Solved Terrys reports Part 2 GMER pt 1
Discussion in 'Malware and Virus Removal Archive' started by Howattee, 2010/12/07.
  1. 2010/12/15
    Howattee Lifetime Subscription
    Howattee Well-Known Member Thread Starter
    Finally Eset results are:
    No threats found - yay
  2. 2010/12/15
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. Run defrag at your convenience.
    11. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    12. Please, let me know, how your computer is doing.
    Sorry, Broni, but what infection?
  5. 2010/12/16
    Here is log:
    All processes killed
    ========== OTL ==========
    [EMPTYTEMP]
    User: All Users
    User: Default User
    User: LocalService
    ->Temporary Internet Files folder emptied: 58600 bytes
    User: NetworkService
    User: Terry
    ->Temp folder emptied: 685052 bytes
    ->Temporary Internet Files folder emptied: 85924444 bytes
    ->Java cache emptied: 0 bytes
    ->FireFox cache emptied: 6900277 bytes
    ->Flash cache emptied: 1345 bytes
    %systemroot%\System32 .tmp files removed: 22106368 bytes
    Windows Temp folder emptied: 45770484 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder
    emptied: 0 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 154.00 mb
    [EMPTYFLASH]
    User: All Users
    User: Default User
    User: LocalService
    User: Terry
    Restore points cleared and new OTL Restore Point set!
    OTL by OldTimer - Version 3.2.17.3 log created on 12162010_141622
    C:\WINDOWS\temp\a60553f318a2ef4d6d9d483b7a1197dePSK_PLUGINS_0 moved successfully.
    Doing now.
  6. 2010/12/16
    Well, actually me computer is doing fine. I think that my problem was all down to overclocking corsair RAM on a Gigabyte motherboard. ho hum.
    Thanks for all your help, Broni.
    Merry Christmas.
  7. 2010/12/16
    Oh and Broni, I take my hat off to your helping me and all those other people on the forums worldwide, just seen the 20K, wow! Rock on.
  8. 2010/12/16
    I don't seem to be able to mark this thread as 'resolved'. Can anyone help please?
  9. 2010/12/16
    True, your computer was rather clean. It's just my canned reply.
    Sorry for not double checking :)
    In this forum, only I can mark topic as resolved.
    Good luck and stay safe :)
  10. 2010/12/17
    Well, thanks again, Broni. I am happy for you to mark this topic resolved.
    Regards & Merry Christmas.
    Terry
    Dumfries
    Scotland
  11. 2010/12/17
    Merry Christmas :)
