Trojan Adclicker shutting down pc!
Discussion in 'Malware and Virus Removal Archive' started by Dion, 2008/07/22.
  1. 2008/07/31
    Dion
    Dion Inactive Thread Starter
    Combo Fix would not run! Bright Blue screen before Window setup screen
    Hi again, tried running CF after copying the file code and it would not react! Deleted it and recopied, still didnt do anything. I also noticed that after the CTL ALT DEL and Passwd required for Windows to start a bright blue screen shows up and then it goes into the setting your personal... screen. Am i doing something wrong? Im still trying to run CF.
  2. 2008/07/31
    Dion
    None of the removal programs are working!
    Neither Combo Fix, DSS or HJT are responding. I looked at the registry and it shows default-value not set the braviax in the HKey current user run folder plus three other prog I know- HPupdater, money and adobe. Should I shut down the PC else something else keeps going bad? Oh pls I cant loose my data!
    Geri Lifetime Subscription
    Geri Inactive Alumni
    Hi
    OK this may have been my fault, did not notice the code box didn't work.
    They this code box.
    File::
    C:\Documents and Settings\All Users\Start Menu\Programs\Startup\wlnd.exe
    Geri
  5. 2008/07/31
    Dion
    Nothing runs
    Tks, since I saw braviax in registry again I added the line to the previous cfscript and threw it in CF and run but still no reaction. I also noticed in CF prperties security tab that it has two admin users one with an s at the end the other singular. Is that right?
  6. 2008/07/31
    Hi Dion
    Ok lets do this again, just to make sure things are as they should be.
    Do this first.
    Click Start>Run in the run box copy and paste or type ComboFix /u then hit Enter to uninstall ComboFix and remove the files/folders it created. This action will also reset the System Restore points, removing the infected files there as well.
    Now download this one and do the CFScript.
    Download ComboFix from Here to your Desktop.
    File::
    If you need to, do it in safe mode. Post the log if you get one. and a new dss log.
    Geri
  7. 2008/08/01
    Dion
    Combofix did not run, manually deleted file, ran MBAM
    Tks for wkg with me.... I see no movement in safe mode, combo did not react
    so I deleted Wlnd fm the directory, deleted braviax fm registry in order to start normal and try again. There i tried unistall combofix, again no movement... But loaded new CF and script and nothing happened. I then ran MBAM, also norton alerts show corrupt or ? need to reinstall... I'll run DSS afterwards and post both logs when they're done. Could I post a screen print? The big red x is again on the clock bar and bubble says Window detects antispyware infection. I'll be back.
  8. 2008/08/01
    Dion
    Here is MBAM log!
    Wow! MBAM found lots of things! How could it get more since I have not gone on the internet? I've avoided it just to keep anymore off! Scary.
    Here is the log: DSS would not run.
    Malwarebytes' Anti-Malware 1.22
    Database version: 982
    Windows 5.0.2195 Service Pack 3
    4:52:15 PM 8/1/2008
    mbam-log-8-1-2008 (16-51-42).txt
    Scan type: Full Scan (C:\|)
    Objects scanned: 83648
    Time elapsed: 42 minute(s), 40 second(s)
    Memory Processes Infected: 0
    Memory Modules Infected: 0
    Registry Keys Infected: 0
    Registry Values Infected: 0
    Registry Data Items Infected: 1
    Folders Infected: 0
    Files Infected: 8
    (No malicious items detected)
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows\AppInit_DLLs (Trojan.FakeAlert) -> Data: c:\winnt\system32\cru629.dat -> No action taken.
    Folders Infected:
    Files Infected:
    C:\WINNT\cru629.dat (Trojan.FakeAlert) -> No action taken.
    C:\WINNT\SYSTEM32\cru629.dat (Trojan.FakeAlert) -> No action taken.
    C:\Documents and Settings\Administrator\delself.bat (Malware.Trace) -> No action taken.
    C:\WINNT\SYSTEM32\DRIVERS\beep.sys (Fake.Beep.Sys) -> No action taken.
    C:\WINNT\SYSTEM32\DLLCACHE\beep.sys (Fake.Beep.Sys) -> No action taken.
    C:\WINNT\SYSTEM32\univrs32.dat (Trojan.Agent) -> No action taken.
    C:\WINNT\braviax.exe (Trojan.Downloader) -> No action taken.
    C:\WINNT\SYSTEM32\braviax.exe (Trojan.FakeAlert) -> No action taken.
    I rebooted and Norton is there now! It said it removed trojan perfcoo yet it keeps coming up with the alert over and over. DSS is now running!
  9. 2008/08/01
    Dion
    DSS Log
    Deckard's System Scanner v20071014.68
    Run by Administrator on 2008-08-01 17:06:40
    Computer is in Normal Mode.
