Windows Vista Why does my System File Checker scan abort?
Discussion in 'Legacy Windows' started by Graham Newey, 2012/02/01.
  1. 2012/02/01
    Graham Newey
    Graham Newey Inactive Thread Starter
    Ran SFC /SCANNOW in "Command Prompt" (as administrator).
    Left computer for 30 minutes.
    When I returned this is what I found---
    "C:\Windows\system32>SFC /SCANNOW
    Beginning system scan. This process will take some time.
    Beginning verification phase of system scan.
    Verification 91% complete.
    Windows Resource Protection could not perform the requested operation. "
    I repeated the process and exactly the same thing happened ie: process aborted at "Verification 91%" mark.
    Can someone advise why this is happening and what I can do to enable the scan to complete?
    NB: Tried a third time and watched it. Same result.No request for my "External Recovery(64 bit)" disk at any time. OS is Vista Home Premium (64 bit).
    All help would be appreciated.
    Regards,
    Graham
  2. 2012/02/02
    Have a look at this, but the post that is marked "Answered" was done by a moderator.
    http://social.technet.microsoft.com...l/thread/d0a2243c-92cd-44a3-9c1e-45d0669416e3
    I would agree with doing the drive Error Checking (CHKDSK), but I might suggest you boot into Safe Mode and run SFC /scannow there, rather than booting into WinRE.
    Here is the full search:
    http://au.search.yahoo.com/search;_...peration"&fr2=sb-top&fr=sfp&type_param=&rd=r1
    although "Windows Resource Protection could not perform the requested operation" tells you nothing about what might have caused the problem.
    Graham Newey
    Dear Arie and Mattman,
    Thanks for your interest. Sorry for delay but when faced with numerous links I like to be able to look at hard copies and my black ink cartridge had deserted me.
    Anyway all is now well.
    Decided to have a look at Arie's Mr.Azeez's article first.
    Step 1: typed--
    findstr /c: "[SR]" %windir%\logs\cbs\cbs.log >%userprofile%\Desktop\sfcdetails.txt--and Enter---all in Command Prompt(admin)
    Nothing on desktop and got following messages--
    "FINDSTR: Cannot open and
    FINDSTR: Cannot open Mary\Desktop\sfcdetails.txt "
    NB: Mary is my lovely wife--she gets everywhere.
    Step 2: Boot into Safe Mode. Results are EXACTLY as in normal mode.
    Step 3:Going round in circles here.
    If I start at Start> type chkdsk in "Start search" and open as admin the scan starts by itself . Mentions something about parameter F not belng found/defined(?) and says scan will be read only. It finishes--can't see much wrong --but then little window disappears! (immediately).
    If I start at Start> cmd> prompt appears and I type chkdsk /r. Am then told that scan cannot happen. Do I want to schedule for next Startup? I say yes and restart. Twiddle my thumbs for half an hour--nothing happens -- chkdsk is presumably running. Leave and com back several times in the next couple of hours. Eventually, arrive to find the Password screen. Complete password and Desktop appears. AT NO TIME IS THERE ANY INDICATION THAT CHKDSK IS RUNNING AND IF SO WHAT THE RESULTS ARE!!! Done this several times. Same result. I assume there is no (chkdsk) problem. Is this a reasonable assumption??
    As you can see I'm getting precisely nowhere.
    Would you care to comment please before I have to resort to Mattmans links---do not fancy that at all!!
    Regards,
    Graham
  6. 2012/02/08
    You don't have to try all the suggestions, but scan them and see if there is something that seems to work.
    That appears to say that the file is not there or for some reason can't be read. Can you find the file yourself? Is it there? Check those paths for yourself. %windir% means the Windows folder. %userprofile% means look in (all) the user's folders. If the file is there, can you tell what is wrong with it. If it is not there, can you find out why it was not generated?
    Just my thoughts, I haven't read though Azeez's instructions. Best guess :)
  7. 2012/02/08
    Graham Newey
    Dear mattman,
    Thanks again for your time.
    Cannot find "sfcdetails.txt" despite using "start search" and "advanced search ".
    However--->Windows\Logs\CBS\---contains 2 files. First one is "CBS.log" (4388kb) and it will not open (default is notepad). Get message--- "! Access is denied ".Ran as admin.
    Second one is "CheckSUR.persist.log" (1kb). This opens to reveal---
    "Checking System Update Readiness.
    Binary Version 6.0.6002.22574
    Package Version 13.0
    2012-01-28 13:29
    Checking Windows Servicing Packages
    Checking Package Manifests and Catalogs
    Checking Package Watchlist
    Checking Component Watchlist
    Checking Packages
    Checking Component Store
    (f) CSI Payload File Missing 0x00000000 services.exe x86_microsoft-windows-s..s-servicecontroller_31bf3856ad364e35_6.0.6002.18005_none_d14b3973ca6acc56
    Summary:
    Seconds executed: 3239
    Found 1 errors
    CSI Payload File Missing Total count: 1 "
    Frankly I've no idea how to establish why "sfcdetails.txt" was not generated.
    At the risk of appearing dumb, also not sure how to "look in (all) the user's folders ".
    I'm now off to investigate "CSI Payload File ". It MUST be important---CSI is one of the most watched Telly progs worldwide!!!
    I might even pluck up the courage to have a go at your links.
    Perhaps you'll this some more thought and advise.
    Regards,
    Graham
  8. 2012/02/09
    Before we get bogged down trying to read log files, have you completed running Error Checking (CHKDSK), including checking for faults (bad sectors) on the disk surface?
    Have you tried going into Safe Mode to run SFC?
  9. 2012/02/10
    Graham Newey
    CHKDSK is verifying free space (stage 5 of 5)...
    88932088 free clusters processed.
    Free space verification is complete.
    Windows has checked the file system and found no problems.
  10. 2012/02/12
    Graham, I have edited your last post instead of quoting it...my bad! :eek: Although, I wanted to highlight that CHKDSK seems clean.
    I run Error Checking rather than CHKDSK. If I see Stage 5 of 5, with little or no errors, I'm happy.
    You said that you ran SFC in Safe Mode, with the same result (but I unfortunately edited it out). I can only suggest that you check through the search I gave you.
    The point "Windows Resource Protection could not perform the requested operation" seems to be at the heart.
    You need to find out why it will not complete.
  11. 2012/02/12
    Graham Newey
    Dear Mattman,
    Comments noted.
    Cannot access WinRE yet but have done the following in "Windows "--
    In "msconfig/selective startup ", I've got six non-microsoft "services" and three "startup items" enabled. Run SFC. Still getting the "Windows Resource Protection could not perform the requested operation" message at "verification 91 % complete ".
    I disable the three "startup items ". Run SFC with exactly same result.
    Therefore, no "startup items" are causing the conflict(?).
    Leaving the "startup items" disabled I disable the six non-microsoft "services" as well. Run SFC with exactly the same result.
    Therefore, no startup items and no non-microsoft "services" are causing the conflict(?).
    So, it MUST be a microsoft "service" that is causing the problem(?).
    I enable my three "startup items" and my six non-microsoft "services ".
    I disable "all" microsoft "services" (except for Application Information,DCOM Server Process Launcher, Group Policy Client, Plug and Play, Remote Procedure Call, Software Licensing, Task Scheduler and User Profile Service which all refuse to be disabled for fairly obvious reasons when I think about it).Run SFC.THIS time the scan goes nowhere and the following message appears--
    "Windows Resource Protection could not start the repair service "
    So, with "all" microsoft "services" SFC runs up to the "verification 91%" point only.
    Without microsoft "services" (well most of them) SFC won't start at all.
    So, what does this tell us? I'm going round in circles. My brain is hurting.
    How do you interpret the situation now please?
    Will continue trying to get into WinRE.
    Regards,
    Graham
  12. 2012/02/13
    Before I suggest any other avenues, what is the main aim of running SFC? What is the issue you are having?
    From my research running SFC will take you back to installing the last Service Pack. Are you having serious problems with Windows?
