Inactive Trojan, possibly rootkit infection.
Discussion in 'Malware and Virus Removal Archive' started by wildfire, 2014/05/14.
  1. 2014/05/14
    wildfire
    wildfire Getting Old Thread Starter
    [Inactive] Trojan, possibly rootkit infection.
    Hi Broni,
    I loaned my laptop out for a couple of months to a friend and it has been returned with an infection. I'm occasionally being redirected to a yahoo? website when entering valid website addresses.
    I've done what I can but the redirection still occurs after an hour or so.
    Logs to follow in this thread.
  2. 2014/05/14
    wildfire
    MBAM Log... Others to follow.
    Malwarebytes Anti-Malware
    www.malwarebytes.org
    Scan Date: 14/05/2014
    Scan Time: 19:45:28
    Logfile: mbam.txt
    Administrator: Yes
    Version: 2.00.1.1004
    Malware Database: v2014.05.14.08
    Rootkit Database: v2014.03.27.01
    License: Trial
    Malware Protection: Enabled
    Malicious Website Protection: Enabled
    Chameleon: Disabled
    OS: Windows 8.1
    CPU: x64
    File System: NTFS
    User: wildfire
    Scan Type: Threat Scan
    Result: Completed
    Objects Scanned: 280871
    Time Elapsed: 19 min, 34 sec
    Memory: Enabled
    Startup: Enabled
    Filesystem: Enabled
    Archives: Enabled
    Rootkits: Disabled
    Shuriken: Enabled
    PUP: Enabled
    PUM: Enabled
    Processes: 0
    (No malicious items detected)
    Modules: 0
    Registry Keys: 0
    Registry Values: 0
    Registry Data: 0
    Folders: 0
    Files: 0
    Physical Sectors: 0
    (end)
    wildfire
    I'm having a problem running DDS.
    "DDS is not meant to run in 'Compatibility Mode'.
    The program shall now exit. "
    What now?
  5. 2014/05/14
    Please, observe following rules:
    • Read all of my instructions very carefully. Your mistakes during cleaning process may have very serious consequences, like unbootable computer.
    • If you're stuck, or you're not sure about certain step, always ask before doing anything else.
    • Please refrain from running any tools, fixes or applying any changes to your computer other than those I suggest.
    • Never run more than one scan at a time.
    • Keep updating me regarding your computer behavior, good, or bad.
    • The cleaning process, once started, has to be completed. Even if your computer appears to act better, it may still be infected. Once the computer is totally clean, I'll certainly let you know.
    • If you leave the topic without explanation in the middle of a cleaning process, you may not be eligible to receive any more help in malware removal forum.
    • I close my topics if you have not replied in 5 days. If you need more time, simply let me know. If I closed your topic and you need it to be reopened, simply PM me.
    [​IMG] Download RogueKiller from one of the following links and save it to your Desktop:
    Link 1
    Link 2
    • Close all the running programs
    • Windows Vista/7/8 users: right click on RogueKiller.exe, click Run as Administrator
    • Otherwise just double-click on RogueKiller.exe
    • Pre-scan will start. Let it finish.
    • Click on SCAN button.
    • Wait until the Status box shows Scan Finished
    • Click on Delete.
    • Wait until the Status box shows Deleting Finished.
    • Click on Report and copy/paste the content of the Notepad into your next reply.
    • RKreport.txt could also be found on your desktop.
    • If more than one log is produced post all logs.
    • If RogueKiller has been blocked, do not hesitate to try a few times more. If really won't run, rename it to winlogon.exe (or winlogon.com) and try again
    [​IMG] Create new restore point before proceeding with the next step....
    How to: http://www.smartestcomputing.us.com/topic/63983-how-to-create-new-restore-point-all-windows/
    Download Malwarebytes Anti-Rootkit (MBAR) from HERE
    • Unzip downloaded file.
    • Open the folder where the contents were unzipped and run mbar.exe
    • Follow the instructions in the wizard to update and allow the program to scan your computer for threats.
    • Click on the Cleanup button to remove any threats and reboot if prompted to do so.
    • Wait while the system shuts down and the cleanup process is performed.
    • Perform another scan with Malwarebytes Anti-Rootkit to verify that no threats remain. If they do, then click Cleanup once more and repeat the process.
