Solved svchost.exe error 0x7c91b21a
Discussion in 'Malware and Virus Removal Archive' started by Jayman007, 2010/06/17.
  1. 2010/06/20
    I'm glad to hear good news :)
    As for recovery console password, see here: http://www.computerhope.com/forum/index.php?topic=53700.msg336447#msg336447
    Just set the value to "zero ".
    Run OTL
      :OTL
      O9 - Extra Button: QQ - {c95fe080-8f5d-11d2-a20b-00aa003c157b} - Reg Error: Value error. File not found
      O9 - Extra 'Tools' menuitem : Tencent QQ - {c95fe080-8f5d-11d2-a20b-00aa003c157b} - Reg Error: Value error. File not found
      O16 - DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} http://fpdownload.macromedia.com/get.../ultrashim.cab  (Reg Error: Key error.)
      O16 - DPF: {CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA} http://java.sun.com/update/1.5.0/jin...ndows-i586.cab (Reg Error: Key error.)
      O16 - DPF: {CAFEEFAC-0015-0000-0012-ABCDEFFEDCBA} http://java.sun.com/update/1.5.0/jin...ndows-i586.cab (Reg Error: Key error.)
      O16 - DPF: {CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jin...ndows-i586.cab (Reg Error: Key error.)
      O16 - DPF: {CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jin...ndows-i586.cab (Reg Error: Key error.)
      O16 - DPF: {CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jin...ndows-i586.cab (Reg Error: Key error.)
      O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab  (Reg Error: Key error.)
      O16 - DPF: Microsoft XML Parser for Java file:///C:/WINDOWS/Java/classes/xmldso.cab  (Reg Error: Key error.)
      [2007/06/05 01:16:27 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Viewpoint
      @Alternate Data Stream - 88 bytes -> C:\WINDOWS\System32\net1.exe:SummaryInformation
      @Alternate Data Stream - 88 bytes -> C:\WINDOWS\System32\dllhost.exe:SummaryInformation
      @Alternate Data Stream - 88 bytes -> C:\WINDOWS\System32\ati2evxx.exe:SummaryInformation
      @Alternate Data Stream - 4752 bytes -> D:\My Documents\home.html:Q30lsldxJoudresxAaaqpcawXc
      @Alternate Data Stream - 370 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:5F7539FF
      @Alternate Data Stream - 197 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:DDE29E40
      @Alternate Data Stream - 179 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:DFC5A2B2
      @Alternate Data Stream - 164 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:D2F2F703
      @Alternate Data Stream - 147 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:B7177954
      @Alternate Data Stream - 126 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:5F64C164
      @Alternate Data Stream - 125 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:B42C512A
      @Alternate Data Stream - 12 bytes -> C:\WINDOWS\system32:{4B9A1497-0817-47C4-9612-D6A1C53ACF57}
      @Alternate Data Stream - 12 bytes -> C:\WINDOWS\system32:{4B9A1497-0817-47C4-9612-D5A1C53ACF57}
      @Alternate Data Stream - 118 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:F10A4358
      @Alternate Data Stream - 118 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:3AC4C770
      @Alternate Data Stream - 109 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:A8ADE5D8
      :Services
      :Reg
      :Files
      :Commands
      [purity]
      [emptytemp]
      [emptyflash]
      [resethosts]
      [Reboot]
    • Open OTL again and click the Quick Scan button. Post the log it produces in your next reply.
  2. 2010/06/21
    Jayman007
    Jayman007 Inactive Thread Starter
    fix log
    All processes killed
    ========== OTL ==========
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Extensions\{c95fe080-8f5d-11d2-a20b-00aa003c157b}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{c95fe080-8f5d-11d2-a20b-00aa003c157b}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Extensions\{c95fe080-8f5d-11d2-a20b-00aa003c157b}\ not found.
    Starting removal of ActiveX control {8FFBE65D-2C9C-4669-84BD-5829DC0B603C}
    C:\WINDOWS\Downloaded Program Files\erma.inf moved successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{8FFBE65D-2C9C-4669-84BD-5829DC0B603C}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{8FFBE65D-2C9C-4669-84BD-5829DC0B603C}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{8FFBE65D-2C9C-4669-84BD-5829DC0B603C}\ not found.
    Starting removal of ActiveX control {CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA}
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_CURRENT_USER\SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA}\ not found.
    Starting removal of ActiveX control {CAFEEFAC-0015-0000-0012-ABCDEFFEDCBA}
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBA}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBA}\ not found.
    Starting removal of ActiveX control {CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}\ not found.
    Starting removal of ActiveX control {CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA}
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA}\ not found.
    Starting removal of ActiveX control {CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA}
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA}\ not found.
    Starting removal of ActiveX control {E2883E8F-472F-4FB0-9522-AC9BF37916A7}
    Registry error reading value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\DownloadInformation\\INF .
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
    File oft XML Parser for Java file:///C:/WINDOWS/Java/classes/xmldso.cab not found.
    Starting removal of ActiveX control Microsoft XML Parser for Java
    Registry error reading value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\Microsoft XML Parser for Java\DownloadInformation\\INF .
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\Microsoft XML Parser for Java\ deleted successfully.
    Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\Microsoft XML Parser for Java\ not found.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\UserShell\AOL9Plus folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\UserShell\AOL9 folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\UserShell folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\Resources\Welcome\BH00 folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\Resources\Welcome folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\Resources\ResourceFolder_03 folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\Resources\ResourceFolder_02 folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\Resources\ResourceFolder_01 folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\Resources\ResourceFolder_00 folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology\Resources folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\Viewpoint Experience Technology folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint\AxMetaStream_Win folder moved successfully.
    C:\Documents and Settings\All Users\Application Data\Viewpoint folder moved successfully.
    Unable to delete ADS C:\WINDOWS\System32\net1.exe:SummaryInformation .
    Unable to delete ADS C:\WINDOWS\System32\dllhost.exe:SummaryInformation .
    Unable to delete ADS C:\WINDOWS\System32\ati2evxx.exe:SummaryInformation .
    Unable to delete ADS D:\My Documents\home.html:Q30lsldxJoudresxAaaqpcawXc .
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:5F7539FF deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:DDE29E40 deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:DFC5A2B2 deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:D2F2F703 deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:B7177954 deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:5F64C164 deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:B42C512A deleted successfully.
    ADS C:\WINDOWS\system32:{4B9A1497-0817-47C4-9612-D6A1C53ACF57} deleted successfully.
    ADS C:\WINDOWS\system32:{4B9A1497-0817-47C4-9612-D5A1C53ACF57} deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:F10A4358 deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:3AC4C770 deleted successfully.
    ADS C:\Documents and Settings\All Users\Application Data\TEMP:A8ADE5D8 deleted successfully.
    ========== FILES ==========
    [EMPTYTEMP]
    User: Administrator
    ->Temporary Internet Files folder emptied: 38766 bytes
    ->FireFox cache emptied: 26005175 bytes
    ->Flash cache emptied: 456 bytes
    User: All Users
    User: Default User
    ->Temporary Internet Files folder emptied: 32902 bytes
    ->Flash cache emptied: 41 bytes
    User: endicia
    ->Temporary Internet Files folder emptied: 196608 bytes
    ->Java cache emptied: 0 bytes
    User: Jason
    ->Temp folder emptied: 3197469 bytes
    ->Temporary Internet Files folder emptied: 32768 bytes
    User: Jay
    ->Temp folder emptied: 352332 bytes
    ->Temporary Internet Files folder emptied: 1611520 bytes
    ->FireFox cache emptied: 316581354 bytes
    ->Google Chrome cache emptied: 0 bytes
    ->Flash cache emptied: 2422 bytes
    User: LocalService
    ->Temporary Internet Files folder emptied: 65670 bytes
    User: LogMeInRemoteUser
    User: LogMeInRemoteUser.JAY-DELL
    User: MAS
    User: NetworkService
    %systemroot% .tmp files removed: 3494513 bytes
    %systemroot%\System32 .tmp files removed: 1611489 bytes
    %systemroot%\System32\drivers .tmp files removed: 16000 bytes
    Windows Temp folder emptied: 255855 bytes
    %systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 34318 bytes
    RecycleBin emptied: 0 bytes
    Total Files Cleaned = 337.00 mb
    [EMPTYFLASH]
    User: Administrator
    User: All Users
    User: Default User
    User: endicia
    User: Jason
    User: Jay
    User: LocalService
    User: MAS
    C:\WINDOWS\System32\drivers\etc\Hosts moved successfully.
    HOSTS file reset successfully
    OTL by OldTimer - Version 3.2.6.0 log created on 06212010_084614
    File\Folder C:\Documents and Settings\Jay\Local Settings\Temp\Perflib_Perfdata_1148.dat not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Temp\Perflib_Perfdata_84c.dat not found!
    C:\Documents and Settings\Jay\Local Settings\Temp\~DFC342.tmp moved successfully.
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\aim_bubble_close[9643].jpg not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\aim_bubble_left[9645].gif not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\aim_bubble_right[9647].gif not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\aim_left_anchor_bubble_bot[9649].gif not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\aim_left_anchor_bubble_top[9650].gif not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\aim_no_anchor_bubble_bot[9652].gif not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\aim_no_anchor_bubble_top[9653].gif not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\aim_right_anchor_bubble_bot[9655].gif not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\aim_right_anchor_bubble_top[9656].gif not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\bidi_controls[9658].gif not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\bubble_closebox[9664].gif not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\eventheader_border[9668].gif not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\labs_bar_icon[9716].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\muc_bubble_left[9673].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\muc_bubble_right[9674].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\muc_left_anchor_bubble_bot[9675].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\muc_left_anchor_bubble_top[9676].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\muc_no_anchor_bubble_bot[9747].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\muc_no_anchor_bubble_top[9749].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\muc_right_anchor_bubble_bot[9682].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\muc_right_anchor_bubble_top[9684].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\shadow-bottom-border[9693].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\shadow-bottom-left[9694].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\shadow-bottom-right[9696].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\shadow-left-side[9697].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\shadow-right-side[9698].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\shadow-top-left[9699].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\shadow-top-right[9702].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\stamp_authentication_key[9718].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\tb_xgroupchat[9606].png not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\toolbar3_bidi3[9706].gif not found!
    File\Folder C:\Documents and Settings\Jay\Local Settings\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\Google Gears for Firefox\mail.google.com\https_443\WebCache-MAIN_IMAGES-jason@pioneerpsg.com-GoogleMail@p2494600848[13]#localserver\toolbar_call_bg[9612].png not found!
    C:\WINDOWS\temp\vmware-SYSTEM-3891100306\vmware-usbarb-SYSTEM-5296.log moved successfully.
    C:\WINDOWS\temp\Perflib_Perfdata_864.dat moved successfully.
    Jayman007
    scan 2 part 1
    OTL logfile created on: 6/21/2010 12:49:01 - Run 2
    OTL by OldTimer - Version 3.2.6.0 Folder = C:\Documents and Settings\Jay\Desktop
    Windows XP Media Center Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
    Internet Explorer (Version = 8.0.6001.18702)
    Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
    2.00 Gb Total Physical Memory | 1.00 Gb Available Physical Memory | 54.00% Memory free
    5.00 Gb Paging File | 4.00 Gb Available in Paging File | 81.00% Paging File free
    Paging file location(s): C:\pagefile.sys 3069 3069 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\WINDOWS | %ProgramFiles% = C:\Program Files
    Drive C: | 49.75 Gb Total Space | 6.45 Gb Free Space | 12.96% Space Free | Partition Type: NTFS
    Drive D: | 136.43 Gb Total Space | 4.13 Gb Free Space | 3.02% Space Free | Partition Type: NTFS
    E: Drive not present or media not loaded
    Drive F: | 1.64 Mb Total Space | 0.00 Mb Free Space | 0.00% Space Free | Partition Type: CDFS
    G: Drive not present or media not loaded
    H: Drive not present or media not loaded
    Drive I: | 17.59 Mb Total Space | 17.31 Mb Free Space | 98.37% Space Free | Partition Type: FAT
    Computer Name: ME
    Current User Name: Jay
    Logged in as Administrator.