    We don't know what Service Pack you have (you don't have the details in your WidowsBBS User Profile or you don't state the system details). Have you installed all the Windows Updates?
  13. 2012/02/17
    Graham Newey
    Dear mattman,
    Thanks for your Post 11.
    I've been waiting for this question.
    I have no issue--well,not major anyway, and no major problems.
    My attitude is that I have a computer system that incorporates the SFC tool. That tool is not working correctly, I want to know why and I want to remedy the situation.
    Possibly you may consider my viewpoint to be somewhat fatuous and,if you do, I would perfectly understand if you would prefer to use your time to assist with other peoples' more "pressing" problems. I won't be offended my friend!
    Concerned re you last para. Looked at my profile etc( have I failed to do something to bring it to everyone's attention?) It states clearly that the OS is Vista Home Premium SP2 (64 bit). The computer is 30 months old and ,from memory, came with SP1. SP2 installed subsequently. Can't remember circumstances. Windows Updates are downloaded/installed automatically so I'm assuming that all available updates are "in ".
    Regards,
    Graham
  14. 2012/02/17
    Well, it may well be there, but as you can see for yourself, your profile isn't displaying the "My System" link, so no one is able to see them.
    As per our instructions:
  15. 2012/02/17
    SpywareDr
    Try this command instead:
    findstr /c: "[SR]" %windir%\logs\cbs\cbs.log > "%userprofile%\Desktop\sfcdetails.txt "
    Note the two added double-quotes (in red).
  16. 2012/02/19
    Graham Newey
    Dear -----
    Admin(Arie) Instructions noted and acted upon. Many thanks.
    SpywareDr---many thanks indeed for your interest. Added double quotes and it worked a treat. Can't help wondering why I've not seen this tip in any of my searches. ANYWAY, my sfcdetails.txt file is enormous. I've run say 12-15 scans and all the results are in the file. To my unpracticed eye all the results appear identical.Lots of corrupted files repaired over and over again! Why would this be?
    Herewith copy of last scan results--
    2012-02-18 23:25:15, Info CSI 000000c9 [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMEJP10\DICTS "\[l:20{10}] "IMJPLN.DIC" from store
    2012-02-18 23:25:15, Info CSI 000000ca [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMEJP10\DICTS "\[l:20{10}] "IMJPST.DIC" from store
    2012-02-18 23:25:15, Info CSI 000000cb [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMEJP10\DICTS "\[l:20{10}] "IMJPZP.DIC" from store
    2012-02-18 23:25:15, Info CSI 000000cc [SR] Repairing corrupted file [ml:520{260},l:86{43}] "\??\C:\Windows\System32\IME\IMEJP10\APPLETS "\[l:22{11}] "IMJPCAC.DLL" from store
    2012-02-18 23:25:15, Info CSI 000000cd [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMEJP10 "\[l:20{10}] "IMJPCD.DLL" from store
    2012-02-18 23:25:16, Info CSI 000000d1 [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMEJP10 "\[l:24{12}] "imjpuexc.exe" from store
    2012-02-18 23:25:16, Info CSI 000000d2 [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMEJP10 "\[l:22{11}] "IMJPTIP.DLL" from store
    2012-02-18 23:25:16, Info CSI 000000d3 [SR] Repairing corrupted file [ml:520{260},l:86{43}] "\??\C:\Windows\System32\IME\IMEJP10\APPLETS "\[l:24{12}] "IMJPCLST.DLL" from store
    2012-02-18 23:25:16, Info CSI 000000d4 [SR] Repairing corrupted file [ml:520{260},l:86{43}] "\??\C:\Windows\System32\IME\IMEJP10\APPLETS "\[l:24{12}] "IMJPCLST.XML" from store
    2012-02-18 23:25:16, Info CSI 000000d5 [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMEJP10 "\[l:24{12}] "imjppdmg.exe" from store
    2012-02-18 23:25:16, Info CSI 000000d6 [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMEJP10 "\[l:24{12}] "IMJPDADM.EXE" from store
    2012-02-18 23:25:16, Info CSI 000000d7 [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMEJP10 "\[l:24{12}] "IMJPDCTP.DLL" from store
    2012-02-18 23:25:16, Info CSI 000000d8 [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMEJP10 "\[l:22{11}] "IMJPUEX.EXE" from store
    2012-02-18 23:25:16, Info CSI 000000d9 [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMEJP10 "\[l:22{11}] "IMJPDCT.EXE" from store
    2012-02-18 23:25:16, Info CSI 000000db [SR] Verify complete
    2012-02-18 23:25:17, Info CSI 000000dc [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:25:17, Info CSI 000000dd [SR] Beginning Verify and Repair transaction
    2012-02-18 23:25:25, Info CSI 000000de [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMEJP10\DICTS "\[l:20{10}] "imjptk.dic" from store
    2012-02-18 23:25:26, Info CSI 000000df [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMEJP10 "\[l:22{11}] "IMJPAPI.DLL" from store
    2012-02-18 23:25:26, Info CSI 000000e0 [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMEJP10 "\[l:22{11}] "imjpcus.dll" from store
    2012-02-18 23:25:27, Info CSI 000000e1 [SR] Repairing corrupted file [ml:520{260},l:86{43}] "\??\C:\Windows\System32\IME\IMEJP10\applets "\[l:24{12}] "mshwjpnr.dll" from store
    2012-02-18 23:25:27, Info CSI 000000e2 [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMEJP10 "\[l:24{12}] "imjputyc.dll" from store
    2012-02-18 23:25:27, Info CSI 000000e3 [SR] Repairing corrupted file [ml:520{260},l:86{43}] "\??\C:\Windows\System32\IME\IMEJP10\APPLETS "\[l:22{11}] "IMJPSKF.DLL" from store
    2012-02-18 23:25:27, Info CSI 000000e4 [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMEJP10\DICTS "\[l:20{10}] "IMJPCH.DIC" from store
    2012-02-18 23:25:27, Info CSI 000000e5 [SR] Repairing corrupted file [ml:520{260},l:86{43}] "\??\C:\Windows\System32\IME\IMEJP10\APPLETS "\[l:24{12}] "IMJPKDIC.DLL" from store
    2012-02-18 23:25:27, Info CSI 000000e7 [SR] Verify complete
    2012-02-18 23:25:28, Info CSI 000000e8 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:25:28, Info CSI 000000e9 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:25:38, Info CSI 000000ea [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMEJP10 "\[l:24{12}] "IMJPDSVR.EXE" from store
    2012-02-18 23:25:38, Info CSI 000000eb [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMEJP10\DICTS "\[l:20{10}] "IMJPGN.GRM" from store
    2012-02-18 23:25:38, Info CSI 000000ec [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMEJP10 "\[l:22{11}] "IMJPMGR.EXE" from store
    2012-02-18 23:25:38, Info CSI 000000ed [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMEJP10\DICTS "\[l:20{10}] "IMJPSB.DIC" from store
    2012-02-18 23:25:39, Info CSI 000000ee [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMEJP10\DICTS "\[l:20{10}] "IMJPNM.DIC" from store
    2012-02-18 23:25:39, Info CSI 000000ef [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMEJP10\HELP "\[l:24{12}] "JPNPADEN.CHM" from store
    2012-02-18 23:25:39, Info CSI 000000f0 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMEJP10\HELP "\[l:20{10}] "IMJPTU.CHM" from store
    2012-02-18 23:25:39, Info CSI 000000f1 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMEJP10\HELP "\[l:20{10}] "IMJPPD.CHM" from store
    2012-02-18 23:25:39, Info CSI 000000f2 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMEJP10\HELP "\[l:20{10}] "IMJPDT.CHM" from store
    2012-02-18 23:25:39, Info CSI 000000f3 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMEJP10\HELP "\[l:20{10}] "IMJPCL.CHM" from store
    2012-02-18 23:25:39, Info CSI 000000f4 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMEJP10\HELP "\[l:22{11}] "IMJPDTE.CHM" from store
    2012-02-18 23:25:39, Info CSI 000000f5 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMEJP10\HELP "\[l:22{11}] "IMJPCLE.CHM" from store
    2012-02-18 23:25:39, Info CSI 000000f7 [SR] Verify complete
    2012-02-18 23:25:39, Info CSI 000000f8 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:25:39, Info CSI 000000f9 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:25:52, Info CSI 000000fd [SR] Verify complete
