USB Drives Not Recognized After SP3
Discussion in 'Windows XP' started by rohasha28, 2009/04/20.
  1. 2009/04/20
    rohasha28
    rohasha28 Inactive Thread Starter
    Hi All,
    I recently installed the SP3 update onto my IBM G40 laptop: XP Home Edition. After the install and subsequent reboots, I plugged in my USB key...and nothing happened. The USB device does not show up in My Computer. It made the *duh dah* connection sound signifying it recognized something being plugged in...and that's it.
    I rightclicked My Computer ->Manage ->Disk Management and still nothing. All I see is my DVD Drive.
    I have tried uninstalling the Composite nodes from Device Manager (as was the advice here (http://www.windowsbbs.com/hardware/76907-sp3-ate-my-usb-2-0-drivers-i-think.html) and restarted my computer...no luck again. It added the composite drives back in.
    I could use some advice! I need to use my memory drives!
    Oh... and I don't know if it means anything but I get an error at my welcome screen about svchost.exe not working and having to shut down, before proceeding normally to my desktop.
    Thanks in advance! :)
  2. 2009/04/20
    Do you have access to another pc to test the USB key?
    rohasha28
    It's not the USB key. I've tried plugging multiple devices sticks/external hard drives, etc.
    Same result.
  5. 2009/04/22
    rohasha28
    Hi Guys,
    Just providing an update. Under device manager, the USB Memory Stick I plug in (and I've tried MANY of them) don't show up under the USB classification. Instead they're under "Disk Drives" with my main hard drive, etc.
    Any advice? I noticed the problem after I installed SP3...
    Thanks!
  6. 2009/04/23
    Hi rohasha28, My 4Gig USB drive shows up > Device Manager > Disk Drives > USBDisk Rundisk USB Device. Also USB Controllers > USB Mass Storage Device. It also shows up Start > Computer > Devices with Removable Storage. Have you tried Restore to a point before SP3? Neil.
  7. 2009/04/23
    If it was me, I would uninstall SP3. Go to the IBM/Lenovo website and get any driver (/software) updates, then try installing SP3 again.