    Current Boot Mode: Normal
    Scan Mode: Current user
    Company Name Whitelist: On
    Skip Microsoft Files: On
    File Age = 90 Days
    Output = Standard
    Quick Scan
    PRC - [2010/06/20 17:21:55 | 000,572,416 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Jay\Desktop\OTL.exe
    PRC - [2010/05/29 17:57:57 | 003,220,912 | ---- | M] (Tonec Inc.) -- C:\Program Files\Internet Download Manager\IDMan.exe
    PRC - [2010/05/27 05:08:36 | 000,436,267 | ---- | M] (http://www.ruby-lang.org/) -- C:\metasploit\ruby\bin\rubyw.exe
    PRC - [2010/05/21 00:56:36 | 000,334,384 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\system32\vmnetdhcp.exe
    PRC - [2010/05/21 00:56:32 | 000,113,200 | ---- | M] (VMware, Inc.) -- C:\Program Files\VMware\VMware Workstation\vmware-authd.exe
    PRC - [2010/05/21 00:56:18 | 000,399,920 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\system32\vmnat.exe
    PRC - [2010/05/20 23:40:20 | 000,539,184 | ---- | M] (VMware, Inc.) -- C:\Program Files\Common Files\VMware\USB\vmware-usbarbitrator.exe
    PRC - [2010/05/19 07:49:40 | 000,414,736 | ---- | M] (Bitsum Technologies) -- C:\Program Files\Process Lasso\ProcessLasso.exe
    PRC - [2010/05/19 07:49:40 | 000,252,944 | ---- | M] (Bitsum Technologies) -- C:\Program Files\Process Lasso\ProcessGovernor.exe
    PRC - [2010/04/25 13:23:58 | 001,284,600 | ---- | M] (Tall Emu) -- C:\Program Files\Tall Emu\Online Armor\oacat.exe
    PRC - [2010/04/19 20:03:32 | 000,405,672 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir Desktop\avwebgrd.exe
    PRC - [2010/04/19 20:03:32 | 000,337,064 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir Desktop\avmailc.exe
    PRC - [2010/04/19 20:03:32 | 000,267,432 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir Desktop\avguard.exe
    PRC - [2010/04/17 17:56:06 | 000,073,960 | ---- | M] (tzuk) -- C:\Program Files\Sandboxie\SbieSvc.exe
    PRC - [2010/03/24 16:38:23 | 000,135,336 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir Desktop\sched.exe
    PRC - [2010/03/24 16:38:19 | 000,282,792 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir Desktop\avgnt.exe
    PRC - [2010/03/24 16:38:19 | 000,076,968 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir Desktop\avshadow.exe
    PRC - [2010/03/18 15:07:02 | 000,136,176 | ---- | M] (Google Inc.) -- C:\Program Files\Google\Update\1.2.183.23\GoogleCrashHandler.exe
    PRC - [2010/03/04 23:38:00 | 000,071,096 | ---- | M] () -- C:\Program Files\CDBurnerXP\NMSAccessU.exe
    PRC - [2010/03/02 22:33:24 | 000,045,056 | ---- | M] () -- C:\Documents and Settings\Jay\Local Settings\Application Data\MagicsilencePlugin\MagicsilencePlugin.exe
    PRC - [2009/11/03 15:48:54 | 000,874,768 | ---- | M] (Intel(R) Corporation) -- C:\Program Files\Intel\WiFi\bin\EvtEng.exe
    PRC - [2009/11/03 15:45:52 | 000,348,160 | ---- | M] (Intel(R) Corporation) -- C:\Program Files\Intel\WiFi\bin\WLKEEPER.exe
    PRC - [2009/11/03 15:45:48 | 001,372,160 | ---- | M] (Intel(R) Corporation) -- C:\Program Files\Intel\WiFi\bin\ZCfgSvc.exe
    PRC - [2009/11/03 15:42:00 | 000,909,312 | ---- | M] (Intel(R) Corporation) -- C:\Program Files\Intel\WiFi\bin\S24EvMon.exe
    PRC - [2009/11/03 15:35:14 | 001,202,448 | ---- | M] (Intel(R) Corporation) -- C:\Program Files\Common Files\Intel\WirelessCommon\iFrmewrk.exe
    PRC - [2009/11/03 15:33:48 | 000,473,360 | ---- | M] (Intel(R) Corporation) -- C:\Program Files\Common Files\Intel\WirelessCommon\RegSrvc.exe
    PRC - [2009/10/11 04:07:08 | 000,320,832 | ---- | M] (BillP Studios) -- C:\Program Files\BillP Studios\WinPatrol\WinPatrol.exe
    PRC - [2009/10/08 21:10:42 | 000,424,688 | ---- | M] (QFX Software Corporation) -- C:\Program Files\KeyScrambler\KeyScrambler.exe
    PRC - [2009/09/30 00:17:50 | 000,013,088 | ---- | M] (Intuit Inc.) -- C:\Program Files\Common Files\Intuit\Update Service\IntuitUpdateService.exe
    PRC - [2009/09/29 05:41:12 | 000,024,645 | ---- | M] (Apache Software Foundation) -- C:\metasploit\apache2\bin\httpd.exe
    PRC - [2009/07/30 19:39:12 | 001,216,648 | ---- | M] (Ext2Fsd Group (www.ext2fsd.com)) -- C:\Program Files\Ext2Fsd\Ext2Mgr.exe
    PRC - [2009/06/28 05:42:41 | 004,505,600 | ---- | M] (PostgreSQL Global Development Group) -- C:\metasploit\postgresql\bin\postgres.exe
    PRC - [2009/06/28 05:42:41 | 000,066,048 | ---- | M] (PostgreSQL Global Development Group) -- C:\metasploit\postgresql\bin\pg_ctl.exe
    PRC - [2008/10/27 11:27:12 | 002,620,416 | ---- | M] (Desksware) -- C:\Program Files\Desksware\Power Favorites\Bookmark.exe
    PRC - [2008/07/25 13:22:52 | 000,031,744 | ---- | M] (DiamondCS) -- C:\Program Files\ProcessGuard\DCSUserProt.exe
    PRC - [2008/07/25 13:22:50 | 000,267,287 | ---- | M] (DiamondCS) -- C:\Program Files\ProcessGuard\procguard.exe
    PRC - [2008/07/25 13:11:58 | 000,120,832 | ---- | M] (DiamondCS) -- C:\Program Files\ProcessGuard\pgaccount.exe
    PRC - [2008/05/01 08:52:36 | 000,200,704 | ---- | M] (OptionNV) -- C:\Program Files\Option\GlobeTrotter Connect\GtDetectSc.exe
    PRC - [2008/04/14 07:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
    PRC - [2008/01/29 15:11:56 | 000,576,104 | ---- | M] (Broadcom Corporation.) -- C:\Program Files\WIDCOMM\Bluetooth Software\BTTray.exe
    PRC - [2007/11/15 11:46:00 | 000,131,072 | ---- | M] (Brio) -- C:\Program Files\FolderSize\FolderSizeSvc.exe
    PRC - [2007/05/11 16:09:48 | 001,050,120 | ---- | M] (O&O Software GmbH) -- C:\WINDOWS\system32\oodag.exe
    PRC - [2007/05/10 10:22:32 | 000,405,504 | ---- | M] (SigmaTel, Inc.) -- C:\Program Files\Sigmatel\C-Major Audio\WDM\stsystra.exe
    PRC - [2006/11/03 10:40:12 | 000,174,656 | ---- | M] () -- C:\WINDOWS\system32\PSIService.exe
    PRC - [2004/06/15 15:02:04 | 000,582,144 | ---- | M] (Basta Computing) -- C:\Program Files\Basta Computing\Horas\Horas.exe
    PRC - [2003/07/25 02:40:06 | 000,335,872 | ---- | M] (Globe Software) -- C:\Program Files\Globe Software\StatBar\StatBar.exe
    PRC - [2000/05/20 17:23:48 | 000,086,016 | ---- | M] () -- C:\WINDOWS\StartupMonitor.exe
    PRC - [1999/05/15 10:48:00 | 000,065,536 | ---- | M] ( ) -- C:\Program Files\Clipomatic\Clipomatic.exe
    MOD - [2010/06/20 17:21:55 | 000,572,416 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Jay\Desktop\OTL.exe
    MOD - [2008/04/14 07:10:20 | 000,110,592 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\msscript.ocx
    MOD - [2008/01/29 15:05:22 | 000,073,728 | ---- | M] (Broadcom Corporation.) -- C:\WINDOWS\system32\BtMmHook.dll
    MOD - [2007/03/27 01:03:20 | 000,057,344 | ---- | M] (BillP Studios) -- C:\Program Files\BillP Studios\WinPatrol\patrolpro.dll
    SRV - File not found [On_Demand | Stopped] -- -- (TivoBeacon2)
    SRV - [2010/06/15 23:38:10 | 001,585,152 | ---- | M] (NanJing Nagasoft Co, LTD.) [On_Demand | Stopped] -- C:\WINDOWS\system32\Nagasoft\vjocx.dll -- (vvdsvc)
    SRV - [2010/05/27 05:08:36 | 000,436,267 | ---- | M] (http://www.ruby-lang.org/) [Auto | Running] -- C:\metasploit\ruby\bin\rubyw.exe -- (metasploitThin)
    SRV - [2010/05/27 05:08:36 | 000,436,267 | ---- | M] (http://www.ruby-lang.org/) [Auto | Running] -- C:\metasploit\ruby\bin\rubyw.exe -- (metasploitProSvc)
    SRV - [2010/05/21 00:56:36 | 000,334,384 | ---- | M] (VMware, Inc.) [Auto | Running] -- C:\WINDOWS\system32\vmnetdhcp.exe -- (VMnetDHCP)
    SRV - [2010/05/21 00:56:32 | 000,113,200 | ---- | M] (VMware, Inc.) [Auto | Running] -- C:\Program Files\VMware\VMware Workstation\vmware-authd.exe -- (VMAuthdService)
    SRV - [2010/05/21 00:56:18 | 000,399,920 | ---- | M] (VMware, Inc.) [Auto | Running] -- C:\WINDOWS\system32\vmnat.exe -- (VMware NAT Service)
    SRV - [2010/05/20 23:40:20 | 000,539,184 | ---- | M] (VMware, Inc.) [Auto | Running] -- C:\Program Files\Common Files\VMware\USB\vmware-usbarbitrator.exe -- (VMUSBArbService)
    SRV - [2010/05/12 05:07:04 | 000,084,657 | ---- | M] (PostgreSQL Global Development Group) [On_Demand | Stopped] -- C:\Program Files\rapid7\nexpose\nsc\nxpgsql\pgsql\bin\pg_ctl.exe -- (nxpgsql)
    SRV - [2010/04/27 16:42:04 | 000,191,024 | ---- | M] (VMware, Inc.) [On_Demand | Stopped] -- C:\Program Files\VMware\VMware Workstation\vmware-ufad.exe -- (ufad-ws60)
    SRV - [2010/04/25 13:29:11 | 003,506,680 | ---- | M] (Tall Emu) [Auto | Stopped] -- C:\Program Files\Tall Emu\Online Armor\oasrv.exe -- (SvcOnlineArmor)
    SRV - [2010/04/25 13:23:58 | 001,284,600 | ---- | M] (Tall Emu) [Auto | Running] -- C:\Program Files\Tall Emu\Online Armor\OAcat.exe -- (OAcat)
    SRV - [2010/04/19 20:03:32 | 000,405,672 | ---- | M] (Avira GmbH) [Auto | Running] -- C:\Program Files\Avira\AntiVir Desktop\AVWEBGRD.EXE -- (AntiVirWebService)
    SRV - [2010/04/19 20:03:32 | 000,337,064 | ---- | M] (Avira GmbH) [Auto | Running] -- C:\Program Files\Avira\AntiVir Desktop\avmailc.exe -- (AntiVirMailService)
    SRV - [2010/04/19 20:03:32 | 000,267,432 | ---- | M] (Avira GmbH) [Auto | Running] -- C:\Program Files\Avira\AntiVir Desktop\avguard.exe -- (AntiVirService)
    SRV - [2010/04/17 17:56:06 | 000,073,960 | ---- | M] (tzuk) [Auto | Running] -- C:\Program Files\Sandboxie\SbieSvc.exe -- (SbieSvc)
    SRV - [2010/04/12 09:24:12 | 000,010,240 | ---- | M] (Tenable Network Security, Inc) [On_Demand | Stopped] -- C:\Program Files\Tenable\Nessus\nessus-service.exe -- (Tenable Nessus)
    SRV - [2010/03/24 16:38:23 | 000,135,336 | ---- | M] (Avira GmbH) [Auto | Running] -- C:\Program Files\Avira\AntiVir Desktop\sched.exe -- (AntiVirSchedulerService)
    SRV - [2010/03/04 23:38:00 | 000,071,096 | ---- | M] () [Auto | Running] -- C:\Program Files\CDBurnerXP\NMSAccessU.exe -- (NMSAccess)
    SRV - [2010/01/27 09:09:02 | 000,117,264 | ---- | M] (CACE Technologies, Inc.) [On_Demand | Stopped] -- C:\Program Files\WinPcap\rpcapd.exe -- (rpcapd) Remote Packet Capture Protocol v.0 (experimental)
    SRV - [2009/11/03 15:48:54 | 000,874,768 | ---- | M] (Intel(R) Corporation) [Auto | Running] -- C:\Program Files\Intel\WiFi\bin\EvtEng.exe -- (EvtEng) Intel(R)
    SRV - [2009/11/03 15:45:52 | 000,348,160 | ---- | M] (Intel(R) Corporation) [Auto | Running] -- C:\Program Files\Intel\WiFi\bin\WLKEEPER.exe -- (WLANKEEPER) Intel(R)
    SRV - [2009/11/03 15:42:00 | 000,909,312 | ---- | M] (Intel(R) Corporation) [Auto | Running] -- C:\Program Files\Intel\WiFi\bin\S24EvMon.exe -- (S24EventMonitor) Intel(R)
    SRV - [2009/11/03 15:33:48 | 000,473,360 | ---- | M] (Intel(R) Corporation) [Auto | Running] -- C:\Program Files\Common Files\Intel\WirelessCommon\RegSrvc.exe -- (RegSrvc) Intel(R)
    SRV - [2009/10/22 16:27:36 | 000,356,008 | ---- | M] (Elcomsoft Co. Ltd.) [On_Demand | Stopped] -- C:\Program Files\ElcomSoft\Distributed Password Recovery\esdprs.exe -- (ElcomSoftDistributedPasswordRecoveryServer)
    SRV - [2009/09/30 00:17:50 | 000,013,088 | ---- | M] (Intuit Inc.) [Auto | Running] -- C:\Program Files\Common Files\Intuit\Update Service\IntuitUpdateService.exe -- (IntuitUpdateService)
    SRV - [2009/09/29 05:41:12 | 000,024,645 | ---- | M] (Apache Software Foundation) [Auto | Running] -- C:\metasploit\apache2\bin\httpd.exe -- (metasploitApache)
    SRV - [2009/07/30 19:39:12 | 001,216,648 | ---- | M] (Ext2Fsd Group (www.ext2fsd.com)) [Auto | Running] -- C:\Program Files\Ext2Fsd\Ext2Mgr.exe -- (Ext2Mgr)
    SRV - [2009/07/09 22:02:02 | 000,329,072 | ---- | M] (GFI Software Ltd.) [On_Demand | Stopped] -- C:\Program Files\GFI\LANguard 9.0\lnssatt.exe -- (gfi_lanss9_attservice)
    SRV - [2009/06/28 05:42:41 | 000,066,048 | ---- | M] (PostgreSQL Global Development Group) [Auto | Running] -- C:\metasploit\postgresql\bin\pg_ctl.exe -- (metasploitPostgreSQL-1)
    SRV - [2009/06/28 05:42:41 | 000,066,048 | ---- | M] (PostgreSQL Global Development Group) [Disabled | Stopped] -- C:\metasploit\postgresql\bin\pg_ctl.exe -- (metasploitPostgreSQL)
    SRV - [2008/12/19 01:47:08 | 009,158,656 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Microsoft SQL Server\MSSQL$MICROSOFTSMLBIZ\Binn\sqlservr.exe -- (MSSQL$MICROSOFTSMLBIZ)
    SRV - [2008/11/02 20:48:48 | 000,116,032 | ---- | M] (LogMeIn, Inc.) [Disabled | Stopped] -- C:\Program Files\LogMeIn\x86\RaMaint.exe -- (LMIMaint)
    SRV - [2008/09/12 01:58:40 | 000,258,048 | ---- | M] () [On_Demand | Stopped] -- C:\Program Files\Franson\GpsGate 2.0\GpsGateService.exe -- (Franson GpsGate 2.0)
    SRV - [2008/09/08 07:59:00 | 000,575,488 | ---- | M] (Nokia.) [On_Demand | Stopped] -- C:\Program Files\PC Connectivity Solution\ServiceLayer.exe -- (ServiceLayer)
    SRV - [2008/09/05 05:09:02 | 000,111,896 | ---- | M] (PCTEL) [On_Demand | Stopped] -- C:\Program Files\AT&T\Communication Manager\RcAppSvc.exe -- (ATTRcAppSvc)
    SRV - [2008/08/01 05:41:46 | 000,015,872 | ---- | M] () [On_Demand | Stopped] -- C:\Program Files\OpenVPN\bin\openvpnserv.exe -- (OpenVPNService)
    SRV - [2008/07/25 13:22:52 | 000,031,744 | ---- | M] (DiamondCS) [Auto | Running] -- C:\Program Files\ProcessGuard\dcsuserprot.exe -- (DCSPGSRV)
    SRV - [2008/05/01 08:52:36 | 000,200,704 | ---- | M] (OptionNV) [Auto | Running] -- C:\Program Files\Option\GlobeTrotter Connect\GtDetectSc.exe -- (GtDetectSc)
    SRV - [2008/02/29 05:31:50 | 000,063,040 | ---- | M] (LogMeIn, Inc.) [Disabled | Stopped] -- C:\Program Files\LogMeIn\x86\LogMeIn.exe -- (LogMeIn)
    SRV - [2007/11/15 11:46:00 | 000,131,072 | ---- | M] (Brio) [Auto | Running] -- C:\Program Files\FolderSize\FolderSizeSvc.exe -- (FolderSize)
    SRV - [2007/07/15 15:30:23 | 000,654,848 | ---- | M] (Macrovision Europe Ltd.) [On_Demand | Stopped] -- C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe -- (FLEXnet Licensing Service)
    SRV - [2007/05/11 16:09:48 | 001,050,120 | ---- | M] (O&O Software GmbH) [Auto | Running] -- C:\WINDOWS\system32\oodag.exe -- (O&O Defrag)
    SRV - [2006/11/03 10:40:12 | 000,174,656 | ---- | M] () [Auto | Running] -- C:\WINDOWS\system32\PSIService.exe -- (ProtexisLicensing)
    SRV - [2006/07/07 08:41:42 | 000,229,376 | ---- | M] (Apple Computer, Inc.) [On_Demand | Stopped] -- C:\Program Files\Gizmo Project\mDNSResponder.exe -- (Bonjour Service)
    SRV - [2005/05/04 09:42:56 | 000,323,584 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Microsoft SQL Server\MSSQL$MICROSOFTSMLBIZ\Binn\sqlagent.EXE -- (SQLAgent$MICROSOFTSMLBIZ)
    SRV - [2005/01/04 02:11:00 | 000,237,626 | ---- | M] () [On_Demand | Stopped] -- C:\Program Files\Nfserver\nfsd.exe -- (Omni-NFS Server)
    SRV - [2003/04/08 02:11:00 | 000,118,784 | ---- | M] () [On_Demand | Stopped] -- C:\Program Files\Nfserver\Lpd.exe -- (XLink LPD)
    DRV - [2010/06/19 03:01:27 | 000,038,976 | ---- | M] (microOLAP Technologies LTD) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\pssdk42.sys -- (PSSDK42)
    DRV - [2010/05/21 00:56:56 | 000,854,064 | ---- | M] (VMware, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\vmx86.sys -- (vmx86)
    DRV - [2010/05/21 00:56:56 | 000,070,704 | ---- | M] (VMware, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\vmci.sys -- (vmci)
    DRV - [2010/05/21 00:55:04 | 000,024,624 | ---- | M] (VMware, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\VMkbd.sys -- (vmkbd)
    DRV - [2010/05/21 00:54:02 | 000,032,688 | ---- | M] (VMware, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\vmnetbridge.sys -- (VMnetBridge)
    DRV - [2010/05/21 00:53:58 | 000,026,288 | ---- | M] (VMware, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\vmnetuserif.sys -- (VMnetuserif)
