Solved Ultra Slow Office Machine 1
Discussion in 'Malware and Virus Removal Archive' started by Blue Star, 2010/08/16.
  1. 2010/08/25
    Now, you know :)
    Run OTL
      :OTL
      :Services
      :Reg
      :Files
      C:\Documents and Settings\Owner.WS08\Incomplete\T-3515161-ive got the world on a string.wma
      C:\Documents and Settings\Owner.WS08\Shared\Dave Matthews band - Where Are You Going.mp3
      C:\Documents and Settings\Owner.WS08\Shared\learn you inside out (best quality).mp3
      C:\Documents and Settings\Owner.WS08\Shared\love song for no one.mp3
      C:\Documents and Settings\Owner.WS08\Shared\master key system.zip
      C:\quarantine\*
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [Reboot]
    OTL Clean-Up
    Clean up with OTL:
    * Double-click OTL.exe to start the program.
    * Close all other programs apart from OTL as this step will require a reboot
    * On the OTL main screen, press the CLEANUP button
    * Say Yes to the prompt and then allow the program to reboot your computer.
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point.
    Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista and 7:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
    5. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Malwarebytes "Quick scan" once in a while to assure safety of your computer.
    8. Run Temporary File Cleaner (TFC) weekly.
    9. Download and install Secunia Personal Software Inspector (PSI): http://secunia.com/vulnerability_scanning/personal/. The Secunia PSI is a FREE security tool designed to detect vulnerable and out-dated programs and plug-ins which expose your PC to attacks. Run it weekly.
    10. (optional) If you want to keep all your programs up to date, download and install FileHippo Update Checker.
    11. Run defrag at your convenience.
    12. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    13. Please, let me know, how your computer is doing.
  2. 2010/08/31
    The issue seems to be resolved.