    • When done, please post the two logs produced they will be in the MBAR folder..... mbar-log-xxxxx.txt and system-log.txt
  6. 2014/05/15
    wildfire
    Rogue Killer Report
    RogueKiller V8.8.15 [Mar 27 2014] by Adlice Software
    mail : http://www.adlice.com/contact/
    Feedback : http://forum.adlice.com
    Website : http://www.adlice.com/softwares/roguekiller/
    Blog : http://www.adlice.com
    Operating System : Windows 8.1 (6.3.9200 ) 64 bits version
    Started in : Normal mode
    User : wildfire [Admin rights]
    Mode : Remove -- Date : 05/15/2014 06:49:16
    | ARK || FAK || MBR |
    ¤¤¤ Bad processes : 4 ¤¤¤
    [SUSP PATH] internetHelper_antiphishing.exe -- C:\ProgramData\Internet Helper Anti-phishing\internetHelper_antiphishing.exe [7] -> KILLED [TermProc]
    [SUSP PATH] mbamscheduler.exe -- C:\Users\wildfire\Desktop\Malwarebytes Anti-Malware\mbamscheduler.exe [7] -> KILLED [TermProc]
    [SUSP PATH] mbam.exe -- C:\Users\wildfire\Desktop\Malwarebytes Anti-Malware\mbam.exe [7] -> KILLED [TermProc]
    [SUSP PATH] mbamservice.exe -- C:\Users\wildfire\Desktop\Malwarebytes Anti-Malware\mbamservice.exe [7] -> KILLED [TermProc]
    ¤¤¤ Registry Entries : 3 ¤¤¤
    [RUN][SUSP PATH] HKLM\[...]\Wow6432Node\[...]\Run : Internet Helper Anti-phishing ( "C:\ProgramData\Internet Helper Anti-phishing\internetHelper_antiphishing.exe" [7]) -> DELETED
    [HJ DESK][PUM] HKLM\[...]\NewStartPanel : {59031a47-3f72-44a7-89c5-5595fe6b30ee} (1) -> REPLACED (0)
    [HJ DESK][PUM] HKLM\[...]\NewStartPanel : {20D04FE0-3AEA-1069-A2D8-08002B30309D} (1) -> REPLACED (0)
    ¤¤¤ Scheduled tasks : 0 ¤¤¤
    ¤¤¤ Startup Entries : 0 ¤¤¤
    ¤¤¤ Web browsers : 0 ¤¤¤
    ¤¤¤ Browser Addons : 0 ¤¤¤
    ¤¤¤ Particular Files / Folders: ¤¤¤
    ¤¤¤ Driver : [NOT LOADED 0x0] ¤¤¤
    ¤¤¤ External Hives: ¤¤¤
    ¤¤¤ Infection : ¤¤¤
    ¤¤¤ HOSTS File: ¤¤¤
    --> %SystemRoot%\System32\drivers\etc\hosts
    ¤¤¤ MBR Check: ¤¤¤
    +++++ PhysicalDrive0: (\\.\PHYSICALDRIVE0 @ IDE) ST1000LM024 HN-M SATA Disk Device +++++
    --- User ---
    [MBR] 1504d674c6b2dddf5ae31bd94d063999
    [BSP] f21676c9aaf6833f61d6cc5f5b227a91 : Empty MBR Code
    Partition table:
    0 - [XXXXXX] UNKNOWN (0x00) [VISIBLE] Offset (sectors): 1 | Size: 953869 MB
    User = LL1 ... OK!
    User = LL2 ... OK!