    2012-02-18 23:25:52, Info CSI 000000fe [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:25:52, Info CSI 000000ff [SR] Beginning Verify and Repair transaction
    2012-02-18 23:26:00, Info CSI 00000101 [SR] Verify complete
    2012-02-18 23:26:00, Info CSI 00000102 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:26:00, Info CSI 00000103 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:26:04, Info CSI 00000105 [SR] Verify complete
    2012-02-18 23:26:04, Info CSI 00000106 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:26:04, Info CSI 00000107 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:26:16, Info CSI 00000109 [SR] Verify complete
    2012-02-18 23:26:16, Info CSI 0000010a [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:26:16, Info CSI 0000010b [SR] Beginning Verify and Repair transaction
    2012-02-18 23:26:21, Info CSI 0000010d [SR] Verify complete
    2012-02-18 23:26:22, Info CSI 0000010e [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:26:22, Info CSI 0000010f [SR] Beginning Verify and Repair transaction
    2012-02-18 23:26:35, Info CSI 00000111 [SR] Verify complete
    2012-02-18 23:26:36, Info CSI 00000112 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:26:36, Info CSI 00000113 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:26:44, Info CSI 00000115 [SR] Verify complete
    2012-02-18 23:26:44, Info CSI 00000116 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:26:44, Info CSI 00000117 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:26:52, Info CSI 00000119 [SR] Verify complete
    2012-02-18 23:26:53, Info CSI 0000011a [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:26:53, Info CSI 0000011b [SR] Beginning Verify and Repair transaction
    2012-02-18 23:27:12, Info CSI 00000123 [SR] Verify complete
    2012-02-18 23:27:12, Info CSI 00000124 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:27:12, Info CSI 00000125 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:27:39, Info CSI 0000013b [SR] Verify complete
    2012-02-18 23:27:40, Info CSI 0000013c [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:27:40, Info CSI 0000013d [SR] Beginning Verify and Repair transaction
    2012-02-18 23:28:30, Info CSI 0000013f [SR] Verify complete
    2012-02-18 23:28:30, Info CSI 00000140 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:28:30, Info CSI 00000141 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:28:57, Info CSI 00000143 [SR] Verify complete
    2012-02-18 23:28:57, Info CSI 00000144 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:28:57, Info CSI 00000145 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:29:02, Info CSI 00000147 [SR] Verify complete
    2012-02-18 23:29:02, Info CSI 00000148 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:29:02, Info CSI 00000149 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:29:07, Info CSI 0000014b [SR] Verify complete
    2012-02-18 23:29:08, Info CSI 0000014c [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:29:08, Info CSI 0000014d [SR] Beginning Verify and Repair transaction
    2012-02-18 23:29:18, Info CSI 0000014e [SR] Repairing corrupted file [ml:520{260},l:84{42}] "\??\C:\Windows\System32\IME\IMESC5\Applets "\[l:24{12}] "PINTLCSA.dll" from store
    2012-02-18 23:29:18, Info CSI 0000014f [SR] Repairing corrupted file [ml:520{260},l:60{30}] "\??\C:\Windows\IME\IMESC5\HELP "\[l:24{12}] "PINTLPAD.CHM" from store
    2012-02-18 23:29:18, Info CSI 00000150 [SR] Repairing corrupted file [ml:520{260},l:60{30}] "\??\C:\Windows\IME\IMESC5\HELP "\[l:24{12}] "PINTLPAE.CHM" from store
    2012-02-18 23:29:18, Info CSI 00000151 [SR] Repairing corrupted file [ml:520{260},l:68{34}] "\??\C:\Windows\System32\IME\IMESC5 "\[l:22{11}] "IMSCTIP.dll" from store
    2012-02-18 23:29:19, Info CSI 00000152 [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMETC10 "\[l:22{11}] "IMTCTIP.dll" from store
    2012-02-18 23:29:26, Info CSI 00000154 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:22{11}] "PINTLGT.IMD" from store
    2012-02-18 23:29:27, Info CSI 00000156 [SR] Verify complete
    2012-02-18 23:29:27, Info CSI 00000157 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:29:27, Info CSI 00000158 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:29:35, Info CSI 00000159 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:24{12}] "PINTLGVR.IMD" from store
    2012-02-18 23:29:38, Info CSI 0000015f [SR] Repairing corrupted file [ml:520{260},l:86{43}] "\??\C:\Windows\System32\IME\IMETC10\Applets "\[l:24{12}] "MSHWCHTR.dll" from store
    2012-02-18 23:29:38, Info CSI 00000160 [SR] Repairing corrupted file [ml:520{260},l:86{43}] "\??\C:\Windows\System32\IME\IMETC10\Applets "\[l:22{11}] "IMTCSKF.dll" from store
    2012-02-18 23:29:38, Info CSI 00000161 [SR] Repairing corrupted file [ml:520{260},l:86{43}] "\??\C:\Windows\System32\IME\IMETC10\Applets "\[l:22{11}] "IMTCDIC.dll" from store
    2012-02-18 23:29:38, Info CSI 00000162 [SR] Repairing corrupted file [ml:520{260},l:86{43}] "\??\C:\Windows\System32\IME\IMETC10\Applets "\[l:22{11}] "IMTCCAC.dll" from store
    2012-02-18 23:29:43, Info CSI 0000016d [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMETC10\DICTS "\[l:18{9}] "IMTCV.IMD" from store
    2012-02-18 23:29:44, Info CSI 00000170 [SR] Verify complete
    2012-02-18 23:29:44, Info CSI 00000171 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:29:44, Info CSI 00000172 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:29:46, Info CSI 00000174 [SR] Verify complete
    2012-02-18 23:29:46, Info CSI 00000175 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:29:46, Info CSI 00000176 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:29:54, Info CSI 00000177 [SR] Repairing corrupted file [ml:520{260},l:68{34}] "\??\C:\Windows\System32\IME\IMESC5 "\[l:24{12}] "PMIGRATE.dll" from store
    2012-02-18 23:29:54, Info CSI 00000178 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:22{11}] "PINTLGR.IMD" from store
    2012-02-18 23:29:54, Info CSI 00000179 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:22{11}] "PINTLGL.IMD" from store
    2012-02-18 23:29:54, Info CSI 0000017a [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:22{11}] "PINTLGJ.IMD" from store
    2012-02-18 23:29:55, Info CSI 0000017b [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:22{11}] "PINTLGI.IMD" from store
    2012-02-18 23:29:55, Info CSI 0000017c [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:22{11}] "PINTLGD.IMD" from store
    2012-02-18 23:29:55, Info CSI 0000017d [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:22{11}] "PINTLGC.IMD" from store
    2012-02-18 23:29:55, Info CSI 0000017e [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:22{11}] "PINTLGB.IMD" from store
    2012-02-18 23:29:55, Info CSI 0000017f [SR] Repairing corrupted file [ml:520{260},l:60{30}] "\??\C:\Windows\IME\IMESC5\HELP "\[l:24{12}] "PINTLGNE.CHM" from store
    2012-02-18 23:29:55, Info CSI 00000180 [SR] Repairing corrupted file [ml:520{260},l:60{30}] "\??\C:\Windows\IME\IMESC5\HELP "\[l:24{12}] "PINTLGNT.CHM" from store
    2012-02-18 23:29:55, Info CSI 00000181 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:24{12}] "PINTLGIX.IMD" from store
    2012-02-18 23:29:55, Info CSI 00000182 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:24{12}] "PINTLGCF.IMD" from store
    2012-02-18 23:29:55, Info CSI 00000183 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:24{12}] "PINTLGDX.IMD" from store
    2012-02-18 23:29:55, Info CSI 00000184 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:24{12}] "PINTLGAB.IMD" from store
    2012-02-18 23:29:55, Info CSI 00000185 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:24{12}] "PINTLGAP.IMD" from store
    2012-02-18 23:29:55, Info CSI 00000186 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:24{12}] "PINTLGAS.IMD" from store
