Volume Control error: There are no active mixer devices available
Discussion in 'Windows XP' started by koukla, 2006/07/12.
  1. 2006/07/12
    koukla
    koukla Inactive Thread Starter
    Lately there has been no sound on my computer.. Its off mute.. the speakers are fine and running properly..
    When i try and click on the volume control icon to change the volume i get this message:
    There are no active mixer devices available. To install mixer devices go to 'Control Panel' click Printers & other hardware and then click hardware.
    This program will now close.
    What does this mean and what should i do?
  2. 2006/07/12
    First step is to reload the audio drivers - these should be on the motherboard CD, if you have one.
    If you don't download and run Everest and let us know the make and model number of the motherboard and I'm sure we can point you to where the drivers can be downloaded.
    koukla
    thanks for that!!
    But this morning when turned my computer on the sound was fine.. So i guess i dont need to download any drivers.
  5. 2006/07/13
    koukla
    Ok.. It isnt working again, so i downloaded Everest..
    Motherboard ID 63-0319-000001-00101111-121203-SPDALE_G$PSLA1110_BIOS DATE: 12/12/03 18:15:21 VER: 08.00.09
    Motherboard Name Asus P4SD-LA
  6. 2006/07/13
    I can't find a motherboard of that description on the Asus site - would you check please that you have not made a typo.
    Is this an OEM computer - HP, Gateway .... ? - if so please post the make and model no.
