Solved Very slow start up/shutdown
Discussion in 'Malware and Virus Removal Archive' started by sean, 2008/02/12.
  1. 2008/02/19
    sean
    sean Well-Known Member Thread Starter
    Hi Geri.
    I am really sorry about these delays in getting back to you, she has taken the laptop last night with her because she needs it for college and work. I know these gaps between finnishing your instructions can cause problems and if you decide not to carry on i will fully understand your decision. I have tried telling her how important it is to let me get on with it very strongly:mad: but i don't think she understands!
    As you can see i am not to pleased, so i will leave the decision with you and like i said FULLY UNDERSTAND if you call it a day.
    MANY THANKS,
    Sean.
  2. 2008/02/19
    john gerritsen
    john gerritsen Inactive
    Download "Spysweeper" to remove adware and spyware and "AVG Free Edition "
    to remove viruses. I have been using both software for years and eliminated several problems. Spysweeper can be tried for free for a period of time. AVG Free Edition is indeed free.
    Good luck,
    John G.
    Geri Lifetime Subscription
    Geri Inactive Alumni
    Hi john gerritsen
    Thanks for your input, but neither Spysweeper or AVG AV will catch and clean everything. nor will it fix it so he can get into safe mode.
    Besides he is using Norton AV and you can not run two anti-virus progams at the same time.
    Geri
    Hi sean
    I have no problem finishing cleaning her computer. Just ask her not to download any programs (if possible) until it's clean. and if any are installed what they are so I'll know it wasn't done by malware.
    It Just makes more work for me when files appear and I have to find out what they are and where they came from.
    I understand needing it for work and school so that is not a problem.
    Do the dss instructions when you can to see if that helps get you into safe mode, if not we'll try something else.
    Geri
  5. 2008/02/20
    sean
    Good morning geri.
    Thanks john for your post, but i think it's best i stick with Geri ;)
    Told her last night.
    When she next come's to our house i will crack on again;), she lives a few miles away and travels on the buses so she is a little worried about carrying it.....scumbag's/muggers.
    MANY THANKS,
    Sean.
  6. 2008/02/24
    sean
    Hey Geri.
    I have only just got the laptop this evening.i have run that command from post number 16 and now i can get into safe mode :). I thought id better check and see what you want me to do next, as i know these tools are always getting updated and it has taken so long to get things moving again.
    MANY THANKS to you.
    Cheers,
    Sean
  7. 2008/02/24
    Hi sean
    OK That's good.
    Lets see where we are.
    Download ATF Cleaner by Atribune and save it to your Desktop.
    This is a good tool to get rid of the temporary garbage you pick up while surfing the net.
    Double click ATF-Cleaner.exe to run the program.
    Check the boxes to the left of:
    Windows Temp
    Current User Temp
    All Users Temp
    Temporary Internet Files
    Prefetch
    Java Cache
    Recycle bin
    The rest are optional - if you want it to remove everything check "Select All ".
    Finally, click Empty Selected. When you get the "Done Cleaning" message, click OK.
    Now lets get a on-line scan.
    Please do an online scan with Kaspersky WebScanner
    Click on "Accept" If your pop "“up blocker blocks the ActiveX download, allow it, click on "Accept" again
    You will be promted to install an ActiveX component from Kaspersky, Click Yes or Install.
    • The program will launch and then begin downloading the latest definition files:
    • Once the files have been downloaded click on NEXT
    • Now click on Scan Settings
    • In the scan settings make that the following are selected:
      • Scan using the following Anti-Virus database:
      • Extended (if available otherwise Standard)
      • Scan Options:
      • Scan Archives
        Scan Mail Bases
    • Click OK
    • Now under select a target to scan:
      • Select My Computer
    • This will start the program and scan your system.
    • The scan will take a while so be patient and let it run.
    • Once the scan is complete it will display if your system has been infected.
      • Now click on the Save as Text button:
    • Save the file to your desktop.
    • Copy and paste that information in your next post.
    Please post the Kaspersky results.
    Geri
  8. 2008/02/24
    sean
    WOW that was Quick:)
    Geri would you believe it i have had a full afternoon with my internet dropping(on phone to isp/router folk) i have downloaded atf and as i look over to the table i can see kas is downloading the anti-virus data base on the laptop, what i am trying to say is i really dont know if it will be able to complete the full scan?