    2012-02-18 23:29:55, Info CSI 00000187 [SR] Repairing corrupted file [ml:520{260},l:68{34}] "\??\C:\Windows\System32\IME\IMESC5 "\[l:20{10}] "imscui.DLL" from store
    2012-02-18 23:29:55, Info CSI 00000188 [SR] Repairing corrupted file [ml:520{260},l:68{34}] "\??\C:\Windows\System32\IME\IMESC5 "\[l:22{11}] "ImSCCfg.DLL" from store
    2012-02-18 23:29:55, Info CSI 00000189 [SR] Repairing corrupted file [ml:520{260},l:68{34}] "\??\C:\Windows\System32\IME\IMESC5 "\[l:24{12}] "IMSCPROP.exe" from store
    2012-02-18 23:29:55, Info CSI 0000018a [SR] Repairing corrupted file [ml:520{260},l:68{34}] "\??\C:\Windows\System32\IME\IMESC5 "\[l:24{12}] "ImSCCore.dll" from store
    2012-02-18 23:29:56, Info CSI 0000018b [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:24{12}] "PINTLGID.IMD" from store
    2012-02-18 23:29:56, Info CSI 0000018c [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMESC5\DICTS "\[l:24{12}] "PINTLGDM.IMD" from store
    2012-02-18 23:29:56, Info CSI 0000018e [SR] Verify complete
    2012-02-18 23:29:57, Info CSI 0000018f [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:29:57, Info CSI 00000190 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:30:07, Info CSI 00000191 [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMETC10 "\[l:20{10}] "imtcui.DLL" from store
    2012-02-18 23:30:07, Info CSI 00000192 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMETC10\HELP "\[l:20{10}] "IMTCTC.CHM" from store
    2012-02-18 23:30:07, Info CSI 00000193 [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMETC10\DICTS "\[l:20{10}] "IMTCPH.IMD" from store
    2012-02-18 23:30:07, Info CSI 00000194 [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMETC10\DICTS "\[l:20{10}] "IMTCLS.IMD" from store
    2012-02-18 23:30:07, Info CSI 00000195 [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMETC10\DICTS "\[l:18{9}] "IMTCL.IMD" from store
    2012-02-18 23:30:07, Info CSI 00000196 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\IME\IMETC10\HELP "\[l:20{10}] "IMTCEN.CHM" from store
    2012-02-18 23:30:07, Info CSI 00000197 [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMETC10 "\[l:22{11}] "IMTCCFG.DLL" from store
    2012-02-18 23:30:07, Info CSI 00000198 [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMETC10\DICTS "\[l:20{10}] "IMTCCJ.IMD" from store
    2012-02-18 23:30:07, Info CSI 00000199 [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMETC10\DICTS "\[l:24{12}] "IMTCPHCS.IMD" from store
    2012-02-18 23:30:07, Info CSI 0000019a [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMETC10 "\[l:24{12}] "IMTCPROP.exe" from store
    2012-02-18 23:30:07, Info CSI 0000019b [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMETC10\DICTS "\[l:24{12}] "IMTCCJCS.IMD" from store
    2012-02-18 23:30:07, Info CSI 0000019c [SR] Repairing corrupted file [ml:520{260},l:70{35}] "\??\C:\Windows\System32\IME\IMETC10 "\[l:24{12}] "IMTCCORE.DLL" from store
    2012-02-18 23:30:08, Info CSI 0000019d [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\IME\IMETC10\DICTS "\[l:18{9}] "IMTCS.IMD" from store
    2012-02-18 23:30:08, Info CSI 0000019f [SR] Verify complete
    2012-02-18 23:30:10, Info CSI 000001a0 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:30:10, Info CSI 000001a1 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:30:31, Info CSI 000001a4 [SR] Verify complete
    2012-02-18 23:30:32, Info CSI 000001a5 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:30:32, Info CSI 000001a6 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:30:45, Info CSI 000001a7 [SR] Repairing corrupted file [ml:520{260},l:62{31}] "\??\C:\Windows\ime\imekr8\dicts "\[l:22{11}] "imkrhjd.lex" from store
    2012-02-18 23:30:45, Info CSI 000001a8 [SR] Repairing corrupted file [ml:520{260},l:80{40}] "\??\C:\Windows\System32\ime\imekr8\dicts "\[l:22{11}] "imkrhjd.dll" from store
    2012-02-18 23:30:46, Info CSI 000001a9 [SR] Repairing corrupted file [ml:520{260},l:68{34}] "\??\C:\Windows\System32\ime\imekr8 "\[l:22{11}] "imkrudt.dll" from store
    2012-02-18 23:30:46, Info CSI 000001aa [SR] Repairing corrupted file [ml:520{260},l:68{34}] "\??\C:\Windows\System32\ime\imekr8 "\[l:22{11}] "imkrapi.dll" from store
    2012-02-18 23:30:46, Info CSI 000001ab [SR] Repairing corrupted file [ml:520{260},l:60{30}] "\??\C:\Windows\ime\imekr8\help "\[l:20{10}] "imkrpd.chm" from store
    2012-02-18 23:30:46, Info CSI 000001ac [SR] Repairing corrupted file [ml:520{260},l:60{30}] "\??\C:\Windows\ime\imekr8\help "\[l:20{10}] "imkren.chm" from store
    2012-02-18 23:30:46, Info CSI 000001ad [SR] Repairing corrupted file [ml:520{260},l:60{30}] "\??\C:\Windows\ime\imekr8\help "\[l:16{8}] "imkr.chm" from store
    2012-02-18 23:30:46, Info CSI 000001ae [SR] Repairing corrupted file [ml:520{260},l:60{30}] "\??\C:\Windows\ime\imekr8\help "\[l:24{12}] "imkrpden.chm" from store
    2012-02-18 23:30:50, Info CSI 000001af [SR] Repairing corrupted file [ml:520{260},l:84{42}] "\??\C:\Windows\System32\ime\imekr8\applets "\[l:24{12}] "mshwkorr.dll" from store
    2012-02-18 23:30:52, Info CSI 000001b0 [SR] Repairing corrupted file [ml:520{260},l:84{42}] "\??\C:\Windows\System32\ime\imekr8\applets "\[l:22{11}] "imkrskf.dll" from store
    2012-02-18 23:30:52, Info CSI 000001b1 [SR] Repairing corrupted file [ml:520{260},l:84{42}] "\??\C:\Windows\System32\ime\imekr8\applets "\[l:22{11}] "imkrcac.dll" from store
    2012-02-18 23:30:53, Info CSI 000001b2 [SR] Repairing corrupted file [ml:520{260},l:68{34}] "\??\C:\Windows\System32\ime\imekr8 "\[l:22{11}] "imkrtip.dll" from store
    2012-02-18 23:30:53, Info CSI 000001b4 [SR] Verify complete
    2012-02-18 23:30:54, Info CSI 000001b5 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:30:54, Info CSI 000001b6 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:31:00, Info CSI 000001b8 [SR] Verify complete
    2012-02-18 23:31:01, Info CSI 000001b9 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:31:01, Info CSI 000001ba [SR] Beginning Verify and Repair transaction
    2012-02-18 23:31:19, Info CSI 000001bc [SR] Verify complete
    2012-02-18 23:31:19, Info CSI 000001bd [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:31:19, Info CSI 000001be [SR] Beginning Verify and Repair transaction
    2012-02-18 23:31:31, Info CSI 000001c0 [SR] Verify complete
    2012-02-18 23:31:32, Info CSI 000001c1 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:31:32, Info CSI 000001c2 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:31:38, Info CSI 000001c4 [SR] Verify complete
    2012-02-18 23:31:39, Info CSI 000001c5 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:31:39, Info CSI 000001c6 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:32:11, Info CSI 000001d6 [SR] Verify complete
    2012-02-18 23:32:12, Info CSI 000001d7 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:32:12, Info CSI 000001d8 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:32:54, Info CSI 000001e2 [SR] Verify complete
    2012-02-18 23:32:55, Info CSI 000001e3 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:32:55, Info CSI 000001e4 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:34:36, Info CSI 000001e6 [SR] Verify complete
    2012-02-18 23:34:37, Info CSI 000001e7 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:34:37, Info CSI 000001e8 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:35:15, Info CSI 000001ea [SR] Verify complete
    2012-02-18 23:35:17, Info CSI 000001eb [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:35:17, Info CSI 000001ec [SR] Beginning Verify and Repair transaction
    2012-02-18 23:35:35, Info CSI 000001ee [SR] Verify complete
    2012-02-18 23:35:36, Info CSI 000001ef [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:35:36, Info CSI 000001f0 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:35:58, Info CSI 000001f2 [SR] Verify complete
