profiles\tjztp4pb.default\
    FireFox -: prefs.js - STARTUP.HOMEPAGE - hxxp://www.google.com/
    FF -: plugin - C:\Program Files\Adobe\Acrobat 7.0\Reader\browser\nppdf32.dll
    FF -: plugin - C:\Program Files\Java\j2re1.4.2_03\bin\NPJava11.dll
    FF -: plugin - C:\Program Files\Java\j2re1.4.2_03\bin\NPJava12.dll
    FF -: plugin - C:\Program Files\Java\j2re1.4.2_03\bin\NPJava13.dll
    FF -: plugin - C:\Program Files\Java\j2re1.4.2_03\bin\NPJava14.dll
    FF -: plugin - C:\Program Files\Java\j2re1.4.2_03\bin\NPJava32.dll
    FF -: plugin - C:\Program Files\Java\j2re1.4.2_03\bin\NPJPI142_03.dll
    FF -: plugin - C:\Program Files\Java\j2re1.4.2_03\bin\NPOJI610.dll
    FF -: plugin - C:\Program Files\Mozilla Firefox\plugins\npatgpc.dll
    FF -: plugin - C:\Program Files\Mozilla Firefox\plugins\npmozax.dll
    FF -: plugin - C:\Program Files\Mozilla Firefox\plugins\npsnapfish.dll
    FF -: plugin - C:\Program Files\Viewpoint\Viewpoint Experience Technology\npViewpoint.dll
    catchme 0.3.1361 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
    Rootkit scan 2008-09-23 16:33:07
    Windows 5.1.2600 Service Pack 3 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    Completion time: 2008-09-23 16:33:59
    ComboFix-quarantined-files.txt 2008-09-23 20:33:57
    Pre-Run: 115,696,418,816 bytes free
    Post-Run: 116,416,270,336 bytes free
    193 --- E O F --- 2008-09-10 11:48:04
    AVG8 I downloaded and installed as a result of this problem. I'm not using any ant-virus at the moment.
    I don't know where Authentium AntiVirus came from, unless they are the author of the Earthlink AntiVirus software, which does not appear to be completely uninstalled.
  10. 2008/09/23
    Hi
    OK please decide on one (1) and install it, you need a AV running on your system.
    Please do this.
    • Please go to Jotti's malware scan
    • Copy and paste the following file path into the "File to upload & scan "box on the top of the page: one at a time
      • C:\WINDOWS\system32\5W3qdc2O.exe
    • Click on the submit button
    • Please post the results in your next reply.
    Highlight and copy the contents of the code box below and paste it into a blank Notepad, then save it to your desktop as;
    Filename: CFScript.txt
    Save As Type: All Files (*.*)
    Close all other windows and programs. Now drag the CFScript.txt onto ComboFix.exe and drop it, using the left mouse button.
    Click here to see how to use CFScript.txt
    Combofix should run and may reboot the computer when it's done. A log will open when it's complete. Post the contents of that log and another fresh HijackThis log.
    Please do not click on the ComboFix window while it is running a scan. This can cause it to stall.
    Folder::
    Registry::
    [-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ati0c xx.sys]
    [-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ati1jlxx.sys]
    [-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ati2jlxx.sys]
    [-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ati6uxxx.sys]
    [-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ati7xxx.sys]
    [-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ati8fhxx.sys]
    Please post the combofix log and the Jotti results.
    Geri
    Geri,
    #9
  11. 2008/09/24
    Stratman50th
    I reinstalled the Earthlink last night and was going to use it since it also has a firewall. Unfortunately, the functionality goes back to my first post here. The services won't start on the AV/Firewall because the system thinks it's still in safe mode. No sound, no printer, no AV software. It seems to be running in some type of hybrid mode:confused:
    I'm in my profile, not safe mode, but it's running in some kind of half safe mode. The Administrator profile is also available as a user, which is strange because it's normally hidden. I can't start the services manually because I get the error 1084 can't start services in safe mode.
    Back on topic. I'll run the above listed software tonight and post the results.
    Thanks again as always!