    I will let you know asap.
    MANY THANKS,
    Sean.
  9. 2008/02/24
    sean
    Yippeee :)
    I really thought it would have dropped the connection
    Cheers,
    Sean.
    KASPERSKY ONLINE SCANNER REPORT
    Sunday, February 24, 2008 8:40:45 PM
    Operating System: Microsoft Windows Vista Home Edition, (Build 6000)
    Kaspersky Online Scanner version: 5.0.98.0
    Kaspersky Anti-Virus database last update: 24/02/2008
    Kaspersky Anti-Virus database records: 578541
    Scan Settings:
    Scan using the following antivirus database: extended
    Scan Archives: true
    Scan Mail Bases: true
    Scan Target - My Computer:
    C:\
    E:\
    F:\
    Scan Statistics:
    Total number of scanned objects: 69783
    Number of viruses found: 1
    Number of infected objects: 1
    Number of suspicious objects: 0
    Duration of the scan process: 00:37:44
    Infected Object Name / Virus Name / Last Action
    C:\Boot\BCD Object is locked skipped
    C:\Boot\BCD.LOG Object is locked skipped
    C:\Deckard\System Scanner\20080224192018\backup\Windows\temp\fwtsqmfile00.sqm Object is locked skipped
    C:\Deckard\System Scanner\20080224192018\backup\Windows\temp\fwtsqmfile01.sqm Object is locked skipped
    C:\Deckard\System Scanner\20080224192018\backup\Windows\temp\fwtsqmfile02.sqm Object is locked skipped
    C:\Deckard\System Scanner\20080224192018\backup\Windows\temp\fwtsqmfile03.sqm Object is locked skipped
    C:\Deckard\System Scanner\20080224192018\backup\Windows\temp\fwtsqmfile04.sqm Object is locked skipped
    C:\Deckard\System Scanner\20080224192018\backup\Windows\temp\fwtsqmfile05.sqm Object is locked skipped
    C:\Deckard\System Scanner\20080224192018\backup\Windows\temp\fwtsqmfile06.sqm Object is locked skipped
    C:\Deckard\System Scanner\20080224192018\backup\Windows\temp\fwtsqmfile07.sqm Object is locked skipped
    C:\Deckard\System Scanner\20080224192018\backup\Windows\temp\fwtsqmfile08.sqm Object is locked skipped
    C:\Deckard\System Scanner\20080224192018\backup\Windows\temp\fwtsqmfile09.sqm Object is locked skipped
    C:\Deckard\System Scanner\20080224192018\backup\Windows\temp\fwtsqmfile10.sqm Object is locked skipped
    C:\Program Files\Common Files\Symantec Shared\NFWEVT.LOG Object is locked skipped
    C:\Program Files\InstallShield Installation Information\{A644254B-92F6-4970-8635-AB0775371E72}\setup.ilg Object is locked skipped
    C:\ProgramData\Symantec\Common Client\settings.bak Object is locked skipped
    C:\ProgramData\Symantec\Common Client\settings.dat Object is locked skipped
    C:\ProgramData\Symantec\LiveUpdate\2008-02-24_Log.ALUSchedulerSvc.LiveUpdate Object is locked skipped
    C:\ProgramData\Symantec\SubEng\submissions.idx Object is locked skipped
    C:\ProgramData\Symantec\SymNetDrv\SNDALRT.log Object is locked skipped
    C:\ProgramData\Symantec\SymNetDrv\SNDCON.log Object is locked skipped
    C:\ProgramData\Symantec\SymNetDrv\SNDDBG.log Object is locked skipped
    C:\ProgramData\Symantec\SymNetDrv\SNDFW.log Object is locked skipped
    C:\ProgramData\Symantec\SymNetDrv\SNDIDS.log Object is locked skipped
    C:\ProgramData\Symantec\SymNetDrv\SNDSYS.log Object is locked skipped
    C:\ProgramData\Microsoft\Crypto\RSA\MachineKeys\beee172858019f87ff4362a8ea67ffe2_6319c3ac-bd64-49d2-88df-a58c2505d8ad Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows\History\Low\History.IE5\index.dat Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows\History\Low\History.IE5\MSHist012008022420080225\index.dat Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\AntiPhishing\B3BB5BBA-E7D5-40AB-A041-A5B1C0B26C8F.dat Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\index.dat Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\MSIMGSIZ.DAT Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows\UsrClass.dat Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG1 Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG2 Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows\UsrClass.dat{34875266-6a72-11db-9114-0014220f037f}.TM.blf Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows\UsrClass.dat{34875266-6a72-11db-9114-0014220f037f}.TMContainer00000000000000000001.regtrans-ms Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows\UsrClass.dat{34875266-6a72-11db-9114-0014220f037f}.TMContainer00000000000000000002.regtrans-ms Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Feeds Cache\index.dat Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows Defender\FileTracker\{FAB9713E-DD36-45E6-9D0D-16FD1246D2F8} Object is locked skipped