    2012-02-18 23:35:59, Info CSI 000001f3 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:35:59, Info CSI 000001f4 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:36:15, Info CSI 000001f6 [SR] Verify complete
    2012-02-18 23:36:16, Info CSI 000001f7 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:36:16, Info CSI 000001f8 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:36:26, Info CSI 000001fc [SR] Verify complete
    2012-02-18 23:36:27, Info CSI 000001fd [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:36:27, Info CSI 000001fe [SR] Beginning Verify and Repair transaction
    2012-02-18 23:36:34, Info CSI 00000200 [SR] Verify complete
    2012-02-18 23:36:34, Info CSI 00000201 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:36:34, Info CSI 00000202 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:37:03, Info CSI 00000205 [SR] Verify complete
    2012-02-18 23:37:04, Info CSI 00000206 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:37:04, Info CSI 00000207 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:37:12, Info CSI 00000209 [SR] Verify complete
    2012-02-18 23:37:12, Info CSI 0000020a [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:37:12, Info CSI 0000020b [SR] Beginning Verify and Repair transaction
    2012-02-18 23:37:22, Info CSI 0000020d [SR] Verify complete
    2012-02-18 23:37:23, Info CSI 0000020e [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:37:23, Info CSI 0000020f [SR] Beginning Verify and Repair transaction
    2012-02-18 23:37:37, Info CSI 00000211 [SR] Verify complete
    2012-02-18 23:37:37, Info CSI 00000212 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:37:37, Info CSI 00000213 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:37:45, Info CSI 00000215 [SR] Verify complete
    2012-02-18 23:37:45, Info CSI 00000216 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:37:45, Info CSI 00000217 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:37:53, Info CSI 00000219 [SR] Verify complete
    2012-02-18 23:37:53, Info CSI 0000021a [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:37:53, Info CSI 0000021b [SR] Beginning Verify and Repair transaction
    2012-02-18 23:38:06, Info CSI 0000021e [SR] Verify complete
    2012-02-18 23:38:07, Info CSI 0000021f [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:38:07, Info CSI 00000220 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:38:14, Info CSI 00000222 [SR] Verify complete
    2012-02-18 23:38:14, Info CSI 00000223 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:38:14, Info CSI 00000224 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:38:20, Info CSI 00000226 [SR] Verify complete
    2012-02-18 23:38:20, Info CSI 00000227 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:38:20, Info CSI 00000228 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:38:28, Info CSI 0000022b [SR] Verify complete
    2012-02-18 23:38:28, Info CSI 0000022c [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:38:28, Info CSI 0000022d [SR] Beginning Verify and Repair transaction
    2012-02-18 23:38:36, Info CSI 00000232 [SR] Verify complete
    2012-02-18 23:38:37, Info CSI 00000233 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:38:37, Info CSI 00000234 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:38:46, Info CSI 00000237 [SR] Verify complete
    2012-02-18 23:38:46, Info CSI 00000238 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:38:46, Info CSI 00000239 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:38:57, Info CSI 0000023b [SR] Verify complete
    2012-02-18 23:38:57, Info CSI 0000023c [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:38:57, Info CSI 0000023d [SR] Beginning Verify and Repair transaction
    2012-02-18 23:39:08, Info CSI 0000023f [SR] Verify complete
    2012-02-18 23:39:09, Info CSI 00000240 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:39:09, Info CSI 00000241 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:39:10, Info CSI 00000243 [SR] Verify complete
    2012-02-18 23:39:11, Info CSI 00000244 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:39:11, Info CSI 00000245 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:39:19, Info CSI 00000247 [SR] Verify complete
    2012-02-18 23:39:20, Info CSI 00000248 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:39:20, Info CSI 00000249 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:39:28, Info CSI 0000024b [SR] Verify complete
    2012-02-18 23:39:28, Info CSI 0000024c [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:39:28, Info CSI 0000024d [SR] Beginning Verify and Repair transaction
    2012-02-18 23:39:35, Info CSI 0000024f [SR] Verify complete
    2012-02-18 23:39:36, Info CSI 00000250 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:39:36, Info CSI 00000251 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:39:51, Info CSI 00000253 [SR] Verify complete
    2012-02-18 23:39:52, Info CSI 00000254 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:39:52, Info CSI 00000255 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:39:55, Info CSI 00000257 [SR] Verify complete
    2012-02-18 23:39:55, Info CSI 00000258 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:39:55, Info CSI 00000259 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:40:00, Info CSI 0000025b [SR] Verify complete
    2012-02-18 23:40:01, Info CSI 0000025c [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:40:01, Info CSI 0000025d [SR] Beginning Verify and Repair transaction
    2012-02-18 23:40:11, Info CSI 00000268 [SR] Verify complete
    2012-02-18 23:40:12, Info CSI 00000269 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:40:12, Info CSI 0000026a [SR] Beginning Verify and Repair transaction
    2012-02-18 23:40:17, Info CSI 0000026d [SR] Verify complete
    2012-02-18 23:40:18, Info CSI 0000026e [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:40:18, Info CSI 0000026f [SR] Beginning Verify and Repair transaction
    2012-02-18 23:40:23, Info CSI 00000271 [SR] Verify complete
    2012-02-18 23:40:24, Info CSI 00000272 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:40:24, Info CSI 00000273 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:40:32, Info CSI 00000275 [SR] Verify complete
    2012-02-18 23:40:32, Info CSI 00000276 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:40:32, Info CSI 00000277 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:40:40, Info CSI 00000278 [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMEJP10 "\[l:24{12}] "IMJPDSVR.EXE" from store
    2012-02-18 23:40:40, Info CSI 00000279 [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMEJP10 "\[l:22{11}] "IMJPMGR.EXE" from store
    2012-02-18 23:40:41, Info CSI 0000027a [SR] Repairing corrupted file [ml:86{43},l:84{42}] "\??\C:\Windows\SysWOW64\IME\IMESC5\Applets "\[l:24{12}] "PINTLCSA.dll" from store
    2012-02-18 23:40:42, Info CSI 0000027c [SR] Verify complete
    2012-02-18 23:40:43, Info CSI 0000027d [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:40:43, Info CSI 0000027e [SR] Beginning Verify and Repair transaction
    2012-02-18 23:40:45, Info CSI 00000280 [SR] Verify complete
    2012-02-18 23:40:46, Info CSI 00000281 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:40:46, Info CSI 00000282 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:40:49, Info CSI 00000283 [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMETC10 "\[l:20{10}] "imtcui.DLL" from store
    2012-02-18 23:40:49, Info CSI 00000284 [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMETC10 "\[l:22{11}] "IMTCCFG.DLL" from store
    2012-02-18 23:40:49, Info CSI 00000285 [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMETC10 "\[l:24{12}] "IMTCPROP.exe" from store
    2012-02-18 23:40:49, Info CSI 00000286 [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMETC10 "\[l:24{12}] "IMTCCORE.DLL" from store
    2012-02-18 23:40:50, Info CSI 00000288 [SR] Repairing corrupted file [ml:70{35},l:68{34}] "\??\C:\Windows\SysWOW64\IME\IMESC5 "\[l:24{12}] "PMIGRATE.dll" from store
