The system has recovered from a serious error
Discussion in 'Windows XP' started by Sillsy, 2008/08/07.
  1. 2008/08/20
    Whiskeyman Inactive Alumni
    If you did uninstall your Brother MFD you will need to remove a leftover Service and a couple of files.
    Go to Start, Run and type in CMD then press <Enter>.
    Now type in: sc delete BrSplService then press <Enter>. Reboot.
    Please re-open HiJackThis and click the button Do a system scan only. Check the boxes next to all the entries listed below (O23 - Service:BrSplService may now be missing).
    C:\WINDOWS\System32\brsvc01a.exe
    C:\WINDOWS\System32\brss01a.exe
    O23 - Service: BrSplService (Brother XP spl Service) - brother Industries Ltd - C:\WINDOWS\System32\brsvc01a.exe
    Now close all windows other than HiJackThis, then click Fix Checked. Close HiJackThis then Reboot.
    Hopefully this should help eliminate any problems with Brother MFD.
  2. 2008/08/21
    Sillsy
    Sillsy Inactive Thread Starter
    Thanks Whiskeyman, just tried what you suggested but this is what happened...
    I did this but it said 'The specified service does not exist as an installed service.'
    The only entry I could find was the 023 - Service etc. The other three weren't listed.
    Sue
    Sillsy
    Hi Mike,
    Back again, and finally finished doing everything you suggested.
    Everything worked well until I got to the DAF Hammerhead and it gave me the same message as before. It is still going at the moment and its been nearly 10 minutes.
    I will leave it for a while and see what happens.
    Sue
  5. 2008/08/21
    Sillsy
    Well I left it for 40 minutes and nothing changed. So I've stopped it.
  6. 2008/08/21
    mflynn
    mflynn Inactive
    Hi Sue
    Good work.
    OK the version.dll error should not cure the issue, but it would be nice to fix it to be sure.
    But has the issue reared its ugly head lately? Let us know if anything has changed about the restarting?
    OK one more run at the Version.dll error.
    Put your Windows XP CD into the cd drive.
    Run DAF Hammerhead
    then
    SFC purge
    when complete
    SFC scan
    Lastly
    Reinstall WMI/WBEM
    Mike
  7. 2008/08/21
    Sillsy
    Thanks Mike,
    All done.
    Apparently the computer shut itself down twice today while I was at work. Once while my husband was using word and once when he was checking his emails.
    Maybe its him!! Except that it happened to me yesterday, there goes that theory.
    Since this problem has started I have also changed the cmos battery and cleaned the dust out of the hard drive.
    Since doing all the cleaning you have suggested the problem has reduced dramatically as it was happening many times a day and at times we couldn't even restart the computer (that may have been the battery though). So things have improved and the speed at which things open has definitely increased. Hopefully we can fix it completely.
    Sue
  8. 2008/08/21
    mflynn
    mflynn Inactive
    Great!
    Ok lets see if it does it again since you completed the last post.
    Let me know!
    I am beginning to think the computer is running hot. Is it enclosed inside a desk enclosure or out in the open?
    Is the room reasonalby cool?
    Mike
  9. 2008/08/21
    Sillsy
    The computer is in the open but it is in the loungeroom where we spend most of our time and obviously have the room heated (it is Winter here right now). So it is a warm room. But we also have the computer on most of the day, but in saying that, it shuts down at any time of the day. I will post again if it shuts down.
    Thanks for your help.
    Sue
  10. 2008/08/21
    mflynn
    mflynn Inactive
    OK good!
    So based on the time of your post that you had finally completed all the steps sucessfully, then it has been about 11 hours and no restart?
    Let me know if it does it again (knock on wood) (fingers crossed)!
    Mike
  11. 2008/08/21
    Sillsy
    Unfortunately it just happened, probably as you were posting. No one was doing anything on the computer, it just decided it was time. It has only been on for about 1 1/2 hours. It is morning here (not sure of the time difference). I will see how it runs today and I will post details tonight (its 9am here).
    Sue
  12. 2008/08/21
    mflynn
    mflynn Inactive
    Not good!
    I think you are running hot or have a weak power supply!
    The power supply will need to be checked with a meter so that requires a shop visit!
    But there is a way we can check for over heating.
    If no children around to put fingers in CPU, then remove the case, this alone may prove it, if it cures the restarts.
    Or if this improves it greatly but not completely then you can put a small fan blowing directly into the case.
    If this works it is time to install additional case fans and perhaps a new CPU cooler fan.
    Mike
  13. 2008/08/22
    Sillsy
    After the 9am shut down, the computer shut down again at 11.30am whilst no-one was on it. But since then it hasn't happened and it is now 10 hours later.
    Leaving the cover off the CPU isn't really an option as there are 2 very curious young children who would no doubt stick their fingers in! But we'll see how things go.
    Thank you to everyone who has contributed to attempting to solve this problem. Thanks Mike, we might not have fixed it, but your suggestions have definitely helped my computer. Just for future reference, should I run those cleaners occassionally, what do you suggest as regular maintenance to keep my computer clean?
    Thanks again
    Sue
  14. 2008/08/23
    mflynn
    mflynn Inactive
    Hi Sue
    Had a busy day Friday so did not get back.
    OK so here is what is happening. You had multiple problems a Virus (WinAntiVirus) that we cleaned, then we did the cleanups with CCleaner and ATF_Cleaner.
    Then the DAF runs which corrected issues caused by WinAntiVirus and other general unknown issues.
    These procedures did make as you said a dramatic improvement in system speed and performance and also cut the number of restarts dramatically also.
    Yes we have made progress, What we did was clear everything else so that we have now refined it down to your real problem!
    Overheating!
    If it is overheating and powering down then this is like a mini stroke in a person they are a prelude to a full blown stroke. A little damage is done to the processor each time this happens until one day it will become worse and eventually be the big one and no more boot at all.
    If you try to live with it, it will just get worse.
    As I said earlier it could be a weak Power Supply unit or even if the PSU is not weak sometimes as they begin to go bad they themselves begin to run hotter and the fan in the PSU cannot exhaust all the excess heat.
    If not the PSU then the CPU cooler fan on top of the CPU may be failing.
    Below are some ways to get more info on the temps.
    Some low priced motherboards do not have sensors to report temps lets hope yours does.
    So lets monitor the Temp (if you have the sensors to do it).
    Download install an run HWMonitor http://majorgeeks.com/HWMonitor_d5842.html
    After installed if it found the sensors then let the computer idle long enough to get an average reading, then throw the coals to it an watch the temp rise.
    The HWM is pretty reliable has good reviews. But the leads to the sensors may not be installed correctly.
    Lets get a couple more opinions:
    http://www.gtopala.net/download/siw-setup.exe
    Install run and look at Sensors.
    http://rh-software.com/downloads/siv.zip
    Unzip and install.
    This is like getting 2nd or more opinions from a Doctor. If the consensus is that you are running hot then better act accordingly.
    To repair this issue, if you yourself can not add extra case fans and/or CPU cooler then this info will allow you to take your unit to a shop and tell them explicitly what you want and why.
    Assuming as you should that the shop may not have good techs or may be a price gouger.
    So you walk in tell them what you want get a price and tell them that is all you want and all you will pay!
