Solved V3 and Alyac Unresponsive to Virus
Discussion in 'Malware and Virus Removal Archive' started by oneofnine, 2010/08/30.
  1. 2010/09/04
    oneofnine
    oneofnine Inactive Thread Starter
    Some C drive space freed.
    Firefox updated.
    Adobe Reader uninstalled
    Foxit PDF Reader installed (This is great. Thank you.).
    Kaspersky online scan unsuccessful. Error message below.
    Update has failed The program could not be started. Please close the window of Kaspersky Online Scanner 7.0 and start the program again from the web site of Kaspersky Lab.
    Successful updating of Kaspersky Online Scanner 7.0 and scanning of your computer requires uninterrupted Internet connection. Please make sure that the Internet connection is established. [ERROR: File operation failure]
  2. 2010/09/04
    Instead of Kaspersky....
    Please run a free online scan with the ESET Online Scanner
    • Disable your antivirus program
    • Tick the box next to YES, I accept the Terms of Use
    • IMPORTANT! UN-check Remove found threats
    • Click Start
    • Accept any security warnings from your browser.
    • Check Scan archives
    • Click Start
    • ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
    • When the scan completes, push List of found threats
    • Push Export to text file , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
    oneofnine
    umm... hmm...
    ESET Online Scanner Log
    C:\Public_html\update.exe probably a variant of Win32/Injector.CLK trojan
    C:\Qoobox\Quarantine\C\WINDOWS\explorer.exe.vir Win32/Bamital.DX trojan
    C:\Qoobox\Quarantine\C\WINDOWS\system32\winlogon.exe.vir Win32/Bamital.DX trojan
    C:\System Volume Information\_restore{D5793852-EE11-4FAB-B335-CF7F4E12B36B}\RP5\A0003994.exe Win32/Bamital.DX trojan
    C:\System Volume Information\_restore{D5793852-EE11-4FAB-B335-CF7F4E12B36B}\RP5\A0003996.exe Win32/Bamital.DX trojan
    C:\WINDOWS\system32\hlp.dat Win32/Bamital.DZ trojan
  5. 2010/09/04
    Run OTL
      :OTL
      :Services
      :Reg
      :Files
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [Reboot]
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point.
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. Run defrag at your convenience.
    11. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    12. Please, let me know, how is your computer doing.
  6. 2010/09/04
    oneofnine
    OTL Log
    All processes killed
    ========== OTL ==========
    ========== FILES ==========
    File move failed. C:\Public_html\update.exe scheduled to be moved on reboot.
    C:\WINDOWS\system32\hlp.dat moved successfully.
    [EMPTYTEMP]
    User: Administrator
    User: All Users
    User: Default User
    User: LocalService
    ->Temp folder emptied: 66016 bytes
    ->Temporary Internet Files folder emptied: 16786 bytes
    User: NetworkService
    ->Temporary Internet Files folder emptied: 33718 bytes
    User: 유민우
    ->Temp folder emptied: 109959061 bytes
    ->Temporary Internet Files folder emptied: 39705175 bytes
    ->Java cache emptied: 261868 bytes
    ->FireFox cache emptied: 64415796 bytes
    ->Google Chrome cache emptied: 74141659 bytes
    ->Apple Safari cache emptied: 0 bytes
    ->Flash cache emptied: 1744 bytes
    Windows Temp folder emptied: 2030075 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 33170 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 277.00 mb
    [EMPTYFLASH]
    User: Administrator
    User: All Users
    User: Default User
    User: LocalService
    User: 유민우
    OTL by OldTimer - Version 3.2.11.0 log created on 09052010_133718
    File\Folder C:\Public_html\update.exe not found!
  7. 2010/09/04
    Go on....
  8. 2010/09/05
    oneofnine
    OTL Run Fix done. OTL Clean Up done. Windows Update is current. WOT installed. Secunia PSI installed. FileHippo Update Checker installed. Going over all your recommendations.
    PC is working well. Again... Thank you!
  9. 2010/09/05
    Excellent!
    Good luck and stay safe :)