    2012-02-18 23:40:50, Info CSI 00000289 [SR] Repairing corrupted file [ml:70{35},l:68{34}] "\??\C:\Windows\SysWOW64\IME\IMESC5 "\[l:20{10}] "imscui.DLL" from store
    2012-02-18 23:40:50, Info CSI 0000028a [SR] Repairing corrupted file [ml:70{35},l:68{34}] "\??\C:\Windows\SysWOW64\IME\IMESC5 "\[l:22{11}] "ImSCCfg.DLL" from store
    2012-02-18 23:40:50, Info CSI 0000028b [SR] Repairing corrupted file [ml:70{35},l:68{34}] "\??\C:\Windows\SysWOW64\IME\IMESC5 "\[l:24{12}] "IMSCPROP.exe" from store
    2012-02-18 23:40:50, Info CSI 0000028c [SR] Repairing corrupted file [ml:70{35},l:68{34}] "\??\C:\Windows\SysWOW64\IME\IMESC5 "\[l:24{12}] "ImSCCore.dll" from store
    2012-02-18 23:40:50, Info CSI 0000028e [SR] Repairing corrupted file [ml:82{41},l:80{40}] "\??\C:\Windows\SysWOW64\ime\imekr8\dicts "\[l:22{11}] "imkrhjd.dll" from store
    2012-02-18 23:40:51, Info CSI 00000290 [SR] Verify complete
    2012-02-18 23:40:51, Info CSI 00000291 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:40:51, Info CSI 00000292 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:41:01, Info CSI 00000297 [SR] Verify complete
    2012-02-18 23:41:01, Info CSI 00000298 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:41:01, Info CSI 00000299 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:41:17, Info CSI 000002a2 [SR] Verify complete
    2012-02-18 23:41:18, Info CSI 000002a3 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:41:18, Info CSI 000002a4 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:41:27, Info CSI 000002b1 [SR] Verify complete
    2012-02-18 23:41:28, Info CSI 000002b2 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:41:28, Info CSI 000002b3 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:41:32, Info CSI 000002b5 [SR] Verify complete
    2012-02-18 23:41:32, Info CSI 000002b6 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:41:32, Info CSI 000002b7 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:41:38, Info CSI 000002b9 [SR] Verify complete
    2012-02-18 23:41:38, Info CSI 000002ba [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:41:38, Info CSI 000002bb [SR] Beginning Verify and Repair transaction
    2012-02-18 23:41:43, Info CSI 000002c0 [SR] Verify complete
    2012-02-18 23:41:43, Info CSI 000002c1 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:41:43, Info CSI 000002c2 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:41:50, Info CSI 000002d4 [SR] Verify complete
    2012-02-18 23:41:51, Info CSI 000002d5 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:41:51, Info CSI 000002d6 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:41:54, Info CSI 000002d7 [SR] Repairing corrupted file [ml:88{44},l:86{43}] "\??\C:\Windows\SysWOW64\IME\IMEJP10\APPLETS "\[l:24{12}] "IMJPCLST.DLL" from store
    2012-02-18 23:41:54, Info CSI 000002d8 [SR] Repairing corrupted file [ml:88{44},l:86{43}] "\??\C:\Windows\SysWOW64\IME\IMEJP10\APPLETS "\[l:24{12}] "IMJPCLST.XML" from store
    2012-02-18 23:41:55, Info CSI 000002d9 [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMEJP10 "\[l:24{12}] "imjppdmg.exe" from store
    2012-02-18 23:41:55, Info CSI 000002db [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMEJP10 "\[l:22{11}] "IMJPTIP.DLL" from store
    2012-02-18 23:41:55, Info CSI 000002dc [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMEJP10 "\[l:24{12}] "IMJPDADM.EXE" from store
    2012-02-18 23:41:55, Info CSI 000002dd [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMEJP10 "\[l:24{12}] "IMJPDCTP.DLL" from store
    2012-02-18 23:41:55, Info CSI 000002de [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMEJP10 "\[l:22{11}] "IMJPUEX.EXE" from store
    2012-02-18 23:41:55, Info CSI 000002df [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMEJP10 "\[l:22{11}] "IMJPDCT.EXE" from store
    2012-02-18 23:41:57, Info CSI 000002ed [SR] Repairing corrupted file [ml:88{44},l:86{43}] "\??\C:\Windows\SysWOW64\IME\IMEJP10\APPLETS "\[l:22{11}] "IMJPCAC.DLL" from store
    2012-02-18 23:41:57, Info CSI 000002ee [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMEJP10 "\[l:20{10}] "IMJPCD.DLL" from store
    2012-02-18 23:41:58, Info CSI 000002f2 [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMEJP10 "\[l:24{12}] "imjpuexc.exe" from store
    2012-02-18 23:41:58, Info CSI 000002f6 [SR] Verify complete
    2012-02-18 23:41:59, Info CSI 000002f7 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:41:59, Info CSI 000002f8 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:42:02, Info CSI 000002f9 [SR] Repairing corrupted file [ml:88{44},l:86{43}] "\??\C:\Windows\SysWOW64\IME\IMEJP10\APPLETS "\[l:24{12}] "IMJPKDIC.DLL" from store
    2012-02-18 23:42:03, Info CSI 000002fa [SR] Repairing corrupted file [ml:88{44},l:86{43}] "\??\C:\Windows\SysWOW64\IME\IMEJP10\APPLETS "\[l:22{11}] "IMJPSKF.DLL" from store
    2012-02-18 23:42:03, Info CSI 000002fb [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMEJP10 "\[l:22{11}] "IMJPAPI.DLL" from store
    2012-02-18 23:42:03, Info CSI 000002fc [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMEJP10 "\[l:22{11}] "imjpcus.dll" from store
    2012-02-18 23:42:04, Info CSI 000002fd [SR] Repairing corrupted file [ml:88{44},l:86{43}] "\??\C:\Windows\SysWOW64\IME\IMEJP10\applets "\[l:24{12}] "mshwjpnr.dll" from store
    2012-02-18 23:42:04, Info CSI 000002fe [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMEJP10 "\[l:24{12}] "imjputyc.dll" from store
    2012-02-18 23:42:04, Info CSI 00000300 [SR] Verify complete
    2012-02-18 23:42:04, Info CSI 00000301 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:42:04, Info CSI 00000302 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:42:10, Info CSI 00000304 [SR] Verify complete
    2012-02-18 23:42:11, Info CSI 00000305 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:42:11, Info CSI 00000306 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:42:19, Info CSI 00000317 [SR] Verify complete
    2012-02-18 23:42:19, Info CSI 00000318 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:42:19, Info CSI 00000319 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:42:29, Info CSI 0000031a [SR] Repairing corrupted file [ml:70{35},l:68{34}] "\??\C:\Windows\SysWOW64\IME\IMESC5 "\[l:22{11}] "IMSCTIP.dll" from store
    2012-02-18 23:42:30, Info CSI 0000031b [SR] Repairing corrupted file [ml:72{36},l:70{35}] "\??\C:\Windows\SysWOW64\IME\IMETC10 "\[l:22{11}] "IMTCTIP.dll" from store
    2012-02-18 23:42:31, Info CSI 0000031d [SR] Verify complete
    2012-02-18 23:42:32, Info CSI 0000031e [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:42:32, Info CSI 0000031f [SR] Beginning Verify and Repair transaction
    2012-02-18 23:42:39, Info CSI 0000032b [SR] Repairing corrupted file [ml:88{44},l:86{43}] "\??\C:\Windows\SysWOW64\IME\IMETC10\Applets "\[l:24{12}] "MSHWCHTR.dll" from store
    2012-02-18 23:42:39, Info CSI 0000032c [SR] Repairing corrupted file [ml:88{44},l:86{43}] "\??\C:\Windows\SysWOW64\IME\IMETC10\Applets "\[l:22{11}] "IMTCSKF.dll" from store
    2012-02-18 23:42:39, Info CSI 0000032d [SR] Repairing corrupted file [ml:88{44},l:86{43}] "\??\C:\Windows\SysWOW64\IME\IMETC10\Applets "\[l:22{11}] "IMTCDIC.dll" from store
    2012-02-18 23:42:39, Info CSI 0000032e [SR] Repairing corrupted file [ml:88{44},l:86{43}] "\??\C:\Windows\SysWOW64\IME\IMETC10\Applets "\[l:22{11}] "IMTCCAC.dll" from store
    2012-02-18 23:42:41, Info CSI 00000331 [SR] Verify complete
    2012-02-18 23:42:42, Info CSI 00000332 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:42:42, Info CSI 00000333 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:42:44, Info CSI 00000335 [SR] Verify complete
    2012-02-18 23:42:45, Info CSI 00000336 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:42:45, Info CSI 00000337 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:42:53, Info CSI 0000033a [SR] Verify complete