    Your ball!
    Mike
  15. 2008/08/23
    Sillsy
    Hi Mike,
    Thanks for that info, I will get on to it in the morning, must get some sleep, its 11pm and the kids will be waking me up before I know it!
    Sue
  16. 2008/08/23
    Sillsy
    Hi Mike,
    From what I understand the minimum temp of HDD is 31C and the max is 38C. What other information do I need? SIV says sensor 1 is 35c, sensor 2 is 26c and sensor 3 is 28c. Only one fan reading, assume that is all I have, 3183rpm. HWMonitor has the same readings.
    What is your opinion?
    Sue
  17. 2008/08/24
    mflynn
    mflynn Inactive
    Well that is excellent for the HD if the sensor wire is actually conected to the HD!
    And all the other temps are OK even tho not knowing what they are connected to.
    If one was connected to the CPU it would be OK. But these readings could be from other things and not even connected to the CPU.
    No way for me to know without looking in the case.
    Someone knowledgeable in these things needs to check this.
    Sorry I forgot to answer your earlier questions. Yes by all means run the CCleaner and ATF-Cleaner every 1 or 2 weeks.
    The DAF should not have to be run except for a specific problem known or unknown but to be sure the first page once a month.
    Now in case there are issues I can not see I am preparing another post that I will send in an hour or so to look deeper into the system.
    Mike
  18. 2008/08/24
    mflynn
    mflynn Inactive
    Hi Sue
    Delayed by weekend activities.
    Just in case there is another cause lets take a deep look at your OS.
    Download Runscanner http://www.runscanner.net/download.aspx
    Extract zip. Run Runscanner select Expert mode click ok. Click scan computer. May take 3 or more minutes.
    Once scan finishes click save log file. Save as the default offered it will opem the log in notepad. Copy and paste the contents back to the thread.
    Mike
  19. 2008/08/24
    Sillsy
    Hi Mike,
    You've been so helpful, I guess its ok if you have a life outside of helping me!!
    Here is the log:
    Runscanner logfile http://www.runscanner.net
    * = signed file
    - = file not found
    General info
    Computer name : USER-N2C5381HSG
    Creation time : 25/08/2008 11:32:18 AM
    Hosts <> 127.0.0.1 : 0
    Hosts file location : %SystemRoot%\System32\drivers\etc
    IE version : 7.0.5730.13
    OS : Microsoft Windows XP
    OS Build : 2600
    OS SP : Service Pack 2
    RunScanner Version : 1.7.0.0
    User Language : English (Australia)
    User rights : Administrator
    Windows folder : C:\WINDOWS
    Running processes
    C:\PROGRA~1\A4Tech\Mouse\Amoumain.exe (A4Tech Co.,Ltd.)
    * C:\WINDOWS\System32\alg.exe (Microsoft Corporation)
    * C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe (Symantec Corporation)
    * C:\WINDOWS\System32\brss01a.exe (brother Industries Ltd)
    * C:\WINDOWS\System32\brsvc01a.exe (brother Industries Ltd)
    * C:\WINDOWS\system32\csrss.exe (Microsoft Corporation)
    * C:\WINDOWS\system32\ctfmon.exe (Microsoft Corporation)
    * C:\WINDOWS\system32\svchost.exe (Microsoft Corporation)
    * C:\WINDOWS\System32\svchost.exe (Microsoft Corporation)
    C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe (Google)
    * C:\Program Files\Google\Google Updater\GoogleUpdater.exe (Google)
    * C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe (Google)
    C:\WINDOWS\htpatch.exe
    C:\PROGRA~1\A4Tech\Keyboard\Ikeymain.exe (A4Tech Co.,Ltd.)
    * C:\Program Files\Internet Explorer\IEXPLORE.EXE (Microsoft Corporation)
    * C:\Program Files\Microsoft IntelliPoint\ipoint.exe (Microsoft Corporation)
    * C:\Program Files\Microsoft IntelliType Pro\itype.exe (Microsoft Corporation)
    * C:\Program Files\Java\jre1.6.0_07\bin\jusched.exe (Sun Microsystems, Inc.)
    * C:\WINDOWS\system32\lsass.exe (Microsoft Corporation)
    * C:\Program Files\Outlook Express\msimn.exe (Microsoft Corporation)
    C:\Program Files\ScanSoft\PaperPort\pptd40nt.exe (ScanSoft, Inc.)
    C:\Program Files\QuickTime\qttask.exe (Apple Computer, Inc.)
    * C:\WINDOWS\SOUNDMAN.EXE (Realtek Semiconductor Corp.)
    * C:\Documents and Settings\Owner\Desktop\RunScanner.exe (Runscanner.net)
    * C:\WINDOWS\system32\services.exe (Microsoft Corporation)
    * C:\Program Files\Samsung\Samsung Media Studio 5\SMSTray.exe (SAMSUNG ELECTRONICS)
    * C:\WINDOWS\AGRSMMSG.exe (Agere Systems)
    * C:\WINDOWS\system32\spoolsv.exe (Microsoft Corporation)
    * C:\Program Files\Common Files\Symantec Shared\AppCore\AppSvc32.exe (Symantec Corporation)
    * C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe (Symantec Corporation)
    * C:\Program Files\Common Files\Symantec Shared\ccApp.exe (Symantec Corporation)
    * C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
    C:\program files\Telstra\Signup\tbpt.exe (Telstra Big Pond)
    * C:\WINDOWS\Explorer.EXE (Microsoft Corporation)
    * C:\Program Files\Messenger\msmsgs.exe (Microsoft Corporation)
    * C:\WINDOWS\system32\winlogon.exe (Microsoft Corporation)
    * c:\windows\System32\smss.exe (Microsoft Corporation)
    Unrated items
    002 C:\program files\Telstra\Signup\tbpt.exe (Telstra Big Pond)
    002 C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe (Google)
    002 C:\WINDOWS\htpatch.exe
    002 C:\PROGRA~1\A4Tech\Keyboard\Ikeymain.exe (A4Tech Co.,Ltd.)
    002 C:\Program Files\ScanSoft\PaperPort\IndexSearch.exe (ScanSoft, Inc.)
    002 C:\WINDOWS\System32\\NeroCheck.exe (Ahead Software Gmbh)
    002 C:\Program Files\ScanSoft\PaperPort\pptd40nt.exe (ScanSoft, Inc.)
    002 C:\Program Files\QuickTime\qttask.exe (Apple Computer, Inc.)
    002 C:\Program Files\REGSHAVE\REGSHAVE.EXE (FUJI PHOTO FILM CO., LTD.)
    002 * C:\Program Files\Samsung\Samsung Media Studio 5\SMSTray.exe (SAMSUNG ELECTRONICS)