    DRV - [2010/05/20 23:40:08 | 000,032,304 | ---- | M] (VMware, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\hcmon.sys -- (hcmon)
    DRV - [2010/05/20 21:19:20 | 000,031,280 | ---- | M] (VMware, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\vmusb.sys -- (vmusb)
    DRV - [2010/05/20 21:19:20 | 000,016,560 | ---- | M] (VMware, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\vmnetadapter.sys -- (VMnetAdapter)
    DRV - [2010/05/06 17:10:20 | 000,068,168 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS -- (SASKUTIL)
    DRV - [2010/04/27 16:41:40 | 000,022,448 | ---- | M] (VMware, Inc.) [Kernel | Auto | Running] -- C:\Program Files\VMware\VMware Workstation\vstor2-ws60.sys -- (vstor2-ws60)
    DRV - [2010/04/25 13:25:50 | 000,029,560 | ---- | M] (Tall Emu Pty Ltd) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\OAnet.sys -- (OAnet)
    DRV - [2010/04/25 13:25:46 | 000,024,440 | ---- | M] (Tall Emu) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\OAmon.sys -- (OAmon)
    DRV - [2010/04/25 13:25:41 | 000,225,936 | ---- | M] (Tall Emu) [File_System | System | Running] -- C:\WINDOWS\system32\drivers\OADriver.sys -- (OADevice)
    DRV - [2010/04/17 17:56:02 | 000,115,944 | ---- | M] (tzuk) [Kernel | On_Demand | Running] -- C:\Program Files\Sandboxie\SbieDrv.sys -- (SbieDrv)
    DRV - [2010/04/06 18:33:10 | 000,025,864 | ---- | M] () [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\btnetBus.sys -- (btnetBUs)
    DRV - [2010/04/06 18:32:48 | 000,023,048 | ---- | M] (IVT Corporation.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\IvtBtBus.sys -- (IvtBtBUs)
    DRV - [2010/04/06 18:32:44 | 000,020,104 | ---- | M] (IVT Corporation.) [Kernel | Boot | Running] -- C:\WINDOWS\System32\Drivers\BtHidBus.sys -- (BtHidBus)
    DRV - [2010/03/24 16:38:23 | 000,124,784 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\avipbb.sys -- (avipbb)
    DRV - [2010/03/24 16:38:23 | 000,060,936 | ---- | M] (Avira GmbH) [File_System | Auto | Running] -- C:\WINDOWS\system32\drivers\avgntflt.sys -- (avgntflt)
    DRV - [2010/02/17 11:25:50 | 000,012,872 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\sasdifsv.sys -- (SASDIFSV)
    DRV - [2010/02/11 19:02:15 | 000,226,880 | ---- | M] (Microsoft Corporation) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\tcpip6.sys -- (Tcpip6)
    DRV - [2010/01/27 09:09:02 | 000,050,704 | ---- | M] (CACE Technologies, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\npf.sys -- (npf)
    DRV - [2009/12/30 12:20:54 | 000,027,064 | ---- | M] (VS Revo Group) [File_System | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\revoflt.sys -- (Revoflt)
    DRV - [2009/12/18 10:58:52 | 000,011,336 | ---- | M] () [Kernel | On_Demand | Stopped] -- C:\Program Files\SystemRequirementsLab\cpudrv.sys -- (cpudrv)
    DRV - [2009/12/08 22:06:09 | 000,104,512 | ---- | M] (SlySoft, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\AnyDVD.sys -- (AnyDVD)
    DRV - [2009/12/03 00:06:12 | 000,126,542 | ---- | M] (R-TT Inc.) [Kernel | On_Demand | Stopped] -- C:\Program Files\R-Drive Image\R-ImageDisk.sys -- (R-ImageDisk)
    DRV - [2009/11/12 14:48:56 | 000,007,168 | ---- | M] () [File_System | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\StarOpen.sys -- (StarOpen)
    DRV - [2009/10/26 05:47:30 | 004,221,952 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\NETw5x32.sys -- (NETw5x32) Intel(R)
    DRV - [2009/10/05 04:33:14 | 000,115,312 | ---- | M] (QFX Software Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\keyscrambler.sys -- (KeyScrambler)
    DRV - [2009/09/28 02:02:44 | 000,014,424 | ---- | M] () [Kernel | On_Demand | Stopped] -- C:\Program Files\PeerBlock\pbfilter.sys -- (pbfilter)
    DRV - [2009/09/27 00:57:34 | 000,025,768 | ---- | M] (Elaborate Bytes AG) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\ElbyCDIO.sys -- (ElbyCDIO)
    DRV - [2009/07/26 16:22:34 | 000,651,264 | ---- | M] (www.ext2fsd.com) [File_System | System | Running] -- C:\WINDOWS\system32\drivers\ext2fsd.sys -- (Ext2Fsd)
    DRV - [2009/06/26 14:21:34 | 000,323,328 | ---- | M] (Realtek Semiconductor Corporation ) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\RTL8187.sys -- (RTLWUSB)
    DRV - [2009/06/11 15:22:26 | 000,107,776 | ---- | M] (Option N.V.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\Gt51Ip.sys -- (GT72NDISIPXP)
    DRV - [2009/05/11 12:49:19 | 000,011,608 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- C:\Program Files\Avira\AntiVir Desktop\avgio.sys -- (avgio)
    DRV - [2009/05/11 10:12:49 | 000,028,520 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\ssmdrv.sys -- (ssmdrv)
    DRV - [2009/04/07 19:45:24 | 000,012,416 | ---- | M] (Windows (R) 2000 DDK provider) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\ekauio.sys -- (Ekauio)
    DRV - [2009/03/15 17:25:46 | 000,056,268 | ---- | M] (PowerISO Computing, Inc.) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\scdemu.sys -- (SCDEmu)
    DRV - [2009/02/26 05:58:57 | 003,565,568 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ati2mtag.sys -- (ati2mtag)
    DRV - [2009/02/24 18:42:14 | 000,116,736 | ---- | M] (MagicISO, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\mcdbus.sys -- (mcdbus)
    DRV - [2009/01/30 14:43:59 | 000,099,776 | ---- | M] (Acronis) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\snapman.sys -- (snapman)
    DRV - [2008/11/21 11:59:02 | 000,027,072 | ---- | M] (Printing Communications Assoc., Inc. (PCAUSA)) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\PCASp50.sys -- (PCASp50)
    DRV - [2008/11/02 20:48:39 | 000,083,288 | ---- | M] (LogMeIn, Inc.) [File_System | Disabled | Stopped] -- C:\WINDOWS\system32\LMIRfsClientNP.dll -- (LMIRfsClientNP)
    DRV - [2008/11/02 20:48:39 | 000,047,640 | ---- | M] (LogMeIn, Inc.) [File_System | Auto | Running] -- C:\WINDOWS\system32\drivers\LMIRfsDriver.sys -- (LMIRfsDriver)
    DRV - [2008/11/01 22:46:48 | 000,094,608 | ---- | M] (R-TT Inc.) [Kernel | On_Demand | Stopped] -- C:\Program Files\R-Drive Image\DrvSnSht.sys -- (DrvSnSht)
    DRV - [2008/09/05 05:03:54 | 000,032,408 | ---- | M] (PCTEL Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\PCTINDIS5.sys -- (PCTINDIS5)
    DRV - [2008/08/26 10:26:12 | 000,018,816 | ---- | M] (Nokia) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\pccsmcfd.sys -- (pccsmcfd)
    DRV - [2008/08/21 03:36:36 | 000,142,976 | ---- | M] (Sierra Wireless Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\swumx80.sys -- (SWUMX80) Sierra Wireless USB MUX Driver (UMTS80)
    DRV - [2008/08/21 03:35:40 | 000,168,192 | ---- | M] (Sierra Wireless Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\swnc8u80.sys -- (SWNC8U80) Sierra Wireless MUX NDIS Driver (UMTS80)
    DRV - [2008/08/14 07:23:56 | 000,011,904 | ---- | M] (Intel Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\s24trans.sys -- (s24trans)
    DRV - [2008/08/01 05:42:02 | 000,025,216 | ---- | M] (The OpenVPN Project) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\tap0901.sys -- (tap0901)
    DRV - [2008/07/25 13:33:06 | 000,026,688 | ---- | M] (DiamondCS) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\procguard.sys -- (procguard)
    DRV - [2008/07/23 17:33:07 | 000,003,712 | ---- | M] () [Kernel | Auto | Running] -- C:\WINDOWS\system32\socketlock.sys -- (SocketLock)
    DRV - [2008/06/26 06:26:36 | 000,335,104 | ---- | M] (Realtek Semiconductor Corporation ) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\RTL8187B.sys -- (RTL8187B)
    DRV - [2008/06/20 06:38:34 | 000,018,816 | ---- | M] (Bytemobile, Inc.) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\tcpipBM.sys -- (tcpipBM)
    DRV - [2008/06/08 23:37:56 | 000,132,904 | ---- | M] (Ahead Software AG) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\imagesrv.sys -- (imagesrv)
    DRV - [2008/06/08 23:37:46 | 000,011,304 | ---- | M] (Ahead Software AG) [Kernel | Boot | Running] -- C:\WINDOWS\System32\Drivers\imagedrv.sys -- (imagedrv)
    DRV - [2008/04/14 01:53:09 | 000,040,320 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nmnt.sys -- (nm)
    DRV - [2008/04/14 01:46:20 | 000,048,128 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\61883.sys -- (61883)
    DRV - [2008/04/14 01:46:20 | 000,038,912 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\avc.sys -- (Avc)
    DRV - [2008/04/14 01:46:09 | 000,051,200 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\msdv.sys -- (MSDV)
    DRV - [2008/04/14 01:45:12 | 000,060,032 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\usbaudio.sys -- (usbaudio) USB Audio Driver (WDM)
    DRV - [2008/04/14 01:36:39 | 000,043,008 | ---- | M] (Advanced Micro Devices, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\amdagp.sys -- (amdagp)
    DRV - [2008/04/14 01:36:39 | 000,040,960 | ---- | M] (Silicon Integrated Systems Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\sisagp.sys -- (sisagp)
    DRV - [2008/04/13 23:36:05 | 000,144,384 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\hdaudbus.sys -- (HDAudBus)
    DRV - [2008/02/29 05:31:52 | 000,012,856 | ---- | M] (LogMeIn, Inc.) [Kernel | Auto | Running] -- C:\Program Files\LogMeIn\x86\rainfo.sys -- (LMIInfo)
    DRV - [2008/02/17 19:55:44 | 000,021,888 | ---- | M] (Windows (R) Codename Longhorn DDK provider) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\hopperp.sys -- (HopperP) WiFi Hopper (XP)
    DRV - [2008/02/17 09:15:06 | 000,074,688 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\btwusb.sys -- (BTWUSB)
    DRV - [2008/02/17 09:15:04 | 000,037,280 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\btwmodem.sys -- (btwmodem)
    DRV - [2008/02/17 09:15:00 | 000,156,392 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\btwdndis.sys -- (BTWDNDIS)
    DRV - [2008/02/17 09:15:00 | 000,055,352 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\btwhid.sys -- (btwhid)
    DRV - [2008/02/17 09:14:58 | 000,037,424 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\btport.sys -- (BTDriver)
    DRV - [2008/02/17 09:14:56 | 000,879,624 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\btkrnl.sys -- (BTKRNL)
    DRV - [2008/02/17 09:14:52 | 000,539,640 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\btaudio.sys -- (btaudio)
    DRV - [2008/02/09 02:00:22 | 000,059,648 | ---- | M] (Option N.V.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\gt72ubus.sys -- (GT72UBUS)
    DRV - [2008/01/21 08:36:56 | 000,035,840 | ---- | M] (Sax software company) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\SAXNDIS.sys -- (SaxNDIS) Ax3soft Packet Driver (SaxNDIS)
    DRV - [2008/01/04 07:21:32 | 000,026,504 | ---- | M] () [Kernel | On_Demand | Running] -- C:\WINDOWS\System32\drivers\swmsflt.sys -- (swmsflt)
    DRV - [2007/11/10 04:57:58 | 000,031,232 | ---- | M] () [Kernel | On_Demand | Stopped] -- C:\Program Files\FireLion Softwares\Anti Keyloggers\kguard.sys -- (kguard)
    DRV - [2007/09/24 17:12:46 | 000,029,768 | ---- | M] (EldoS Corporation) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\elrawdsk.sys -- (ElRawDisk)
    DRV - [2007/06/27 12:05:52 | 000,053,184 | ---- | M] (FTDI Ltd.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ftdibus.sys -- (FTDIBUS)
    DRV - [2007/06/27 12:04:14 | 000,071,488 | ---- | M] (FTDI Ltd.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ftser2k.sys -- (FTSER2K)
    DRV - [2007/06/19 02:15:44 | 000,025,773 | ---- | M] (Greatis Software) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\regguard.sys -- (RegGuard)
    DRV - [2007/06/17 12:43:50 | 000,186,592 | ---- | M] (Jungo) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\windrvr6.sys -- (WinDriver6)
    DRV - [2007/06/12 11:08:44 | 000,052,944 | ---- | M] (ELTIMA Software) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\evserial.sys -- (evserial) Virtual Serial Ports Driver (Eltima Softwate)
    DRV - [2007/06/12 11:08:38 | 000,026,448 | ---- | M] (ELTIMA Software) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\evsbc.sys -- (VSBC) Virtual Serial Bus Enumerator (Eltima Software)
    DRV - [2007/05/29 11:38:10 | 000,014,848 | ---- | M] (Silicon Laboratories) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\SiUSBXp.sys -- (SIUSBXP)
    DRV - [2007/05/29 11:38:10 | 000,014,848 | ---- | M] (Silicon Laboratories) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\SiUSBXp.sys -- (INFUNLTD)
    DRV - [2007/05/10 10:24:34 | 001,222,840 | ---- | M] (SigmaTel, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\sthda.sys -- (STHDA)
    DRV - [2007/05/03 21:22:04 | 000,188,672 | ---- | M] (TrueCrypt Foundation) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\truecrypt.sys -- (truecrypt)
    DRV - [2007/04/04 20:27:14 | 001,471,104 | ---- | M] (Vimicro Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\usbVM31b.sys -- (ZSMC301b) Vimicro USB PC Camera (ZC0301PL)
    DRV - [2007/03/31 02:38:14 | 000,008,064 | ---- | M] (Option N.V.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\gtptser.sys -- (GTPTSER)
    DRV - [2007/02/26 23:45:39 | 000,005,248 | ---- | M] () [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\giveio.sys -- (giveio)
    DRV - [2007/02/07 15:46:52 | 000,017,280 | ---- | M] (ELTIMA Software) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\vsb.sys -- (vsbus)
    DRV - [2007/01/15 11:00:06 | 000,045,056 | ---- | M] (ELTIMA Software) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\vserial.sys -- (vserial)
    DRV - [2006/11/21 18:25:44 | 000,045,568 | R--- | M] (Broadcom Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\bcm4sbxp.sys -- (bcm4sbxp)
    DRV - [2006/11/15 00:16:24 | 000,032,256 | ---- | M] (REDC) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\rimmptsk.sys -- (rimmptsk)
    DRV - [2006/10/17 11:55:28 | 001,711,104 | ---- | M] (Intel® Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\NETw3x32.sys -- (NETw3x32) Intel(R)
    DRV - [2006/10/01 19:37:02 | 000,026,624 | ---- | M] (The OpenVPN Project) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\tap0801.sys -- (tap0801)
    DRV - [2006/09/08 17:01:20 | 000,051,328 | ---- | M] (REDC) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\rimsptsk.sys -- (rimsptsk)
    DRV - [2006/07/25 00:00:00 | 000,498,464 | R--- | M] (Creative Technology Ltd.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\V0230VID.sys -- (V0230VID)
    DRV - [2006/04/27 04:13:04 | 001,429,632 | ---- | M] (Intel® Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\w39n51.sys -- (w39n51) Intel(R)
    DRV - [2006/04/03 22:00:56 | 000,014,949 | ---- | M] (franson.biz) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\bizVSerialNT.sys -- (bizVSerial)
    DRV - [2006/03/27 01:51:14 | 000,030,820 | ---- | M] (Paragon Software Group) [Kernel | Boot | Running] -- C:\WINDOWS\system32\drivers\hotcore.sys -- (hotcore)
    DRV - [2006/03/24 00:00:00 | 000,006,272 | R--- | M] (EyePower Games Pte. Ltd.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\V0230Vfx.sys -- (V0230Vfx)
    DRV - [2006/03/08 12:35:10 | 000,191,872 | ---- | M] (Synaptics, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\SynTP.sys -- (SynTP)
    DRV - [2006/03/07 22:36:20 | 000,013,351 | ---- | M] (ISecSoft Inc.) [Kernel | Auto | Running] -- C:\Program Files\Anti Keylogger Elite\AKEProtect.sys -- (AKEProtect)
    DRV - [2006/01/10 12:07:58 | 000,004,864 | ---- | M] (GTek Technologies Ltd.) [Kernel | On_Demand | Stopped] -- C:\Program Files\Dell Support\GTAction\triggers\DSproct.sys -- (DSproct)
