Resolved Toshiba Laptop WIFI Download Speed
Discussion in 'Networking (Hardware & Software)' started by bmartin, 2015/02/10.
  1. 2015/02/10
    bmartin
    bmartin Well-Known Member Thread Starter
    I have three wired Desktop and one Laptop network connected to the router that provides 50 Mbps download speed. All of these devices can get that speed 90% of the time, which is great. However, my wife uses a Toshiba laptop that at best gets 20 Mbps or less using the WIFI connection. When I connect the laptop by wire it get consist download speeds of 50 Mbps. What would normally be restricting the wifi download speed to 20 Mbps on the Toshiba. I have an Acer in the same room that hits the 50 Mbps most of the time. The Toshiba is using a Realtor RT:8187SE wifi pcie card, which i think is capable of handling up to 54 Mbps. Any one have any suggestions.
  2. 2015/02/10
    The adaptors are not all created equally.
    Data transfer rates
    Most of us prefer faster everything for the most efficient work and play possible. Higher data transfer rates mean that data is transferred faster and work done quicker. Currently the three most popular wireless networking standards are as follows:
    802.11a
    802.11a is an IEEE wireless networking standard that specifies a maximum data transfer rate of 54Mbps and an operating frequency of 5GHz.
    802.11b
    802.11b is an IEEE wireless networking standard that specifies a maximum data transfer rate of 11Mbps and an operating frequency of 2.4GHz.
    802.11g
    802.11g is an IEEE wireless networking standard that specifies a maximum data transfer rate of 54Mbps and an operating frequency of 2.4GHz. And it is backward compatible with 802.11b.
    http://www.newegg.com/Product/CategoryIntelligenceArticle.aspx?articleId=224
    The Realtek adapter is 80211g, max rate is 54 mb/s on paper. Real world is closer to 20-30 mb/s or even less, due to interference, signal overlap, waves from other devices such as microwave ovens, baby monitors, speakers, etc. Antenna quality is also a major factor. On a laptop, the antenna is behind the screen. And as was said, not all adapters are equal in quality and performance.
    Check the toshiba site and see if newer drivers are available for the adapter.
  5. 2015/02/10
    bmartin
    Hey Tony T I get around 20-22 Mbps as a max speed. I believe the card is my problem. I guess the real issue is if I can find a better replacement card for RTL8187SE that can do better. Of course I am not sure if there is one. One thing I know for sure the card in my Acer is Atheros AR5B125 and man is it a go get. It pops at about 50 Mbps almost all the time.
  6. 2015/02/10
    If you want better speed, one option is to attach a USB wifi card & disable the inbuilt RTL wifi card. Its the cheapest solution.
  7. 2015/02/11
    That atheros adapter is 80211n, backward compatible with b & g, up to approx 600 mb/s depending upon the channels and number of antennas. Most 80211 adapters in laptops have 3 antennas.
    Bear in mind that 20 mb.s is still extremely fast and will support anything you want to do on your LAN or the Internet. Plenty fast to stream multimedia without buffering.
  8. 2015/02/11
    bmartin
    rfinfo do you have any recommendations for the USB solution.
  9. 2015/02/11
    What kind of problems are you having that you need more speed to the laptop?
  10. 2015/02/11
    bmartin
    Mr Bill It is not so much as a problem. It is simply that this is the only laptop in the room that can't use the max. speed that I pay for, which is 50 Mbps. If there a way to max out on the available speed with another wifi card then that's what I want. I can solve my slower download speed just by running a wire to the laptop from the router, but a laptop is just that and I don't need another desktop. It is nothing more then getting the best speed to the laptop that is possible. The 20 Mbps or less is ok, but 50 Mbps is better. Just a need for speed I guess, lol.
  11. 2015/02/11
    Any usb wifi dongle that is 80211n will deliver your modem's limit.
  12. 2015/02/11
    bmartin
    Tony that's what I thought, but I purchased a 80211n and I get less download speed with it then I do with Pcie card. Strange.
  13. 2015/02/11
    How are you measuring your bandwidth rate? Your ISP may provide 50mbps but that is only on their network. Once the packets leave their network the rate changes and vice verse. For example, you can download a file from xyz.com and not get 50 mbps because xyz.com's server is limited to 30 mbps.
    If you use speed test sites they are not always accurate either.
    I just did a test at speedtest.net site on my wired desktop:
    32 ms ping
    108.20 mbps download
    11.82 mbps upload
    At my Cox ISP site on my wired desktop:
    32 ms ping
    68.12 mbps download
    11.81 mbps upload
    Another test from my Cox ISP site in my 80211g laptop:
    32 ms ping
    9.85 mbps download
    6.38 mbps upload
  14. 2015/02/11
    Have you thought that maybe that machine isn't clean of Virus/Malware/Spyware? Just a thought.
    Maybe go to the Malware section on here and run what is asked and let Broni advise what to do.
  15. 2015/02/12
    bmartin
    I hear you Tony about speed testing. I use speedtest.net site just as a reference point of comparison and not other sites. Here is all I know. I have two wireless laptops, Acer and Toshiba. Both are running win 7 and are similar otherwise relating to CPU speed and memory. Both laptops are in the same room and when wired to router produce the same downland test results using speedtest.net, which is around 50 Mbps. As I mentioned before the acer burns rubber when using it built in wifi card 45Mbps or better most of the time, but the poor Toshiba is lucky to get 20 Mbps. I thought the wifi card in the Toshiba was the weak link, but when I got the usb dong it was worst. So now I am not sure what the deal is. I guess I just accept the wifi speed or wire it up.
  16. 2015/02/12
    Follow MrBills suggestion above and start a thread in the malware forum.
  17. 2015/02/14
    bmartin
    Problem solved with a new Genuine Toshiba Qosmio X505 WIFI Wlan Wireless Card RTL8191SE. This card is humming at 49 Mbps. That's what I am talking about. Thanks guys for your suggestions