    C:\Users\Ruth\AppData\Local\Microsoft\Windows Sidebar\Settings.ini Object is locked skipped
    C:\Users\Ruth\AppData\Roaming\Microsoft\Windows\Cookies\index.dat Object is locked skipped
    C:\Users\Ruth\AppData\Roaming\Microsoft\Windows\Cookies\Low\index.dat Object is locked skipped
    C:\Users\Ruth\Downloads\Install-NWlsdmVyOXQ-a2V5aW4-a2V5aW4.exe Infected: not-virus:Hoax.Win32.Renos.kd skipped
    C:\Users\Ruth\NTUSER.DAT Object is locked skipped
    C:\Users\Ruth\ntuser.dat.LOG1 Object is locked skipped
    C:\Users\Ruth\ntuser.dat.LOG2 Object is locked skipped
    C:\Users\Ruth\NTUSER.DAT{3a539871-6a70-11db-887c-d362bd253390}.TM.blf Object is locked skipped
    C:\Users\Ruth\NTUSER.DAT{3a539871-6a70-11db-887c-d362bd253390}.TMContainer00000000000000000001.regtrans-ms Object is locked skipped
    C:\Users\Ruth\NTUSER.DAT{3a539871-6a70-11db-887c-d362bd253390}.TMContainer00000000000000000002.regtrans-ms Object is locked skipped
    C:\Windows\Debug\PASSWD.LOG Object is locked skipped
    C:\Windows\Debug\sam.log Object is locked skipped
    C:\Windows\Debug\WIA\wiatrace.log Object is locked skipped
    C:\Windows\Logs\CBS\CBS.log Object is locked skipped
    C:\Windows\Logs\CBS\CBS.persist.log Object is locked skipped
    C:\Windows\Logs\DPX\setupact.log Object is locked skipped
    C:\Windows\Logs\DPX\setuperr.log Object is locked skipped
    C:\Windows\MEMORY.DMP Object is locked skipped
    C:\Windows\Microsoft.NET\Framework\v3.0\Windows Communication Foundation\SMSvcHost.exe.config Object is locked skipped
    C:\Windows\Panther\UnattendGC\diagerr.xml Object is locked skipped
    C:\Windows\Panther\UnattendGC\diagwrn.xml Object is locked skipped
    C:\Windows\Panther\UnattendGC\setupact.log Object is locked skipped
    C:\Windows\Panther\UnattendGC\setuperr.log Object is locked skipped
    C:\Windows\security\database\secedit.sdb Object is locked skipped
    C:\Windows\SoftwareDistribution\ReportingEvents.log Object is locked skipped
    C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-0.C7483456-A289-439d-8115-601632D005A0 Object is locked skipped
    C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-1.C7483456-A289-439d-8115-601632D005A0 Object is locked skipped
    C:\Windows\System32\catroot2\edb.log Object is locked skipped
    C:\Windows\System32\catroot2\{127D0A1D-4EF2-11D1-8608-00C04FC295EE}\catdb Object is locked skipped
    C:\Windows\System32\catroot2\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\catdb Object is locked skipped
    C:\Windows\System32\config\COMPONENTS Object is locked skipped
    C:\Windows\System32\config\COMPONENTS.LOG1 Object is locked skipped
    C:\Windows\System32\config\COMPONENTS.LOG2 Object is locked skipped
    C:\Windows\System32\config\DEFAULT Object is locked skipped
    C:\Windows\System32\config\DEFAULT.LOG1 Object is locked skipped
    C:\Windows\System32\config\DEFAULT.LOG2 Object is locked skipped
    C:\Windows\System32\config\SAM Object is locked skipped
    C:\Windows\System32\config\SAM.LOG1 Object is locked skipped
    C:\Windows\System32\config\SAM.LOG2 Object is locked skipped
    C:\Windows\System32\config\SECURITY Object is locked skipped
    C:\Windows\System32\config\SECURITY.LOG1 Object is locked skipped
    C:\Windows\System32\config\SECURITY.LOG2 Object is locked skipped
    C:\Windows\System32\config\SOFTWARE Object is locked skipped
    C:\Windows\System32\config\SOFTWARE.LOG1 Object is locked skipped
    C:\Windows\System32\config\SOFTWARE.LOG2 Object is locked skipped
    C:\Windows\System32\config\SYSTEM Object is locked skipped
    C:\Windows\System32\config\SYSTEM.LOG1 Object is locked skipped
    C:\Windows\System32\config\SYSTEM.LOG2 Object is locked skipped