    002 C:\Program Files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe (Scansoft, Inc.)
    002 C:\PROGRA~1\A4Tech\Mouse\Amoumain.exe (A4Tech Co.,Ltd.)
    004 C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe (Adobe Systems, Inc.)
    004 C:\Program Files\ERUNT\AUTOBACK.EXE
    005 C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe (Adobe Systems, Inc.)
    005 * C:\Program Files\Google\Google Updater\GoogleUpdater.exe (Google)
    005 C:\Program Files\Microsoft Office\Office\OSA9.EXE (Microsoft Corporation)
    010 C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe (Adobe LM Service)
    010 C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe (GoogleDesktopManager)
    010 C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe (InstallDriver Table Manager)
    011 C:\WINDOWS\System32\DRIVERS\Amps2prt.sys (A4Tech PS/2 Port Mouse Driver)
    011 C:\WINDOWS\System32\Drivers\BrScnUsb.sys (Brother USB Still Image driver)
    011 C:\WINDOWS\system32\drivers\MASPINT.sys (MASPINT)
    011 * C:\WINDOWS\system32\Drivers\SIVX32.sys (SIV Kernel Driver)
    041 C:\Program Files\EPSON\EPSON Web-To-Page\EPSON Web-To-Page.dll (SEIKO EPSON CORPORATION) {EE5D279F-081B-4404-994D-C6B60AAEBA6D}
    045 C:\Program Files\EPSON\EPSON Web-To-Page\EPSON Web-To-Page.dll (SEIKO EPSON CORPORATION) {EE5D279F-081B-4404-994D-C6B60AAEBA6D}
    047 Zone: : msn
    052 C:\Program Files\EPSON\EPSON Web-To-Page\EPSON Web-To-Page.dll (SEIKO EPSON CORPORATION) {E99421FB-68DD-40F0-B4AC-B7027CAE2F1A}
    052 * C:\Program Files\Google\GoogleToolbarNotifier\3.0.1225.9868\swg.dll (Google Inc.) {AF69DE43-7D58-4638-B6FA-CE66B5AD205D}
    061 C:\PROGRA~1\MICROS~2\Office\OLKFSTUB.DLL (Microsoft Corporation) {0006F045-0000-0000-C000-000000000046}
    061 C:\PROGRA~1\COMMON~1\MICROS~1\WEBFOL~1\MSONSEXT.DLL {BDEADF00-C265-11d0-BCED-00A0C90AB50F}
    062 C:\Program Files\Graphisoft\ArchiCAD 10\GSShellX.dll (Graphisoft R&D) {FC66F851-FFAB-11D1-B226-0000C01A73E9}
    062 C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\PDFShell.dll (Adobe Systems, Inc.) {F9DB5320-233E-11D1-9F84-707F02C10627}
    100 Start Page HKCU : http://www.impressionablekids.com.au/
    102 GUID / CLSID not found {32683183-48a0-441b-a342-7c2a440a9478}
    104 C:\WINDOWS\Downloaded Program Files\symdlmgr.dll (Symantec Corporation) {6A344D34-5231-452A-8A57-D064AC9B7862}
    120 Domain {36E68565-96FB-4DBE-AF27-3B5E107D75AD} : nsw.bigpond.net.au
    120 TcpIp SearchList : vic.bigpond.net.au
    121 C:\PROGRA~1\Google\GOOGLE~3\GOEC62~1.DLL (Google)
    173 C:\Program Files\EPSON\Creativity Suite\Easy Photo Print\EPPShell.dll (SEIKO EPSON CORPORATION) {509FE1AF-ADD5-49EC-BC55-7CF81FD16E78}
    221 C:\Program Files\EPSON\Creativity Suite\Easy Photo Print\EPPShell.dll (SEIKO EPSON CORPORATION) {509FE1AF-ADD5-49EC-BC55-7CF81FD16E78}
    231 C:\Program Files\Graphisoft\ArchiCAD 10\GSShellX.dll (Graphisoft R&D) Graphisoft Shell Extension 3.0
    231 C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\PDFShell.dll (Adobe Systems, Inc.) PDF Column Info
    Missing files
    011 C:\WINDOWS\system32\drivers\Abiosdsk.sys
    011 C:\WINDOWS\system32\drivers\abp480n5.sys
    011 C:\WINDOWS\system32\drivers\adpu160m.sys
    011 C:\WINDOWS\system32\drivers\Aha154x.sys
    011 C:\WINDOWS\system32\drivers\aic78u2.sys
    011 C:\WINDOWS\system32\drivers\aic78xx.sys
    011 C:\WINDOWS\system32\drivers\AliIde.sys
    011 C:\WINDOWS\system32\drivers\amsint.sys
    011 C:\WINDOWS\system32\drivers\asc.sys
    011 C:\WINDOWS\system32\drivers\asc3350p.sys
    011 C:\WINDOWS\system32\drivers\asc3550.sys
    011 C:\WINDOWS\system32\drivers\Atdisk.sys
    011 C:\WINDOWS\system32\drivers\cd20xrnt.sys
    011 C:\WINDOWS\system32\drivers\Changer.sys
    011 C:\WINDOWS\system32\drivers\CmdIde.sys
    011 C:\WINDOWS\system32\drivers\Cpqarray.sys
    011 C:\WINDOWS\system32\drivers\dac2w2k.sys
    011 C:\WINDOWS\system32\drivers\dac960nt.sys
    011 C:\WINDOWS\system32\drivers\dpti2o.sys
    011 C:\WINDOWS\system32\drivers\hpn.sys
    011 C:\WINDOWS\system32\drivers\i2omgmt.sys
    011 C:\WINDOWS\system32\drivers\i2omp.sys
    011 C:\WINDOWS\system32\drivers\ini910u.sys
    011 C:\WINDOWS\system32\drivers\IntelIde.sys
    011 C:\WINDOWS\system32\drivers\lbrtfdc.sys
    011 C:\WINDOWS\system32\drivers\mraid35x.sys
    011 C:\WINDOWS\system32\drivers\PCIDump.sys
    011 C:\WINDOWS\system32\drivers\PDCOMP.sys
    011 C:\WINDOWS\system32\drivers\PDFRAME.sys
    011 C:\WINDOWS\system32\drivers\PDRELI.sys
    011 C:\WINDOWS\system32\drivers\PDRFRAME.sys
    011 C:\WINDOWS\system32\drivers\perc2.sys
    011 C:\WINDOWS\system32\drivers\perc2hib.sys
    011 C:\WINDOWS\system32\drivers\ql1080.sys
    011 C:\WINDOWS\system32\drivers\Ql10wnt.sys
    011 C:\WINDOWS\system32\drivers\ql12160.sys
    011 C:\WINDOWS\system32\drivers\ql1240.sys
    011 C:\WINDOWS\system32\drivers\ql1280.sys
    011 C:\WINDOWS\system32\drivers\Simbad.sys
    011 C:\WINDOWS\system32\drivers\Sparrow.sys
    011 C:\WINDOWS\system32\drivers\sym_hi.sys
    011 C:\WINDOWS\system32\drivers\sym_u3.sys
    011 C:\WINDOWS\system32\drivers\symc810.sys
    011 C:\WINDOWS\system32\drivers\symc8xx.sys
    011 C:\WINDOWS\system32\drivers\TosIde.sys
    011 C:\WINDOWS\system32\drivers\ultra.sys
    011 C:\WINDOWS\system32\drivers\ViaIde.sys
    011 C:\WINDOWS\system32\drivers\WDICA.sys
    061 deskpan.dll
    Sue
  20. 2008/08/25
    mflynn
    mflynn Inactive
    Hi Sue
    That list looks good also, no issues.