  12. 2008/09/24
    Stratman50th
    Scanner results
    Scan taken on 24 Sep 2008 23:31:26 (GMT)
    A-Squared
    Found nothing
    AntiVir
    Found TR/Crypt.ULPM.Gen
    ArcaVir
    Found Trojan.Downloader.Agent.Ahdb
    Avast
    Found Win32:Trojan-gen {Other}
    AVG Antivirus
    Found nothing
    BitDefender
    Found Trojan.Adclicker.HB
    ClamAV
    Found Trojan.Downloader-56035
    CPsecure
    Found Troj.W32.Agent.wro
    Dr.Web
    Found Trojan.Popuper.7420
    F-Prot Antivirus
    Found nothing
    F-Secure Anti-Virus
    Found Trojan-Downloader.Win32.Agent.ahdb
    Ikarus
    Kaspersky Anti-Virus
    NOD32
    Found a variant of Win32/TrojanClicker.Agent.NEB
    Norman Virus Control
    Found W32/Smalltroj.HITE
    Panda Antivirus
    Found nothing
    Sophos Antivirus
    Found Mal/HckPk-A
    VirusBuster
    Found nothing
    VBA32
    Last file scanned at least one scanner reported something about: driverRemove.sys (MD5: f85c5890333e35375a547b2c9184bdf4, size: 4992 bytes), detected by:
    Scanner Malware name
    A-Squared X
    AntiVir TR/Spy.Banker.AAZN
    ArcaVir X
    Avast X
    AVG Antivirus X
    BitDefender Trojan.Spy.Banker.AAZM
    ClamAV X
    CPsecure X
    Dr.Web X
    F-Prot Antivirus X
    F-Secure Anti-Virus Trojan.Win32.KillFiles.abs
    Ikarus X
    Kaspersky Anti-Virus Trojan.Win32.KillFiles.abs
    NOD32 X
    Norman Virus Control X
    Panda Antivirus X
    Sophos Antivirus X
    VirusBuster X
    VBA32 X
  13. 2008/09/24
    Stratman50th
    ComboFix
    ComboFix 08-09-24.07 - Don 2008-09-24 19:40:05.3 - NTFSx86 NETWORK
    Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.708 [GMT -4:00]
    Command switches used :: C:\Documents and Settings\Don\Desktop\CFScript.txt
    C:\Program Files\Authentium\Firewall SDK\Driver\grtdimon.cat
    C:\Program Files\Authentium\Firewall SDK\Driver\grtdimon.inf
    C:\Program Files\Authentium\Firewall SDK\Driver\GRTdiMon.sys
    C:\Program Files\Authentium\Firewall SDK\Filter\grfilter.cat
    C:\Program Files\Authentium\Firewall SDK\Filter\grfilter.inf
    C:\Program Files\Authentium\Firewall SDK\Filter\GRFilter.sys
    ((((((((((((((((((((((((( Files Created from 2008-08-24 to 2008-09-24 )))))))))))))))))))))))))))))))
    2008-09-18 16:30 . 2008-09-23 17:48 <DIR> d-------- C:\Documents and Settings\All Users\Application Data\avg8
    2008-09-23 22:10 --------- d-----w C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy
    2008-09-23 21:49 --------- d-----w C:\Program Files\EarthLink
    ((((((((((((((((((((((((((((( snapshot@2008-09-23_16.33.36.31 )))))))))))))))))))))))))))))))))))))))))
    + 2008-09-23 21:49:55 42,472 ----a-w C:\WINDOWS\assembly\GAC_MSIL\CenturianShellMenu\1.1.5.25016__a4004c7b772007f8\CenturianShellMenu.dll
    "Earthlink Protection Control Center "= "C:\Program Files\EarthLink\EarthLink Protection Control Center\BIN\elnk_pcc2.exe" [2007-08-08 67048]
    "NoClose "= 0 (0x0)
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\image file execution options\xwsetup.EXE]
    "Debugger "=ntsd -d
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
    "EnableFirewall "= 0 (0x0)
    S3 AuthFw;AuthFw;C:\Program Files\Authentium\Firewall SDK\AuthFw.exe [ ]
    Rootkit scan 2008-09-24 19:40:43
    hidden files: 0
    Completion time: 2008-09-24 19:41:25
    ComboFix-quarantined-files.txt 2008-09-24 23:41:23
    ComboFix2.txt 2008-09-24 23:29:17
    ComboFix3.txt 2008-09-23 20:34:00
    Pre-Run: 116,309,192,704 bytes free
    Post-Run: 116,294,324,224 bytes free
    169 --- E O F --- 2008-09-10 11:48:04
  14. 2008/09/24
    Stratman50th
    Stratman50th Inactive Thread Starter
    Hijack This log
    Scan saved at 7:45:38 PM, on 9/24/2008
    C:\WINDOWS\explorer.exe
    O4 - HKLM\..\Run: [Earthlink Protection Control Center] "C:\Program Files\EarthLink\EarthLink Protection Control Center\BIN\elnk_pcc2.exe" /tray
    O23 - Service: ADSService - EarthLink, Inc. - C:\Program Files\Common Files\ADS\ADSService.exe
    O23 - Service: AuthFw - Unknown owner - C:\Program Files\Authentium\Firewall SDK\AuthFw.exe (file missing)
    O23 - Service: ELNK Update Service (ELNKUpdateService) - EarthLink, Inc. - C:\Program Files\EarthLink\EarthLink Protection Control Center\bin\UpdateService.exe
    End of file - 6805 bytes
  15. 2008/09/24
    Hi
    OK I'll have noahdfear take a look in here. He may have a idea what is happening.