    DRV - [2005/12/12 08:36:00 | 000,009,760 | ---- | M] (Alcor Micro Corp.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\softctrl.sys -- (softctrl)
    DRV - [2005/11/01 18:08:00 | 000,308,992 | ---- | M] (REDC) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\rixdptsk.sys -- (rismxdp)
    DRV - [2005/09/23 13:38:54 | 000,068,260 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\StMp3Rec.sys -- (StMp3Rec)
    DRV - [2005/09/20 06:23:02 | 000,238,080 | ---- | M] (TamoSoft, Inc.) [CommView] Intel(R) PRO/Wireless 7100 Adapter Driver [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\commipw.sys -- (CommIpw)
    DRV - [2005/08/13 05:50:46 | 000,016,128 | ---- | M] (Dell Inc) [Kernel | System | Running] -- C:\WINDOWS\SYSTEM32\DRIVERS\APPDRV.SYS -- (APPDRV)
    DRV - [2005/07/22 08:02:12 | 001,035,008 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\HSF_DPV.sys -- (HSF_DPV)
    DRV - [2005/07/22 08:01:08 | 000,201,600 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\HSFHWAZL.sys -- (HSFHWAZL)
    DRV - [2005/07/22 08:01:00 | 000,717,952 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\HSF_CNXT.sys -- (winachsf)
    DRV - [2005/07/15 02:14:34 | 000,027,904 | ---- | M] (REDC) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\risdptsk.sys -- (risdptsk)
    DRV - [2005/01/13 10:06:48 | 000,035,107 | ---- | M] (Winternals) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\VDiskBus.sys -- (vdiskbus)
    DRV - [2004/10/15 18:50:20 | 000,015,295 | ---- | M] (Brother Industries Ltd.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\BrScnUsb.sys -- (BrScnUsb)
    DRV - [2004/09/21 00:44:48 | 000,005,652 | ---- | M] () [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\bvrp_pci.sys -- (bvrp_pci)
    DRV - [2004/08/04 10:29:56 | 001,897,408 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\nv4_mini.sys -- (nv)
    DRV - [2004/07/10 21:54:26 | 000,024,576 | ---- | M] (The OpenVPN Project) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\tap0801co.sys -- (tap0801co) TAP-Win32 Adapter V8 (coLinux)
    DRV - [2004/04/02 03:13:36 | 000,091,392 | ---- | M] (TamoSoft, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\commsym.sys -- (COMMSYM)
    DRV - [2004/03/24 09:12:34 | 000,017,280 | ---- | M] (Printing Communications Assoc., Inc. (PCAUSA)) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\nsndis5.sys -- (NSNDIS5)
    DRV - [2004/02/13 21:46:00 | 000,017,153 | ---- | M] (Dell Inc) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\omci.sys -- (omci)
    DRV - [2003/10/03 05:47:14 | 000,666,624 | ---- | M] (GlobespanVirata, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\PRISMUSB.sys -- (PRISM_USB)
    DRV - [2002/12/16 18:11:02 | 000,076,288 | ---- | M] (Rainbow Technologies, Inc.) [Kernel | Auto | Running] -- C:\WINDOWS\System32\Drivers\SENTINEL.SYS -- (Sentinel)
    DRV - [2002/12/16 18:11:02 | 000,026,120 | ---- | M] (Rainbow Technologies Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\SNTNLUSB.SYS -- (Sntnlusb)
    DRV - [2001/08/18 04:57:38 | 000,016,128 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\MODEMCSA.sys -- (MODEMCSA)
    DRV - [2001/08/18 02:07:44 | 000,019,072 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\sparrow.sys -- (Sparrow)
    DRV - [2001/08/18 02:07:42 | 000,030,688 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\sym_u3.sys -- (sym_u3)
    DRV - [2001/08/18 02:07:40 | 000,028,384 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\sym_hi.sys -- (sym_hi)
    DRV - [2001/08/18 02:07:36 | 000,032,640 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\symc8xx.sys -- (symc8xx)
    DRV - [2001/08/18 02:07:34 | 000,016,256 | ---- | M] (Symbios Logic Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\symc810.sys -- (symc810)
    DRV - [2001/08/18 01:52:22 | 000,036,736 | ---- | M] (Promise Technology, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\ultra.sys -- (ultra)
    DRV - [2001/08/18 01:52:20 | 000,045,312 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\ql12160.sys -- (ql12160)
    DRV - [2001/08/18 01:52:20 | 000,040,320 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\ql1080.sys -- (ql1080)
    DRV - [2001/08/18 01:52:18 | 000,049,024 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\ql1280.sys -- (ql1280)
    DRV - [2001/08/18 01:52:16 | 000,179,584 | ---- | M] (Mylex Corporation) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\dac2w2k.sys -- (dac2w2k)
    DRV - [2001/08/18 01:52:12 | 000,017,280 | ---- | M] (American Megatrends Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\mraid35x.sys -- (mraid35x)
    DRV - [2001/08/18 01:52:00 | 000,026,496 | ---- | M] (Advanced System Products, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\asc.sys -- (asc)
    DRV - [2001/08/18 01:51:58 | 000,014,848 | ---- | M] (Advanced System Products, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\asc3550.sys -- (asc3550)
    DRV - [2001/08/18 01:51:56 | 000,005,248 | ---- | M] (Acer Laboratories Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\aliide.sys -- (AliIde)
    DRV - [2001/08/18 01:51:54 | 000,006,656 | ---- | M] (CMD Technology, Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\DRIVERS\cmdide.sys -- (CmdIde)
    DRV - [2000/09/19 11:16:56 | 000,003,584 | ---- | M] () [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\DLPORTIO.SYS -- (DLPortIO)
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Default_Page_URL = www.google.com/ig/dell?hl=en&client=dell-usuk&channel=us&ibd=6061004
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Start Page = www.google.com/ig/dell?hl=en&client=dell-usuk&channel=us&ibd=6061004
    IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = about:blank
    IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    FF - HKLM\software\mozilla\Firefox\Extensions\\{000a9d1c-beef-4f90-9363-039d445309b8}: C:\Program Files\Google\Google Gears\Firefox\ [2010/03/06 13:55:07 | 000,000,000 | ---D | M]
    FF - HKLM\software\mozilla\Firefox\Extensions\\{22119944-ED35-4ab1-910B-E619EA06A115}: C:\Program Files\Siber Systems\AI RoboForm\Firefox [2007/06/27 21:35:58 | 000,000,000 | ---D | M]
    FF - HKLM\software\mozilla\Mozilla Firefox 3.6.3\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/06/10 00:03:27 | 000,000,000 | ---D | M]
    FF - HKLM\software\mozilla\Mozilla Firefox 3.6.3\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/06/17 01:29:11 | 000,000,000 | ---D | M]
    [2008/07/01 15:02:26 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Extensions
    [2008/10/06 15:54:12 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\3b24fhi1.New profile\extensions
    [2010/06/20 11:58:16 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions
    [2010/01/17 11:38:07 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{195A3098-0BD5-4e90-AE22-BA1C540AFD1E}
    [2010/05/18 20:15:18 | 000,000,000 | ---D | M] (IE Tab 2 (FF 3.6+)) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{1BC9BA34-1EED-42ca-A505-6D2F1A935BBB}
    [2010/04/29 02:44:31 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{20a82645-c095-46ed-80e3-08825760534b}
    [2009/12/26 06:59:37 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{2fa4ed95-0317-4c6a-a74c-5f3e3912c1f9}
    [2010/06/02 17:27:10 | 000,000,000 | ---D | M] (Leet Key) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{3335F91D-2AEF-4097-B831-C96C60349822}
    [2010/03/17 11:56:44 | 000,000,000 | ---D | M] (Flashblock) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{3d7eb24f-2740-49df-8937-200b1cc08f8a}
    [2010/05/12 16:22:52 | 000,000,000 | ---D | M] (Gmail Manager) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{582195F5-92E7-40a0-A127-DB71295901D7}
    [2010/06/12 14:57:07 | 000,000,000 | ---D | M] (NoScript) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{73a6fe31-595d-460b-a920-fcc0f8843232}
    [2010/05/01 04:38:36 | 000,000,000 | ---D | M] (PlainOldFavorites) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{7E7165E2-0767-448c-852F-5FA8714F2C37}
    [2010/06/04 06:18:45 | 000,000,000 | ---D | M] (FireFTP) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{a7c6cf7f-112c-4500-a7ea-39801a327e5f}
    [2010/05/29 11:26:50 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{cd617375-6743-4ee8-bac4-fbf10f35729e}
    [2010/04/30 19:09:38 | 000,000,000 | ---D | M] (Adblock Plus) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}
    [2010/06/18 04:59:58 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{dc572301-7619-498c-a57d-39143191b318}
    [2009/11/22 06:02:33 | 000,000,000 | ---D | M] (Adobe DLM (powered by getPlus(R))) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{E2883E8F-472F-4fb0-9522-AC9BF37916A7}
    [2009/08/01 03:15:46 | 000,000,000 | ---D | M] (User Agent Switcher) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{e968fc70-8f95-4ab9-9e79-304de2a71ee1}
    [2010/05/27 00:02:15 | 000,000,000 | ---D | M] (FoxLingo) -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\{ef62e1ce-d2a4-4cdd-b7ec-92b120366b66}
    [2010/04/29 02:44:23 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\amznUWL@amazon.com
    [2010/05/19 20:40:21 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\bettergmail2@ginatrapani.org
    [2009/01/07 10:32:44 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\bkmrksync@nokia.com
    [2010/06/10 12:24:36 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\canitbecheaper@trafficbroker.co.uk
    [2010/02/12 13:09:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\change@c-est-simple.com
    [2010/06/04 06:18:43 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\firefox-tagger@yapta.com
    [2010/05/28 15:53:28 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\izer@camelcamelcamel.com
    [2009/02/24 11:49:21 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\LogMeInClient@logmein.com
    [2010/03/13 02:05:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\master@desksware.com
    [2010/05/12 15:56:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\ShortenURL@loucypher
    [2009/07/13 18:16:02 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\TabSidebar@blueprintit.co.uk
    [2010/03/16 18:07:51 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Mozilla\Firefox\Profiles\ruv5qlwc.original\extensions\tinyurl.addon@fast-chat.co.uk
    [2010/06/20 11:58:16 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
    [2009/06/05 00:48:33 | 000,000,000 | ---D | M] (No name found) -- C:\Program Files\Mozilla Firefox\extensions\{3112ca9c-de6d-4884-a869-9855de68056c}
    [2009/01/15 14:06:43 | 000,000,000 | ---D | M] (TextAloud Firefox Plugin) -- C:\Program Files\Mozilla Firefox\extensions\{99a0337c-6303-4879-b72e-500fd9aaca8c}
    [2010/04/29 15:42:05 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}
    [2009/12/16 08:41:23 | 000,393,216 | ---- | M] (Invenda Corporation) -- C:\Program Files\Mozilla Firefox\plugins\NPcol400.dll
    [2008/06/18 13:43:04 | 000,086,016 | ---- | M] (Coupons, Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npCouponPrinter.dll
    [2010/04/12 17:29:19 | 000,411,368 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npdeployJava1.dll
    [2007/05/02 23:37:48 | 000,061,440 | ---- | M] (Joost Technologies B.V. ) -- C:\Program Files\Mozilla Firefox\plugins\npJoostPlugin.dll
    [2006/01/19 02:50:00 | 000,319,488 | ---- | M] ( ) -- C:\Program Files\Mozilla Firefox\plugins\npsnapfish.dll
  5. 2010/06/21
    Jayman007
    Jayman007 Inactive Thread Starter
    part 2
    O1 HOSTS File: ([2010/06/21 12:26:47 | 000,000,098 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\Hosts
    O1 - Hosts: ::1 localhost
    O2 - BHO: (IDMIEHlprObj Class) - {0055C089-8582-441B-A0BF-17B458C2A3A8} - C:\Program Files\Internet Download Manager\IDMIECC.dll (Tonec Inc.)
    O2 - BHO: (Adobe PDF Reader Link Helper) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll (Adobe Systems Incorporated)
    O2 - BHO: (Powermarks IEC) - {6172E460-FAE3-11D2-B494-004005A47AAA} - C:\Program Files\Powermarks 3.5\iec.dll (Kaylon Technologies Inc.)
    O2 - BHO: (no name) - {724d43a9-0d85-11d4-9908-00400523e39a} - C:\Program Files\Siber Systems\AI RoboForm\roboform.dll (Siber Systems Inc.)
    O2 - BHO: (Adobe PDF Conversion Toolbar Helper) - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll (Google Inc.)
    O2 - BHO: (Google Gears Helper) - {E0FEFE40-FBF9-42AE-BA58-794CA7E3FB53} - C:\Program Files\Google\Google Gears\Internet Explorer\0.5.36.0\gears.dll (Google Inc.)
    O3 - HKLM\..\Toolbar: (Spb Wallet) - {2913D3DD-9363-4C21-B205-C19A584A0674} - C:\Program Files\Spb Wallet\SpbWalletToolbar.dll ()
    O3 - HKLM\..\Toolbar: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O3 - HKLM\..\Toolbar: (&RoboForm) - {724d43a0-0d85-11d4-9908-00400523e39a} - C:\Program Files\Siber Systems\AI RoboForm\roboform.dll (Siber Systems Inc.)
    O3 - HKLM\..\Toolbar: (Powermarks) - {E166B4A2-83E7-11D3-B4FD-004005A47AAA} - C:\Program Files\Powermarks 3.5\iec.dll (Kaylon Technologies Inc.)
    O3 - HKLM\..\Toolbar: (TextAloud) - {F053C368-5458-45B2-9B4D-D8914BDDDBFF} - C:\Program Files\TextAloud\TAForIE.dll ()
    O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {00000000-5736-4205-0008-F7ED0776FB27} - No CLSID value found.
    O3 - HKCU\..\Toolbar\WebBrowser: (&Google) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - c:\Program Files\Google\GoogleToolbar3.dll (Google Inc.)
    O3 - HKCU\..\Toolbar\WebBrowser: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O3 - HKCU\..\Toolbar\WebBrowser: (&RoboForm) - {724D43A0-0D85-11D4-9908-00400523E39A} - C:\Program Files\Siber Systems\AI RoboForm\roboform.dll (Siber Systems Inc.)
    O4 - HKLM..\Run: [!1_pgaccount] C:\Program Files\ProcessGuard\pgaccount.exe (DiamondCS)
    O4 - HKLM..\Run: [@OnlineArmor GUI] C:\Program Files\Tall Emu\Online Armor\oaui.exe (Tall Emu)
    O4 - HKLM..\Run: [avgnt] C:\Program Files\Avira\AntiVir Desktop\avgnt.exe (Avira GmbH)
    O4 - HKLM..\Run: [BluetoothAuthenticationAgent] C:\WINDOWS\System32\bthprops.cpl (Microsoft Corporation)
    O4 - HKLM..\Run: [IntelWireless] C:\Program Files\Common Files\Intel\WirelessCommon\iFrmewrk.exe (Intel(R) Corporation)
    O4 - HKLM..\Run: [IntelZeroConfig] C:\Program Files\Intel\WiFi\bin\ZCfgSvc.exe (Intel(R) Corporation)
    O4 - HKLM..\Run: [ProcessGovernor] C:\Program Files\Process Lasso\ProcessGovernor.exe (Bitsum Technologies)
    O4 - HKLM..\Run: [ProcessLassoManagementConsole] C:\Program Files\Process Lasso\ProcessLasso.exe (Bitsum Technologies)
    O4 - HKCU..\Run: [!1_ProcessGuard_Startup] C:\Program Files\ProcessGuard\procguard.exe (DiamondCS)
    O4 - HKCU..\Run: [Antivirus System Tray Tool] C:\Program Files\Avira\AntiVir Desktop\avgnt.exe (Avira GmbH)
    O4 - HKCU..\Run: [cdloader] C:\DOCUMENTS AND SETTINGS\Jay\APPLICATION DATA\mjusbsp\CDLOADER2.EXE (magicJack L.P.)
    O4 - HKCU..\Run: [KeyScrambler] C:\Program Files\KeyScrambler\KeyScrambler.exe (QFX Software Corporation)
    O4 - HKCU..\Run: [pgaccount] C:\Program Files\ProcessGuard\pgaccount.exe (DiamondCS)
    O4 - HKCU..\Run: [StartupMonitor] C:\WINDOWS\StartupMonitor.exe ()
    O4 - HKCU..\Run: [WinPatrol PLUS] C:\Program Files\BillP Studios\WinPatrol\winpatrol.exe (BillP Studios)
    O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Bluetooth.lnk = C:\Program Files\WIDCOMM\Bluetooth Software\BTTray.exe (Broadcom Corporation.)