    Tho I am sure that you have a cooling issue or a weak power supply lets do the below and see a little more of your system.
    But first while computer is off see if you can reach another wall socket and plug into a different socket. If you use a power strip see if you can switch it with another.
    Now for another view into your system.
    Run HiJackThis click do system scan only, then click Config- Misc tools Ckeck the 2 boxes at the end of Generate Startup List then click Generate Startup List. When Startup.txt opens copy and paste it here.
    Next still in Misc tools click Open Install manager then click Save list after saving then paste this log to the BBS.
    Unless I find something here it will likely be the PSU or running hot!
    Has it restarted many times lately?
    Mike
  21. 2008/08/25
    Sillsy
    Hi Mike,
    First log here:
    StartupList report, 26/08/2008, 7:54:58 AM
    StartupList version: 1.52.2
    Started from : C:\Program Files\Trend Micro\HijackThis\HijackThis.EXE
    Detected: Windows XP SP2 (WinNT 5.01.2600)
    Detected: Internet Explorer v7.00 (7.00.6000.16705)
    * Using default options
    * Including empty and uninteresting sections
    * Showing rarely important sections
    C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
    c:\program files\norton pc checkup\pc_checkup.exe
    Listing of startup folders:
    Shell folders Startup:
    [C:\Documents and Settings\Owner\Start Menu\Programs\Startup]
    Adobe Gamma.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
    ERUNT AutoBackup.lnk = C:\Program Files\ERUNT\AUTOBACK.EXE
    Shell folders AltStartup:
    *Folder not found*
    User shell folders Startup:
    *Folder not found*
    User shell folders AltStartup:
    *Folder not found*
    Shell folders Common Startup:
    [C:\Documents and Settings\All Users\Start Menu\Programs\Startup]
    Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
    Google Updater.lnk = C:\Program Files\Google\Google Updater\GoogleUpdater.exe
    Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
    Shell folders Common AltStartup:
    *Folder not found*
    User shell folders Common Startup:
    *Folder not found*
    User shell folders Alternate Common Startup:
    *Folder not found*
    Checking Windows NT UserInit:
    [HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon]
    UserInit = C:\WINDOWS\system32\userinit.exe,
    [HKLM\Software\Microsoft\Windows\CurrentVersion\Winlogon]
    *Registry key not found*
    [HKCU\Software\Microsoft\Windows NT\CurrentVersion\Winlogon]
    *Registry value not found*
    [HKCU\Software\Microsoft\Windows\CurrentVersion\Winlogon]
    Autorun entries from Registry:
    HKLM\Software\Microsoft\Windows\CurrentVersion\Run
    HTpatch = C:\WINDOWS\htpatch.exe
    SoundMan = SOUNDMAN.EXE
    AGRSMMSG = AGRSMMSG.exe
    NeroCheck = C:\WINDOWS\System32\\NeroCheck.exe
    iKeyWorks = C:\PROGRA~1\A4Tech\Keyboard\Ikeymain.exe
    WheelMouse = C:\PROGRA~1\A4Tech\Mouse\Amoumain.exe
    {F7D90BD2-14A9-11d3-AD9E-00AA0064EC94} = C:\program files\Telstra\Signup\tbpt.exe
    REGSHAVE = C:\Program Files\REGSHAVE\REGSHAVE.EXE /AUTORUN
    SSBkgdUpdate = "C:\Program Files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe" -Embedding -boot
    PaperPort PTD = C:\Program Files\ScanSoft\PaperPort\pptd40nt.exe
    IndexSearch = C:\Program Files\ScanSoft\PaperPort\IndexSearch.exe
    SunJavaUpdateSched = "C:\Program Files\Java\jre1.6.0_07\bin\jusched.exe "
    ccApp = "C:\Program Files\Common Files\Symantec Shared\ccApp.exe "
    osCheck = "C:\Program Files\Norton AntiVirus\osCheck.exe "
    Google Desktop Search = "C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe" /startup
    QuickTime Task = "C:\Program Files\QuickTime\qttask.exe" -atboottime
    Symantec PIF AlertEng = "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" /a /m "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\AlertEng.dll "
    Adobe Reader Speed Launcher = "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe "
    itype = "C:\Program Files\Microsoft IntelliType Pro\itype.exe "
    IntelliPoint = "C:\Program Files\Microsoft IntelliPoint\ipoint.exe "
    SMSTray = C:\Program Files\Samsung\Samsung Media Studio 5\SMSTray.exe
    HKLM\Software\Microsoft\Windows\CurrentVersion\RunOnce
    *No values found*
    HKLM\Software\Microsoft\Windows\CurrentVersion\RunOnceEx
    *No values found*
    HKLM\Software\Microsoft\Windows\CurrentVersion\RunServices
    HKLM\Software\Microsoft\Windows\CurrentVersion\RunServicesOnce
    HKCU\Software\Microsoft\Windows\CurrentVersion\Run
    MSMSGS = "C:\Program Files\Messenger\msmsgs.exe" /background
    swg = C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
    ctfmon.exe = C:\WINDOWS\system32\ctfmon.exe
    EPSON Stylus CX9300F Series = C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATICFP.EXE /FU "C:\DOCUME~1\Owner\LOCALS~1\Temp\E_S14.tmp" /EF "HKCU "
    HKCU\Software\Microsoft\Windows\CurrentVersion\RunOnce
    *No values found*
    HKCU\Software\Microsoft\Windows\CurrentVersion\RunOnceEx
    HKCU\Software\Microsoft\Windows\CurrentVersion\RunServices
    HKCU\Software\Microsoft\Windows\CurrentVersion\RunServicesOnce
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\Run
