Solved Updates equal error, part two.
Discussion in 'Malware and Virus Removal Archive' started by Bdog, 2010/08/27.
  1. 2010/08/29
    Bdog
    Bdog Inactive Thread Starter
    KASPERSKY ONLINE SCANNER 7.0: scan report
    Sunday, August 29, 2010
    Operating system: Microsoft Windows XP Professional Service Pack 3 (build 2600)
    Kaspersky Online Scanner version: 7.0.26.13
    Last database update: Sunday, August 29, 2010 18:44:42
    Records in database: 4167612
    Scan settings:
    scan using the following database: extended
    Scan archives: yes
    Scan e-mail databases: yes
    Scan area - My Computer:
    A:\
    C:\
    D:\
    E:\
    Scan statistics:
    Objects scanned: 121340
    Threats found: 0
    Infected objects found: 0
    Suspicious objects found: 0
    Scan duration: 05:55:58
    No threats found. Scanned area is clean.
    Selected area has been scanned.
    Broni....there is not much to show; good thing? :)
  2. 2010/08/29
    Surely is :)
    Your computer is clean [​IMG]
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point.
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. Run defrag at your convenience.
    11. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    12. Please, let me know, how is your computer doing.
    Bdog
    Broni, will I have to remove Kaspersky and reload my antivirus now, then continue with the steps you have outlined?
  5. 2010/08/29
    Yes, please.
  6. 2010/08/29
    Bdog
    Righto....
  7. 2010/08/30
    Bdog
    I couldn't find Kaspersky in my add and remove. I thought there were files that had to be downloaded onto my computer?
  8. 2010/08/30
    Don't worry about it.
    Proceed with other steps.
  9. 2010/08/30
    Bdog
    I tried the update shield, lower right.... failed to install KB2229593. I downloaded same file to my desktop and will try that next.
    You had mentioned there were a couple of Trojans present.... should I be changing my passwords now, as in step 4?
    There is a browsing protection with shaw; will WOT conflict with or compliment?
    The other downloads sound like an asset...thanks.
  10. 2010/08/30
    Bdog
    Broni, I tried the download once again and it failed, however, I was prompted to continue without copying the file "helpsvc.exe" and it worked.
    If all is Ok with that procedure..... I thank you for all your time and help.
    Cheers, Barry.
  11. 2010/08/30
    Good news :)
    Yes.
    You'll be fine with WOT installed.
    Good luck and stay safe :)
  12. 2010/08/30
    Bdog
    Thanks again Broni.....
    Cheers, Barry.:D
  13. 2010/08/30
    Sure thing :)
  14. 2010/08/31
    Bdog
    Hi Broni,
    I was not sure if I should post here or where I started (Windows XP) with the KB2229593 problem.
    I posted at the latter since I thought we were done here.... wanted you to know.
    The auto update keeps sending me the same update.
    Cheers, Barry.
  15. 2010/08/31
    In this forum, we make sure, your computer is free of malware and your computer is clean :)
    Because the access to malware forum is very limited, your best option is to create new topic about your current issue, at Windows section.
    You'll get more attention.
  16. 2010/08/31
    Bdog
    Good... thanks Broni. :)
  17. 2010/08/31
    No problem :)