    -- HijackThis (run as Administrator.exe) ---------------------------------------
    Scan saved at 5:09:55 PM, on 8/1/2008
    Platform: Windows 2000 SP3 (WinNT 5.00.2195)
    MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
    C:\WINNT\System32\smss.exe
    C:\WINNT\system32\winlogon.exe
    C:\WINNT\system32\services.exe
    C:\WINNT\system32\lsass.exe
    C:\WINNT\System32\SCardSvr.exe
    C:\WINNT\System32\S24EvMon.exe
    C:\WINNT\System32\wltrysvc.exe
    C:\WINNT\System32\bcmwltry.exe
    C:\WINNT\system32\svchost.exe
    C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
    C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
    C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
    C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
    C:\WINNT\system32\LEXBCES.EXE
    C:\WINNT\system32\spoolsv.exe
    C:\WINNT\system32\LEXPPS.EXE
    C:\WINNT\System32\Ati2evxx.exe
    C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
    C:\WINNT\system32\basfipm.exe
    C:\WINNT\System32\drivers\CDAC11BA.EXE
    C:\WINNT\System32\svchost.exe
    C:\WINNT\System32\RegSrvc.exe
    C:\WINNT\system32\regsvc.exe
    C:\WINNT\System32\RoamMgr.exe
    C:\WINNT\system32\stisvc.exe
    C:\WINNT\System32\WBEM\WinMgmt.exe
    C:\WINNT\system32\mspmspsv.exe
    C:\WINNT\system32\faxsvc.exe
    C:\Program Files\Intel\Switching\User\RoamSvc.exe
    C:\WINNT\system32\ZCfgSvc.exe
    C:\WINNT\Explorer.EXE
    C:\Program Files\Apoint\Apoint.exe
    C:\WINNT\system32\carpserv.exe
    C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
    C:\WINNT\system32\PRPCUI.exe
    C:\WINNT\System32\DSentry.exe
    C:\Program Files\Common Files\Adaptec Shared\CreateCD\CreateCD50.exe
    C:\Program Files\Roxio\Easy CD Creator 5\DirectCD\DirectCD.exe
    C:\WINNT\System32\spool\DRIVERS\W32X86\3\CMPDPSRV.EXE
    C:\WINNT\system32\spool\drivers\w32x86\3\hpztsb07.exe
    C:\Program Files\HP\hpcoretech\hpcmpmgr.exe
    C:\WINNT\system32\hphmon06.exe
    C:\Program Files\Hewlett-Packard\HP Software Update\HPWuSchd2.exe
    C:\Program Files\Dell\QuickSet\Quickset.exe
    C:\Program Files\Microsoft Money\System\reminder.exe
    C:\PROGRA~1\MI3AA1~1\wcescomm.exe
    C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe
    C:\Program Files\Apoint\Apntex.exe
    C:\Program Files\Digital Line Detect\DLG.exe
    C:\Program Files\Dynex Enhanced G Notebook Card Adapter\DynexWCUI.exe
    C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpqtra08.exe
    C:\PROGRA~1\MI3AA1~1\rapimgr.exe
    C:\Program Files\HP\hpcoretech\comp\hptskmgr.exe
    C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpqSTE08.exe
    C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpqgalry.exe
    C:\WINNT\system32\msiexec.exe
    C:\Program Files\Norton Internet Security\Norton AntiVirus\navapsvc.exe
    C:\Program Files\Common Files\Symantec Shared\Security Console\NSCSRVCE.EXE
    C:\Program Files\Common Files\Symantec Shared\NMain.exe
    C:\Documents and Settings\Administrator\Desktop\dss.exe
    C:\PROGRA~1\TRENDM~1\HIJACK~1\ADMINI~1.EXE
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://red.clientapps.yahoo.com/cus.../*http://www.yahoo.com/ext/search/search.html
    R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://red.clientapps.yahoo.com/customize/ie/defaults/su/ymsgr/*http://www.yahoo.com
    R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = 127.0.0.1
    R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
    O2 - BHO: &Yahoo! Toolbar Helper - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
    O3 - Toolbar: MSN - {BDAD1DAD-C946-4A17-ADC1-64B5B4FF55D0} - C:\Program Files\MSN Apps\MSN Toolbar\01.02.3000.1001\en-us\msntb.dll
    O3 - Toolbar: Norton Internet Security 2006 - {0B53EAC3-8D69-4b9e-9B19-A37C9A5676A7} - C:\Program Files\Common Files\Symantec Shared\AdBlocking\NISShExt.dll
    O3 - Toolbar: Norton AntiVirus - {C4069E3A-68F1-403E-B40E-20066696354B} - C:\Program Files\Norton Internet Security\Norton AntiVirus\NavShExt.dll
    O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
    O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINNT\system32\msdxm.ocx
    O4 - HKLM\..\Run: [Synchronization Manager] mobsync.exe /logon
    O4 - HKLM\..\Run: [Apoint] C:\Program Files\Apoint\Apoint.exe
    O4 - HKLM\..\Run: [ATIModeChange] Ati2mdxx.exe
    O4 - HKLM\..\Run: [CARPService] carpserv.exe
    O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
    O4 - HKLM\..\Run: [PRPCMonitor] PRPCUI.exe
    O4 - HKLM\..\Run: [PRONoMgr.exe] C:\Program Files\Intel\NCS\PROSet\PRONoMgr.exe
    O4 - HKLM\..\Run: [DVDSentry] C:\WINNT\System32\DSentry.exe
    O4 - HKLM\..\Run: [CreateCD50] "C:\Program Files\Common Files\Adaptec Shared\CreateCD\CreateCD50.exe" -r
    O4 - HKLM\..\Run: [AdaptecDirectCD] "C:\Program Files\Roxio\Easy CD Creator 5\DirectCD\DirectCD.exe "
    O4 - HKLM\..\Run: [CMPDPSRV] C:\WINNT\System32\spool\DRIVERS\W32X86\3\CMPDPSRV.EXE
    O4 - HKLM\..\Run: [msnappau] "C:\Program Files\MSN Apps\Updater\01.05.0000.1009\en-us\msnappau.exe "