    2012-02-18 23:42:54, Info CSI 0000033b [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:42:54, Info CSI 0000033c [SR] Beginning Verify and Repair transaction
    2012-02-18 23:42:59, Info CSI 0000033d [SR] Repairing corrupted file [ml:86{43},l:84{42}] "\??\C:\Windows\SysWOW64\ime\imekr8\applets "\[l:22{11}] "imkrcac.dll" from store
    2012-02-18 23:43:00, Info CSI 0000033e [SR] Repairing corrupted file [ml:70{35},l:68{34}] "\??\C:\Windows\SysWOW64\ime\imekr8 "\[l:22{11}] "imkrtip.dll" from store
    2012-02-18 23:43:00, Info CSI 0000033f [SR] Repairing corrupted file [ml:70{35},l:68{34}] "\??\C:\Windows\SysWOW64\ime\imekr8 "\[l:22{11}] "imkrudt.dll" from store
    2012-02-18 23:43:01, Info CSI 00000341 [SR] Repairing corrupted file [ml:520{260},l:64{32}] "\??\C:\Windows\PolicyDefinitions "\[l:24{12}] "inetres.admx" from store
    2012-02-18 23:43:01, Info CSI 00000343 [SR] Repairing corrupted file [ml:86{43},l:84{42}] "\??\C:\Windows\SysWOW64\ime\imekr8\applets "\[l:24{12}] "mshwkorr.dll" from store
    2012-02-18 23:43:01, Info CSI 00000345 [SR] Repairing corrupted file [ml:520{260},l:76{38}] "\??\C:\Windows\PolicyDefinitions\en-US "\[l:24{12}] "InetRes.adml" from store
    2012-02-18 23:43:02, Info CSI 00000347 [SR] Repairing corrupted file [ml:70{35},l:68{34}] "\??\C:\Windows\SysWOW64\ime\imekr8 "\[l:22{11}] "imkrapi.dll" from store
    2012-02-18 23:43:02, Info CSI 00000348 [SR] Repairing corrupted file [ml:86{43},l:84{42}] "\??\C:\Windows\SysWOW64\ime\imekr8\applets "\[l:22{11}] "imkrskf.dll" from store
    2012-02-18 23:43:02, Info CSI 0000034b [SR] Verify complete
    2012-02-18 23:43:03, Info CSI 0000034c [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:43:03, Info CSI 0000034d [SR] Beginning Verify and Repair transaction
    2012-02-18 23:43:05, Info CSI 0000034f [SR] Verify complete
    2012-02-18 23:43:06, Info CSI 00000350 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:43:06, Info CSI 00000351 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:43:13, Info CSI 00000353 [SR] Verify complete
    2012-02-18 23:43:13, Info CSI 00000354 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:43:13, Info CSI 00000355 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:43:20, Info CSI 00000357 [SR] Verify complete
    2012-02-18 23:43:21, Info CSI 00000358 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:43:21, Info CSI 00000359 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:43:33, Info CSI 00000375 [SR] Verify complete
    2012-02-18 23:43:33, Info CSI 00000376 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:43:33, Info CSI 00000377 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:43:42, Info CSI 00000379 [SR] Verify complete
    2012-02-18 23:43:42, Info CSI 0000037a [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:43:42, Info CSI 0000037b [SR] Beginning Verify and Repair transaction
    2012-02-18 23:44:03, Info CSI 0000037d [SR] Verify complete
    2012-02-18 23:44:03, Info CSI 0000037e [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:44:03, Info CSI 0000037f [SR] Beginning Verify and Repair transaction
    2012-02-18 23:44:10, Info CSI 00000381 [SR] Verify complete
    2012-02-18 23:44:11, Info CSI 00000382 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:44:11, Info CSI 00000383 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:44:17, Info CSI 00000385 [SR] Verify complete
    2012-02-18 23:44:17, Info CSI 00000386 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:44:17, Info CSI 00000387 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:44:22, Info CSI 0000038a [SR] Verify complete
    2012-02-18 23:44:22, Info CSI 0000038b [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:44:22, Info CSI 0000038c [SR] Beginning Verify and Repair transaction
    2012-02-18 23:44:30, Info CSI 0000038d [SR] Cannot repair member file [l:24{12}] "services.exe" of Microsoft-Windows-Services-ServiceController, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file is missing
    You can imagine how large the whole file is!! If you would like any more of the scan results please advise.(GO TO PAGE 2!!)
    So where do I go from here?
    Regards to all,
    Graham
  17. 2012/02/19
    Graham Newey
    Last post too long!
    Here is remainder of scan results--to be viewed before the results in previous post--
    2012-02-18 23:20:51, Info CSI 00000006 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:20:51, Info CSI 00000007 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:20:54, Info CSI 00000009 [SR] Verify complete
    2012-02-18 23:20:55, Info CSI 0000000a [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:20:55, Info CSI 0000000b [SR] Beginning Verify and Repair transaction
    2012-02-18 23:20:57, Info CSI 0000000d [SR] Verify complete
    2012-02-18 23:20:58, Info CSI 0000000e [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:20:58, Info CSI 0000000f [SR] Beginning Verify and Repair transaction
    2012-02-18 23:21:02, Info CSI 00000011 [SR] Verify complete
    2012-02-18 23:21:03, Info CSI 00000012 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:21:03, Info CSI 00000013 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:21:06, Info CSI 00000015 [SR] Verify complete
    2012-02-18 23:21:07, Info CSI 00000016 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:21:07, Info CSI 00000017 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:21:10, Info CSI 00000019 [SR] Verify complete
    2012-02-18 23:21:11, Info CSI 0000001a [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:21:11, Info CSI 0000001b [SR] Beginning Verify and Repair transaction
    2012-02-18 23:21:14, Info CSI 0000001d [SR] Verify complete
    2012-02-18 23:21:15, Info CSI 0000001e [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:21:15, Info CSI 0000001f [SR] Beginning Verify and Repair transaction
    2012-02-18 23:21:18, Info CSI 00000021 [SR] Verify complete
    2012-02-18 23:21:18, Info CSI 00000022 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:21:18, Info CSI 00000023 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:21:21, Info CSI 00000025 [SR] Verify complete
    2012-02-18 23:21:22, Info CSI 00000026 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:21:22, Info CSI 00000027 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:21:25, Info CSI 00000029 [SR] Verify complete
    2012-02-18 23:21:26, Info CSI 0000002a [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:21:26, Info CSI 0000002b [SR] Beginning Verify and Repair transaction
    2012-02-18 23:21:28, Info CSI 0000002d [SR] Verify complete
    2012-02-18 23:21:29, Info CSI 0000002e [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:21:29, Info CSI 0000002f [SR] Beginning Verify and Repair transaction
    2012-02-18 23:21:32, Info CSI 00000031 [SR] Verify complete
    2012-02-18 23:21:33, Info CSI 00000032 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:21:33, Info CSI 00000033 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:21:35, Info CSI 00000035 [SR] Verify complete
    2012-02-18 23:21:36, Info CSI 00000036 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:21:36, Info CSI 00000037 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:21:38, Info CSI 00000039 [SR] Verify complete
    2012-02-18 23:21:39, Info CSI 0000003a [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:21:39, Info CSI 0000003b [SR] Beginning Verify and Repair transaction
    2012-02-18 23:21:42, Info CSI 0000003d [SR] Verify complete
    2012-02-18 23:21:43, Info CSI 0000003e [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:21:43, Info CSI 0000003f [SR] Beginning Verify and Repair transaction
    2012-02-18 23:21:45, Info CSI 00000041 [SR] Verify complete
    2012-02-18 23:21:46, Info CSI 00000042 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:21:46, Info CSI 00000043 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:21:48, Info CSI 00000045 [SR] Verify complete
