Solved trojan dropper gen infection
Discussion in 'Malware and Virus Removal Archive' started by bchirpy, 2010/04/04.
  1. 2010/04/09
    bchirpy
    bchirpy Inactive Thread Starter
    KASPERSKY ONLINE SCANNER 7.0: scan report
    Friday, April 9, 2010
    Operating system: Microsoft Windows XP Home Edition Service Pack 3 (build 2600)
    Kaspersky Online Scanner version: 7.0.26.13
    Last database update: Thursday, April 08, 2010 17:27:19
    Records in database: 3923499
    Scan settings:
    scan using the following database: extended
    Scan archives: yes
    Scan e-mail databases: yes
    Scan area - My Computer:
    A:\
    C:\
    D:\
    E:\
    Scan statistics:
    Objects scanned: 119666
    Threats found: 2
    Infected objects found: 1
    Suspicious objects found: 1
    Scan duration: 05:49:33
    File name / Threat / Threats count
    C:\Qoobox\Quarantine\C\WINDOWS\system32\drivers\_qowdk_.sys.zip Infected: Rootkit.Win32.Agent.bert 1
    C:\_OTL\MovedFiles\04052010_092218\C_Documents and Settings\Deb\Local Settings\Application Data\Identities\{6014D3D0-EF9B-4CC9-831A-CD589A809834}\Microsoft\Outlook Express\Deleted Items.dbx Suspicious: Trojan-Spy.HTML.Fraud.gen 1
    Selected area has been scanned.
  2. 2010/04/09
    crunchie
    crunchie Inactive
    Both of those found are quarantined and will be removed when we get rid of OTL.
    If the computer seems fine, let me know and we will go through the next procedure.
    bchirpy
    Things seem good with the comp right now - rescanned with mbam and all clear at last :O) - could you also advise should i wait until we have removed otl before turning restore points back on?
  5. 2010/04/09
    crunchie
    crunchie Inactive
    Will sort the restore points now :).
    Run OTL
      :Commands
      [emptytemp]
      [CLEARALLRESTOREPOINTS]
      [Reboot]
    • Then click the [color= "#FF0000"]Run Fix[/color] button at the top.
    • Let the program run unhindered, reboot the PC when it is done.
    • Post log from this run.
    • Open OTL again and click the Quick Scan button. Post the log it produces in your next reply.
  6. 2010/04/09
    bchirpy
    All processes killed
    [EMPTYTEMP]
    User: Administrator
    User: Administrator.DEBBIE
    User: Administrator.DEBBIE.000
    User: All Users
    User: Deb
    ->Temp folder emptied: 145760917 bytes
    ->Temporary Internet Files folder emptied: 250414352 bytes
    ->Java cache emptied: 128094 bytes
    ->Apple Safari cache emptied: 0 bytes
    ->Flash cache emptied: 4908 bytes
    User: Default User
    User: HelpAssistant
    User: LocalService
    ->Temp folder emptied: 65748 bytes
    ->Temporary Internet Files folder emptied: 32902 bytes
    User: NetworkService
    ->Temp folder emptied: 66016 bytes
    Windows Temp folder emptied: 587 bytes
    RecycleBin emptied: 104 bytes
    Total Files Cleaned = 378.00 mb
    Restore points cleared and new OTL Restore Point set!
    OTL by OldTimer - Version 3.2.1.0 log created on 04092010_115423
    File\Folder C:\Documents and Settings\Deb\Local Settings\Temp\hsperfdata_Deb\196 not found!
    File\Folder C:\Documents and Settings\Deb\Local Settings\Temp\hsperfdata_Deb\2904 not found!
    File\Folder C:\Documents and Settings\Deb\Local Settings\Temp\fla12C.tmp not found!
    File\Folder C:\Documents and Settings\Deb\Local Settings\Temp\fla12F.tmp not found!
    File\Folder C:\Documents and Settings\Deb\Local Settings\Temp\fla130.tmp not found!
    File\Folder C:\Documents and Settings\Deb\Local Settings\Temp\fla132.tmp not found!
    C:\Documents and Settings\Deb\Local Settings\Temporary Internet Files\Content.IE5\SC03NKMO\sh15[1].html moved successfully.
    C:\Documents and Settings\Deb\Local Settings\Temporary Internet Files\Content.IE5\PNLRVU3E\the-body-shop[1].htm moved successfully.
    C:\Documents and Settings\Deb\Local Settings\Temporary Internet Files\Content.IE5\HJZKJMP1\eBayISAPI[1].htm moved successfully.
    C:\Documents and Settings\Deb\Local Settings\Temporary Internet Files\Content.IE5\HJZKJMP1\new[2].htm moved successfully.
    C:\Documents and Settings\Deb\Local Settings\Temporary Internet Files\Content.IE5\3LQA9TVT\92260-active-trojan-dropper-gen-infection-5[1].html moved successfully.
    C:\Documents and Settings\Deb\Local Settings\Temporary Internet Files\Content.IE5\3LQA9TVT\cSell_Mar05;seg=GL_ActSucBid30D_Mar05;seg=GL_Sellers_Listed_within12mont;sz=728x90;ord=1270804228104;dcopt=ist;tile=1;um=6;us=12;eb_trk=145806;pr=22;xp=29;np=22[1].htm moved successfully.
    C:\Documents and Settings\Deb\Local Settings\Temporary Internet Files\Content.IE5\3DLG15QB\728x90%3Bord%3D1270804228104%3Bdcopt%3Dist%3Btile%3D1%3Bum%3D6%3Bus%3D12%3Beb_trk%3D145806%3Bpr%3D22%3Bxp%3D29%3Bnp%3D22,;mtfIFrameRequest=false;ord=1270804235[1].htm moved successfully.
    C:\Documents and Settings\Deb\Local Settings\Temporary Internet Files\Content.IE5\3DLG15QB\iframe3[1].htm moved successfully.
    C:\Documents and Settings\Deb\Local Settings\Temporary Internet Files\Content.IE5\3DLG15QB\myebaysummary;sz=160x600;ord=1270804228104;tile=2;um=6;us=12;eb_trk=138772;pr=22;xp=29;np=22[1].htm moved successfully.
    C:\Documents and Settings\Deb\Local Settings\Temporary Internet Files\AntiPhishing\2CEDBFBC-DBA8-43AA-B1FD-CC8E6316E3E2.dat moved successfully.
  7. 2010/04/09
    crunchie
    crunchie Inactive
    Last thing to do as follows;
    Launch OTL and click on the Cleanup button. Follow the prompts.
    This should cleanup OTL and the folders it created, along with Combofix etc.
    Hopefully that should sort you out. If this returns, try and remember exactly what you were doing and where you doing it :).
  8. 2010/04/09
    bchirpy
    Thanks so much Crunchie its been a steep learning curve - your a star! :O)
  9. 2010/04/09
    crunchie
    crunchie Inactive
    No worries :). Stay clean.
  10. 2010/04/09
    bchirpy
    I hope so - makes me feel like the great unwashed!! I actually think this was from facebook on one of the apps!!
  11. 2010/04/09
    crunchie
    crunchie Inactive
    That would not surprise me.
