Resolved System Shutdown sometimes does restart instead
Discussion in 'Windows 7' started by jorjab, 2015/06/16.
  1. 2015/06/22
  2. 2015/06/22
    jorjab Lifetime Subscription
    jorjab Well-Known Member Thread Starter
    In Autoruns remove the following items:
    rdpclip
    FAHConsole
    HotKeysCmds
    IgfxTray
    Persistance
    Realtek HD Audio Manager
    USB 3.0 Monitor
    Wondershare Helper Compact
    Microsoft Office
    HP Simple Save Monitor
    Monitor Ink Alerts - HP OfficeJet Pro 8600
    Internet Explorer
    Windows Mail (Both Entries)
    Reboot the computer after removing those items and see if the behavior still occurs.
  5. 2015/06/28
    SpywareDr
    Create a new "Shutdown" shortcut on your Desktop using the following for the command:
    C:\Windows\System32\shutdown.exe -s -t 0 -f​
    Now double-click that new Shortcut icon and see if it stays shutdown.
    If not, check your CMOS/BIOS Settings and try and disable anything that refers to "Wake-on-LAN ", Wake-on-whatever.
  6. 2015/06/28
    Ok - will try that and post. Problem happened once more to me the other day and most of the time does not occur.
  7. 2015/07/15
    I have used both the suggested shortcut as well as now performing normal way of shutdown. Problem has not happened since my last post. I have no idea what is causing the occasional problem and as it is now not happening ( of course it will happen after this post ;) Murphy's Law I think?)
    Will close this post and only repost if I ever find an answer .
    Thank you all anyway for your help and suggestions.
  8. 2015/07/15
    SpywareDr
  9. 2015/07/15
    Thanks for letting us know. :)
  10. 2015/07/15
    I waited so long to post again as I wanted to see if it would happen again.