    O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINNT\system32\spool\drivers\w32x86\3\hpztsb07.exe
    O4 - HKLM\..\Run: [HPHUPD06] C:\Program Files\Hewlett-Packard\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\hphupd06.exe
    O4 - HKLM\..\Run: [HP Component Manager] "C:\Program Files\HP\hpcoretech\hpcmpmgr.exe "
    O4 - HKLM\..\Run: [HPHmon06] C:\WINNT\system32\hphmon06.exe
    O4 - HKLM\..\Run: [SSC_UserPrompt] "C:\Program Files\Common Files\Symantec Shared\Security Center\UsrPrmpt.exe "
    O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\Hewlett-Packard\HP Software Update\HPWuSchd2.exe
    O4 - HKLM\..\Run: [Dell QuickSet] C:\Program Files\Dell\QuickSet\Quickset.exe
    O4 - HKCU\..\Run: [Reminder] C:\Program Files\Microsoft Money\System\reminder.exe
    O4 - HKCU\..\Run: [H/PC Connection Agent] "C:\PROGRA~1\MI3AA1~1\wcescomm.exe "
    O4 - HKCU\..\Run: [updateMgr] "C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe" AcRdB7_0_9
    O4 - HKUS\.DEFAULT\..\RunOnce: [^SetupICWDesktop] C:\Program Files\Internet Explorer\Connection Wizard\icwconn1.exe /desktop (User 'Default user')
    O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
    O4 - Global Startup: Digital Line Detect.lnk = C:\Program Files\Digital Line Detect\DLG.exe
    O4 - Global Startup: Dynex Wireless Networking Utility.lnk = C:\Program Files\Dynex Enhanced G Notebook Card Adapter\DynexWCUI.exe
    O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpqtra08.exe
    O4 - Global Startup: HP Image Zone Fast Start.lnk = C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpqthb08.exe
    O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office00\Office\OSA9.EXE
    O4 - Global Startup: QuickBooks Update Agent.lnk = C:\Program Files\Common Files\Intuit\QuickBooks\QBUpdate\qbupdate.exe
    O9 - Extra button: Create Mobile Favorite - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MI3AA1~1\INetRepl.dll
    O9 - Extra button: (no name) - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MI3AA1~1\INetRepl.dll
    O9 - Extra 'Tools' menuitem: Create Mobile Favorite... - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MI3AA1~1\INetRepl.dll
    O9 - Extra button: Messenger - {4528BBE0-4E08-11D5-AD55-00010333D0AD} - C:\Program Files\Yahoo!\Messenger\yhexbmes0411.dll
    O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {4528BBE0-4E08-11D5-AD55-00010333D0AD} - C:\Program Files\Yahoo!\Messenger\yhexbmes0411.dll
    O9 - Extra button: Related - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINNT\web\related.htm
    O9 - Extra 'Tools' menuitem: Show &Related Links - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINNT\web\related.htm
    O16 - DPF: {1F2F4C9E-6F09-47BC-970D-3C54734667FE} (LSSupCtl Class) - http://www.symantec.com/techsupp/asa/ctrl/LSSupCtl.cab
    O16 - DPF: {2917297F-F02B-4B9D-81DF-494B6333150B} (Minesweeper Flags Class) - http://messenger.zone.msn.com/binary/MineSweeper.cab
    O16 - DPF: {30528230-99F7-4BB4-88D8-FA1D4F56A2AB} (YInstStarter Class) - http://us.dl1.yimg.com/download.yahoo.com/dl/yinst/yinst_current.cab
    O16 - DPF: {3451DEDE-631F-421C-8127-FD793AFC6CC8} - https://www-secure.symantec.com/techsupp/asa/ctrl/SymAData.cab
    O16 - DPF: {44990200-3C9D-426D-81DF-AAB636FA4345} (Symantec SmartIssue) - https://www-secure.symantec.com/techsupp/asa/ctrl/tgctlsi.cab
    O16 - DPF: {44990301-3C9D-426D-81DF-AAB636FA4345} (Symantec Script Runner Class) - https://www-secure.symantec.com/techsupp/asa/ctrl/tgctlsr.cab
    O16 - DPF: {62475759-9E84-458E-A1AB-5D2C442ADFDE} - http://a1540.g.akamai.net/7/1540/52...pple.com/mickey/us/win/QuickTimeInstaller.exe
    O16 - DPF: {8E0D4DE5-3180-4024-A327-4DFAD1796A8D} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsClient.cab
    O16 - DPF: {A17E30C4-A9BA-11D4-8673-60DB54C10000} (YahooYMailTo Class) - http://us.dl1.yimg.com/download.yahoo.com/dl/installs/yse/ymmapi_416.dll
    O16 - DPF: {E7D2588A-7FB5-47DC-8830-832605661009} (Live Collaboration) - http://liveca12.custhelp.com/7530-b327h/rnl/java/RntX.cab
    O16 - DPF: {EF791A6B-FC12-4C68-99EF-FB9E207A39E6} (McFreeScan Class) - http://download.mcafee.com/molbin/iss-loc/vso/en-us/tools/mcfscan/1,5,0,4338/mcfscan.cab
    O20 - AppInit_DLLs: C:\WINNT\system32\cru629.dat
    O23 - Service: Ati HotKey Poller - Unknown owner - C:\WINNT\System32\Ati2evxx.exe
    O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
    O23 - Service: Broadcom ASF IP monitoring service v3.0.1 (BAsfIpM) - Broadcom Corp. - C:\WINNT\system32\basfipm.exe
    O23 - Service: C-DillaCdaC11BA - Macrovision - C:\WINNT\System32\drivers\CDAC11BA.EXE
    O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
    O23 - Service: Symantec Internet Security Password Validation (ccISPwdSvc) - Symantec Corporation - C:\Program Files\Norton Internet Security\ccPwdSvc.exe
    O23 - Service: Symantec Network Proxy (ccProxy) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
    O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
    O23 - Service: COM Host (comHost) - Symantec Corporation - C:\Program Files\Norton Internet Security\comHost.exe