    HKCU\Software\Microsoft\Windows NT\CurrentVersion\Run
    Autorun entries in Registry subkeys of:
    [OptionalComponents]
    *No subkeys found*
    *No subkeys found*
    *No subkeys found*
    *No subkeys found*
    File association entry for .EXE:
    HKEY_CLASSES_ROOT\exefile\shell\open\command
    (Default) = "%1" %*
    File association entry for .COM:
    HKEY_CLASSES_ROOT\comfile\shell\open\command
    (Default) = "%1" %*
    File association entry for .BAT:
    HKEY_CLASSES_ROOT\batfile\shell\open\command
    (Default) = "%1" %*
    File association entry for .PIF:
    HKEY_CLASSES_ROOT\piffile\shell\open\command
    (Default) = "%1" %*
    File association entry for .SCR:
    HKEY_CLASSES_ROOT\scrfile\shell\open\command
    (Default) = "%1" /S
    File association entry for .HTA:
    HKEY_CLASSES_ROOT\htafile\shell\open\command
    (Default) = C:\WINDOWS\system32\mshta.exe "%1" %*
    File association entry for .TXT:
    HKEY_CLASSES_ROOT\txtfile\shell\open\command
    (Default) = %SystemRoot%\system32\NOTEPAD.EXE %1
    Enumerating Active Setup stub paths:
    HKLM\Software\Microsoft\Active Setup\Installed Components
    (* = disabled by HKCU twin)
    [<{12d0ed0d-0ee0-4f90-8827-78cefb8f4988}] *
    StubPath = C:\WINDOWS\system32\ieudinit.exe
    [>{22d6f312-b0f6-11d0-94ab-0080c74c7e95}]
    StubPath = C:\WINDOWS\inf\unregmp2.exe /ShowWMP
    [>{26923b43-4d38-484f-9b9e-de460746276c}] *
    StubPath = C:\WINDOWS\system32\ie4uinit.exe -UserIconConfig
    [>{60B49E34-C7CC-11D0-8953-00A0C90347FF}] *
    StubPath = RunDLL32 IEDKCS32.DLL,BrandIE4 SIGNUP
    [>{61D8F9C3-79AF-4C07-9A42-64C99F59EC4B}] *
    [>{881dd1c5-3dcf-431b-b061-f3f88e8be88a}] *
    StubPath = %systemroot%\system32\shmgrate.exe OCInstallUserConfigOE
    [{2C7339CF-2B09-4501-B3F3-F3508C9228ED}] *
    StubPath = %SystemRoot%\system32\regsvr32.exe /s /n /i:/UserInstall %SystemRoot%\system32\themeui.dll
    [{44BBA840-CC51-11CF-AAFA-00AA00B6015C}] *
    StubPath = "%ProgramFiles%\Outlook Express\setup50.exe" /APP:OE /CALLER:WINNT /user /install
    [{44BBA842-CC51-11CF-AAFA-00AA00B6015B}] *
    StubPath = rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\msnetmtg.inf,NetMtg.Install.PerUser.NT
    [{5945c046-1e7d-11d1-bc44-00c04fd912be}] *
    StubPath = rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\msmsgs.inf,BLC.QuietInstall.PerUser
    [{6BF52A52-394A-11d3-B153-00C04F79FAA6}] *
    StubPath = rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\wmp11.inf,PerUserStub
    [{7790769C-0471-11d2-AF11-00C04FA35D02}] *
    StubPath = "%ProgramFiles%\Outlook Express\setup50.exe" /APP:WAB /CALLER:WINNT /user /install
    [{89820200-ECBD-11cf-8B85-00AA005B4340}] *
    StubPath = regsvr32.exe /s /n /i:U shell32.dll
    [{89820200-ECBD-11cf-8B85-00AA005B4383}] *
    StubPath = C:\WINDOWS\system32\ie4uinit.exe -BaseSettings
    Enumerating ICQ Agent Autostart apps:
    HKCU\Software\Mirabilis\ICQ\Agent\Apps
    Load/Run keys from C:\WINDOWS\WIN.INI:
    load=*INI section not found*
    run=*INI section not found*
    Load/Run keys from Registry:
    HKLM\..\Windows NT\CurrentVersion\WinLogon: load=*Registry value not found*
    HKLM\..\Windows NT\CurrentVersion\WinLogon: run=*Registry value not found*
    HKLM\..\Windows\CurrentVersion\WinLogon: load=*Registry key not found*
    HKLM\..\Windows\CurrentVersion\WinLogon: run=*Registry key not found*
    HKCU\..\Windows NT\CurrentVersion\WinLogon: load=*Registry value not found*
    HKCU\..\Windows NT\CurrentVersion\WinLogon: run=*Registry value not found*
    HKCU\..\Windows\CurrentVersion\WinLogon: load=*Registry key not found*
    HKCU\..\Windows\CurrentVersion\WinLogon: run=*Registry key not found*
    HKCU\..\Windows NT\CurrentVersion\Windows: load=
    HKCU\..\Windows NT\CurrentVersion\Windows: run=*Registry value not found*
    HKLM\..\Windows NT\CurrentVersion\Windows: load=*Registry value not found*
    HKLM\..\Windows NT\CurrentVersion\Windows: run=*Registry value not found*
    HKLM\..\Windows NT\CurrentVersion\Windows: AppInit_DLLs=C:\PROGRA~1\Google\GOOGLE~3\GOEC62~1.DLL
    Shell & screensaver key from C:\WINDOWS\SYSTEM.INI:
    Shell=*INI section not found*
    SCRNSAVE.EXE=*INI section not found*
    drivers=*INI section not found*
    Shell & screensaver key from Registry:
    Shell=Explorer.exe
    SCRNSAVE.EXE=C:\WINDOWS\System32\ssmypics.scr
    drivers=*Registry value not found*
    Policies Shell key:
    HKCU\..\Policies: Shell=*Registry key not found*
    HKLM\..\Policies: Shell=*Registry value not found*
    Checking for EXPLORER.EXE instances:
    C:\WINDOWS\Explorer.exe: PRESENT!
    C:\Explorer.exe: not present
    C:\WINDOWS\Explorer\Explorer.exe: not present
    C:\WINDOWS\System\Explorer.exe: not present
    C:\WINDOWS\System32\Explorer.exe: not present
    C:\WINDOWS\Command\Explorer.exe: not present
    C:\WINDOWS\Fonts\Explorer.exe: not present
    Checking for superhidden extensions:
    .lnk: HIDDEN! (arrow overlay: yes)
    .pif: HIDDEN! (arrow overlay: yes)
    .exe: not hidden
    .com: not hidden
    .bat: not hidden
    .hta: not hidden
    .scr: not hidden
    .shs: HIDDEN!
    .shb: HIDDEN!
    .vbs: not hidden
    .vbe: not hidden
    .wsh: not hidden
    .scf: HIDDEN! (arrow overlay: NO!)
