the system has recovered from a serious error
Discussion in 'Windows XP' started by johnmcneil, 2010/05/27.
  1. 2010/05/27
    johnmcneil
    johnmcneil Inactive Thread Starter
    c;\docume~1\owneru~1\locals~1\temp\wer4737.dir00\mini052710-03.dmp
    c;\docume~1\owneru~1\locals~1\temp\wer4737.dir00\sysdata.xml
    i was trying to burn some music and put a cd in and it cut off and restarted didnt think much about it but it continued to do it. when it comes back on it gives me a system error and that is what it gives me when it pops up those two at the top so if you can do anything with it i would be very happy. oh yea it allso makes my computer run slow anyway i know yall can handel it you have be for and it was very helpfull.
  2. 2010/05/27
    goddez1
    goddez1 Inactive
    johnmcneil
    it dose it when i turn it on in the mornnings and usaly i dont have to have a cd or dvd in for it to act like that but that is what it tells me when the error pops up, thats all i know about it i had some people useing the internet and they could have given me a bug
  5. 2010/05/27
    Hi, If you could give us more info it might help to diagnose your problem. Can you put your 'System Details' in through User CP please.
    What is your Burning Media? Did you Rip the music with WMP or another software?
    Were you using AV program when your friends used the PC? Neil.:confused:
  6. 2010/05/27
    goddez1
    goddez1 Inactive
  7. 2010/05/28
    First set up the computer so that it does not restart on system failure ....
    Set up the computer so that it does not automatically restart on system failure .....
    Control Panel > System > Advanced > Startup and Recovery > Settings ....
    Under System failure uncheck 'Automatically restart' and under Write debugging information select 'Kernel memory dump' from the dropdown list and OK out.
    The computer will now show the BSOD in the event of a System failure giving details of the Stop message and the contents of the memory will be dumped to disk.
    Post the error message on the blue screen here.
    Run the minidump -c:\docume~1\owneru~1\locals~1\temp\wer4737.dir00\mini052710-03.dmp through BlueScreenView and post the file names highlighted in pink and the name of any file noted in the blue screen as shown on the BlueScreenView page above.
  8. 2010/05/28
    johnmcneil
    hi, i went to the website you gave me, i went to the second site and did the resolution im going to see how that works if it dont ill get back intouch with someone and see what else we can come up with.Thank you for your time and have a good day!
  9. 2010/05/28
    Making Pete's advice little bit easier...
    Download BlueScreenView ((in Zip file)
    No installation required.
    Unzip downloaded file and double click on BlueScreenView.exe file to run the program.
    When scanning is done, go Edit>Select All.
    Go File>Save Selected Items, and save the report as BSOD.txt.
    Open BSOD.txt in Notepad, copy all content, and paste it into your next reply.
  10. 2010/05/28
    goddez1
    goddez1 Inactive
    Hi John,
    I hope you don't mean you will not be back "if it works ". We like to know and share the total experience. We need the results both "good" and "bad ". Don't leave the final chapter out the your story.....please. Share the final fix that worked for you. Help save future members who will suffer from the same problem.
    All the above aside, I'm real curious about this tool "bluescreen view ". I'd like to see how and if it works. :)
  11. 2010/05/29
    johnmcneil
    the system has recoverd a seirous error
    broni,
    i tryed to download the blue screen view and it want download it trys but it dosent do it what should i do.
  12. 2010/05/29
    It doesn't so what?
  13. 2010/05/31
    johnmcneil
    Dump File : Mini052710-03.dmp
    Crash Time : 5/27/2010 6:04:43 PM
    Bug Check String : KERNEL_MODE_EXCEPTION_NOT_HANDLED
    Bug Check Code : 0x1000008e
    Parameter 1 : 0xc0000005
    Parameter 2 : 0x806f0753
    Parameter 3 : 0xeece7378
    Parameter 4 : 0x00000000
    Caused By Driver : hal.dll
    Caused By Address : hal.dll+2753
    File Description : Hardware Abstraction Layer DLL
    Product Name : Microsoft® Windows® Operating System
    Company : Microsoft Corporation
    File Version : 5.1.2600.5512 (xpsp.080413-2111)
    Processor : 32-bit
    Computer Name :
    Full Path : C:\WINDOWS\Minidump\Mini052710-03.dmp
    Processors Count : 1
    Major Version : 15
    Minor Version : 2600
    Dump File : Mini052710-02.dmp
    Crash Time : 5/27/2010 6:01:12 PM
    Parameter 3 : 0xee699ac8
    Processor : 32-bit
    Computer Name :
    Full Path : C:\WINDOWS\Minidump\Mini052710-02.dmp
    Major Version : 15
    Dump File : Mini052710-01.dmp
    Crash Time : 5/27/2010 5:40:15 PM
    Parameter 3 : 0xef11dfe8
    Processor : 32-bit
    Computer Name :
    Full Path : C:\WINDOWS\Minidump\Mini052710-01.dmp
    Major Version : 15
  14. 2010/05/31
    I suggest you disconnect the CD-rom drive - remove the power cable and see if the issue remains.
    Alternatively in Device Manager right click on the CD-Rom drive and disable it and test.
  15. 2010/05/31
    johnmcneil
    do not have the option to disable the cd/dvd rom and dont know how to go in and the computer and disable it
  16. 2010/05/31
    You should have ....
    Device Manager - click on the + sign next to DVD/CD-ROM drives which will expand to show the model of CD-ROM drive installed.
    Right click on that and the small window which opens should have the following options ....
    Update Driver
    Disable
    Uninstall
    Scan for hardware changes
    Properties
    Click on disable.
  17. 2010/05/31
    johnmcneil
    hey, peteC
    just want to let you know i have three of them do i need to disable them all?
    HL-DT-ST DVD-RAM-DVD GH22NP20
    PIONEER DVD-ROM DVD-115
    VOBID INSTANTDRIVE CD SCSI CDROM DEVICE
    Those are the one's i have listed under my device manager hope that will help you know which one to turn off if not all
  18. 2010/06/01
    johnmcneil
    hey, peteC man i hate to be a bother to you im learning as we go but which one do i download there are three of them posted on it sorry hope im not bothering you
  20. 2010/06/01
    No bother - we'll stick with this until a resolution is found :)
    Sorry - I'm not with you - can you explain please.
  21. 2010/06/01
    johnmcneil
    i dont know what to download the site that you have for me to go to it takes me to hawk22