    Finished : << RKreport[0]_D_05152014_064916.txt >>
    RKreport[0]_S_05152014_064826.txt
  7. 2014/05/15
    wildfire
    MBAR Log
    Malwarebytes Anti-Rootkit BETA 1.07.0.1009
    Database version: v2014.05.14.11
    Windows 8 x64 NTFS
    Internet Explorer 11.0.9600.17105
    wildfire :: HP_LAPTOP [administrator]
    15/05/2014 06:55:45
    mbar-log-2014-05-15 (06-55-45).txt
    Scan type: Quick scan
    Scan options enabled: Anti-Rootkit | Drivers | MBR | Physical Sectors | Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken
    Scan options disabled:
    Objects scanned: 279308
    Time elapsed: 18 minute(s), 34 second(s)
    Memory Processes Detected: 0
    Memory Modules Detected: 0
    Registry Keys Detected: 0
    Registry Values Detected: 0
    Registry Data Items Detected: 0
    Folders Detected: 0
    Files Detected: 0
    Physical Sectors Detected: 0
    (end)
  8. 2014/05/15
    wildfire
    MBAR System Log
    (c) Malwarebytes Corporation 2011-2012
    OS version: 6.2.9200 Windows 8 x64
    Account is Administrative
    Internet Explorer version: 11.0.9600.17105
    File system is: NTFS
    Disk drives: C:\ DRIVE_FIXED, D:\ DRIVE_FIXED
    CPU speed: 1.697000 GHz
    Memory total: 8156106752, free: 6464598016
    Memory total: 8156106752, free: 6478680064
    Downloaded database version: v2014.05.14.11
    Downloaded database version: v2014.03.27.01
    Initializing...
    Done!
    Scanning drivers directory: C:\WINDOWS\SYSTEM32\drivers...
    Done!
    Drive 0
    Scanning MBR on drive 0...
    Inspecting partition table:
    This drive is a GPT Drive.
    MBR Signature: 55AA
    Disk Signature: 1E28E0A4
    GPT Protective MBR Partition information:
    Partition 0 type is EFI-GPT (0xee)
    Partition is NOT ACTIVE.
    Partition starts at LBA: 1 Numsec = 1953525167
    Partition 1 type is Empty (0x0)
    Partition starts at LBA: 0 Numsec = 0
    Partition 2 type is Empty (0x0)
    Partition 3 type is Empty (0x0)
    GPT Partition information:
    GPT Header Signature 4546492050415254
    GPT Header Revision 65536 Size 92 CRC 597156104
    GPT Header CurrentLba = 1 BackupLba 1953525167
    GPT Header FirstUsableLba 34 LastUsableLba 1953525134
    GPT Header Guid 71819f05-2a69-43b4-a7b9-95b9d8cb5d5
    GPT Header Contains 128 partition entries starting at LBA 2
    GPT Header Partition entry size = 128
    Backup GPT header Signature 4546492050415254
    Backup GPT header Revision 65536 Size 92 CRC 597156104
    Backup GPT header CurrentLba = 1953525167 BackupLba 1
    Backup GPT header FirstUsableLba 34 LastUsableLba 1953525134
    Backup GPT header Guid 71819f05-2a69-43b4-a7b9-95b9d8cb5d5
    Backup GPT header Contains 128 partition entries starting at LBA 1953525135
    Backup GPT header Partition entry size = 128
    Partition 0 Type de94bba4-6d1-4d40-a16a-bfd5179d6ac
    Partition ID bfbb4528-f4e9-4e3b-8fd9-85dcd4a6d4e7
    FirstLBA 2048 Last LBA 821247
    Attributes 1
    Partition Name Basic data partition
    Partition 1 Type c12a7328-f81f-11d2-ba4b-0a0c93ec93b
    Partition ID 319f0fc2-df2-44ba-a3b1-5ec092f5cabd
    FirstLBA 821248 Last LBA 1353727
    Attributes 0
    Partition Name EFI system partition
    GPT Partition 1 is bootable
    Partition 2 Type e3c9e316-b5c-4db8-817d-f92df0215ae
    Partition ID 8aa643ee-3257-4a1a-a516-977a5401b42
    FirstLBA 1353728 Last LBA 1615871
    Attributes 0
    Partition Name Microsoft reserved partition
    Partition 3 Type ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
    Partition ID a0f6c43d-6cf-4d77-a8bb-8ef1f7187aa6
    FirstLBA 1615872 Last LBA 1911212031
    Attributes 0
    Partition 4 Type de94bba4-6d1-4d40-a16a-bfd5179d6ac
    Partition ID 575f3842-b7a8-47c3-ab7c-94108ac546e5
    FirstLBA 1911212032 Last LBA 1912006655
    Attributes 1
    Partition Name
    Partition 5 Type ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
    Partition ID 790914c-b6e4-4c5d-b347-2653655a4870
    FirstLBA 1912006656 Last LBA 1953523711
    Attributes 1
    Disk Size: 1000204886016 bytes
    Sector size: 512 bytes
    Done!
    Scan finished
    Removal queue found; removal started
    Removing C:\ProgramData\Malwarebytes' Anti-Malware (portable)\MBR-0-i.mbam...