    O23 - Service: Logical Disk Manager Administrative Service (dmadmin) - VERITAS Software Corp. - C:\WINNT\System32\dmadmin.exe
    O23 - Service: HP Port Resolver - Hewlett-Packard Company - C:\WINNT\system32\hpbpro.exe
    O23 - Service: HP Status Server - Hewlett-Packard Company - C:\WINNT\system32\hpboid.exe
    O23 - Service: Adapter Switching (IntelRoam) - Intel Corporation - C:\Program Files\Intel\Switching\User\RoamSvc.exe
    O23 - Service: LexBce Server (LexBceS) - Lexmark International, Inc. - C:\WINNT\system32\LEXBCES.EXE
    O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
    O23 - Service: Norton AntiVirus Auto-Protect Service (navapsvc) - Symantec Corporation - C:\Program Files\Norton Internet Security\Norton AntiVirus\navapsvc.exe
    O23 - Service: Intel NCS NetService (NetSvc) - Intel(R) Corporation - C:\Program Files\Intel\NCS\Sync\NetSvc.exe
    O23 - Service: Norton Protection Center Service (NSCService) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\Security Console\NSCSRVCE.EXE
    O23 - Service: Pml Driver HPZ12 - HP - C:\WINNT\System32\HPZipm12.exe
    O23 - Service: RegSrvc - Intel Corporation - C:\WINNT\System32\RegSrvc.exe
    O23 - Service: RoamMgr - Intel Corporation - C:\WINNT\System32\RoamMgr.exe
    O23 - Service: Spectrum24 Event Monitor (S24EventMonitor) - Intel Corporation - C:\WINNT\System32\S24EvMon.exe
    O23 - Service: Symantec AVScan (SAVScan) - Symantec Corporation - C:\Program Files\Norton Internet Security\Norton AntiVirus\SAVScan.exe
    O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
    O23 - Service: Symantec SPBBCSvc (SPBBCSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
    O23 - Service: Symantec Core LC - Unknown owner - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
    O23 - Service: Symantec RemoteAssist - Symantec, Inc. - C:\Program Files\Common Files\Symantec Shared\Support Controls\ssrc.exe
    O23 - Service: Broadcom Wireless LAN Tray Service (wltrysvc) - Unknown owner - C:\WINNT\System32\wltrysvc.exe
    O24 - Desktop Component 0: (no name) - http://bp2.blogger.com/_aLkNPLFRQYo/Rr1h9-oozHI/AAAAAAAAACY/ckU6letc8OU/s320/Theotokos.jpg
    End of file - 13322 bytes
    -- Files created between 2008-07-01 and 2008-08-01 -----------------------------
    2008-08-01 16:53:57 675372 ---h----- C:\WINNT\ShellIconCache
    2008-07-26 15:58:41 16384 --a-----t C:\WINNT\system32\Perflib_Perfdata_990.dat
    2008-07-26 15:57:32 68096 --a------ C:\WINNT\zip.exe
    2008-07-26 15:57:32 49152 --a------ C:\WINNT\VFind.exe
    2008-07-26 15:57:32 212480 --a------ C:\WINNT\swxcacls.exe <Not Verified; SteelWerX; SteelWerX Extended Configurator ACLists>
    2008-07-26 15:57:32 136704 --a------ C:\WINNT\swsc.exe <Not Verified; SteelWerX; SteelWerX Service Controller>
    2008-07-26 15:57:32 161792 --a------ C:\WINNT\swreg.exe <Not Verified; SteelWerX; SteelWerX Registry Editor>
    2008-07-26 15:57:32 98816 --a------ C:\WINNT\sed.exe
    2008-07-26 15:57:32 80412 --a------ C:\WINNT\grep.exe
    2008-07-26 15:57:32 89504 --a------ C:\WINNT\fdsv.exe <Not Verified; Smallfrogs Studio; >
    2008-07-23 05:40:44 16384 --a-----t C:\WINNT\system32\Perflib_Perfdata_9cc.dat
    2008-07-23 04:53:32 0 d-------- C:\Program Files\Trend Micro
    2008-07-23 04:23:39 0 d-------- C:\Documents and Settings\Administrator\Application Data\Malwarebytes
    2008-07-23 04:23:31 0 d-------- C:\Documents and Settings\All Users\Application Data\Malwarebytes
    2008-07-23 04:23:28 0 d-------- C:\Program Files\Malwarebytes' Anti-Malware
    2008-07-22 18:19:50 0 d-------- C:\WINNT\LMI48F.tmp
    2008-07-22 18:19:41 0 d-------- C:\WINNT\LMI48E.tmp
    -- Find3M Report ---------------------------------------------------------------
    2008-08-01 17:11:19 6144 --a------ C:\WINNT\system32\cru629.dat
    2008-08-01 17:00:32 0 d-------- C:\Documents and Settings\Administrator\Application Data\AdobeUM
    2008-07-30 04:07:51 0 d-a------ C:\Program Files\Common Files
    2008-07-23 04:25:35 0 d-------- C:\Program Files\Common Files\Symantec Shared
    2008-07-19 20:21:18 0 d-------- C:\Program Files\Norton Internet Security
    2008-06-25 06:49:33 0 d-------- C:\Program Files\Intuit
    2008-06-02 20:38:06 0 d-------- C:\Program Files\Symantec
    -- Registry Dump ---------------------------------------------------------------
    "Synchronization Manager "= "mobsync.exe" [07/24/02 01:00p C:\WINNT\SYSTEM32\MOBSYNC.EXE]
    "Apoint "= "C:\Program Files\Apoint\Apoint.exe" [08/23/02 02:28a]
    "ATIModeChange "= "Ati2mdxx.exe" [09/04/01 11:24p C:\WINNT\SYSTEM32\Ati2mdxx.exe]
    "CARPService "= "carpserv.exe" [01/23/03 10:06p C:\WINNT\SYSTEM32\carpserv.exe]
    "ATIPTA "= "C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe" [01/04/03 12:00a]
    "PRPCMonitor "= "PRPCUI.exe" [10/07/02 10:00a C:\WINNT\SYSTEM32\prpcui.exe]
    "PRONoMgr.exe "= "C:\Program Files\Intel\NCS\PROSet\PRONoMgr.exe" [12/18/02 09:20p]
    "DVDSentry "= "C:\WINNT\System32\DSentry.exe" [07/17/02 05:18p]