    O4 - Startup: C:\Documents and Settings\Jay\Start Menu\Programs\Startup\MagicsilencePlugin.lnk = C:\Documents and Settings\Jay\Local Settings\Application Data\MagicsilencePlugin\MagicsilencePlugin.exe ()
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: InstallVisualStyle = C:\WINDOWS\Resources\Themes\Royale\Royale.msstyles (Microsoft)
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: InstallTheme = C:\WINDOWS\Resources\Themes\Royale.theme ()
    O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 323
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoStrCmpLogical = [binary data]
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveAutoRun = 67108863
    O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDrives = 0
    O8 - Extra context menu item: &ieSpell Options - C:\Program Files\ieSpell\iespell.dll (Red Egg Software)
    O8 - Extra context menu item: Add to Power Favorites - C:\Program Files\Desksware\Power Favorites\copyurl.htm ()
    O8 - Extra context menu item: Append to existing PDF - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Check &Spelling - C:\Program Files\ieSpell\iespell.dll (Red Egg Software)
    O8 - Extra context menu item: Convert link target to Adobe PDF - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert link target to existing PDF - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert selected links to Adobe PDF - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert selected links to existing PDF - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert selection to Adobe PDF - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert selection to existing PDF - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Convert to Adobe PDF - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
    O8 - Extra context menu item: Customize Menu - C:\Program Files\Siber Systems\AI RoboForm\RoboFormComCustomizeIEMenu.html ()
    O8 - Extra context menu item: Download all links with IDM - C:\Program Files\Internet Download Manager\IEGetAll.htm ()
    O8 - Extra context menu item: Download FLV video content with IDM - C:\Program Files\Internet Download Manager\IEGetVL.htm ()
    O8 - Extra context menu item: Download FLV videos with IDM from 10 last requested - C:\Program Files\Internet Download Manager\IEGetVL2.htm ()
    O8 - Extra context menu item: Download with IDM - C:\Program Files\Internet Download Manager\IEExt.htm ()
    O8 - Extra context menu item: Open using &Advanced JPEG Compressor - C:\Program Files\Advanced JPEG Compressor\ajcieex.htm ()
    O8 - Extra context menu item: RoboForm Toolbar - C:\Program Files\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html ()
    O8 - Extra context menu item: Send to &Bluetooth Device... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm ()
    O8 - Extra context menu item: Send To Bluetooth - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm ()
    O9 - Extra Button: Trace - {04849C74-016E-4a43-8AA5-1F01DE57F4A1} - C:\Program Files\VisualRoute\vrie.dll (VisualWare)
    O9 - Extra 'Tools' menuitem : VisualRoute Trace - {04849C74-016E-4a43-8AA5-1F01DE57F4A1} - C:\Program Files\VisualRoute\vrie.dll (VisualWare)
    O9 - Extra 'Tools' menuitem : &Gears Settings - {09C04DA7-5B76-4EBC-BBEE-B25EAC5965F5} - C:\Program Files\Google\Google Gears\Internet Explorer\0.5.36.0\gears.dll (Google Inc.)
    O9 - Extra Button: Create Mobile Favorite - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\Program Files\Microsoft ActiveSync\INetRepl.dll (Microsoft Corporation)
    O9 - Extra 'Tools' menuitem : Create Mobile Favorite... - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\Program Files\Microsoft ActiveSync\INetRepl.dll (Microsoft Corporation)
    O9 - Extra 'Tools' menuitem : &KeyScrambler Options - {5C106A59-CC3C-4caa-81A4-6D909B5ACE23} - C:\Program Files\KeyScrambler\KeyScramblerIE.dll (QFX Software Corporation)
    O9 - Extra Button: RoboForm - {724d43aa-0d85-11d4-9908-00400523e39a} - C:\Program Files\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html ()
    O9 - Extra 'Tools' menuitem : RoboForm Toolbar - {724d43aa-0d85-11d4-9908-00400523e39a} - C:\Program Files\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html ()
    O9 - Extra Button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm ()
    O9 - Extra 'Tools' menuitem : @btrez.dll,-12650 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm ()
    O10 - NameSpace_Catalog5\Catalog_Entries\000000000004 [] - C:\WINDOWS\system32\nwprovau.dll (Microsoft Corporation)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000001 - C:\WINDOWS\System32\idmmbc.dll (Tonec Inc.)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000002 - C:\WINDOWS\System32\idmmbc.dll (Tonec Inc.)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000003 - C:\WINDOWS\System32\idmmbc.dll (Tonec Inc.)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000004 - C:\WINDOWS\System32\idmmbc.dll (Tonec Inc.)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000005 - C:\WINDOWS\System32\idmmbc.dll (Tonec Inc.)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000006 - C:\WINDOWS\System32\idmmbc.dll (Tonec Inc.)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000007 - C:\WINDOWS\System32\idmmbc.dll (Tonec Inc.)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000008 - C:\WINDOWS\System32\idmmbc.dll (Tonec Inc.)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000009 - C:\WINDOWS\System32\idmmbc.dll (Tonec Inc.)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000010 - C:\Program Files\Avira\AntiVir Desktop\avsda.dll (Avira GmbH)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000011 - C:\Program Files\Avira\AntiVir Desktop\avsda.dll (Avira GmbH)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000022 - C:\WINDOWS\System32\idmmbc.dll (Tonec Inc.)
    O10 - Protocol_Catalog9\Catalog_Entries\000000000023 - C:\Program Files\Avira\AntiVir Desktop\avsda.dll (Avira GmbH)
    O15 - HKCU\..Trusted Domains: advanta.com ([www] https in Trusted sites)
    O15 - HKCU\..Trusted Domains: bankofamerica.com ([]https in Trusted sites)
    O15 - HKCU\..Trusted Domains: commerceonline.com ([]https in Trusted sites)
    O15 - HKCU\..Trusted Domains: forexdirectory.net ([www] http in Trusted sites)
    O15 - HKCU\..Trusted Domains: google.com ([]http in Trusted sites)
    O15 - HKCU\..Trusted Domains: google.com ([]https in Trusted sites)
    O15 - HKCU\..Trusted Domains: google.com ([mail] http in Trusted sites)
    O15 - HKCU\..Trusted Domains: ingdirect.com ([]https in Trusted sites)
    O15 - HKCU\..Trusted Domains: intuit.com ([ttlc] https in Trusted sites)
    O15 - HKCU\..Trusted Domains: macromedia.com ([www] http in Trusted sites)
    O15 - HKCU\..Trusted Domains: microsoft.com ([*.update] http in Trusted sites)
    O15 - HKCU\..Trusted Domains: microsoft.com ([*.update] https in Trusted sites)
    O15 - HKCU\..Trusted Domains: microsoft.com ([office] http in Trusted sites)
    O15 - HKCU\..Trusted Domains: nv.gov ([www.nevadatax] https in Trusted sites)
    O15 - HKCU\..Trusted Domains: scbeasy.com ([www] https in Trusted sites)
    O15 - HKCU\..Trusted Domains: schickquattro.com ([www] http in Trusted sites)
    O15 - HKCU\..Trusted Domains: turbotax.com ([]https in Trusted sites)
    O15 - HKCU\..Trusted Domains: vaporwarez.com ([www] http in Trusted sites)
    O15 - HKCU\..Trusted Domains: vaporwarez.com ([www] https in Trusted sites)
    O15 - HKCU\..Trusted Domains: wamu.com ([]https in Trusted sites)
    O15 - HKCU\..Trusted Domains: windowsupdate.com ([download] http in Trusted sites)
    O16 - DPF: {6C269571-C6D7-4818-BCA4-32A035E8C884} http://ccfiles.creative.com/Web/softwareupdate/su/ocx/15101/CTSUEng.cab (Creative Software AutoUpdate)
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_20-windows-i586.cab (Java Plug-in 1.6.0_20)
    O16 - DPF: {CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_20-windows-i586.cab (Java Plug-in 1.6.0_20)
    O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_20-windows-i586.cab (Java Plug-in 1.6.0_20)
    O16 - DPF: {F6ACF75C-C32C-447B-9BEF-46B766368D29} http://ccfiles.creative.com/Web/softwareupdate/su/ocx/15112/CTPID.cab (Creative Software AutoUpdate Support Package)
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.1
    O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\WINDOWS\explorer.exe (Microsoft Corporation)
    O20 - HKLM Winlogon: GinaDLL - (C:\WINDOWS\SYSTEM32\RtlGina\RtlGina.DLL) - C:\WINDOWS\system32\RtlGina\RtlGina.dll (Realtek)
    O20 - Winlogon\Notify\!SASWinLogon: DllName - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll (SUPERAntiSpyware.com)
    O20 - Winlogon\Notify\AtiExtEvent: DllName - Ati2evxx.dll - C:\WINDOWS\System32\ati2evxx.dll (ATI Technologies Inc.)
    O20 - Winlogon\Notify\KeyScrambler: DllName - KeyScramblerLogon.dll - C:\WINDOWS\System32\KeyScramblerLogon.dll (QFX Software Corporation)
    O20 - Winlogon\Notify\LMIinit: DllName - LMIinit.dll - C:\WINDOWS\System32\LMIinit.dll (LogMeIn, Inc.)
    O24 - Desktop WallPaper: C:\Documents and Settings\Jay\Application Data\FastStone\FSIV\FSViewerWallPaper.bmp
    O24 - Desktop BackupWallPaper: C:\Documents and Settings\Jay\Application Data\FastStone\FSIV\FSViewerWallPaper.bmp
    O28 - HKLM ShellExecuteHooks: {4F07DA45-8170-4859-9B5F-037EF2970034} - C:\Program Files\Tall Emu\Online Armor\oaevent.dll (Tall Emu)
    O28 - HKLM ShellExecuteHooks: {5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} - C:\Program Files\SUPERAntiSpyware\SASSEH.DLL (SuperAdBlocker.com)
    O28 - HKLM ShellExecuteHooks: {EDB0E980-90BD-11D4-8599-0008C7D3B6F8} - C:\Program Files\Qualcomm\Eudora\EuShlExt.dll (Qualcomm Inc.)
    O32 - HKLM CDRom: AutoRun - 1
    O32 - AutoRun File - [2005/08/16 16:43:04 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
    O32 - AutoRun File - [2008/02/29 20:13:53 | 000,575,080 | R--- | M] (magicJack L.P.) - F:\autorun.exe -- [ CDFS ]
    O32 - AutoRun File - [2008/02/29 20:13:53 | 000,016,158 | R--- | M] () - F:\autorun.ico -- [ CDFS ]
    O32 - AutoRun File - [2008/02/29 20:13:53 | 000,000,308 | R--- | M] () - F:\autorun.inf -- [ CDFS ]
    O32 - AutoRun File - [2008/01/04 18:17:30 | 000,000,270 | ---- | M] () - I:\autorun.inf -- [ FAT ]
    O37 - HKLM\...com [@ = comfile] -- "%1" %*
    ========== Files/Folders - Created Within 90 Days ==========
    [2010/06/21 08:46:14 | 000,000,000 | ---D | C] -- C:\_OTL
    [2010/06/20 17:21:58 | 000,572,416 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Jay\Desktop\OTL.exe
    [2010/06/20 17:19:14 | 000,000,000 | --SD | C] -- C:\ComboFix
    [2010/06/20 02:10:27 | 000,000,000 | -HSD | C] -- C:\RECYCLER
    [2010/06/19 12:32:52 | 000,000,000 | ---D | C] -- C:\WINDOWS\ERDNT
    [2010/06/19 12:20:40 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\HostsXpert
    [2010/06/19 05:08:14 | 000,000,000 | RH-D | C] -- C:\Documents and Settings\Jay\Recent
    [2010/06/19 02:35:25 | 000,000,000 | ---D | C] -- C:\metasploit
    [2010/06/19 02:24:59 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Local Settings\Application Data\MagicRingForever
    [2010/06/19 02:11:37 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Local Settings\Application Data\MagicsilencePlugin
    [2010/06/18 04:29:44 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Application Data\Dell
    [2010/06/18 04:16:28 | 000,000,000 | ---D | C] -- C:\iolo
    [2010/06/18 04:01:10 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Application Data\iolo
    [2010/06/18 04:01:10 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\iolo
    [2010/06/18 03:32:13 | 000,000,000 | ---D | C] -- C:\Program Files\Microsoft Windows 7 Upgrade Advisor
    [2010/06/18 01:46:05 | 000,000,000 | ---D | C] -- C:\Program Files\VirusTotalUploader2
    [2010/06/17 13:07:45 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\RegCure download from 7sky.at.ua
    [2010/06/13 01:39:52 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\BlueSoleil 6.4.314.3
    [2010/06/12 23:08:04 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\BlueSol.ver6.4.249.0.KEYMAKER.maxiumaaaaa
    [2010/06/11 11:51:09 | 000,000,000 | ---D | C] -- C:\Program Files\magicBlock
    [2010/06/11 00:07:30 | 000,000,000 | ---D | C] -- C:\Program Files\Xirrus
    [2010/06/10 23:59:09 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Ekahau Site Survey
    [2010/06/10 23:57:38 | 000,000,000 | ---D | C] -- C:\Program Files\Ekahau
    [2010/06/09 22:09:28 | 000,000,000 | ---D | C] -- C:\Program Files\WinPcap
    [2010/06/08 17:42:07 | 000,000,000 | ---D | C] -- D:\My Documents\GpsGate
    [2010/06/08 17:40:56 | 000,000,000 | ---D | C] -- C:\Program Files\Franson
    [2010/06/08 11:48:00 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Local Settings\Application Data\MetaGeek,_LLC
    [2010/06/08 11:32:54 | 000,000,000 | ---D | C] -- C:\Program Files\MetaGeek
    [2010/06/07 17:08:48 | 000,000,000 | ---D | C] -- C:\pioneerpsg
    [2010/06/07 16:59:38 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\PioneerPSG
    [2010/06/03 16:01:06 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Config
    [2010/06/03 16:00:38 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Inet
    [2010/06/02 22:12:29 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\Traders Pro Elite
    [2010/05/30 05:08:45 | 000,000,000 | ---D | C] -- D:\My Documents\My Virtual Machines
    [2010/05/30 03:37:14 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Local Settings\Application Data\VMware
    [2010/05/30 03:22:06 | 000,334,384 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\vmnetdhcp.exe
    [2010/05/30 03:22:04 | 000,399,920 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\vmnat.exe
    [2010/05/30 03:22:01 | 000,026,288 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\vmnetuserif.sys
    [2010/05/30 03:21:53 | 000,760,368 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\vnetlib.dll
    [2010/05/30 03:21:33 | 000,024,624 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\VMkbd.sys
    [2010/05/30 03:20:35 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\VMware
    [2010/05/30 02:30:30 | 000,000,000 | ---D | C] -- C:\TopoGrafix Image Files
    [2010/05/27 04:50:17 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\SecTaskMan
    [2010/05/27 04:49:46 | 000,000,000 | ---D | C] -- C:\Program Files\Security Task Manager
    [2010/05/27 02:10:14 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Application Data\Malwarebytes