    C:\Windows\System32\config\TxR\{250834b7-750c-494d-bdc3-da86b6e2101a}.TxR.0.regtrans-ms Object is locked skipped
    C:\Windows\System32\config\TxR\{250834b7-750c-494d-bdc3-da86b6e2101a}.TxR.1.regtrans-ms Object is locked skipped
    C:\Windows\System32\config\TxR\{250834b7-750c-494d-bdc3-da86b6e2101a}.TxR.2.regtrans-ms Object is locked skipped
    C:\Windows\System32\config\TxR\{250834b7-750c-494d-bdc3-da86b6e2101a}.TxR.blf Object is locked skipped
    C:\Windows\System32\config\TxR\{250834B7-750C-494d-BDC3-DA86B6E2101B}.TM.blf Object is locked skipped
    C:\Windows\System32\config\TxR\{250834B7-750C-494d-BDC3-DA86B6E2101B}.TMContainer00000000000000000001.regtrans-ms Object is locked skipped
    C:\Windows\System32\config\TxR\{250834B7-750C-494d-BDC3-DA86B6E2101B}.TMContainer00000000000000000002.regtrans-ms Object is locked skipped
    C:\Windows\System32\LogFiles\Scm\SCM.EVM Object is locked skipped
    C:\Windows\System32\LogFiles\WUDF\WUDFTrace.etl Object is locked skipped
    C:\Windows\System32\restore\MachineGuid.txt Object is locked skipped
    C:\Windows\System32\spool\SpoolerETW.etl Object is locked skipped
    C:\Windows\System32\sysprep\Panther\diagerr.xml Object is locked skipped
    C:\Windows\System32\sysprep\Panther\diagwrn.xml Object is locked skipped
    C:\Windows\System32\sysprep\Panther\setupact.log Object is locked skipped
    C:\Windows\System32\sysprep\Panther\setuperr.log Object is locked skipped
    C:\Windows\System32\wbem\Logs\WMITracing.log Object is locked skipped
    C:\Windows\System32\wbem\Repository\INDEX.BTR Object is locked skipped
    C:\Windows\System32\wbem\Repository\MAPPING1.MAP Object is locked skipped
    C:\Windows\System32\wbem\Repository\MAPPING2.MAP Object is locked skipped
    C:\Windows\System32\wbem\Repository\OBJECTS.DATA Object is locked skipped
    C:\Windows\System32\winevt\Logs\Application.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\DFS Replication.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\HardwareEvents.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Internet Explorer.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Key Management Service.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Media Center.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Bits-Client%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-CodeIntegrity%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-CorruptedFileRecovery-Client%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-CorruptedFileRecovery-Server%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-DateTimeControlPanel%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Diagnosis-DPS%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Diagnosis-MSDT%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Diagnosis-PLA%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Diagnostics-Networking%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Diagnostics-Performance%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-DiskDiagnostic%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-DiskDiagnosticDataCollector%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-DiskDiagnosticResolver%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-DriverFrameworks-UserMode%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Forwarding%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-GroupPolicy%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Help%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-International%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Kernel-WDI%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Kernel-WHEA.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-LanguagePackSetup%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-MeetingSpace%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-MemoryDiagnostics-Results%4Debug.