    .url: HIDDEN! (arrow overlay: yes)
    .js: not hidden
    .jse: not hidden
    Verifying REGEDIT.EXE integrity:
    - Regedit.exe found in C:\WINDOWS
    - .reg open command is normal (regedit.exe %1)
    - Company name OK: 'Microsoft Corporation'
    - Original filename OK: 'REGEDIT.EXE'
    - File description: 'Registry Editor'
    Registry check passed
    Enumerating Browser Helper Objects:
    (no name) - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll - {02478D38-C3F9-4EFB-9B51-7695ECA05670}
    (no name) - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3}
    (no name) - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43}
    (no name) - c:\program files\google\googletoolbar2.dll - {AA58ED58-01DD-4d91-8333-CF10577473F7}
    (no name) - C:\Program Files\Google\GoogleToolbarNotifier\3.0.1225.9868\swg.dll - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D}
    (no name) - C:\Program Files\EPSON\EPSON Web-To-Page\EPSON Web-To-Page.dll - {E99421FB-68DD-40F0-B4AC-B7027CAE2F1A}
    Enumerating Task Scheduler jobs:
    At1.job
    Norton AntiVirus - Run Full System Scan - Owner.job
    Enumerating Download Program Files:
    [Shockwave ActiveX Control]
    InProcServer32 = C:\WINDOWS\system32\Adobe\Director\SwDir.dll
    CODEBASE = http://download.macromedia.com/pub/shockwave/cabs/director/sw.cab
    [YInstStarter Class]
    InProcServer32 = C:\PROGRA~1\Yahoo!\Common\yinsthelper.dll
    CODEBASE = C:\Program Files\Yahoo!\Common\yinsthelper.dll
    [Symantec Download Manager]
    InProcServer32 = C:\WINDOWS\Downloaded Program Files\symdlmgr.dll
    CODEBASE = https://webdl.symantec.com/activex/symdlmgr.cab
    [Java Plug-in 1.6.0_07]
    InProcServer32 = C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
    CODEBASE = http://java.sun.com/update/1.6.0/jinstall-1_6_0_07-windows-i586.cab
    InProcServer32 = C:\Program Files\Java\jre1.6.0_07\bin\npjpi160_07.dll
    Enumerating Winsock LSP files:
    NameSpace #1: C:\WINDOWS\System32\mswsock.dll
    NameSpace #2: C:\WINDOWS\System32\winrnr.dll
    NameSpace #3: C:\WINDOWS\System32\mswsock.dll
    Protocol #1: C:\WINDOWS\system32\mswsock.dll
    Protocol #2: C:\WINDOWS\system32\mswsock.dll
    Protocol #3: C:\WINDOWS\system32\mswsock.dll
    Protocol #4: C:\WINDOWS\system32\rsvpsp.dll
    Protocol #5: C:\WINDOWS\system32\rsvpsp.dll
    Protocol #6: C:\WINDOWS\system32\mswsock.dll
    Protocol #7: C:\WINDOWS\system32\mswsock.dll
    Protocol #8: C:\WINDOWS\system32\mswsock.dll
    Protocol #9: C:\WINDOWS\system32\mswsock.dll
    Protocol #10: C:\WINDOWS\system32\mswsock.dll
    Protocol #11: C:\WINDOWS\system32\mswsock.dll
    Protocol #12: C:\WINDOWS\system32\mswsock.dll
    Protocol #13: C:\WINDOWS\system32\mswsock.dll
    Protocol #14: C:\WINDOWS\system32\mswsock.dll
    Protocol #15: C:\WINDOWS\system32\mswsock.dll
    Protocol #16: C:\WINDOWS\system32\mswsock.dll
    Protocol #17: C:\WINDOWS\system32\mswsock.dll
    Protocol #18: C:\WINDOWS\system32\mswsock.dll
    Protocol #19: C:\WINDOWS\system32\mswsock.dll
    Enumerating Windows NT/2000/XP services
    2Wire USB: system32\DRIVERS\2WirePCP.sys (manual start)
    Microsoft ACPI Driver: System32\DRIVERS\ACPI.sys (system)
    Adobe LM Service: "C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe" (manual start)
    Microsoft Kernel Acoustic Echo Canceller: system32\drivers\aec.sys (manual start)
    AFD Networking Support Environment: \SystemRoot\System32\drivers\afd.sys (system)
    Agere Systems Soft Modem: System32\DRIVERS\AGRSM.sys (manual start)
    Service for Realtek AC97 Audio (WDM): system32\drivers\ALCXWDM.SYS (manual start)
    Alerter: %SystemRoot%\System32\svchost.exe -k LocalService (autostart)
    Application Layer Gateway Service: %SystemRoot%\System32\alg.exe (manual start)
    A4Tech PS/2 Port Mouse Driver: System32\DRIVERS\Amps2prt.sys (manual start)
    Application Management: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
    RAS Asynchronous Media Driver: System32\DRIVERS\asyncmac.sys (manual start)
    Standard IDE/ESDI Hard Disk Controller: System32\DRIVERS\atapi.sys (system)
    ATM ARP Client Protocol: System32\DRIVERS\atmarpc.sys (manual start)
    Windows Audio: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    Audio Stub Driver: System32\DRIVERS\audstub.sys (manual start)
    Automatic LiveUpdate Scheduler: "C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe" (autostart)
    Background Intelligent Transfer Service: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    BrSplService: C:\WINDOWS\System32\brsvc01a.exe (autostart)
    Computer Browser: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    Brother USB Still Image driver: System32\Drivers\BrScnUsb.sys (manual start)
    Brother MFC Serial Port Interface WDM Driver: System32\Drivers\BrSerIf.sys (manual start)
    Brother MFC USB Serial WDM Driver: System32\Drivers\BrUsbSer.sys (manual start)
    Symantec Event Manager: "C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe" /h ccCommon (autostart)
    Symantec Settings Manager: "C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe" /h ccCommon (autostart)
    CD-ROM Driver: System32\DRIVERS\cdrom.sys (system)
    Indexing Service: %SystemRoot%\system32\cisvc.exe (manual start)
    ClipBook: %SystemRoot%\system32\clipsrv.exe (manual start)
    Symantec Lic NetConnect service: "C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe" /h cltCommon (autostart)
    COM+ System Application: C:\WINDOWS\System32\dllhost.exe /Processid:{02D4B3F1-FD88-11D1-960D-00805FC79235} (manual start)
    Cryptographic Services: %SystemRoot%\system32\svchost.exe -k netsvcs (autostart)
    DCOM Server Process Launcher: %SystemRoot%\system32\svchost -k DcomLaunch (autostart)
    DHCP Client: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    Disk Driver: System32\DRIVERS\disk.sys (system)
    Logical Disk Manager Administrative Service: %SystemRoot%\System32\dmadmin.exe /com (manual start)
    dmboot: System32\drivers\dmboot.sys (disabled)
    dmio: System32\drivers\dmio.sys (disabled)
    dmload: System32\drivers\dmload.sys (disabled)
    Logical Disk Manager: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    Microsoft Kernel DLS Syntheiszer: system32\drivers\DMusic.sys (manual start)
    DNS Client: %SystemRoot%\System32\svchost.exe -k NetworkService (autostart)
    Microsoft Kernel DRM Audio Descrambler: system32\drivers\drmkaud.sys (manual start)
    Symantec Eraser Control driver: \??\C:\Program Files\Common Files\Symantec Shared\EENGINE\eeCtrl.sys (system)
    Speedstream Ethernet USB Adapter: system32\DRIVERS\enethusb.sys (manual start)
    EraserUtilRebootDrv: \??\C:\Program Files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys (manual start)
    Error Reporting Service: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    Event Log: %SystemRoot%\system32\services.exe (autostart)
    COM+ Event System: C:\WINDOWS\System32\svchost.exe -k netsvcs (manual start)
    Fast User Switching Compatibility: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