    "CreateCD50 "= "C:\Program Files\Common Files\Adaptec Shared\CreateCD\CreateCD50.exe" [12/17/02 08:14p]
    "AdaptecDirectCD "= "C:\Program Files\Roxio\Easy CD Creator 5\DirectCD\DirectCD.exe" [12/17/02 07:28p]
    "CMPDPSRV "= "C:\WINNT\System32\spool\DRIVERS\W32X86\3\CMPDPSRV.EXE" [10/31/01 01:25p]
    "QuickTime Task "= "C:\Program Files\QuickTime\qttask.exe" [01/05/04 11:47p]
    "msnappau "= "C:\Program Files\MSN Apps\Updater\01.05.0000.1009\en-us\msnappau.exe" [06/09/05 02:56p]
    "HPDJ Taskbar Utility "= "C:\WINNT\system32\spool\drivers\w32x86\3\hpztsb07.exe" [11/03/02 05:56p]
    "HPHUPD06 "= "C:\Program Files\Hewlett-Packard\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\hphupd06.exe" [06/06/04 11:53p]
    "HP Component Manager "= "C:\Program Files\HP\hpcoretech\hpcmpmgr.exe" [05/12/04 03:18p]
    "HPHmon06 "= "C:\WINNT\system32\hphmon06.exe" [06/06/04 11:42p]
    "ccApp "= "C:\Program Files\Common Files\Symantec Shared\ccApp.exe" [02/11/08 05:22p]
    "SSC_UserPrompt "= "C:\Program Files\Common Files\Symantec Shared\Security Center\UsrPrmpt.exe" [11/02/04 03:59p]
    "HP Software Update "= "C:\Program Files\Hewlett-Packard\HP Software Update\HPWuSchd2.exe" [12/15/05 11:18a]
    "Dell QuickSet "= "C:\Program Files\Dell\QuickSet\Quickset.exe" [12/18/02 03:16a]
    "Reminder "= "C:\Program Files\Microsoft Money\System\reminder.exe" [07/24/98 11:00p]
    "H/PC Connection Agent "= "C:\PROGRA~1\MI3AA1~1\wcescomm.exe" [04/22/05 07:19p]
    "updateMgr "= "C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe" [03/30/06 04:45p]
    [HKEY_USERS\.default\software\microsoft\windows\currentversion\runonce]
    "^SetupICWDesktop "=C:\Program Files\Internet Explorer\Connection Wizard\icwconn1.exe /desktop
    Adobe Reader Speed Launch.lnk - C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe [9/23/2005 10:05:26 PM]
    Digital Line Detect.lnk - C:\Program Files\Digital Line Detect\DLG.exe [8/11/2003 6:19:27 AM]
    Dynex Wireless Networking Utility.lnk - C:\Program Files\Dynex Enhanced G Notebook Card Adapter\DynexWCUI.exe [11/24/2007 3:32:49 AM]
    HP Digital Imaging Monitor.lnk - C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpqtra08.exe [12/15/2005 11:40:44 AM]
    HP Image Zone Fast Start.lnk - C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpqthb08.exe [5/28/2004 11:06:36 PM]
    Microsoft Office.lnk - C:\Program Files\Microsoft Office00\Office\OSA9.EXE [2/17/1999 3:05:56 PM]
    QuickBooks Update Agent.lnk - C:\Program Files\Common Files\Intuit\QuickBooks\QBUpdate\qbupdate.exe [10/2/2007 9:03:35 PM]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
    "DisableRegistryTools "=0 (0x0)
    "HideLegacyLogonScripts "=0 (0x0)
    "HideLogoffScripts "=0 (0x0)
    "RunLogonScriptSync "=1 (0x1)
    "RunStartupScriptSync "=0 (0x0)
    "HideStartupScripts "=0 (0x0)
    [HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\system]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\ActiveSync]
    WcesWlgn.dll 04/22/05 07:19p 7168 C:\WINNT\SYSTEM32\WcesWlgn.dll
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\Sebring]
    C:\WINNT\System32\LgNotify.dll 01/13/03 12:17a 110592 C:\WINNT\SYSTEM32\LgNotify.dll
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\windows]
    "appinit_dlls "=C:\WINNT\system32\cru629.dat
    [HKEY_LOCAL_MACHINE\system\currentcontrolset\control\securityproviders]
    SecurityProviders msapsspc.dll, schannel.dll, digest.dll, msnsspc.dll,
    Domestic Security Version 4.00
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\sglfb.sys]
    @= "Driver "
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\tga.sys]
    @= "Driver "
    -- End of Deckard's System Scanner: finished at 2008-08-01 17:14:46 ------------
    Ok getting closer! Let me know when I can go online and update and get a new virus protector!
  10. 2008/08/01
    Dion
    Trying to run ComboFix
    I rebooted and every program beeps the windows message screen such as: NIRCMD.com - bad image and the body says: The app or DLL C:\WNNT\system32\cru629.dat is not a valid windows image This pops up for every application that runs. Should I run combofix now? I dont see the entries the code box wanted to delete but Ill apply it anyways...
  11. 2008/08/01
    Dion
    Combo Fix Log
    When CF was shutting down the message registry maximum entry is too low, windows may not operate properly. Pop ups stopped now just one before the log saying that not all entries were written, some were left open? Cant recall exactly... At least it ran and no more red dot or alerts!! Tk u Tk u Tk u! Let me know when I could go online and update plus get better antivirus protection! ;):)
    Here is the log:
    ComboFix 08-07-31.06 - Administrator 08/01/2008 17:56:13.3 - NTFSx86
    Microsoft Windows 2000 Professional 5.0.2195.3.1252.1.1033.18.305 [GMT -5:00]
    Running from: C:\Documents and Settings\Administrator\Desktop\ComboFix.exe
    Command switches used :: C:\Documents and Settings\Administrator\Desktop\CFScript.txt
    WARNING -THIS MACHINE DOES NOT HAVE THE RECOVERY CONSOLE INSTALLED !!
