Solved System crashes
Discussion in 'Malware and Virus Removal Archive' started by SVEN, 2012/01/14.
  1. 2012/01/15
    SVEN
    SVEN Well-Known Member Thread Starter
    C:\System Volume Information\_restore{991CD2A5-379A-4DD2-8A03-B4CDCC050A6E}\RP587\A0062369.exe a variant of Win32/Toolbar.SearchSuite application cleaned by deleting - quarantined
    C:\System Volume Information\_restore{991CD2A5-379A-4DD2-8A03-B4CDCC050A6E}\RP587\A0062375.dll probably a variant of Win32/Toolbar.SearchSuite application cleaned by deleting - quarantined
    C:\System Volume Information\_restore{991CD2A5-379A-4DD2-8A03-B4CDCC050A6E}\RP587\A0062377.dll a variant of Win32/Toolbar.SearchSuite application cleaned by deleting - quarantined
    C:\System Volume Information\_restore{991CD2A5-379A-4DD2-8A03-B4CDCC050A6E}\RP593\A0065551.DLL a variant of Win32/FunWeb.AA application cleaned by deleting - quarantined
    C:\System Volume Information\_restore{991CD2A5-379A-4DD2-8A03-B4CDCC050A6E}\RP593\A0065552.DLL Win32/Toolbar.MyWebSearch application cleaned by deleting - quarantined
    C:\System Volume Information\_restore{991CD2A5-379A-4DD2-8A03-B4CDCC050A6E}\RP593\A0065553.DLL Win32/Toolbar.MyWebSearch application cleaned by deleting - quarantined
    C:\System Volume Information\_restore{991CD2A5-379A-4DD2-8A03-B4CDCC050A6E}\RP627\A0067652.exe a variant of Win32/Toolbar.MyWebSearch.O application cleaned by deleting - quarantined
    C:\System Volume Information\_restore{991CD2A5-379A-4DD2-8A03-B4CDCC050A6E}\RP627\A0067654.DLL a variant of Win32/FunWeb.AA application cleaned by deleting - quarantined
    C:\System Volume Information\_restore{991CD2A5-379A-4DD2-8A03-B4CDCC050A6E}\RP627\A0067655.DLL Win32/Toolbar.MyWebSearch application cleaned by deleting - quarantined
    C:\System Volume Information\_restore{991CD2A5-379A-4DD2-8A03-B4CDCC050A6E}\RP627\A0067656.DLL Win32/Toolbar.MyWebSearch application cleaned by deleting - quarantined
    I disabled the Java update
  2. 2012/01/15
    Read my previous reply.
    Then....
    Your computer is clean [​IMG]
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point, using following OTL script:
    Run OTL
    • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [EMPTYFLASH]
    [emptyjava]
    [CLEARALLRESTOREPOINTS]
    [Reboot]
    • Post resulting log.
    2. Now, we'll remove all tools, we used during our cleaning process
    Clean up with OTL:
    • Double-click OTL.exe to start the program.
    • Close all other programs apart from OTL as this step will require a reboot
    • On the OTL main screen, press the CLEANUP button
    • Say Yes to the prompt and then allow the program to reboot your computer.
    3. Make sure, Windows Updates are current.
    4. If any Trojan was listed among your infection(s), make sure, you change all of your on-line important passwords (bank account(s), secured web sites, etc.) immediately!
    7. Run Temporary File Cleaner (TFC) weekly.
    10. (Windows XP only) Run defrag at your convenience.
    11. When installing\updating ANY program, make sure you always select "Custom " installation, so you can UN-check any possible "drive-by-install" (foistware), like toolbars etc., which may try to install along with the legitimate program. Do NOT click "Next" button without looking at any given page.
    12. Read How did I get infected?, With steps so it does not happen again!: http://www.bleepingcomputer.com/forums/topic2520.html
    13. Please, let me know, how your computer is doing.
    SVEN
    Broni.
    I ran the fix, but it will not reboot, it just sits there and I can not even move it to the side. It says Prcessing complete, my taskbar and all icons on the desk top are gone.
    Do I force a reboot by holding the power button?
    Sven
    Never mind, it just rebootet
  5. 2012/01/15
    SVEN
    All processes killed
    ========== OTL ==========
    [EMPTYTEMP]
    User: Administrator
    User: All Users
    User: Default User
    User: LocalService
    User: NetworkService
    ->Temp folder emptied: 2302 bytes
    User: Sven Albrecht
    ->Temp folder emptied: 25816 bytes
    ->Temporary Internet Files folder emptied: 4886335 bytes
    ->Java cache emptied: 0 bytes
    ->Flash cache emptied: 456 bytes
    Windows Temp folder emptied: 127074 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 5.00 mb
    [EMPTYFLASH]
    User: Administrator
    User: All Users
    User: Default User
    User: LocalService
    User: Sven Albrecht
    [EMPTYJAVA]
    User: Administrator
    User: All Users
    User: Default User
    User: LocalService
    User: Sven Albrecht
    Total Java Files Cleaned = 0.00 mb
    Restore points cleared and new OTL Restore Point set!
    OTL by OldTimer - Version 3.2.31.0 log created on 01152012_131245
    File\Folder C:\Documents and Settings\Sven Albrecht\Local Settings\Temp\Perflib_Perfdata_7fc.dat not found!
    File\Folder C:\WINDOWS\temp\logishrd\LVPrcInj01.dll not found!
  6. 2012/01/15
    SVEN
    Hi Broni
    Thank you very much for all your help.
    My system is running great and I had no more BSOD's.
    Thanks again.
    Sven
  7. 2012/01/15
    Yes!! [​IMG]
    Good luck and stay safe :)