    Removing C:\ProgramData\Malwarebytes' Anti-Malware (portable)\MBR-0-r.mbam...
    Removal finished
  9. 2014/05/15
    wildfire
    Update, I haven't had any re-directions for a couple of hours, but will continue the cleaning process just to make sure.
  10. 2014/05/15
    Good :)
    Please download ComboFix from Here, Here or Here to your Desktop.
    **Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**
    • Never rename Combofix unless instructed.
    • Close any open browsers.
    • Very Important! Temporarily disable your anti-virus and any anti-malware real-time protection before performing a scan. They can interfere with ComboFix or remove some of its embedded files which may cause "unpredictable results ".
    • Click on this link to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
    • WARNING: Combofix will disconnect your machine from the Internet as soon as it starts
      If the connection is not there use restore point you created prior to running Combofix.
    • Double click on combofix.exe & follow the prompts.
    • NOTE1. If Combofix asks you to install Recovery Console, please allow it.
    • When finished, it will produce a report for you.
    • Please post the "C:\ComboFix.txt"
    **Note 1: Do not mouseclick combofix's window while it's running. That may cause it to stall
    **Note 2 for AVG and CA Internet Security (Total Defense Internet Security) users: ComboFix will not run until AVG/CA Internet Security is uninstalled as a protective measure against the anti-virus. This is because AVG/CA Internet Security "falsely" detects ComboFix (or its embedded files) as a threat and may remove them resulting in the tool not working correctly which in turn can cause "unpredictable results ". Since AVG/CA Internet Security cannot be effectively disabled before running ComboFix, the author recommends you to uninstall AVG/CA Internet Security first.
    Use AppRemover to uninstall it: http://www.appremover.com/
    We can reinstall it when we're done with CF.
    **Note 3: If you receive an error Illegal operation attempted on a registery key that has been marked for deletion, restart computer to fix the issue.
    **Note 4: Some infections may take some significant time to be cured. As long as your computer clock is running Combofix is still working. Be patient.
    NOTE.
    If, for some reason, Combofix refuses to run, try the following...
    Delete Combofix file, download fresh one, but rename combofix.exe to your_name.exe BEFORE saving it to your desktop.
    Do NOT run it yet.
    Download Rkill (courtesy of BleepingComputer.com) to your desktop.
    There are 2 different versions. If one of them won't run then download and try to run the other one.
    You only need to get one of these to run, not all of them. You may get warnings from your antivirus about this tool, ignore them or shutdown your antivirus.
    rKill.exe: http://www.bleepingcomputer.com/download/rkill/dl/10/
    iExplore.exe (renamed rKill.exe): http://www.bleepingcomputer.com/download/rkill/dl/11/
    Restart computer in safe mode
    • Double-click on the Rkill desktop icon to run the tool.
    • If using Vista or Windows 7 right-click on it and choose Run As Administrator.
    • A black DOS box will briefly flash and then disappear. This is normal and indicates the tool ran successfully.
    • If not, delete the file, then download and use the one provided in Link 2.
    • Do not reboot until instructed.
    • If the tool does not run from any of the links provided, please let me know.
    When the scan is done Notepad will open with rKill.txt log.
    NOTE. rKill.txt log will also be present on your desktop.
    Once you've gotten one of them to run, immediately run your_name.exe by double clicking on it.
    IF you had to run rKill post BOTH logs, rKill.txt and Combofix.txt.
  11. 2014/05/16
    wildfire
    Hi Broni,
    I'm Kinda busy right now (UTD are in a cup final tomorrow :)).
    I'll run combofix on Sunday and post results, thanks for your help so far.
    EDIT: No more redirections since I last posted.
  12. 2014/05/16
    wildfire
    Hi Broni, real life has taken over for the moment (not to mention we lost the cup final :().
    Please keep this thread open and I'll post combofix logs as soon as. For now everything seems to be fine.
    Thanks for your help so far.
  14. 2014/05/20
    wildfire
    Evening Broni. I dropped laptop earlier. HD is FUBAR :-(.
    I'm going to restore lappy to factory settings once I buy new harddrive on Tuesday. Looking forward to a few hours of windows updates. :-$
    Anyway for now please mark this thread as solved and thanks for your help.
  16. 2014/05/25
    Thanks for letting me know :)