    FILE ::
    C:\WINNT\LMI48E.tmp
    C:\WINNT\LMI48F.tmp
    C:\WINNT\system32\braviax.exe
    C:\WINNT\t\
    ((((((((((((((((((((((((( Files Created from 2008-07-01 to 2008-08-01 )))))))))))))))))))))))))))))))
    2008-08-01 16:53 . 08-08-01 17:30 676,046 ---h----- C:\WINNT\ShellIconCache
    2008-07-23 05:15 . 08-07-23 05:15 <DIR> d-------- C:\Deckard
    2008-07-23 04:53 . 08-07-23 04:53 <DIR> d-------- C:\Program Files\Trend Micro
    2008-07-23 04:23 . 08-07-23 04:23 <DIR> d-------- C:\Program Files\Malwarebytes' Anti-Malware
    2008-07-23 04:23 . 08-07-23 04:23 <DIR> d-------- C:\Documents and Settings\All Users\Application Data\Malwarebytes
    2008-07-23 04:23 . 08-07-23 04:23 <DIR> d-------- C:\Documents and Settings\Administrator\Application Data\Malwarebytes
    2008-07-23 04:23 . 08-07-20 20:21 38,472 --a------ C:\WINNT\SYSTEM32\DRIVERS\mbamswissarmy.sys
    2008-07-23 04:23 . 08-07-20 20:21 17,144 --a------ C:\WINNT\SYSTEM32\DRIVERS\mbam.sys
    2008-07-22 18:19 . 08-07-22 18:19 <DIR> d-------- C:\WINNT\LMI48F.tmp
    2008-07-22 18:19 . 08-07-22 18:20 <DIR> d-------- C:\WINNT\LMI48E.tmp
    2008-07-20 07:05 . 08-07-20 07:05 137 --a------ C:\WINNT\SYSTEM32\MRT.INI
    2008-08-01 23:08 --------- d-----w C:\Documents and Settings\Administrator\Application Data\AdobeUM
    2008-07-23 09:25 --------- d-----w C:\Program Files\Common Files\Symantec Shared
    2008-07-20 01:21 --------- d-----w C:\Program Files\Norton Internet Security
    2008-06-25 11:49 --------- d-----w C:\Program Files\Intuit
    2008-06-03 01:38 805 ----a-w C:\WINNT\system32\drivers\SYMEVENT.INF
    2008-06-03 01:38 123,952 ----a-w C:\WINNT\system32\drivers\SYMEVENT.SYS
    2008-06-03 01:38 10,671 ----a-w C:\WINNT\system32\drivers\SYMEVENT.CAT
    2008-06-03 01:38 --------- d-----w C:\Program Files\Symantec
    2006-06-20 21:55 45,511,639 ----a-w C:\Program Files\NIS06910IE.exe
    2006-03-30 23:05 0 ----a-w C:\Program Files\error.dat
    2005-11-10 23:15 3,932 ----a-w C:\Documents and Settings\Administrator\Application Data\CMLayout.dat
    2005-11-10 23:15 268 ----a-w C:\Documents and Settings\Administrator\Application Data\CMCPaper.dat
    2003-01-22 22:08 271 ---ha-w C:\Program Files\DESKTOP.INI
    2003-01-22 22:08 21,952 ---ha-w C:\Program Files\FOLDER.HTT
    2001-05-21 14:54 3,932 ------w C:\Documents and Settings\Default User\Application Data\CMLayout.dat
    ((((((((((((((((((((((((((((( snapshot@Sat 2008-07-26_16.03.06.98 )))))))))))))))))))))))))))))))))))))))))
    + 2005-10-21 01:02:28 163,328 ----a-w C:\WINNT\ERDNT\subs\ERDNT.EXE
    "Reminder "= "C:\Program Files\Microsoft Money\System\reminder.exe" [98-07-24 23:00 36352]
    "H/PC Connection Agent "= "C:\PROGRA~1\MI3AA1~1\wcescomm.exe" [05-04-22 19:19 1196032]
    "updateMgr "= "C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe" [06-03-30 16:45 313472]
    "Apoint "= "C:\Program Files\Apoint\Apoint.exe" [02-08-23 02:28 143360]
    "ATIPTA "= "C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe" [03-01-04 00:00 294912]
    "PRONoMgr.exe "= "C:\Program Files\Intel\NCS\PROSet\PRONoMgr.exe" [02-12-18 21:20 86016]
    "DVDSentry "= "C:\WINNT\System32\DSentry.exe" [02-07-17 17:18 28672]
    "CreateCD50 "= "C:\Program Files\Common Files\Adaptec Shared\CreateCD\CreateCD50.exe" [02-12-17 20:14 131157]
    "AdaptecDirectCD "= "C:\Program Files\Roxio\Easy CD Creator 5\DirectCD\DirectCD.exe" [02-12-17 19:28 684032]
    "CMPDPSRV "= "C:\WINNT\System32\spool\DRIVERS\W32X86\3\CMPDPSRV.EXE" [01-10-31 13:25 45056]
    "QuickTime Task "= "C:\Program Files\QuickTime\qttask.exe" [04-01-05 23:47 98304]
    "msnappau "= "C:\Program Files\MSN Apps\Updater\01.05.0000.1009\en-us\msnappau.exe" [05-06-09 14:56 219648]
    "HPDJ Taskbar Utility "= "C:\WINNT\system32\spool\drivers\w32x86\3\hpztsb07.exe" [02-11-03 17:56 188416]
    "HPHUPD06 "= "C:\Program Files\Hewlett-Packard\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\hphupd06.exe" [04-06-06 23:53 49152]
    "HP Component Manager "= "C:\Program Files\HP\hpcoretech\hpcmpmgr.exe" [04-05-12 15:18 241664]
    "HPHmon06 "= "C:\WINNT\system32\hphmon06.exe" [04-06-06 23:42 659456]
    "ccApp "= "C:\Program Files\Common Files\Symantec Shared\ccApp.exe" [08-02-11 17:22 53096]
    "SSC_UserPrompt "= "C:\Program Files\Common Files\Symantec Shared\Security Center\UsrPrmpt.exe" [04-11-02 15:59 218240]