    Floppy Disk Controller Driver: System32\DRIVERS\fdc.sys (manual start)
    Floppy Disk Driver: System32\DRIVERS\flpydisk.sys (manual start)
    FltMgr: system32\drivers\fltmgr.sys (system)
    Volume Manager Driver: System32\DRIVERS\ftdisk.sys (system)
    Game Port Enumerator: System32\DRIVERS\gameenum.sys (manual start)
    GoogleDesktopManager: "C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe" (manual start)
    Generic Packet Classifier: System32\DRIVERS\msgpc.sys (manual start)
    Google Updater Service: "C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe" (autostart)
    Help and Support: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    HID Input Service: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    Microsoft HID Class Driver: system32\DRIVERS\hidusb.sys (manual start)
    HTTP: System32\Drivers\HTTP.sys (manual start)
    HTTP SSL: %SystemRoot%\System32\svchost.exe -k HTTPFilter (manual start)
    i8042 Keyboard and PS/2 Mouse Port Driver: System32\DRIVERS\i8042prt.sys (system)
    InstallDriver Table Manager: "C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe" (manual start)
    CD-Burning Filter Driver: System32\DRIVERS\imapi.sys (system)
    IMAPI CD-Burning COM Service: C:\WINDOWS\System32\imapi.exe (manual start)
    Intel Processor Driver: System32\DRIVERS\intelppm.sys (system)
    IPv6 Windows Firewall Driver: system32\drivers\ip6fw.sys (manual start)
    IP Traffic Filter Driver: System32\DRIVERS\ipfltdrv.sys (manual start)
    IP in IP Tunnel Driver: System32\DRIVERS\ipinip.sys (manual start)
    IP Network Address Translator: System32\DRIVERS\ipnat.sys (manual start)
    IPSEC driver: System32\DRIVERS\ipsec.sys (system)
    IR Enumerator Service: System32\DRIVERS\irenum.sys (manual start)
    PnP ISA/EISA Bus Driver: System32\DRIVERS\isapnp.sys (system)
    Symantec IS Password Validation: "C:\Program Files\Norton AntiVirus\isPwdSvc.exe" (manual start)
    Keyboard Class Driver: System32\DRIVERS\kbdclass.sys (system)
    Keyboard HID Driver: system32\DRIVERS\kbdhid.sys (system)
    Microsoft Kernel Wave Audio Mixer: system32\drivers\kmixer.sys (manual start)
    Server: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    Workstation: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    LiveUpdate: "C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE" (manual start)
    LiveUpdate Notice Service Ex: "C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe" /h ccCommon (autostart)
    LiveUpdate Notice Service: "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" /m "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PifEng.dll" (autostart)
    TCP/IP NetBIOS Helper: %SystemRoot%\System32\svchost.exe -k LocalService (autostart)
    Messenger: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    NetMeeting Remote Desktop Sharing: C:\WINDOWS\System32\mnmsrvc.exe (manual start)
    Unimodem Streaming Filter Device: system32\drivers\MODEMCSA.sys (manual start)
    Mouse Class Driver: System32\DRIVERS\mouclass.sys (system)
    Mouse HID Driver: System32\DRIVERS\mouhid.sys (manual start)
    WebDav Client Redirector: System32\DRIVERS\mrxdav.sys (manual start)
    MRXSMB: System32\DRIVERS\mrxsmb.sys (system)
    Distributed Transaction Coordinator: C:\WINDOWS\System32\msdtc.exe (manual start)
    Windows Installer: C:\WINDOWS\system32\msiexec.exe /V (manual start)
    Microsoft Streaming Service Proxy: system32\drivers\MSKSSRV.sys (manual start)
    Microsoft Streaming Clock Proxy: system32\drivers\MSPCLOCK.sys (manual start)
    Microsoft Streaming Quality Manager Proxy: system32\drivers\MSPQM.sys (manual start)
    Microsoft System Management BIOS Driver: System32\DRIVERS\mssmbios.sys (manual start)
    Microsoft MPU-401 MIDI UART Driver: system32\drivers\msmpu401.sys (manual start)
    NAVENG: \??\C:\PROGRA~1\COMMON~1\SYMANT~1\VIRUSD~1\20080825.003\NAVENG.SYS (manual start)
    NAVEX15: \??\C:\PROGRA~1\COMMON~1\SYMANT~1\VIRUSD~1\20080825.003\NAVEX15.SYS (manual start)
    Remote Access NDIS TAPI Driver: System32\DRIVERS\ndistapi.sys (manual start)
    NDIS Usermode I/O Protocol: System32\DRIVERS\ndisuio.sys (manual start)
    Remote Access NDIS WAN Driver: System32\DRIVERS\ndiswan.sys (manual start)
    NetBIOS Interface: System32\DRIVERS\netbios.sys (system)
    NetBT: System32\DRIVERS\netbt.sys (system)
    Network DDE: %SystemRoot%\system32\netdde.exe (manual start)
    Network DDE DSDM: %SystemRoot%\system32\netdde.exe (manual start)
    Net Logon: %SystemRoot%\System32\lsass.exe (manual start)
    Network Connections: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
    Network Location Awareness (NLA): %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
    NT LM Security Support Provider: %SystemRoot%\System32\lsass.exe (manual start)
    Removable Storage: %SystemRoot%\system32\svchost.exe -k netsvcs (autostart)
    nv: System32\DRIVERS\nv4_mini.sys (manual start)
    IPX Traffic Filter Driver: System32\DRIVERS\nwlnkflt.sys (manual start)
    IPX Traffic Forwarder Driver: System32\DRIVERS\nwlnkfwd.sys (manual start)
    Office Source Engine: "C:\Program Files\Common Files\Microsoft Shared\Source Engine\OSE.EXE" (manual start)
    Parallel port driver: System32\DRIVERS\parport.sys (manual start)
    PCI Bus Driver: System32\DRIVERS\pci.sys (system)
    PCIIde: System32\DRIVERS\pciide.sys (system)
    Plug and Play: %SystemRoot%\system32\services.exe (autostart)
    Microsoft IntelliPoint Filter Driver: system32\DRIVERS\point32.sys (manual start)
    IPSEC Services: %SystemRoot%\System32\lsass.exe (autostart)
    WAN Miniport (PPTP): System32\DRIVERS\raspptp.sys (manual start)
    Processor Driver: System32\DRIVERS\processr.sys (system)
    Protected Storage: %SystemRoot%\system32\lsass.exe (autostart)
    QoS Packet Scheduler: System32\DRIVERS\psched.sys (manual start)
    Direct Parallel Link Driver: System32\DRIVERS\ptilink.sys (manual start)
    Remote Access Auto Connection Driver: System32\DRIVERS\rasacd.sys (system)
    Remote Access Auto Connection Manager: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
    WAN Miniport (L2TP): System32\DRIVERS\rasl2tp.sys (manual start)
    Remote Access Connection Manager: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
    Remote Access PPPOE Driver: System32\DRIVERS\raspppoe.sys (manual start)
    Direct Parallel: System32\DRIVERS\raspti.sys (manual start)
    Rdbss: System32\DRIVERS\rdbss.sys (system)
    RDPCDD: System32\DRIVERS\RDPCDD.sys (system)
    Remote Desktop Help Session Manager: C:\WINDOWS\system32\sessmgr.exe (manual start)
    Digital CD Audio Playback Filter Driver: System32\DRIVERS\redbook.sys (system)
    Routing and Remote Access: %SystemRoot%\System32\svchost.exe -k netsvcs (disabled)
    Remote Procedure Call (RPC) Locator: %SystemRoot%\System32\locator.exe (manual start)
    Remote Procedure Call (RPC): %SystemRoot%\system32\svchost -k rpcss (autostart)
    QoS RSVP: %SystemRoot%\System32\rsvp.exe (manual start)
