[USB malfuction on external hard drive]
Discussion in 'PC Hardware' started by bigchief, 2008/07/10.
  1. 2008/07/10
    bigchief
    bigchief Inactive Thread Starter
    I have the same problem AFan. my computer is telling me the same thing. I have a eternal hard drive that has been working good, but is saying the same thing your is saying. I need to know how i can tranfer my files to another drive
    Thanks,
    bigchief:confused:
  2. 2008/07/11
    bigchief
    Pleasse do not hijack an existing thread even though the problem may appear to be the same. I have split your post to a new thread.
    It is amost impossible to determine if your problem is caused by a fault in the drive enclosure electronics or on the hard drive itself.
    Your best - and probably only, bet is to remove the drive from the case and hitch it up as a slave drive in the computer. If the drive is recognised copy the data off.
    If the drive is recognised I would check it out with the drive manufacturer's disk diagnostics and if it passes get hold of another external enclosure and fit the drive to it.
    ExcelStore ....
    http://www.excelstor.com/en/download.asp
    Hitachi .....
    http://www.hitachigst.com/hdd/support/download.htm
    Samsung ....
    http://www.samsung.com/global/business/hdd/support/utilities/Support_HUTIL.html
    Seagate, Maxtor, Quantum .....
    http://www.seagate.com/www/en-us/support/downloads/
    Western Digital ....
    http://support.wdc.com/download/
