[The System Restore filter encountered the unexpected error '0xC0000056]
Discussion in 'Windows XP' started by kenton, 2006/03/31.
  1. 2006/03/31
    kenton
    kenton Inactive Thread Starter
    What meant this error?(it happens when i work with javascript database, locally, html page on my harddrive)
    Event Type: Error
    Event Source: sr
    Event Category: None
    Event ID: 1
    Date: 2006.03.28.
    Time: 20:48:48
    User: N/A
    Computer: Username
    Description:
    The System Restore filter encountered the unexpected error '0xC0000056' while processing the file 'database2.lnk' on the volume 'HarddiskVolume1'. It has stopped monitoring the volume.
    For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
    Data:
    0000: 0e 00 00 00 04 00 4e 00 ......N.
    0008: 00 00 00 00 01 00 00 c0 .......À
    0010: 00 00 00 00 00 00 00 00 ........
    0018: 00 00 00 00 00 00 00 00 ........
    0020: 00 00 00 00 00 00 00 00 ........
  2. 2006/03/31
    vbmark
    vbmark Inactive
    kenton
    Start by running chkdsk & emptying all your TEMP folders.
  6. 2006/04/05
    kenton
    Except 'Temporary Internet Files', what else TEMP folders?
  7. 2006/04/05
    Temp files in Documents and Settings ....
    Start > Run > type in %temp% > OK
    and C:\Windows\Temp.
    In both cases there will be one or two files which cannot be deleted as they are in use. Best sort by date and select those of yesterday or earlier for deletion.
  8. 2006/04/05
    kenton
    C:\DOCUME~1\User\LOCALS~1\Temp contains 13 folders, besides .tmp files.
    Does i need remove all of them? Is this safe, and is there a necessity for?
    Usually I clean MSIE 'Temporary Internet Files'.
  9. 2006/04/05
    The folders are temporary folders - they are safe to delete, but check them out just in case you recognise something that you may wish to keep. Those that may be needed by programs on a temporary basis will be recreated when required.
  10. 2006/04/11
    kenton
    Is there a sense clean temporary files from %temp% directory?
    Better system performance, etc?? I clean Temporary Internet Files in Internet Explorer only.
  11. 2006/04/11
    Yes. removing all the junk helps for Windows to find the correct file & space to write these files.