    Security Accounts Manager: %SystemRoot%\system32\lsass.exe (autostart)
    Smart Card: %SystemRoot%\System32\SCardSvr.exe (manual start)
    Task Scheduler: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    Secdrv: System32\DRIVERS\secdrv.sys (manual start)
    Secondary Logon: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    System Event Notification: %SystemRoot%\system32\svchost.exe -k netsvcs (autostart)
    Serenum Filter Driver: System32\DRIVERS\serenum.sys (manual start)
    Serial port driver: System32\DRIVERS\serial.sys (system)
    Windows Firewall/Internet Connection Sharing (ICS): %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    Shell Hardware Detection: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    SiS AGP Filter: System32\DRIVERS\SISAGPX.sys (system)
    SIV Kernel Driver: \??\C:\WINDOWS\system32\Drivers\SIVX32.sys (manual start)
    SPBBCDrv: \??\C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCDrv.sys (system)
    Microsoft Kernel Audio Splitter: system32\drivers\splitter.sys (manual start)
    Print Spooler: %SystemRoot%\system32\spoolsv.exe (autostart)
    System Restore Filter Driver: System32\DRIVERS\sr.sys (system)
    System Restore Service: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    SRTSP: System32\Drivers\SRTSP.SYS (manual start)
    SRTSPL: System32\Drivers\SRTSPL.SYS (manual start)
    SRTSPX: System32\Drivers\SRTSPX.SYS (system)
    Srv: System32\DRIVERS\srv.sys (manual start)
    SSDP Discovery Service: %SystemRoot%\System32\svchost.exe -k LocalService (manual start)
    Windows Image Acquisition (WIA): %SystemRoot%\System32\svchost.exe -k imgsvc (autostart)
    Software Bus Driver: System32\DRIVERS\swenum.sys (manual start)
    Microsoft Kernel GS Wavetable Synthesizer: system32\drivers\swmidi.sys (manual start)
    MS Software Shadow Copy Provider: C:\WINDOWS\System32\dllhost.exe /Processid:{EC170CCB-C7CC-4726-A69E-4B736731BCA2} (manual start)
    Symantec Core LC: "C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe" (manual start)
    Symantec AppCore Service: "C:\Program Files\Common Files\Symantec Shared\AppCore\AppSvc32.exe" (autostart)
    SYMDNS: \SystemRoot\System32\Drivers\SYMDNS.SYS (manual start)
    SymEvent: \??\C:\WINDOWS\system32\Drivers\SYMEVENT.SYS (manual start)
    SYMFW: \SystemRoot\System32\Drivers\SYMFW.SYS (manual start)
    SYMIDS: \SystemRoot\System32\Drivers\SYMIDS.SYS (manual start)
    SYMIDSCO: \??\C:\PROGRA~1\COMMON~1\SYMANT~1\SymcData\IDS-DI~1\20080813.001\SymIDSCo.sys (manual start)
    SYMNDIS: \SystemRoot\System32\Drivers\SYMNDIS.SYS (manual start)
    SYMREDRV: \SystemRoot\System32\Drivers\SYMREDRV.SYS (manual start)
    SYMTDI: \SystemRoot\System32\Drivers\SYMTDI.SYS (system)
    Microsoft Kernel System Audio Device: system32\drivers\sysaudio.sys (manual start)
    Performance Logs and Alerts: %SystemRoot%\system32\smlogsvc.exe (manual start)
    Telephony: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
    TCP/IP Protocol Driver: System32\DRIVERS\tcpip.sys (system)
    Terminal Device Driver: System32\DRIVERS\termdd.sys (system)
    Terminal Services: %SystemRoot%\System32\svchost -k DComLaunch (manual start)
    Themes: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    Distributed Link Tracking Client: %SystemRoot%\system32\svchost.exe -k netsvcs (autostart)
    Microcode Update Driver: System32\DRIVERS\update.sys (manual start)
    Universal Plug and Play Device Host: %SystemRoot%\System32\svchost.exe -k LocalService (manual start)
    Uninterruptible Power Supply: %SystemRoot%\System32\ups.exe (manual start)
    Microsoft USB Generic Parent Driver: System32\DRIVERS\usbccgp.sys (manual start)
    Microsoft USB 2.0 Enhanced Host Controller Miniport Driver: System32\DRIVERS\usbehci.sys (manual start)
    USB2 Enabled Hub: System32\DRIVERS\usbhub.sys (manual start)
    Microsoft USB Open Host Controller Miniport Driver: System32\DRIVERS\usbohci.sys (manual start)
    Microsoft USB PRINTER Class: System32\DRIVERS\usbprint.sys (manual start)
    USB Scanner Driver: system32\DRIVERS\usbscan.sys (manual start)
    USB Mass Storage Driver: System32\DRIVERS\USBSTOR.SYS (manual start)
    VGA Display Controller.: \SystemRoot\System32\drivers\vga.sys (system)
    Volume Shadow Copy: %SystemRoot%\System32\vssvc.exe (manual start)
    Windows Time: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
    Remote Access IP ARP Driver: System32\DRIVERS\wanarp.sys (manual start)
    Microsoft WINMM WDM Audio Compatibility Driver: system32\drivers\wdmaud.sys (manual start)
    WebClient: %SystemRoot%\System32\svchost.exe -k LocalService (autostart)
    Windows Management Instrumentation: %systemroot%\system32\svchost.exe -k netsvcs (autostart)
    Portable Media Serial Number Service: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
    WMI Performance Adapter: C:\WINDOWS\system32\wbem\wmiapsrv.exe (manual start)
    Windows Media Player Network Sharing Service: "C:\Program Files\Windows Media Player\WMPNetwk.exe" (manual start)
    WpdUsb: system32\DRIVERS\wpdusb.sys (manual start)
    Security Center: %SystemRoot%\System32\svchost.exe -k netsvcs (disabled)
    Automatic Updates: %systemroot%\system32\svchost.exe -k netsvcs (autostart)
    Windows Driver Foundation - User-mode Driver Framework Platform Driver: system32\DRIVERS\WudfPf.sys (system)
    Windows Driver Foundation - User-mode Driver Framework Reflector: system32\DRIVERS\wudfrd.sys (manual start)
    Windows Driver Foundation - User-mode Driver Framework: %SystemRoot%\system32\svchost.exe -k WudfServiceGroup (autostart)
    Wireless Zero Configuration: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
    Network Provisioning Service: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
    Enumerating Windows NT logon/logoff scripts:
    *No scripts set to run*
    Windows NT checkdisk command:
    BootExecute = autocheck autochk *
    Windows NT 'Wininit.ini':
    PendingFileRenameOperations: *Registry value not found*
    Enumerating ShellServiceObjectDelayLoad items:
    PostBootReminder: C:\WINDOWS\system32\SHELL32.dll
    CDBurn: C:\WINDOWS\system32\SHELL32.dll
    WebCheck: C:\WINDOWS\system32\webcheck.dll
    WPDShServiceObj: C:\WINDOWS\system32\WPDShServiceObj.dll
    SysTray: C:\WINDOWS\system32\stobject.dll
    HKCU\Software\Microsoft\Windows\CurrentVersion\policies\Explorer\Run
    HKLM\Software\Microsoft\Windows\CurrentVersion\policies\Explorer\Run
    End of report, 37,773 bytes
    Report generated in 0.469 seconds
    Command line options:
    /verbose - to add additional info on each section
    /complete - to include empty sections and unsuspicious data
    /full - to include several rarely-important sections
    /force9x - to include Win9x-only startups even if running on WinNT
    /forcent - to include WinNT-only startups even if running on Win9x
    /forceall - to include all Win9x and WinNT startups, regardless of platform
    /history - to list version history only
    Second post to follow.
    Sue