    "HP Software Update "= "C:\Program Files\Hewlett-Packard\HP Software Update\HPWuSchd2.exe" [05-12-15 11:18 49152]
    "Dell QuickSet "= "C:\Program Files\Dell\QuickSet\Quickset.exe" [02-12-18 03:16 360448]
    "Synchronization Manager "= "mobsync.exe" [02-07-24 13:00 111376 C:\WINNT\SYSTEM32\MOBSYNC.EXE]
    "ATIModeChange "= "Ati2mdxx.exe" [01-09-04 23:24 28672 C:\WINNT\SYSTEM32\Ati2mdxx.exe]
    "CARPService "= "carpserv.exe" [03-01-23 22:06 4608 C:\WINNT\SYSTEM32\carpserv.exe]
    "PRPCMonitor "= "PRPCUI.exe" [02-10-07 10:00 45568 C:\WINNT\SYSTEM32\prpcui.exe]
    [HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\RunOnce]
    "^SetupICWDesktop "= "C:\Program Files\Internet Explorer\Connection Wizard\icwconn1.exe" [02-07-24 13:00 186640]
    Adobe Reader Speed Launch.lnk - C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe [2005-09-23 22:05:26 29696]
    Digital Line Detect.lnk - C:\Program Files\Digital Line Detect\DLG.exe [2003-08-11 06:19:27 24576]
    Dynex Wireless Networking Utility.lnk - C:\Program Files\Dynex Enhanced G Notebook Card Adapter\DynexWCUI.exe [2007-11-24 03:32:49 1454080]
    HP Digital Imaging Monitor.lnk - C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpqtra08.exe [2005-12-15 11:40:44 282624]
    HP Image Zone Fast Start.lnk - C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpqthb08.exe [2004-05-28 23:06:36 53248]
    Microsoft Office.lnk - C:\Program Files\Microsoft Office00\Office\OSA9.EXE [1999-02-17 15:05:56 65588]
    QuickBooks Update Agent.lnk - C:\Program Files\Common Files\Intuit\QuickBooks\QBUpdate\qbupdate.exe [2007-10-02 21:03:35 815104]
    03-01-13 00:17 110592 C:\WINNT\SYSTEM32\LgNotify.dll
    05-04-22 19:19 7168 C:\WINNT\SYSTEM32\WcesWlgn.dll
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\drivers32]
    "aux "= mmdrv.dll
    [HKEY_LOCAL_MACHINE\software\microsoft\security center]
    "AntiVirusDisableNotify "=dword:00000001
    "UpdatesDisableNotify "=dword:00000001
    R0 fasttrak;fasttrak;C:\WINNT\system32\DRIVERS\fasttrak.sys [03-01-22 16:52 ]
    R0 Fd16_700;Fd16_700;C:\WINNT\system32\DRIVERS\fd16_700.sys [99-09-25 18:11 ]
    R0 mraid2k;mraid2k;C:\WINNT\system32\DRIVERS\mraid2k.sys [03-01-22 16:52 ]
    R1 cdudf;cdudf;C:\WINNT\system32\drivers\cdudf.sys [02-12-17 19:29 ]
    R2 PRPC;PRPC;C:\WINNT\system32\drivers\PRPC.sys [02-10-07 10:00 ]
    R3 MIPMN;Intel Adapter Switching Driver;C:\WINNT\system32\DRIVERS\mipmn2k.sys [02-11-22 21:09 ]
    R3 usbhub20;USB Hub Support;C:\WINNT\system32\DRIVERS\usbhub20.sys [03-01-15 18:46 ]
    R3 w70n5;Intel(R) PRO/Wireless 7100 Adapter Driver;C:\WINNT\system32\DRIVERS\w70n5.sys [03-01-12 21:11 ]
    S3 BrSerIf;Brother MFC Serial Port Interface WDM Driver;C:\WINNT\system32\Drivers\BrSerIf.sys [04-06-12 00:27 ]
    S3 BrUsbSer;Brother MFC USB Serial WDM Driver;C:\WINNT\system32\Drivers\BrUsbSer.sys [04-01-09 23:28 ]
    S3 EL90BC;3Com EtherLink XL B/C Adapter Driver;C:\WINNT\system32\DRIVERS\el90xbc5.sys [99-10-23 19:22 ]
    S3 HPPLSBULK;HPPLSBULK;C:\WINNT\system32\drivers\hpplsbulk.sys [05-02-02 18:29 ]
    S3 PCASp50;PCASp50 NDIS Protocol Driver;C:\WINNT\system32\Drivers\PCASp50.sys []
    S3 usb_rndisy;USB RNDIS Adapter;C:\WINNT\system32\DRIVERS\usb8023y.sys [05-02-28 16:45 ]
    2008-05-19 C:\WINNT\Tasks\DFRG.job
    - C:\WINNT\SYSTEM32\DFRG.MSC [07-04-04 09:35 ]
    2008-07-02 C:\WINNT\Tasks\Studiopa 1094706297.job
    - C:\Program Files\Intuit\QuickBooks Pro\AutoBackupEXE.exe [07-10-02 20:00 ]
    catchme 0.3.1361 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
    Rootkit scan 2008-08-01 18:08:03
    Windows 5.0.2195 Service Pack 3 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    Completion time: 2008-08-01 18:16:44 - machine was rebooted [Administrator]
    ComboFix-quarantined-files.txt 2008-08-01 23:16:26
    ComboFix2.txt 2008-07-30 09:10:33
    ComboFix3.txt 2008-07-26 21:03:34
    Pre-Run: 26,989,099,520 bytes free
    Post-Run: 26,907,384,832 bytes free
    143 --- E O F --- 2008-07-20 12:07:44
  12. 2008/08/01
    Hi Dion
    OK go on-line and run MBAM again.
    It's important to make sure you check for updates before running the scan.
    Also, you did not let MBAM clean the infection, see here...
    Here are the instructions for MBAM.
    • Click the Update tab, then click Check for updates.