    [2010/05/27 02:09:53 | 000,038,224 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbamswissarmy.sys
    [2010/05/27 02:09:49 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Malwarebytes
    [2010/05/27 02:09:47 | 000,020,952 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbam.sys
    [2010/05/27 02:09:46 | 000,000,000 | ---D | C] -- C:\Program Files\Malwarebytes' Anti-Malware
    [2010/05/26 00:13:40 | 000,000,000 | ---D | C] -- C:\Program Files\PeerBlock
    [2010/05/23 22:57:43 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Application Data\X-NetStat
    [2010/05/23 22:57:28 | 000,000,000 | ---D | C] -- C:\Program Files\X-NetStat Professional
    [2010/05/22 23:53:03 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\SAK
    [2010/05/22 19:52:12 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\.gem
    [2010/05/21 23:59:13 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\backup-date250109
    [2010/05/21 23:15:40 | 000,000,000 | ---D | C] -- C:\Program Files\CORE Security Technologies
    [2010/05/21 23:10:23 | 000,090,112 | ---- | C] (E-Tech.CA) -- C:\Documents and Settings\Jay\Desktop\dc2000.exe
    [2010/05/21 19:55:53 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Application Data\ProcessLasso
    [2010/05/21 19:55:49 | 000,000,000 | ---D | C] -- C:\Program Files\Process Lasso
    [2010/05/21 04:58:53 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\Security Tools
    [2010/05/21 04:57:14 | 000,000,000 | ---D | C] -- C:\Program Files\GFI
    [2010/05/21 04:34:50 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\GLNSS9020090709
    [2010/05/21 04:00:04 | 000,000,000 | ---D | C] -- C:\Snort
    [2010/05/21 00:56:56 | 000,854,064 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\vmx86.sys
    [2010/05/21 00:56:56 | 000,070,704 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\vmci.sys
    [2010/05/21 00:54:02 | 000,051,248 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\vmnetbridge.dll
    [2010/05/21 00:54:02 | 000,032,688 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\vmnetbridge.sys
    [2010/05/20 23:40:08 | 000,032,304 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\hcmon.sys
    [2010/05/20 23:13:38 | 000,252,464 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\vmnc.dll
    [2010/05/20 21:49:01 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\Rob
    [2010/05/20 21:19:20 | 000,059,952 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\vnetinst.dll
    [2010/05/20 21:19:20 | 000,031,280 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\vmusb.sys
    [2010/05/20 21:19:20 | 000,018,736 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\vmnet.sys
    [2010/05/20 21:19:20 | 000,016,560 | ---- | C] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\vmnetadapter.sys
    [2010/05/20 20:15:33 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\regid.1986-12.com.adobe
    [2010/05/20 20:14:55 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Adobe
    [2010/05/20 20:12:35 | 000,000,000 | ---D | C] -- C:\PhotoshopPortable
    [2010/05/20 16:13:02 | 000,000,000 | ---D | C] -- C:\Program Files\Cain
    [2010/05/20 02:45:01 | 000,000,000 | ---D | C] -- C:\WINDOWS\5350-8641-2429-7641-5705
    [2010/05/19 18:55:00 | 000,000,000 | ---D | C] -- D:\My Documents\Pioneer Protective Services Group
    [2010/05/15 15:15:53 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Local Settings\Application Data\VS Revo Group
    [2010/05/15 15:14:39 | 000,027,064 | ---- | C] (VS Revo Group) -- C:\WINDOWS\System32\drivers\revoflt.sys
    [2010/05/15 04:29:25 | 000,038,976 | ---- | C] (microOLAP Technologies LTD) -- C:\WINDOWS\System32\drivers\pssdk42.sys
    [2010/05/15 03:08:52 | 000,000,000 | ---D | C] -- C:\Program Files\rapid7
    [2010/05/14 16:23:16 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\.zenmap
    [2010/05/14 16:12:31 | 000,000,000 | ---D | C] -- C:\Program Files\Nmap
    [2010/05/14 16:08:08 | 000,000,000 | ---D | C] -- C:\Program Files\Metasploit
    [2010/05/14 04:49:03 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Intel
    [2010/05/14 04:36:27 | 000,000,000 | ---D | C] -- C:\Program Files\SystemRequirementsLab
    [2010/05/14 04:35:45 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Application Data\SystemRequirementsLab
    [2010/05/12 18:34:18 | 000,000,000 | ---D | C] -- C:\Program Files\Tadawulfx Trader 4
    [2010/05/11 08:49:01 | 000,000,000 | ---D | C] -- C:\Hashfile
    [2010/05/11 07:58:01 | 000,000,000 | ---D | C] -- D:\My Documents\vaporstore payments
    [2010/05/09 16:49:14 | 000,000,000 | ---D | C] -- D:\My Documents\Avatars
    [2010/05/06 17:52:31 | 000,000,000 | ---D | C] -- C:\Device
    [2010/05/05 20:01:01 | 000,000,000 | ---D | C] -- C:\Program Files\Typograf
    [2010/05/03 15:31:25 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\New Folder
    [2010/05/01 01:30:11 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Application Data\Serif
    [2010/04/30 23:30:28 | 000,044,544 | ---- | C] (DiamondCS) -- C:\WINDOWS\System32\procguard.dll
    [2010/04/30 23:30:28 | 000,026,688 | ---- | C] (DiamondCS) -- C:\WINDOWS\System32\drivers\procguard.sys
    [2010/04/30 22:59:07 | 000,000,000 | R--D | C] -- C:\Sandbox
    [2010/04/30 22:58:04 | 000,000,000 | ---D | C] -- C:\Program Files\Sandboxie
    [2010/04/30 18:56:46 | 000,000,000 | ---D | C] -- D:\My Documents\Web Easy
    [2010/04/30 18:42:18 | 000,000,000 | ---D | C] -- C:\Program Files\Avanquest
    [2010/04/30 18:31:24 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\site pics
    [2010/04/29 20:06:56 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Application Data\FileZilla
    [2010/04/29 20:04:42 | 000,000,000 | ---D | C] -- C:\Program Files\FileZilla FTP Client
    [2010/04/27 16:42:46 | 000,064,960 | ---- | C] (StorageCraft Technology Corporation) -- C:\WINDOWS\System32\drivers\stcp2v30.sys
    [2010/04/27 14:11:55 | 000,000,000 | ---D | C] -- C:\Program Files\SopCast
    [2010/04/25 19:27:44 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\Coins
    [2010/04/22 23:55:03 | 000,000,000 | ---D | C] -- C:\Program Files\MetaTrader - FXOpen
    [2010/04/19 23:38:52 | 000,000,000 | ---D | C] -- C:\Program Files\CMS MetaTrader 4 Client Terminal
    [2010/04/17 11:53:14 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\FX Zapper V1.2 Package
    [2010/04/16 17:55:03 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Desktop\soons phone vids
    [2010/04/15 00:31:21 | 000,000,000 | ---D | C] -- C:\Program Files\Candleworks
    [2010/04/14 23:50:01 | 000,000,000 | ---D | C] -- C:\Program Files\FXCM MT4 powered by BT
    [2010/04/13 20:40:44 | 004,199,784 | ---- | C] (Amyuni Technologies
    http://www.amyuni.com) -- C:\WINDOWS\System32\cdintf400.dll
    [2010/04/13 20:40:05 | 000,000,000 | ---D | C] -- C:\Program Files\Quicken
    [2010/04/11 03:06:25 | 000,000,000 | ---D | C] -- C:\Program Files\PDF Password Remover
    [2010/04/08 00:59:46 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Application Data\mkvtoolnix
    [2010/04/08 00:58:41 | 000,000,000 | ---D | C] -- C:\Program Files\MKVtoolnix
    [2010/04/05 18:40:49 | 000,000,000 | ---D | C] -- C:\Program Files\Windows Installer Clean Up
    [2010/04/05 18:40:22 | 000,000,000 | ---D | C] -- C:\Program Files\MSECACHE
    [2010/04/04 12:07:37 | 000,000,000 | ---D | C] -- C:\Program Files\Transmission Remote
    [2010/04/03 15:23:17 | 000,000,000 | ---D | C] -- C:\Program Files\Ahead
    [2010/04/03 11:23:02 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Application Data\Canneverbe Limited
    [2010/04/03 11:23:00 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Canneverbe Limited
    [2010/04/03 11:21:49 | 000,000,000 | ---D | C] -- C:\Program Files\CDBurnerXP
    [2010/03/29 19:26:57 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Local Settings\Application Data\wizdXP
    [2010/03/29 19:26:04 | 000,000,000 | ---D | C] -- C:\Program Files\wizdxp
    [2010/03/28 12:29:49 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Apple Computer
    [2010/03/28 12:29:03 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Apple
    [2010/03/28 12:28:48 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Local Settings\Application Data\Apple
    [2010/03/28 12:28:43 | 000,000,000 | ---D | C] -- C:\Program Files\Apple Software Update
    [2010/03/28 12:28:43 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Apple
    [2010/03/28 12:27:45 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jay\Local Settings\Application Data\Apple Computer
    [2010/03/27 22:31:19 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\DivX Shared
    [2010/03/27 21:49:05 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\DivX
    [2010/03/24 11:40:30 | 000,651,264 | ---- | C] (www.ext2fsd.com) -- C:\WINDOWS\System32\drivers\ext2fsd.sys
    [2010/03/24 11:40:30 | 000,000,000 | ---D | C] -- C:\Program Files\Ext2Fsd
    [1 C:\Documents and Settings\Jay\*.tmp files -> C:\Documents and Settings\Jay\*.tmp -> ]
    ========== Files - Modified Within 90 Days ==========
    [2010/06/21 12:47:37 | 000,005,551 | ---- | M] () -- C:\WINDOWS\win.ini
    [2010/06/21 12:46:03 | 000,000,876 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
    [2010/06/21 12:44:11 | 000,000,006 | -H-- | M] () -- C:\WINDOWS\tasks\SA.DAT
    [2010/06/21 12:44:01 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
    [2010/06/21 12:41:30 | 000,000,012 | ---- | M] () -- C:\WINDOWS\bthservsdp.dat
    [2010/06/21 12:41:27 | 024,903,680 | ---- | M] () -- C:\Documents and Settings\Jay\ntuser.dat
    [2010/06/21 12:41:27 | 000,000,278 | -HS- | M] () -- C:\Documents and Settings\Jay\ntuser.ini
    [2010/06/21 12:26:47 | 000,000,098 | ---- | M] () -- C:\WINDOWS\System32\drivers\etc\Hosts
    [2010/06/21 12:21:41 | 000,326,964 | ---- | M] () -- C:\WINDOWS\System32\pguard.dat
    [2010/06/21 12:21:40 | 000,549,316 | ---- | M] () -- C:\WINDOWS\System32\pghash.dat
    [2010/06/21 12:15:49 | 000,000,982 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\magicJack.lnk
    [2010/06/21 12:12:00 | 000,000,970 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskUserS-1-5-21-3030420016-499448262-1378471451-1006UA.job
    [2010/06/21 12:12:00 | 000,000,880 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
    [2010/06/20 21:17:25 | 000,000,000 | ---- | M] () -- C:\WINDOWS\MEMORY.DMP
    [2010/06/20 19:05:20 | 001,151,011 | ---- | M] () -- D:\My Documents\jason pm file.xbel
    [2010/06/20 17:21:55 | 000,572,416 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Jay\Desktop\OTL.exe
    [2010/06/20 15:12:00 | 000,000,918 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskUserS-1-5-21-3030420016-499448262-1378471451-1006Core.job
    [2010/06/20 01:59:27 | 000,002,206 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
    [2010/06/20 01:46:44 | 000,002,441 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Xirrus Wi-Fi Inspector.lnk
    [2010/06/20 01:28:45 | 000,000,069 | ---- | M] () -- C:\WINDOWS\NeroDigital.ini
    [2010/06/20 00:57:01 | 000,000,284 | ---- | M] () -- C:\WINDOWS\system.ini
    [2010/06/19 12:55:07 | 000,463,390 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
    [2010/06/19 12:55:07 | 000,081,458 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
    [2010/06/19 12:55:06 | 000,554,596 | ---- | M] () -- C:\WINDOWS\System32\PerfStringBackup.INI
    [2010/06/19 05:22:04 | 000,008,330 | ---- | M] () -- D:\My Documents\cc_20100619_052157.reg
    [2010/06/19 03:03:42 | 000,001,024 | ---- | M] () -- C:\.rnd
    [2010/06/19 03:01:27 | 000,038,976 | ---- | M] (microOLAP Technologies LTD) -- C:\WINDOWS\System32\drivers\pssdk42.sys
    [2010/06/19 02:41:46 | 000,001,024 | ---- | M] () -- C:\Documents and Settings\Jay\.rnd
    [2010/06/19 02:11:45 | 000,001,209 | ---- | M] () -- C:\Documents and Settings\Jay\Start Menu\Programs\Startup\MagicsilencePlugin.lnk
    [2010/06/18 14:29:17 | 000,000,829 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\Advanced JPEG Compressor.lnk
    [2010/06/18 04:29:45 | 000,002,630 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\Dell Driver Download Manager.lnk
    [2010/06/18 04:01:15 | 000,074,703 | ---- | M] () -- C:\WINDOWS\System32\mfc45.dll
    [2010/06/18 03:32:14 | 000,001,910 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Windows 7 Upgrade Advisor.lnk
    [2010/06/18 00:36:53 | 000,293,376 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\c66wtg28.exe
    [2010/06/17 23:59:05 | 000,115,398 | ---- | M] () -- D:\My Documents\cc_20100617_235848.reg
    [2010/06/17 16:56:00 | 000,000,798 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\SUPERAntiSpyware Professional.lnk
    [2010/06/17 14:08:32 | 000,525,824 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\dds.EXE
    [2010/06/15 22:51:03 | 000,000,637 | ---- | M] () -- C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Bluetooth.lnk
    [2010/06/13 10:21:21 | 000,000,032 | ---- | M] () -- C:\WINDOWS\0
    [2010/06/11 13:53:07 | 011,137,024 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\gmapsupp.img
    [2010/06/10 12:09:46 | 000,403,920 | ---- | M] () -- C:\WINDOWS\System32\FNTCACHE.DAT
    [2010/06/08 17:46:53 | 000,089,210 | ---- | M] () -- D:\My Documents\50012_1.8WSolarManual.pdf
    [2010/06/07 17:37:55 | 000,201,216 | ---- | M] () -- C:\Documents and Settings\Jay\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2010/06/07 16:49:07 | 000,002,577 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\logo.png
    [2010/06/07 12:06:31 | 000,098,204 | ---- | M] () -- D:\My Documents\Welcome to SCB Easy Net headset redacted.pdf
    [2010/06/07 12:05:56 | 000,096,887 | ---- | M] () -- D:\My Documents\Welcome to SCB Easy Net headset.pdf
    [2010/06/07 11:35:52 | 001,569,290 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\Welcome to SCB Easy Net.psd
    [2010/06/07 11:16:32 | 000,111,889 | ---- | M] () -- D:\My Documents\Welcome to SCB Easy Net 1500 528 .pdf
    [2010/06/07 10:49:13 | 000,005,278 | ---- | M] () -- C:\WINDOWS\Sandboxie.ini
    [2010/06/04 14:54:47 | 004,280,249 | ---- | M] () -- D:\My Documents\joomla_15_quickstart.pdf
    [2010/06/03 16:04:40 | 000,000,165 | ---- | M] () -- C:\WINDOWS\QUICKEN.INI
    [2010/06/01 14:24:56 | 002,615,349 | ---- | M] () -- D:\My Documents\41910.pdf
    [2010/06/01 09:57:43 | 000,429,832 | ---- | M] () -- D:\My Documents\alfa-awus036h-awus050nh-installing-drivers.pdf
