Inactive Virus and other issues
Discussion in 'Malware and Virus Removal Archive' started by madness77, 2011/10/15.
  1. 2011/10/15
    Looks good now.
    What are the current issues?
    With malware infections being as they are today, it's strongly recommended to have the Windows Recovery Console pre-installed on your machine before doing any malware removal.
    The Windows Recovery Console will allow you to boot up into a special recovery (repair) mode. This allows us to more easily help you should your computer have a problem after an attempted removal of malware. It is a simple procedure that will only take a few moments of your time.
    Go to Microsoft's website => http://support.microsoft.com/kb/310994
    Select the download that's appropriate for your Operating System
    Download the file & save it as it's originally named.
    Transfer all files you just downloaded, to the desktop of the infected computer.
    Disable your AntiVirus and AntiSpyware applications, usually via a right click on the System Tray icon. They may otherwise interfere with our tools
    • Drag the setup package onto ComboFix.exe and drop it.
    • Follow the prompts to start ComboFix and when prompted, agree to the End-User License Agreement to install the Microsoft Recovery Console.
    • At the next prompt, click 'Yes' to run the full ComboFix scan.
    • When the tool is finished, it will produce a report for you.
    Please post the C:\ComboFix.txt.
    If successful you can reinstall AVG.
