Resolved Validation Failure
Discussion in 'Windows XP' started by oldmanjim, 2012/11/04.
  1. 2012/12/01
    As Bill said, unless you have a sticker on the case that has the product key on it for you to use then yes you will most likely have to buy a new license for Windows XP.
    Just to make sure that there is not a problem with your Windows installation you can perform a validation check here, Genuine Windows Validation. If the validation check fails then we will know that the product key is not valid.
  2. 2012/12/03
    oldmanjim
    oldmanjim Inactive Thread Starter
    I don't have a sticker that I can find. Thanks for all the help. I'm contacting MS to get a hold of a valid product key.
    Ok cool. Once you get a valid product key that is genuine, then make sure you install Service Pack 2 and Service Pack 3.
  5. 2012/12/03
    Did you download Belarc Advisor from my last post and get the key code that it shows?
  6. 2012/12/13
    oldmanjim
    No, sorry I haven't responded. I got a new computer. Thanks for all your help guys
  7. 2012/12/14
    Your Welcome. :)
    Since this issue is now resolved, please mark this thread as 'Resolved'.
