which is better [System Mechanic Pro, and Advanced System care Pro]
Discussion in 'Other PC Software' started by etap, 2010/04/17.
  1. 2010/04/17
    etap
    etap Inactive Thread Starter
    I would like to know,which software is better,System Mechanic Pro, and Advanced System care Pro. I am useing system mechanic pro because it has a virus program build in.I am useing it on desktop,which is XP,and IE6.THX
    my email (removed by moderator)
    etap,
  2. 2010/04/17
    Christer
    Christer Geek Member Staff
    etap,
    I have no opinion but I removed you Email addy to prevent spamming of your account. Answers to the thread, please.
    Hi etap, Iola are the System Mechanic guys and I have used it in the past - No problems. I'm wary of Registry cleaners being used unnecessarily and most of the Moderators here don't advise them unless you have viruses/trojans/malware, and then you follow instructions for cleaning your HD.
    It's a matter of your choice really where you'll get the best bang for your bucks. If the software has a complete Anti-Virus program included - this may be your answer. Cheers Neil.:cool:
  5. 2010/04/19
    MitchellCooley Inactive
    I guess it depends why you are using it. If it is for the virus and malware protection, then there are several excellent free programs available. If it is for the "speed up your computer ", "defrag the registery ": then my opinion is you are wasting money.
    Mitch
