What does a colon do in MS Excel?
Discussion in 'Other PC Software' started by Roger at CCCC, 2007/07/04.
  1. 2007/07/04
    Roger at CCCC
    Roger at CCCC Inactive Thread Starter
    I've used MS Excel for a long time, but I encountered something new the other day. I was trying to enter the contrast ratio for an LCD screen into a cell in my Excel spreadsheet. The contrast ratio was 700:1. But as soon as I entered "700:1 ", Excel converted it to "29.17 ". I assumed that Excel would NOT convert 700:1 and leave my entry as a character string because the ":" is not a numeric digit or an arithmetic operation and I did not have an "=" sign at the beginning of the string. But that's not what happened.
    Of course, I could put a double or single quote at the beginning of the string, and then "700:1 or '700:1 would remain in the spreadsheet cell. Also, I realize that the ":" operator is a range indicator, but I was not entering a cell location, just two numbers. So what was Excel doing with what I entered, and why did it convert 700:1 into 29.17 ?
    Thanks for any comments on this minor but annoying problem.
  2. 2007/07/05
    Doubt this will help...But I entered 700:1 and it changed it to 700:01:00 for 1/29/1900 4:01:00 AM...Any attempt to format the cell changed it to 29.17.
    Found exactly the same - and none of the the formats offerd would accept 700:1 - 700 to 1 yes :)
  5. 2007/07/05
    If I select text for the format of a cell I can enter 700:1.
    You are rght, but the cell must be formatted as text before enterng 700:1 - not after :(
  7. 2007/07/05
    Yup, but that's what I said ;)
  8. 2007/07/05
    Course, Roger already knew about texting it....
  9. 2007/07/06
    Roger at CCCC
    Thanks to all who responded. I guess it's still a mystery as to what Excel actually does to change "700:1" into 29.17. If anybody else has any ideas, I would still be interested. Thanks again !!
  10. 2007/07/06
    In Excel 2007 it gets converted to 700:01:00, listing it as a 'custom' format [h]:mm:ss.
  11. 2007/07/06
    Roger at CCCC
    Thanks, Arie, I finally understand !!
    700:1 is interpreted by Excel as a TIME and converts it to
    700 hours and 1 minute.
    700 hours divided by 24 hours/day = 29.17 days so that's where the 29.17 comes from.
    Thanks !!
  12. 2007/07/07
    yup :D
    Your welcome.