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-MUI%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-NetworkAccessProtection%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-ParentalControls%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Program-Compatibility-Assistant%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-ReadyBoost%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-ReliabilityAnalysisComponent%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-RemoteAssistance%4Admin.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-RemoteAssistance%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Resource-Exhaustion-Detector%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Resource-Exhaustion-Resolver%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Resource-Leak-Diagnostic%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-RestartManager%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-TaskScheduler%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-UAC%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-UAC-FileVirtualization%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-WindowsUpdateClient%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Winlogon%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Winsock-WS2HELP%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-Wired-AutoConfig%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Microsoft-Windows-WLAN-AutoConfig%4Operational.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Security.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\Setup.evtx Object is locked skipped
    C:\Windows\System32\winevt\Logs\System.evtx Object is locked skipped
    C:\Windows\Tasks\SCHEDLGU.TXT Object is locked skipped
    C:\Windows\WindowsUpdate.log Object is locked skipped
    C:\Windows\winsxs\x86_microsoft-windows-n..n_service_datastore_31bf3856ad364e35_6.0.6000.16386_none_cef7ceb03914a67f\dnary.xsd Object is locked skipped
    Scan process completed.
  10. 2008/02/24
    Hi sean
    OK Cool, I thought it would be worse that it is.
    You need to delete this.
    Then do the following.
    Click Start>Run in the run box copy and paste or type ComboFix /u then hit Enter to uninstall ComboFix and remove the files/folders it created.
    Delete these.
    SDFix.exe
    This folder.
    C:\SDFix
    Run ATF Cleaner again.
    Do one more Kaspersky scan and make sure it shows this,
    Number of viruses found: 0
    Number of infected objects: 0
    If it shows anything else post the log.
    Let me know
    Geri
  11. 2008/02/24
    sean
    Good morning Geri.
    I have completed your instructions except i couldent find c:\SDFix to delete? only on the destop?
    Heres the latest kas scan results,if you need the full log please let me know?
    MANY THANKS for your time,
    Sean.
    Scan Settings:
    Scan Archives: true
    C:\
    E:\
    F:\
    Scan Statistics:
    Total number of scanned objects: 69580
    Duration of the scan process: 00:36:14
  12. 2008/02/25
    Hi sean
    OK, Good that is what we wanted to see.
    This would be a good time to set a new system restore point for your machine.
    Set New System Restore Point Windows XP. - Set New System Restore Point Windows Vista
    Do not do this unless there are no other user accounts to be diagnosed.
    Please look at this link for some preventive recommendations, It could keep you from ending up back here to the Spyware and Virus Removal Forms.
    http://www.windowsbbs.com/showthread.php?t=67958
    Let me know that things are running OK and I'll mark this one resolved.
    Surf Safely
    Geri
  13. 2008/02/25
    sean
    Hi Geri.
    That's great news :D. Hope this is ok but i have a few more questions :eek:
    Am i ok now to run that norton removal tool and is it ok to use with vista?
    Ruth has windows defender turned on, is it ok to turn this off and install AVG free ?
    Should i install java's latest relase and uninstall the old one she has on?
    I have heard that windows firewall is not too good,would it be better to turn this off and install comodo free?
    The laptop is quite slow at start up / shut down, is there anything from the new hjt log she could really do without / not needed?
    And finnaly ;) is it ok to delete that dss tool?
    Cheers and THANKS,
    Sean.