    [2010/05/31 11:40:26 | 000,358,803 | ---- | M] () -- D:\My Documents\GoldWars.pdf
    [2010/05/27 05:59:48 | 000,132,622 | ---- | M] () -- D:\My Documents\Statement_May 2010.pdf
    [2010/05/26 20:53:47 | 001,400,639 | ---- | M] () -- D:\My Documents\PPSG_Logo_2.pdf
    [2010/05/26 01:31:39 | 001,018,694 | ---- | M] () -- D:\My Documents\PPSG_Logo.pdf
    [2010/05/25 23:53:16 | 000,001,471 | ---- | M] () -- C:\WINDOWS\System32\drivers\etc\hosts.bak
    [2010/05/25 15:47:58 | 000,817,550 | ---- | M] () -- D:\My Documents\Cannot start magicJack.pdf
    [2010/05/24 02:25:45 | 000,000,371 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\StopAutoShares.reg
    [2010/05/22 15:52:52 | 000,060,270 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\Welcome to SCB Easy Net new.pdf
    [2010/05/21 23:15:59 | 000,000,612 | ---- | M] () -- C:\WINDOWS\ODBC.INI
    [2010/05/21 00:56:56 | 000,854,064 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\vmx86.sys
    [2010/05/21 00:56:56 | 000,070,704 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\vmci.sys
    [2010/05/21 00:56:36 | 000,334,384 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\vmnetdhcp.exe
    [2010/05/21 00:56:18 | 000,399,920 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\vmnat.exe
    [2010/05/21 00:55:24 | 000,760,368 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\vnetlib.dll
    [2010/05/21 00:55:04 | 000,024,624 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\VMkbd.sys
    [2010/05/21 00:54:02 | 000,051,248 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\vmnetbridge.dll
    [2010/05/21 00:54:02 | 000,032,688 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\vmnetbridge.sys
    [2010/05/21 00:53:58 | 000,026,288 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\vmnetuserif.sys
    [2010/05/20 23:40:08 | 000,032,304 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\hcmon.sys
    [2010/05/20 23:13:38 | 000,252,464 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\vmnc.dll
    [2010/05/20 21:19:20 | 000,059,952 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\vnetinst.dll
    [2010/05/20 21:19:20 | 000,031,280 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\vmusb.sys
    [2010/05/20 21:19:20 | 000,018,736 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\vmnet.sys
    [2010/05/20 21:19:20 | 000,016,560 | ---- | M] (VMware, Inc.) -- C:\WINDOWS\System32\drivers\vmnetadapter.sys
    [2010/05/20 19:30:52 | 000,044,059 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\Welcome to SCB Easy Net.pdf
    [2010/05/20 01:43:15 | 000,428,501 | ---- | M] () -- D:\My Documents\browser-uniqueness.pdf
    [2010/05/19 23:14:34 | 000,246,971 | ---- | M] () -- D:\My Documents\051810_virtual_townhall.pdf
    [2010/05/18 01:20:00 | 000,040,597 | ---- | M] () -- D:\My Documents\LNB+V-H.pdf
    [2010/05/18 01:18:57 | 000,053,552 | ---- | M] () -- D:\My Documents\DiseqPositioner.pdf
    [2010/05/18 01:18:29 | 000,021,109 | ---- | M] () -- D:\My Documents\LNB-4.pdf
    [2010/05/18 01:18:10 | 000,010,785 | ---- | M] () -- D:\My Documents\LNB-2.pdf
    [2010/05/18 01:17:40 | 000,063,572 | ---- | M] () -- D:\My Documents\mixTV.pdf
    [2010/05/18 01:17:08 | 000,145,220 | ---- | M] () -- D:\My Documents\compass.pdf
    [2010/05/18 01:16:34 | 000,085,500 | ---- | M] () -- D:\My Documents\4x4Great.pdf
    [2010/05/18 01:15:02 | 000,087,432 | ---- | M] () -- D:\My Documents\4x4LNBMazz.pdf
    [2010/05/18 01:13:31 | 000,103,714 | ---- | M] () -- D:\My Documents\Mz830-C-Ku.pdf
    [2010/05/18 01:12:59 | 000,059,542 | ---- | M] () -- D:\My Documents\C-Ku-2.pdf
    [2010/05/16 09:13:33 | 000,278,356 | ---- | M] () -- D:\My Documents\Cracking_Passwords_Guide.pdf
    [2010/05/16 07:38:02 | 001,732,286 | ---- | M] () -- D:\My Documents\OASettings100516.OA
    [2010/05/15 15:14:40 | 000,000,849 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Revo Uninstaller Pro.lnk
    [2010/05/15 11:47:14 | 000,000,218 | ---- | M] () -- C:\Documents and Settings\Jay\.recently-used.xbel
    [2010/05/15 04:21:05 | 000,209,898 | ---- | M] () -- D:\My Documents\Nessus_Activation_Code_Installation.pdf
    [2010/05/15 03:02:28 | 000,308,210 | ---- | M] () -- D:\My Documents\NeXpose_Extended_API_v1.2_Guide.pdf
    [2010/05/15 03:00:36 | 000,206,869 | ---- | M] () -- D:\My Documents\NeXposeQuickInstall.pdf
    [2010/05/14 05:06:13 | 000,005,033 | ---- | M] () -- C:\WirelessDiagLog.csv
    [2010/05/14 04:40:46 | 000,021,963 | ---- | M] () -- D:\My Documents\wordlist_tools.sh
    [2010/05/14 03:43:08 | 000,377,271 | ---- | M] () -- D:\My Documents\Silky_report.pdf
    [2010/05/12 22:28:31 | 000,274,247 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\post-a75824-cambodia-inter3.jpg.html
    [2010/05/12 19:06:57 | 000,001,595 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\FXDD - MetaTrader.lnk
    [2010/05/12 18:34:27 | 000,001,586 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Tadawulfx trader 4.lnk
    [2010/05/10 05:45:40 | 000,346,624 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\epen.jpg
    [2010/05/10 03:30:21 | 000,002,472 | ---- | M] () -- D:\My Documents\QOS.w54
    [2010/05/09 03:31:30 | 001,022,470 | ---- | M] () -- D:\My Documents\Backtrack_4_How_To_Nessus_4_2_Persistent_Changes.pdf
    [2010/05/09 03:30:42 | 000,999,251 | ---- | M] () -- D:\My Documents\Backtrack_4_USB_Full_Disk_Encryption.pdf
    [2010/05/04 04:39:10 | 000,988,342 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\wpa-01.cap
    [2010/05/04 02:40:44 | 017,350,974 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\Hack.wmv
    [2010/05/03 01:55:17 | 000,000,859 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\windirstat.exe.lnk
    [2010/05/03 01:33:20 | 000,041,451 | ---- | M] () -- D:\My Documents\margin_change.pdf
    [2010/05/02 18:01:25 | 000,002,803 | ---- | M] () -- C:\settings.cfg
    [2010/05/01 01:34:51 | 000,119,224 | ---- | M] () -- C:\Documents and Settings\Jay\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
    [2010/04/29 15:39:38 | 000,038,224 | ---- | M] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbamswissarmy.sys
    [2010/04/29 15:39:26 | 000,020,952 | ---- | M] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbam.sys
    [2010/04/29 03:08:57 | 000,665,088 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\Webpage PPSG.pub
    [2010/04/29 03:02:48 | 000,029,027 | ---- | M] () -- D:\My Documents\2010_4_15_18_0_1_2.pdf
    [2010/04/27 16:42:46 | 000,064,960 | ---- | M] (StorageCraft Technology Corporation) -- C:\WINDOWS\System32\drivers\stcp2v30.sys
    [2010/04/27 14:11:55 | 000,000,676 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\SopCast.lnk
    [2010/04/25 13:25:50 | 000,029,560 | ---- | M] (Tall Emu Pty Ltd) -- C:\WINDOWS\System32\drivers\OAnet.sys
    [2010/04/25 13:25:46 | 000,024,440 | ---- | M] (Tall Emu) -- C:\WINDOWS\System32\drivers\OAmon.sys
    [2010/04/25 13:25:41 | 000,225,936 | ---- | M] (Tall Emu) -- C:\WINDOWS\System32\drivers\OADriver.sys
    [2010/04/25 06:31:58 | 000,050,688 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\keygen.exe
    [2010/04/24 23:33:52 | 000,019,374 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\Bhumbol_and_Sirikit.jpg
    [2010/04/22 23:55:10 | 000,001,593 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\MetaTrader - FXOpen.lnk
    [2010/04/22 21:16:01 | 000,064,384 | ---- | M] () -- D:\My Documents\UGN-3050_Personal-Tracker.pdf
    [2010/04/22 18:34:18 | 000,845,132 | ---- | M] () -- D:\My Documents\bluediving-0.9.gz
    [2010/04/22 18:30:10 | 000,820,137 | ---- | M] () -- D:\My Documents\bluediving-0.8.gz
    [2010/04/22 18:19:06 | 000,043,748 | ---- | M] () -- D:\My Documents\Blooover.jar
    [2010/04/22 18:08:38 | 000,362,135 | ---- | M] () -- D:\My Documents\21c3_Bluetooth_Hacking.pdf
    [2010/04/22 17:45:41 | 000,188,361 | ---- | M] () -- D:\My Documents\FANTOMDRIVES22-207-017Apr16Apr3010ls41.pdf
    [2010/04/22 17:04:26 | 001,273,638 | ---- | M] () -- D:\My Documents\DEE-iN_GPS_TRACKING.pdf
    [2010/04/22 16:52:36 | 000,337,176 | ---- | M] () -- D:\My Documents\ACCESSORIESGPS.pdf
    [2010/04/22 16:44:03 | 000,909,936 | ---- | M] () -- D:\My Documents\fulltext.pdf
    [2010/04/21 12:38:44 | 000,000,103 | ---- | M] () -- C:\Documents and Settings\Jay\Application Data\default.pls
    [2010/04/20 19:03:15 | 000,293,909 | ---- | M] () -- D:\My Documents\en_US-customer_agreement-fxddmalta.pdf
    [2010/04/20 09:31:16 | 000,894,503 | ---- | M] () -- D:\My Documents\FXS Express Monthly - April 10.pdf
    [2010/04/19 23:38:57 | 000,001,698 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\CMS MetaTrader 4 Client Terminal.lnk
    [2010/04/19 22:58:41 | 000,029,027 | ---- | M] () -- D:\My Documents\2010_4_15_18_0_1.pdf
    [2010/04/19 22:47:03 | 000,000,708 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\VTTrader 2.lnk
    [2010/04/19 13:20:51 | 000,134,389 | ---- | M] () -- D:\My Documents\2e.tuckwellLBMAConf2003.pdf
    [2010/04/19 13:15:17 | 000,020,464 | ---- | M] () -- D:\My Documents\cometa.pdf
    [2010/04/19 13:14:23 | 002,053,006 | ---- | M] () -- D:\My Documents\COMETA_part2.pdf
    [2010/04/19 13:11:25 | 000,773,433 | ---- | M] () -- D:\My Documents\COMETA_part1.pdf
    [2010/04/19 10:03:46 | 000,045,928 | ---- | M] () -- D:\My Documents\obama-briefing-intro-letter.pdf
    [2010/04/16 10:59:00 | 000,008,790 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\n781974571_4410.jpg
    [2010/04/16 10:58:18 | 000,009,664 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\5453_1177520566373_1478899103_448840_7975285_n.jpg
    [2010/04/16 10:47:12 | 000,046,800 | ---- | M] () -- C:\Documents and Settings\Jay\Desktop\23968_102493123125729_100000951257443_15513_5303731_n.jpg
    [2010/04/15 00:31:25 | 000,001,667 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\FXCM Trading Station.lnk
    [2010/04/14 23:50:06 | 000,001,618 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\FXCM MT4 powered by BT.lnk
    [2010/04/14 09:46:52 | 000,328,857 | ---- | M] () -- D:\My Documents\CCTV.pdf
    [2010/04/13 20:35:26 | 000,030,461 | ---- | M] () -- D:\My Documents\securepay.fxcm.co.u...pdf
    [2010/04/13 08:56:39 | 000,035,526 | ---- | M] () -- D:\My Documents\ESign Nevada.pdf
    [2010/04/13 06:03:19 | 000,694,736 | ---- | M] () -- D:\My Documents\2009 Lieberman J Form 1040 Individual Tax Return.tax2009
    [2010/04/13 04:01:12 | 000,907,607 | ---- | M] () -- D:\My Documents\Passport_SSN_CADL.pdf
    [2010/04/13 03:53:48 | 000,019,545 | ---- | M] () -- C:\WINDOWS\hpoins01.dat
    [2010/04/12 12:16:32 | 000,059,829 | ---- | M] () -- D:\My Documents\Online trading application fxcm ...pdf
    [2010/04/12 12:13:11 | 000,010,504 | ---- | M] () -- D:\My Documents\Online trading application ...pdf
    [2010/04/11 22:02:32 | 000,522,781 | ---- | M] () -- D:\My Documents\user guide for connecttalk softphone.pdf
    [2010/04/11 03:08:40 | 000,059,289 | ---- | M] () -- D:\My Documents\loat_signed.pdf
    [2010/04/11 03:07:47 | 000,644,687 | ---- | M] () -- D:\My Documents\loat.1.pdf
    [2010/04/11 02:48:31 | 000,648,745 | ---- | M] () -- D:\My Documents\LOAT_2.pdf
    [2010/04/08 01:40:05 | 000,000,873 | ---- | M] () -- C:\WINDOWS\graphedt.INI
    [2010/04/08 00:58:57 | 000,001,563 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\mkvmerge GUI.lnk
    [2010/04/07 22:58:45 | 000,292,650 | ---- | M] () -- D:\My Documents\file_4.pdf
    [2010/04/06 18:33:10 | 000,025,864 | ---- | M] () -- C:\WINDOWS\System32\drivers\btnetBus.sys
    [2010/04/06 18:32:48 | 000,023,048 | ---- | M] (IVT Corporation.) -- C:\WINDOWS\System32\drivers\IvtBtBus.sys
    [2010/04/06 18:32:44 | 000,020,104 | ---- | M] (IVT Corporation.) -- C:\WINDOWS\System32\drivers\BtHidBus.sys
    [2010/04/06 02:44:50 | 000,386,462 | ---- | M] () -- D:\My Documents\SF4000_Account_Transfer_Form.pdf
    [2010/04/06 02:28:15 | 000,156,985 | ---- | M] () -- D:\My Documents\file_3.pdf
    [2010/04/05 22:08:02 | 000,317,024 | ---- | M] () -- D:\My Documents\[OPEN_SOURCE_GUIDE]BN68-02223A_3.pdf
    [2010/04/05 22:07:02 | 000,317,024 | ---- | M] () -- D:\My Documents\[OPEN_SOURCE_GUIDE]BN68-02223A_2.pdf
    [2010/04/05 22:05:38 | 000,317,024 | ---- | M] () -- D:\My Documents\[OPEN_SOURCE_GUIDE]BN68-02223A.pdf
    [2010/04/05 22:04:45 | 000,265,074 | ---- | M] () -- D:\My Documents\TV_Software_Upgrade_Guide_2.pdf
    [2010/04/05 22:00:08 | 000,420,296 | ---- | M] () -- D:\My Documents\swupgrade_Guide_-_Eng.pdf
    [2010/04/05 21:57:44 | 000,265,074 | ---- | M] () -- D:\My Documents\TV_Software_Upgrade_Guide.pdf
    [2010/04/05 20:00:16 | 003,432,834 | ---- | M] () -- D:\My Documents\BN68-01983A-00Eng-0317.pdf
    [2010/04/04 12:39:00 | 500,236,323 | ---- | M] () -- C:\Exploited teen asia Filipino bar teen anal.wmv
    [2010/04/04 04:39:51 | 001,272,114 | ---- | M] () -- D:\My Documents\OASettings100404.OA
    [2010/04/01 22:28:18 | 000,111,513 | ---- | M] () -- C:\WINDOWS\System32\3x4KT-HE.exe
    [2010/04/01 01:59:17 | 000,006,742 | ---- | M] () -- D:\My Documents\Iron Man 2 [2010] English DVDRip.XviD-ALLiANCE.nfo
    [2010/03/30 15:57:14 | 000,029,194 | ---- | M] () -- D:\My Documents\060327m.pdf
    [2010/03/27 23:31:37 | 000,042,671 | ---- | M] () -- D:\My Documents\ref 103 Taking Erythromycin.pdf
    [2010/03/27 22:32:08 | 000,665,728 | ---- | M] () -- D:\My Documents\2006.pdf
    [2010/03/27 22:30:29 | 000,053,826 | ---- | M] () -- D:\My Documents\treat1.pdf
    [2010/03/24 16:38:23 | 000,124,784 | ---- | M] (Avira GmbH) -- C:\WINDOWS\System32\drivers\avipbb.sys
    [2010/03/24 16:38:23 | 000,060,936 | ---- | M] (Avira GmbH) -- C:\WINDOWS\System32\drivers\avgntflt.sys
  6. 2010/06/21
    Jayman007
    part 3
    [2010/06/19 05:22:01 | 000,008,330 | ---- | C] () -- D:\My Documents\cc_20100619_052157.reg
    [2010/06/19 04:29:16 | 000,000,000 | ---- | C] () -- C:\WINDOWS\MEMORY.DMP
    [2010/06/19 02:11:45 | 000,001,209 | ---- | C] () -- C:\Documents and Settings\Jay\Start Menu\Programs\Startup\MagicsilencePlugin.lnk
    [2010/06/18 19:24:43 | 000,293,376 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\c66wtg28.exe
    [2010/06/18 14:29:17 | 000,000,829 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\Advanced JPEG Compressor.lnk
    [2010/06/18 04:29:45 | 000,002,630 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\Dell Driver Download Manager.lnk
    [2010/06/18 04:01:15 | 000,074,703 | ---- | C] () -- C:\WINDOWS\System32\mfc45.dll
