Solved system32 error
Discussion in 'Malware and Virus Removal Archive' started by mireille2, 2008/06/12.
  1. 2008/06/15
    mireille2
    mireille2 Inactive Thread Starter
    Kaspersky Scan
    Hi Geri
    Could you please send me the link for the Kaspersky Online Scan?
    Thank you!
    mireille2
  2. 2008/06/15
    Geri Lifetime Subscription
    Geri Inactive Alumni
    Hi
    Here you go.
    Please do an online scan with Kaspersky WebScanner
    Click on "Accept" If your pop "“up blocker blocks any windows from opening.
    Click Run on the window that opens.
    Windows Vista users you must open the web browser using the Run as Administrator command.
    • The program will launch and then begin downloading the latest definition files:
    • Under Scan on the left side.Click on My Computer
    • This will start the program and scan your system.
    • Click the "Scan Report" On the left side.
    • The scan will take a while so be patient and let it run.
    • Once the scan is complete it will display if your system has been infected.
      • Click the Save Report As button, and in the Browse dialog box, type a name for the scan report file that you want to create and select its type Text file. Click OK to save the file.:
    • Save the text file to your desktop.
    • Copy and paste that information in your next post.
    Geri
    mireille2
    New Kaspersky Scan Report
    KASPERSKY ONLINE SCANNER 7 REPORT
    Sunday, June 15, 2008
    Operating System: Microsoft Windows XP Home Edition Service Pack 2 (build 2600)
    Kaspersky Online Scanner 7 version: 7.0.25.0
    Program database last update: Monday, June 16, 2008 02:43:29
    Records in database: 870683
    Scan settings:
    Scan using the following database: extended
    Scan archives: yes
    Scan mail databases: yes
    Scan area - My Computer:
    C:\
    D:\
    Scan statistics:
    Files scanned: 44296
    Threat name: 1
    Infected objects: 1
    Suspicious objects: 0
    Duration of the scan: 01:08:07
    File name / Threat name / Threats count
    C:\RECYCLER\S-1-5-21-1482476501-1417001333-839522115-1003\Dc1.mp3 Infected: Trojan-Downloader.WMA.Wimad.n 1
    The selected area was scanned.
  5. 2008/06/15
    Hi mireille2
    OK Very good.
    That is in your recycle bin.
    Empty your recycle bin
    Now do this.
    Click Start>Run in the run box copy and paste or type ComboFix /u then hit Enter to uninstall ComboFix and remove the files/folders it created.
    Now this.
    Please re-open HiJackThis and scan only. Check the boxes next to all the entries listed below.
    O3 - Toolbar: (no name) - {0ff9a677-542a-481d-a6d6-3fa32d8a806d} - (no file)
    O4 - HKCU\..\Run: [SweetIM] C:\Program Files\Macrogaming\SweetIM\SweetIM.exe
    Now close all windows other than HiJackThis, then click Fix Checked.
    Close HJT.
    You also need to update your Java. Using Add/Remove Programs in the Control Panel, remove all Java and/or JRE installations. Reboot when done. Then, go to Sun and download then install the Java Runtime Environment (JRE) 6 Update *.
    * = The Latest version available .
    Let me know how things are running.
    Geri
  6. 2008/06/16
    mireille2
    ComboFix/u
    Hi Geri
    I can't uninstall ComboFix. I followed your instructions and I get a message box saying that it can't find that file. But I still have ComboFix on my deskktop.
    Thank You!
    mireille2
  7. 2008/06/16
    mireille2
    combofis uninstall
    Hi Geri
    Please disregard my last post, I did finally uninstall ComboFix. And I fixed the files using Hijackthis. And I removed all the Java installations I had and downloaded and installed the recent one.
    Things seem to run good so far.
    Thank you very much for you help.
    mireille2
  8. 2008/06/16
    Hi mireille2
    OK That's good to hear.
    Glad I could help out.
    Please look at this link for some preventive recommendations, It could keep you from ending up back here to the Spyware and Virus Removal Forums.
    http://www.windowsbbs.com/showthread.php?t=67958
    I'll mark this one Resolved.
    Surf Safely.
    Geri