    If he posts please follow his directions.
    One of us will get back to you.
    Edit>
    OK please do this.
    Please post this log from here.
    C:\Qoobox\ComboFix2.txt
    Also post a Kaspersky scan.
    Please do an online scan with Kaspersky WebScanner
    Click on “Accept” If your pop –up blocker blocks any windows from opening.
    Click Run on the window that opens.
    Windows Vista users you must open the web browser using the Run as Administrator command.
    • The program will launch and then begin downloading the latest definition files:
    • Under Scan on the left side.Click on My Computer
    • This will start the program and scan your system.
    • Click the “Scan Report” On the left side.
    • The scan will take a while so be patient and let it run.
    • Once the scan is complete it will display if your system has been infected.
      • Click the Save Report As button, and in the Browse dialog box, type a name for the scan report file that you want to create and select its type Text file. Click OK to save the file.:
    • Save the text file to your desktop.
    • Copy and paste that information in your next post.
    Please post the Kaspersky results.
    Geri
  16. 2008/09/25
    Stratman50th
    ComboFix2
    ComboFix 08-09-24.07 - Don 2008-09-24 19:25:41.2 - NTFSx86 NETWORK
    Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.738 [GMT -4:00]
  17. 2008/09/25
    Stratman50th
    Sorry, I can't get it to run the Kaspersky scan. It crashes Mozilla, and IE wants the latest version of Java. I can get Java downlaoded, but when it trys to install, it says that the policy prohibits the install. I can't recall where it is to change the policy.
    Got another scanner I should try?
  18. 2008/09/25
    Hi
    OK lets try Panda.
    Please go HERE to run Panda's ActiveScan
    • Once you are on the Panda site click the Scan your PC button
    • A new window will open...click the Check Now button
    • Enter your Country
    • Enter your State/Province
    • Enter your e-mail address and click send
    • Select either Home User or Company
    • Click the big Scan Now button
    • If it wants to install an ActiveX component allow it
    • It will start downloading the files it requires for the scan (Note: It may take a couple of minutes)
    • When download is complete, click on My Computer to start the scan
    • When the scan completes, if anything malicious is detected, click the See Report button, then Save Report and save it to a convenient location. Post the contents of the ActiveScan report
    Also there was a big portion of the combofix2.txt log missing.
    You may have some corrupted system files that is causing this problem.
    Geri
  19. 2008/09/26
    Stratman50th
    I thought I captured it all, but I'll check again. If not, should I run the scan again?
  20. 2008/09/26
    Stratman50th
    ComboFix (the whole thing this time)
    "NoClose "= 0 (0x0)
    "Debugger "=ntsd -d
    Rootkit scan 2008-09-24 19:28:02
    hidden files: 0
    Completion time: 2008-09-24 19:29:16
    ComboFix-quarantined-files.txt 2008-09-24 23:29:15
    ComboFix2.txt 2008-09-23 20:34:00
    Pre-Run: 116,345,315,328 bytes free
    Post-Run: 116,332,171,264 bytes free
    157 --- E O F --- 2008-09-10 11:48:04
  21. 2008/09/26
    Stratman50th
    Looks like it's going to be one of those days....
    FYI, the blocked script was google analytics.
