Thunderbird 1.0 and receipts
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by Christer, 2005/03/03.
  1. 2005/03/04
    JSS3rd Lifetime Subscription
    JSS3rd Geek Member
    No, it's where a ThunderBIRD lives. :D
  2. 2005/03/04
    captjlddavis
    captjlddavis Well-Known Member
    JSS
    re:Outhouse Express
    I have it someplace, but suppressed.( don't recall how ) - I also have M$ IE - but never updated or used......
    BMOORE
    you are correct:
    I guess I misworded - I was refereing to same ISP email address not program.
    Yes - if you send form ONE email address to ANOTHER email address in the same ISP account - you get the RR
    Sorry if I confused things.
    regards:captjlddavis
    Westside
    Westside Inactive Alumni
    I sent request from one account of mine to another, from TB1.0 (the sedentary bird), and open in Mozilla1.7.5, and received the request. I then went back to TB1.0, and there was another request. Now, I am in Netscape7.2. I got an announcement to cut it out sending passwords so many time in a short period of time. But, for now, I got two confirmations. I think that this thread is getting nowhere.
    I am doing this way, before sending I click on Options|Return receipt. That preference will be good for the one time.
    I just got the third confirmation in Netscape 7.2. Is it possible that these request end up in the Junk folder? My ISP sent a curt message to that effect, and since it is server based, and I don't look at all that garbage, I would never know. This is a consideration.
    By the way, I did not have to go near OE. Now, OE is something else. I will be posting soon about it
  5. 2005/03/04
    JSS3rd Geek Member
    UNLESS one of the addresses is an alias for the other, which is my situation. JSS3rd@, JSS@, Jim@, and Dad@ are all aliases for my actual address. No RRR when I send from one to another.
  6. 2005/03/04
    captjlddavis
    JSS..
    if it makes you happy, I stand corrected....
  7. 2005/03/04
    Ramona
    Ramona Geek Member Alumni
    Christer,
    What about disabling email scanning, and Firewall, just to see if either is the culprit?
    Ramona
  8. 2005/03/04
    Westside
    Ramona,
    I know what is in your mind. I am scanning outgoing mail with AVG, by the way. But, I would eliminate, antivirus, firewall or any security software, one at a time.
  9. 2005/03/06
    Christer
    Disabling Norton Internet Security (antivirus and firewall) made no difference
    Christer
  10. 2005/03/08
    Christer
    Yesterday, I sent a mail with an attachment to two recipients. The one using Thunderbird did receive the attachment but the one using Outlook Express (or Microsoft Outlook) didn't receive it.
    Sending the same mail with the same attachment from OE to the same recipients, the attachment was received by both.
    Christer
  11. 2005/03/11
    Christer
    I was browsing mozilla.org and came across Why Use Mozilla ? where under "Mail & Newsgroups" it says:
    The emphasis of "return receipts" is mine but could it be that I should install an extension of Thunderbird or something for this to work?
    Christer
  12. 2005/03/16
    liviu.laudat
    liviu.laudat Inactive
    Firebird receipts..
    I also tested what Christer said and it's true...Is there an answer for this problem?I'm very much interested..
