Use DVI or VGA
Discussion in 'PC Hardware' started by MitchellCooley, 2008/06/07.
  1. 2008/06/07
    MitchellCooley Inactive Thread Starter
    My new computer and monitor came with both DVI and VGA cables. When I set it up I used the VGA cable since I wasn't sure what DVI was. Now that I have done a little reading on the net, should I switch to DVI?
    PC Specs are:
    HP Pavilion AMD Athlon(tm) 64 X2 Dual Core Processor 4400+ with 3GB RAM
    Vista Home Premium
    NVIDIA GeForce 6150SE nForce 430
    20" Wide Screen LCD Monitor
    Mitch
  2. 2008/06/07
    In theory DVI will give a better 'picture', although you might not notice any real difference in everyday working, but for videos, etc it is preferred if available.
    So easy to try - just switch cables, assuming both monitor and PC have DVI input/output.
    Thanks Pete,
    Will give it a try. Check it out for a day or so. Let you know.
    Mitch
  5. 2008/06/08
    Well, monitor came with the cables and connection, but computer has no connection for dvi. oh well.
    Mitch
  6. 2008/06/08
    I guess the monitor is a 'standard package' used with other HP towers and as it is DVI capable would have the appropriate cables supplied.
    A little surprised that the computer does not have DVI - so commonplace these days.
  7. 2008/06/08
    mflynn
    mflynn Inactive
    Hi Mitch
    Also if you did have the "right" video card with both DVI and VGA then you have the possibility of Dual Monitors.
    NOTE: the fact the video card has both does not garantee dual monitors. Most do support this but some mfgs do not, even with both connectors.
    Mike
  9. 2008/06/09
  10. 2008/06/09
    Hi Mike,
    If I had dual monitors, able to do and see more, my wife would kill me:D
    Mitch