    • Once the program has updated click the scanner tab, select 'Perform Quick Scan', then click Scan.
    • The scan may take some time to finish,so please be patient.
    • When the scan is complete, click OK, then Show Results to view the results.
    • Make sure that everything is checked, and click Remove Selected.
    • When disinfection is completed, a log will open in Notepad and you may be prompted to Restart. (See Note below)
    • The log is automatically saved by MBAM and can be viewed by clicking the Logs tab in MBAM.
    • Post the entire report in your next reply along with a fresh HijackThis log.
    Please post the MBAM log.
    What anti-virus are you planning on going to?
    Make sure you let me know before you remove Norton, there is a removal tool you will need to use.
    Geri
  13. 2008/08/02
    Dion
    New MBAM, HJT log
    Hi Geri, thanks for your patience again. The PC had gone on night mode and when I put it on it came up from start up, I didn't know how to pull up the "fix" button again without rescanning and I so wanted to post the log! :eek: sorry. I just ran the updated quick scan and here is the MBAM, HJT logs:
  14. 2008/08/02
    Dion
    Cant open my thread! Has the page icon?
    I tried to post to my thread and couldnt! Could you pls combine or continue here! Merged
    These are the MBAM and HJT logs sent from Lovely PC now!:D
    Malwarebytes' Anti-Malware 1.24
    Database version: 1015
    7:12:13 AM 8/2/2008
    mbam-log-8-2-2008 (07-12-13).txt
    Scan type: Quick Scan
    Objects scanned: 36388
    Time elapsed: 5 minute(s), 56 second(s)
    Registry Keys Infected: 1
    Folders Infected: 0
    Files Infected: 0
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Ias (Trojan.Agent) -> Quarantined and deleted successfully.
    Folders Infected:
    Files Infected:
    7:12:13 AM 8/2/2008
    Folders Infected: 0
    Files Infected: 0
    Folders Infected:
    Files Infected:
    Scan saved at 7:12:42 AM, on 8/2/2008
    C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe
    C:\WINNT\system32\wuauclt.exe
    C:\WINNT\system32\NOTEPAD.EXE
    End of file - 13467 bytes
  15. 2008/08/02
    Dion
    New Antivirus
    Oh yes, Geri, I would like to go with AVGfree or if it better with pay I would go there too. I sure need to remove Norton. This last time it restarted it said my subscription expired and it locked up -big lock screen saying i must activate! and yet now its back on again. MBAM just found another trojan that it didnt alert. Need better protection now!! Pls advise
  16. 2008/08/02
    Hi Dion
    AVGFree is a good AV, I'm of the opinion that you get what you pay for. I buy eTrust AV and I have for a number of years, noahdfear also uses eTrust and we both recommend it if you are going to buy a AV.
    http://shop.ca.com/virus/antivirus.aspx
    Which ever one you go with you will need to run Norton removal tool before installing any other AV.
    Go here and run the Norton Removal Tool for the product version you have.
    http://service1.symantec.com/SUPPORT/tsgeninfo.nsf/docid/2005033108162039
    Now we need to do a few things.
    Please re-open HiJackThis and scan only. Check the boxes next to all the entries listed below.
    O24 - Desktop Component 0: (no name) - http://bp2.blogger.com/_aLkNPLFRQYo/.../Theotokos.jpg <<If you don't know what this is fix it.
    Now close all windows other than HiJackThis, then click Fix Checked.
    Close HJT.
    Download ATF Cleaner by Atribune and save it to your Desktop.
    This is a good tool to get rid of the temporary garbage you pick up while surfing the net.
    Double click ATF-Cleaner.exe to run the program.
    Check the boxes to the left of:
    Windows Temp
    Current User Temp
    All Users Temp
    Cookies
    Temporary Internet Files
    Prefetch
    Java Cache
    Recycle bin
    The rest are optional - if you want it to remove everything check "Select All ".
    Finally, click Empty Selected. When you get the "Done Cleaning" message, click OK.
    Now lets get a on-line scan.
    Scanning with Kaspersky WebScanner
    You will be promted to install an ActiveX component from Kaspersky, Click Yes.
    • The program will launch and then begin downloading the latest definition files:
    • Once the files have been downloaded click on NEXT
    • Now click on Scan Settings
    • In the scan settings make that the following are selected:
      • Scan using the following Anti-Virus database:
      • Extended (if available otherwise Standard)
      • Scan Options:
      • Scan Archives
        Scan Mail Bases
    • Click OK
    • Now under select a target to scan:
      • Select My Computer
    • This will program will start and scan your system.
    • The scan will take a while so be patient and let it run.
    • Once the scan is complete it will display if your system has been infected.
      • Now click on the Save as Text button:
    • Save the file to your desktop.
    Please post the Kaspersky results.
    Geri
  17. 2008/08/08
    Dion
    I can finally post! Kaspersrky lic expire?
    Hello again:confused: I have tried to view and post from the fixed pc but the thread wont show up just the multi pages icon and profile comes up!! I finally was able to see the thread on this pc today! Did the ATF, now trying to run Kaspersky it said a windows msg pop up said K license expired? Is that real or a virus again? I also looked for the AV link and I found its now CA I'll give it a try for sure. Let me know if I should keep trying Kaspersky, to post it I may have to start another thread! Tks!!
  18. 2008/08/08
    Hi Dion
    OK Kaspersky has discontinued that version. Please try this one.
    Please do an online scan with Kaspersky WebScanner
    Click on "Accept" If your pop "“up blocker blocks any windows from opening.
    Click Run on the window that opens.
    Windows Vista users you must open the web browser using the Run as Administrator command.
    • Under Scan on the left side.Click on My Computer
    • This will start the program and scan your system.
    • Click the "Scan Report" On the left side.
      • Click the Save Report As button, and in the Browse dialog box, type a name for the scan report file that you want to create and select its type Text file. Click OK to save the file.:
    • Save the text file to your desktop.
    • Copy and paste that information in your next post.
    Geri