    Scan saved at 15:52:29, on 25/02/2008
    Platform: Windows Vista (WinNT 6.00.1904)
    MSIE: Internet Explorer v7.00 (7.00.6000.16609)
    C:\Windows\system32\Dwm.exe
    C:\Windows\Explorer.EXE
    C:\Windows\system32\taskeng.exe
    C:\Program Files\Windows Defender\MSASCui.exe
    C:\Program Files\TOSHIBA\Power Saver\TPwrMain.exe
    C:\Program Files\TOSHIBA\SmoothView\SmoothView.exe
    C:\Program Files\TOSHIBA\FlashCards\TCrdMain.exe
    C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
    C:\Windows\RtHDVCpl.exe
    C:\Program Files\TOSHIBA\ConfigFree\NDSTray.exe
    C:\Windows\System32\igfxtray.exe
    C:\Windows\System32\rundll32.exe
    C:\Program Files\Synaptics\SynTP\SynToshiba.exe
    C:\Windows\System32\hkcmd.exe
    C:\Windows\System32\igfxpers.exe
    C:\Program Files\Windows Sidebar\sidebar.exe
    C:\Program Files\TOSHIBA\TOSCDSPD\TOSCDSPD.exe
    C:\Program Files\Windows Media Player\wmpnscfg.exe
    C:\Windows\ehome\ehtray.exe
    C:\Program Files\MSN Messenger\msnmsgr.exe
    C:\Windows\ehome\ehmsas.exe
    C:\Windows\System32\mobsync.exe
    C:\Program Files\TOSHIBA\ConfigFree\CFSwMgr.exe
    C:\Windows\system32\igfxext.exe
    C:\Windows\system32\igfxsrvc.exe
    C:\Windows\system32\SearchFilterHost.exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.co.uk/
    R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
    R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
    O1 - Hosts: ::1 localhost
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
    O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0\bin\ssv.dll
    O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
    O4 - HKLM\..\Run: [Windows Defender] %ProgramFiles%\Windows Defender\MSASCui.exe -hide
    O4 - HKLM\..\Run: [TPwrMain] %ProgramFiles%\TOSHIBA\Power Saver\TPwrMain.EXE
    O4 - HKLM\..\Run: [HSON] %ProgramFiles%\TOSHIBA\TBS\HSON.exe
    O4 - HKLM\..\Run: [SmoothView] %ProgramFiles%\Toshiba\SmoothView\SmoothView.exe
    O4 - HKLM\..\Run: [00TCrdMain] %ProgramFiles%\TOSHIBA\FlashCards\TCrdMain.exe
    O4 - HKLM\..\Run: [NvSvc] RUNDLL32.EXE C:\Windows\system32\nvsvc.dll,nvsvcStart
    O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\Windows\system32\NvCpl.dll,NvStartup
    O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\Windows\system32\NvMcTray.dll,NvTaskbarInit
    O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
    O4 - HKLM\..\Run: [RtHDVCpl] RtHDVCpl.exe
    O4 - HKLM\..\Run: [NDSTray.exe] NDSTray.exe
    O4 - HKLM\..\Run: [osCheck] "C:\Program Files\Norton Internet Security\osCheck.exe "
    O4 - HKLM\..\Run: [topi] C:\Program Files\TOSHIBA\Toshiba Online Product Information\topi.exe -startup
    O4 - HKLM\..\Run: [IgfxTray] C:\Windows\system32\igfxtray.exe
    O4 - HKLM\..\Run: [HotKeysCmds] C:\Windows\system32\hkcmd.exe
    O4 - HKLM\..\Run: [Persistence] C:\Windows\system32\igfxpers.exe
    O4 - HKLM\..\Run: [Toshiba Registration] C:\Program Files\Toshiba\Registration\ToshibaRegistration.exe
    O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe "
    O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe "
    O4 - HKCU\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
    O4 - HKCU\..\Run: [TOSCDSPD] C:\Program Files\TOSHIBA\TOSCDSPD\TOSCDSPD.exe
    O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files\Windows Media Player\WMPNSCFG.exe
    O4 - HKCU\..\Run: [ehTray.exe] C:\Windows\ehome\ehTray.exe
    O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\MSN Messenger\msnmsgr.exe" /background
    O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOCAL SERVICE')
    O4 - HKUS\S-1-5-19\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'LOCAL SERVICE')
    O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETWORK SERVICE')
    O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\npjpi160.dll
    O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\npjpi160.dll
    O9 - Extra button: eBay - {C08CAF1D-C0A3-40D5-9970-06D067EAC017} - http://www.webtip.ch/cgi-bin/toshiba/tracker_url.pl?EN (file missing)
    O13 - Gopher Prefix:
    O16 - DPF: {0EB0E74A-2A76-4AB3-A7FB-9BD8C29F7F75} (CKAVWebScan Object) - http://www.kaspersky.com/kos/eng/partner/default/kavwebscan_unicode.cab
    O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\Windows\system32\agrsmsvc.exe
    O23 - Service: Apple Mobile Device - Apple, Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
    O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
    O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
    O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    O23 - Service: ConfigFree Service (CFSvcs) - TOSHIBA CORPORATION - C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe
    O23 - Service: Symantec Lic NetConnect service (CLTNetCnService) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    O23 - Service: COM Host (comHost) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\VAScanner\comHost.exe
    O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1150\Intel 32\IDriverT.exe
    O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
    O23 - Service: Symantec IS Password Validation (ISPwdSvc) - Symantec Corporation - C:\Program Files\Norton Internet Security\isPwdSvc.exe
    O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
    O23 - Service: MSCSPTISRV - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\MSCSPTISRV.exe
    O23 - Service: PACSPTISVR - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\PACSPTISVR.exe
    O23 - Service: Sony SPTI Service (SPTISRV) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\SPTISRV.exe
    O23 - Service: Symantec AppCore Service (SymAppCore) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\AppCore\AppSvc32.exe
    O23 - Service: TOSHIBA Optical Disc Drive Service (TODDSrv) - TOSHIBA Corporation - C:\Windows\system32\TODDSrv.exe
    O23 - Service: TOSHIBA Power Saver (TosCoSrv) - TOSHIBA Corporation - C:\Program Files\TOSHIBA\Power Saver\TosCoSrv.exe
    O23 - Service: TOSHIBA Bluetooth Service - TOSHIBA CORPORATION - c:\Program Files\Toshiba\Bluetooth Toshiba Stack\TosBtSrv.exe
    O23 - Service: Ulead Burning Helper (UleadBurningHelper) - Ulead Systems, Inc. - C:\Program Files\Common Files\Ulead Systems\DVD\ULCDRSvr.exe
    End of file - 8143 bytes
  14. 2008/02/25
    Hi sean
    Yes...doing combofix /u was suppose to delete that also?
    In any case Yes delete dss.exe and this folder C:\Deckard
    Yes, The tool had a problem with Vista at one time, but I believe that has been fixed, Make sure you do no surfing between switching Anti-Virus programs
    Windows Defender and AVG are to different things
    Windows Defender is a Spyware program and you can keep it on.
    AVG Free is Anti-Virus
    Yes it would, That would be my choice.
    This may improve when you switch AV's. and doing a Defrag and Check Disk would not hurt either. Here is a link with instructions, You can skip the Disk Clean up, ATF Cleaner does the job.
    http://www.microsoft.com/atwork/getstarted/speed.mspx
    Fix these with HJT. Do a scan only check the boxes next to these and click fix checked. With no other windows open.
    O16 - DPF: {0EB0E74A-2A76-4AB3-A7FB-9BD8C29F7F75} (CKAVWebScan Object) - http://www.kaspersky.com/kos/eng/par...an_unicode.cab
    Yes, make sure you remove the old one in Control Panel, Programs and Features.
    Here is a link.
    Sun and download then install the Java Runtime Environment (JRE) 6 Update 4.
    Let me know that everything is OK and I'll mark this one Resolved.
    Geri
  15. 2008/02/26
    sean
    A very good morning to you Geri.
    Alls good here, i have completed all your instructions to the letter:
    Norton = banished, avg free running, full scan found= 0 viruses found :D
    Java updated, old one gone :D
    dss removed :D
    Windows firewall turned off, comodo firewall on :D
    Defrag / Check Disk complete :D
    lines in hjt fixed :D
    So all's that's left to say is a MASSIVE THANK YOU for sticking with me until we finnished what was a slow fix with the delays in getting back to you.
    Cheers and good luck to you,
    Sean and Ruth.
  16. 2008/02/26
    Hi sean
    OK, Good Job
    You're welcome, always glad to help. :)
    Surf Safely
    Geri