    2012-02-18 23:22:26, Info CSI 00000046 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:22:26, Info CSI 00000047 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:22:29, Info CSI 00000049 [SR] Verify complete
    2012-02-18 23:22:35, Info CSI 0000004a [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:22:35, Info CSI 0000004b [SR] Beginning Verify and Repair transaction
    2012-02-18 23:22:37, Info CSI 0000004d [SR] Verify complete
    2012-02-18 23:22:38, Info CSI 0000004e [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:22:38, Info CSI 0000004f [SR] Beginning Verify and Repair transaction
    2012-02-18 23:22:41, Info CSI 00000051 [SR] Verify complete
    2012-02-18 23:22:42, Info CSI 00000052 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:22:42, Info CSI 00000053 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:22:44, Info CSI 00000055 [SR] Verify complete
    2012-02-18 23:22:45, Info CSI 00000056 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:22:45, Info CSI 00000057 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:22:49, Info CSI 00000059 [SR] Verify complete
    2012-02-18 23:22:49, Info CSI 0000005a [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:22:49, Info CSI 0000005b [SR] Beginning Verify and Repair transaction
    2012-02-18 23:22:55, Info CSI 0000005d [SR] Verify complete
    2012-02-18 23:22:56, Info CSI 0000005e [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:22:56, Info CSI 0000005f [SR] Beginning Verify and Repair transaction
    2012-02-18 23:22:59, Info CSI 00000061 [SR] Verify complete
    2012-02-18 23:23:00, Info CSI 00000062 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:23:00, Info CSI 00000063 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:23:04, Info CSI 00000065 [SR] Verify complete
    2012-02-18 23:23:05, Info CSI 00000066 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:23:05, Info CSI 00000067 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:23:07, Info CSI 00000069 [SR] Verify complete
    2012-02-18 23:23:08, Info CSI 0000006a [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:23:08, Info CSI 0000006b [SR] Beginning Verify and Repair transaction
    2012-02-18 23:23:11, Info CSI 0000006d [SR] Verify complete
    2012-02-18 23:23:12, Info CSI 0000006e [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:23:12, Info CSI 0000006f [SR] Beginning Verify and Repair transaction
    2012-02-18 23:23:16, Info CSI 00000071 [SR] Verify complete
    2012-02-18 23:23:17, Info CSI 00000072 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:23:17, Info CSI 00000073 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:23:23, Info CSI 00000075 [SR] Verify complete
    2012-02-18 23:23:24, Info CSI 00000076 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:23:24, Info CSI 00000077 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:23:26, Info CSI 00000079 [SR] Verify complete
    2012-02-18 23:23:27, Info CSI 0000007a [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:23:27, Info CSI 0000007b [SR] Beginning Verify and Repair transaction
    2012-02-18 23:23:30, Info CSI 0000007d [SR] Verify complete
    2012-02-18 23:23:30, Info CSI 0000007e [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:23:30, Info CSI 0000007f [SR] Beginning Verify and Repair transaction
    2012-02-18 23:23:34, Info CSI 00000081 [SR] Verify complete
    2012-02-18 23:23:35, Info CSI 00000082 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:23:35, Info CSI 00000083 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:23:38, Info CSI 00000085 [SR] Verify complete
    2012-02-18 23:23:39, Info CSI 00000086 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:23:39, Info CSI 00000087 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:23:47, Info CSI 00000089 [SR] Verify complete
    2012-02-18 23:23:48, Info CSI 0000008a [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:23:48, Info CSI 0000008b [SR] Beginning Verify and Repair transaction
    2012-02-18 23:23:56, Info CSI 0000008d [SR] Verify complete
    2012-02-18 23:23:57, Info CSI 0000008e [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:23:57, Info CSI 0000008f [SR] Beginning Verify and Repair transaction
    2012-02-18 23:24:09, Info CSI 00000093 [SR] Verify complete
    2012-02-18 23:24:10, Info CSI 00000094 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:24:10, Info CSI 00000095 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:24:24, Info CSI 00000098 [SR] Verify complete
    2012-02-18 23:24:25, Info CSI 00000099 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:24:25, Info CSI 0000009a [SR] Beginning Verify and Repair transaction
    2012-02-18 23:24:37, Info CSI 0000009e [SR] Verify complete
    2012-02-18 23:24:37, Info CSI 0000009f [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:24:37, Info CSI 000000a0 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:24:49, Info CSI 000000a2 [SR] Verify complete
    2012-02-18 23:24:49, Info CSI 000000a3 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:24:49, Info CSI 000000a4 [SR] Beginning Verify and Repair transaction
    2012-02-18 23:25:04, Info CSI 000000c6 [SR] Verify complete
    2012-02-18 23:25:05, Info CSI 000000c7 [SR] Verifying 100 (0x0000000000000064) components
    2012-02-18 23:25:05, Info CSI 000000c8 [SR] Beginning Verify and Repair transaction
    Graham
  18. 2012/02/20
    SpywareDr
    I'd run the hard drive manufacturer's hard drive diagnostics next. If you see errors there as well, the hard drive is failing and needs to be replaced.
    To run the diags, download and burn the Ultimate Boot CD to CD. It has all the hard drive manufacturer's diagnostic utilities, (plus much more). Simply boot your computer from this CD and select the utility you want to run.
    If you aren't sure who made the hard drive in your computer, use Seagate's Seatools as it will work with most any make of drive.
    The following instructions may prove helpful for burning the UBCD .iso file to disc:
    How can I write (burn) ISO files to CD or DVD?
  19. 2012/02/21
    Yes, check the diags.
    The other area I might consider is a failed/uncompleted installation of the Service Pack (or maybe the Updates). You could try re-running SP2 (something I would try, I haven't done it on Vista).
  20. 2012/02/24
    Graham Newey
    Graham Newey Inactive Thread Starter
    Dear mattman and SpywareDr,
    Am I to understand that the "manufacturer's hard drive diagnostics" are within my system and I use the UBCD to access them?
    Downloaded Seatools and ran all basic tests. AOK.
    Neither of you have actually commented on my sfcdetails.txt. To my unpracticed eye there seemed to be corruption and missing file(s)----?
    I have one (further!) problem. My broadband package only allows me 2GB usage per month (ending 11.3.2012). Being a skint pensioner I cannot afford unlimited usage. So I have to be careful and won't be able to get UBCD (300MB) and new SP2 (550MB) until later in the period. Pitiful I know.
    Regards,
    Graham
  21. 2012/02/25
    Run the extended Seagate tests.
    Run Error Checking (CHKDSK) in Windows, look it up in Help and Support. Do a scan of the disk surface. It will say that you need to restart the computer to run the scan.
    Yes, it says there corrupted files. That's why I suggested re-running the Service Pack (and/or Updates).
    Your internet connection....are you still running a contract that has run out?? My contract lasts for 24 months. If your contract has run out, ask them why you have not been a offered current download contract. Look at what other providers offer. Some offer mega-downloads for low cost (don't forget that you might bundle your land-line and possibly mobile phone). If you want to stay with your current internet provider and you have out-lived their contract, ask them for a "current contract ", otherwise they will rip-you-off using the old one.