    [2010/06/18 03:32:14 | 000,001,910 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Windows 7 Upgrade Advisor.lnk
    [2010/06/17 23:58:55 | 000,115,398 | ---- | C] () -- D:\My Documents\cc_20100617_235848.reg
    [2010/06/17 23:19:43 | 000,525,824 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\dds.EXE
    [2010/06/17 16:56:00 | 000,000,798 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\SUPERAntiSpyware Professional.lnk
    [2010/06/15 22:51:03 | 000,000,637 | ---- | C] () -- C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Bluetooth.lnk
    [2010/06/11 13:52:42 | 011,137,024 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\gmapsupp.img
    [2010/06/11 00:07:32 | 000,002,441 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Xirrus Wi-Fi Inspector.lnk
    [2010/06/08 17:46:52 | 000,089,210 | ---- | C] () -- D:\My Documents\50012_1.8WSolarManual.pdf
    [2010/06/07 16:49:05 | 000,002,577 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\logo.png
    [2010/06/07 12:06:30 | 000,098,204 | ---- | C] () -- D:\My Documents\Welcome to SCB Easy Net headset redacted.pdf
    [2010/06/07 12:05:56 | 000,096,887 | ---- | C] () -- D:\My Documents\Welcome to SCB Easy Net headset.pdf
    [2010/06/07 11:16:32 | 000,111,889 | ---- | C] () -- D:\My Documents\Welcome to SCB Easy Net 1500 528 .pdf
    [2010/06/04 14:54:21 | 004,280,249 | ---- | C] () -- D:\My Documents\joomla_15_quickstart.pdf
    [2010/06/01 14:24:50 | 002,615,349 | ---- | C] () -- D:\My Documents\41910.pdf
    [2010/06/01 09:57:42 | 000,429,832 | ---- | C] () -- D:\My Documents\alfa-awus036h-awus050nh-installing-drivers.pdf
    [2010/05/31 11:40:25 | 000,358,803 | ---- | C] () -- D:\My Documents\GoldWars.pdf
    [2010/05/27 05:59:47 | 000,132,622 | ---- | C] () -- D:\My Documents\Statement_May 2010.pdf
    [2010/05/26 20:53:37 | 001,400,639 | ---- | C] () -- D:\My Documents\PPSG_Logo_2.pdf
    [2010/05/26 01:30:56 | 001,018,694 | ---- | C] () -- D:\My Documents\PPSG_Logo.pdf
    [2010/05/25 15:47:55 | 000,817,550 | ---- | C] () -- D:\My Documents\Cannot start magicJack.pdf
    [2010/05/25 00:59:06 | 000,388,823 | ---- | C] () -- C:\hping.exe
    [2010/05/24 02:25:43 | 000,000,371 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\StopAutoShares.reg
    [2010/05/23 23:03:59 | 000,050,688 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\keygen.exe
    [2010/05/22 15:52:52 | 000,060,270 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\Welcome to SCB Easy Net new.pdf
    [2010/05/20 21:30:17 | 001,569,290 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\Welcome to SCB Easy Net.psd
    [2010/05/20 19:30:52 | 000,044,059 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\Welcome to SCB Easy Net.pdf
    [2010/05/20 01:43:13 | 000,428,501 | ---- | C] () -- D:\My Documents\browser-uniqueness.pdf
    [2010/05/19 23:14:34 | 000,246,971 | ---- | C] () -- D:\My Documents\051810_virtual_townhall.pdf
    [2010/05/18 01:19:59 | 000,040,597 | ---- | C] () -- D:\My Documents\LNB+V-H.pdf
    [2010/05/18 01:18:56 | 000,053,552 | ---- | C] () -- D:\My Documents\DiseqPositioner.pdf
    [2010/05/18 01:18:29 | 000,021,109 | ---- | C] () -- D:\My Documents\LNB-4.pdf
    [2010/05/18 01:18:10 | 000,010,785 | ---- | C] () -- D:\My Documents\LNB-2.pdf
    [2010/05/18 01:17:39 | 000,063,572 | ---- | C] () -- D:\My Documents\mixTV.pdf
    [2010/05/18 01:17:07 | 000,145,220 | ---- | C] () -- D:\My Documents\compass.pdf
    [2010/05/18 01:16:33 | 000,085,500 | ---- | C] () -- D:\My Documents\4x4Great.pdf
    [2010/05/18 01:15:01 | 000,087,432 | ---- | C] () -- D:\My Documents\4x4LNBMazz.pdf
    [2010/05/18 01:13:29 | 000,103,714 | ---- | C] () -- D:\My Documents\Mz830-C-Ku.pdf
    [2010/05/18 01:12:59 | 000,059,542 | ---- | C] () -- D:\My Documents\C-Ku-2.pdf
    [2010/05/16 09:13:32 | 000,278,356 | ---- | C] () -- D:\My Documents\Cracking_Passwords_Guide.pdf
    [2010/05/16 07:37:55 | 001,732,286 | ---- | C] () -- D:\My Documents\OASettings100516.OA
    [2010/05/15 15:14:40 | 000,000,849 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Revo Uninstaller Pro.lnk
    [2010/05/15 11:47:14 | 000,000,218 | ---- | C] () -- C:\Documents and Settings\Jay\.recently-used.xbel
    [2010/05/15 04:21:04 | 000,209,898 | ---- | C] () -- D:\My Documents\Nessus_Activation_Code_Installation.pdf
    [2010/05/15 03:02:27 | 000,308,210 | ---- | C] () -- D:\My Documents\NeXpose_Extended_API_v1.2_Guide.pdf
    [2010/05/15 03:00:35 | 000,206,869 | ---- | C] () -- D:\My Documents\NeXposeQuickInstall.pdf
    [2010/05/14 04:40:46 | 000,021,963 | ---- | C] () -- D:\My Documents\wordlist_tools.sh
    [2010/05/14 03:43:07 | 000,377,271 | ---- | C] () -- D:\My Documents\Silky_report.pdf
    [2010/05/12 22:28:30 | 000,274,247 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\post-a75824-cambodia-inter3.jpg.html
    [2010/05/12 19:06:57 | 000,001,595 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\FXDD - MetaTrader.lnk
    [2010/05/12 18:34:27 | 000,001,586 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Tadawulfx trader 4.lnk
    [2010/05/10 06:05:07 | 000,346,624 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\epen.jpg
    [2010/05/10 02:49:02 | 000,002,472 | ---- | C] () -- D:\My Documents\QOS.w54
    [2010/05/09 03:31:28 | 001,022,470 | ---- | C] () -- D:\My Documents\Backtrack_4_How_To_Nessus_4_2_Persistent_Changes.pdf
    [2010/05/09 03:30:39 | 000,999,251 | ---- | C] () -- D:\My Documents\Backtrack_4_USB_Full_Disk_Encryption.pdf
    [2010/05/04 04:46:01 | 000,988,342 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\wpa-01.cap
    [2010/05/04 02:22:33 | 017,350,974 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\Hack.wmv
    [2010/05/03 01:55:17 | 000,000,859 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\windirstat.exe.lnk
    [2010/05/03 01:33:20 | 000,041,451 | ---- | C] () -- D:\My Documents\margin_change.pdf
    [2010/05/02 18:38:18 | 000,002,803 | ---- | C] () -- C:\settings.cfg
    [2010/04/30 22:58:26 | 000,005,278 | ---- | C] () -- C:\WINDOWS\Sandboxie.ini
    [2010/04/29 03:08:56 | 000,665,088 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\Webpage PPSG.pub
    [2010/04/29 03:02:48 | 000,029,027 | ---- | C] () -- D:\My Documents\2010_4_15_18_0_1_2.pdf
    [2010/04/27 14:11:55 | 000,000,676 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\SopCast.lnk
    [2010/04/24 23:33:51 | 000,019,374 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\Bhumbol_and_Sirikit.jpg
    [2010/04/22 23:55:10 | 000,001,593 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\MetaTrader - FXOpen.lnk
    [2010/04/22 21:16:01 | 000,064,384 | ---- | C] () -- D:\My Documents\UGN-3050_Personal-Tracker.pdf
    [2010/04/22 18:33:38 | 000,845,132 | ---- | C] () -- D:\My Documents\bluediving-0.9.gz
    [2010/04/22 18:28:13 | 000,820,137 | ---- | C] () -- D:\My Documents\bluediving-0.8.gz
    [2010/04/22 18:19:06 | 000,043,748 | ---- | C] () -- D:\My Documents\Blooover.jar
    [2010/04/22 18:08:38 | 000,362,135 | ---- | C] () -- D:\My Documents\21c3_Bluetooth_Hacking.pdf
    [2010/04/22 17:45:40 | 000,188,361 | ---- | C] () -- D:\My Documents\FANTOMDRIVES22-207-017Apr16Apr3010ls41.pdf
    [2010/04/22 17:04:06 | 001,273,638 | ---- | C] () -- D:\My Documents\DEE-iN_GPS_TRACKING.pdf
    [2010/04/22 16:51:01 | 000,337,176 | ---- | C] () -- D:\My Documents\ACCESSORIESGPS.pdf
    [2010/04/22 16:43:49 | 000,909,936 | ---- | C] () -- D:\My Documents\fulltext.pdf
    [2010/04/20 19:03:15 | 000,293,909 | ---- | C] () -- D:\My Documents\en_US-customer_agreement-fxddmalta.pdf
    [2010/04/20 09:31:16 | 000,894,503 | ---- | C] () -- D:\My Documents\FXS Express Monthly - April 10.pdf
    [2010/04/19 23:38:57 | 000,001,698 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\CMS MetaTrader 4 Client Terminal.lnk
    [2010/04/19 22:58:41 | 000,029,027 | ---- | C] () -- D:\My Documents\2010_4_15_18_0_1.pdf
    [2010/04/19 22:47:03 | 000,000,708 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\VTTrader 2.lnk
    [2010/04/19 13:20:51 | 000,134,389 | ---- | C] () -- D:\My Documents\2e.tuckwellLBMAConf2003.pdf
    [2010/04/19 13:15:17 | 000,020,464 | ---- | C] () -- D:\My Documents\cometa.pdf
    [2010/04/19 13:12:16 | 002,053,006 | ---- | C] () -- D:\My Documents\COMETA_part2.pdf
    [2010/04/19 13:11:19 | 000,773,433 | ---- | C] () -- D:\My Documents\COMETA_part1.pdf
    [2010/04/19 10:03:46 | 000,045,928 | ---- | C] () -- D:\My Documents\obama-briefing-intro-letter.pdf
    [2010/04/16 10:58:12 | 000,008,790 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\n781974571_4410.jpg
    [2010/04/16 10:57:37 | 000,009,664 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\5453_1177520566373_1478899103_448840_7975285_n.jpg
    [2010/04/16 10:46:38 | 000,046,800 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\23968_102493123125729_100000951257443_15513_5303731_n.jpg
    [2010/04/15 00:31:25 | 000,001,667 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\FXCM Trading Station.lnk
    [2010/04/14 23:50:06 | 000,001,618 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\FXCM MT4 powered by BT.lnk
    [2010/04/14 09:46:52 | 000,328,857 | ---- | C] () -- D:\My Documents\CCTV.pdf
    [2010/04/13 20:39:52 | 000,000,165 | ---- | C] () -- C:\WINDOWS\QUICKEN.INI
    [2010/04/13 20:35:26 | 000,030,461 | ---- | C] () -- D:\My Documents\securepay.fxcm.co.u...pdf
    [2010/04/13 08:56:38 | 000,035,526 | ---- | C] () -- D:\My Documents\ESign Nevada.pdf
    [2010/04/13 03:56:49 | 000,907,607 | ---- | C] () -- D:\My Documents\Passport_SSN_CADL.pdf
    [2010/04/13 03:48:48 | 000,019,545 | ---- | C] () -- C:\WINDOWS\hpoins01.dat
    [2010/04/13 03:48:48 | 000,016,606 | ---- | C] () -- C:\WINDOWS\hpomdl01.dat
    [2010/04/12 12:16:32 | 000,059,829 | ---- | C] () -- D:\My Documents\Online trading application fxcm ...pdf
    [2010/04/12 12:13:11 | 000,010,504 | ---- | C] () -- D:\My Documents\Online trading application ...pdf
    [2010/04/11 22:02:31 | 000,522,781 | ---- | C] () -- D:\My Documents\user guide for connecttalk softphone.pdf
    [2010/04/11 03:08:40 | 000,059,289 | ---- | C] () -- D:\My Documents\loat_signed.pdf
    [2010/04/11 03:07:47 | 000,644,687 | ---- | C] () -- D:\My Documents\loat.1.pdf
    [2010/04/09 20:16:08 | 000,161,196 | ---- | C] () -- C:\Documents and Settings\Jay\Desktop\Buzz.mp3
    [2010/04/08 00:58:57 | 000,001,563 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\mkvmerge GUI.lnk
    [2010/04/07 22:58:39 | 000,292,650 | ---- | C] () -- D:\My Documents\file_4.pdf
    [2010/04/07 01:27:37 | 000,648,745 | ---- | C] () -- D:\My Documents\LOAT_2.pdf
    [2010/04/06 02:44:50 | 000,386,462 | ---- | C] () -- D:\My Documents\SF4000_Account_Transfer_Form.pdf
    [2010/04/06 02:28:14 | 000,156,985 | ---- | C] () -- D:\My Documents\file_3.pdf
    [2010/04/05 22:08:01 | 000,317,024 | ---- | C] () -- D:\My Documents\[OPEN_SOURCE_GUIDE]BN68-02223A_3.pdf
    [2010/04/05 22:07:02 | 000,317,024 | ---- | C] () -- D:\My Documents\[OPEN_SOURCE_GUIDE]BN68-02223A_2.pdf
    [2010/04/05 22:05:38 | 000,317,024 | ---- | C] () -- D:\My Documents\[OPEN_SOURCE_GUIDE]BN68-02223A.pdf
    [2010/04/05 22:04:44 | 000,265,074 | ---- | C] () -- D:\My Documents\TV_Software_Upgrade_Guide_2.pdf
    [2010/04/05 22:00:08 | 000,420,296 | ---- | C] () -- D:\My Documents\swupgrade_Guide_-_Eng.pdf
    [2010/04/05 21:57:43 | 000,265,074 | ---- | C] () -- D:\My Documents\TV_Software_Upgrade_Guide.pdf
    [2010/04/05 19:59:50 | 003,432,834 | ---- | C] () -- D:\My Documents\BN68-01983A-00Eng-0317.pdf
    [2010/04/05 02:37:26 | 500,236,323 | ---- | C] () -- C:\Exploited teen asia Filipino bar teen anal.wmv
    [2010/04/04 04:39:33 | 001,272,114 | ---- | C] () -- D:\My Documents\OASettings100404.OA
    [2010/04/03 11:21:51 | 000,007,168 | ---- | C] () -- C:\WINDOWS\System32\drivers\StarOpen.sys
    [2010/04/01 22:28:18 | 000,111,513 | ---- | C] () -- C:\WINDOWS\System32\3x4KT-HE.exe
    [2010/04/01 01:59:17 | 000,006,742 | ---- | C] () -- D:\My Documents\Iron Man 2 [2010] English DVDRip.XviD-ALLiANCE.nfo
    [2010/03/31 20:21:30 | 000,005,033 | ---- | C] () -- C:\WirelessDiagLog.csv
    [2010/03/30 15:57:13 | 000,029,194 | ---- | C] () -- D:\My Documents\060327m.pdf
    [2010/03/27 23:31:36 | 000,042,671 | ---- | C] () -- D:\My Documents\ref 103 Taking Erythromycin.pdf
    [2010/03/27 22:32:06 | 000,665,728 | ---- | C] () -- D:\My Documents\2006.pdf
    [2010/03/27 22:30:29 | 000,053,826 | ---- | C] () -- D:\My Documents\treat1.pdf
    [2010/01/27 09:09:02 | 000,053,299 | ---- | C] () -- C:\WINDOWS\System32\pthreadVC.dll
    [2009/09/30 05:45:46 | 000,020,849 | ---- | C] () -- C:\WINDOWS\hplj1010.ini
    [2009/06/30 16:08:08 | 000,027,648 | ---- | C] () -- C:\WINDOWS\System32\AVSredirect.dll
    [2009/06/28 07:21:05 | 000,000,038 | ---- | C] () -- C:\WINDOWS\AviSplitter.INI
    [2009/06/08 08:58:17 | 000,026,504 | ---- | C] () -- C:\WINDOWS\System32\drivers\swmsflt.sys
    [2008/12/07 12:44:54 | 000,025,864 | ---- | C] () -- C:\WINDOWS\System32\drivers\btnetBus.sys
    [2008/11/14 12:45:54 | 000,000,165 | ---- | C] () -- C:\WINDOWS\startUp manager.INI
    [2008/11/03 12:28:30 | 000,185,856 | ---- | C] () -- C:\WINDOWS\System32\Bmp2Jpeg.dll
    [2008/10/15 18:48:34 | 000,000,000 | ---- | C] () -- C:\WINDOWS\oodcnt.INI
    [2008/10/07 14:32:29 | 000,000,099 | ---- | C] () -- C:\WINDOWS\(null)toolkit.ini
    [2008/09/29 08:52:51 | 000,921,600 | ---- | C] () -- C:\WINDOWS\System32\vorbisenc.dll
    [2008/09/29 08:52:51 | 000,237,568 | ---- | C] () -- C:\WINDOWS\System32\OggDS.dll
    [2008/09/29 08:52:51 | 000,188,416 | ---- | C] () -- C:\WINDOWS\System32\vorbis.dll
    [2008/09/29 08:52:51 | 000,045,056 | ---- | C] () -- C:\WINDOWS\System32\ogg.dll
    [2008/09/12 01:58:50 | 000,163,840 | ---- | C] () -- C:\WINDOWS\System32\GpsGateComClient.dll
    [2008/09/12 01:56:54 | 000,118,784 | ---- | C] () -- C:\WINDOWS\System32\GateApiXP.dll
    [2008/08/04 03:45:47 | 000,000,041 | ---- | C] () -- C:\WINDOWS\Dreambox Uploader.ini
    [2008/07/23 17:33:07 | 000,003,712 | ---- | C] () -- C:\WINDOWS\System32\socketlock.sys
    [2008/06/02 09:27:23 | 000,007,680 | ---- | C] () -- C:\WINDOWS\System32\ff_vfw.dll
    [2008/06/02 09:27:23 | 000,000,547 | ---- | C] () -- C:\WINDOWS\System32\ff_vfw.dll.manifest
    [2008/05/27 08:52:49 | 000,000,000 | R--- | C] () -- C:\WINDOWS\System32\svconfig.ini
    [2008/05/27 07:13:38 | 000,000,873 | ---- | C] () -- C:\WINDOWS\graphedt.INI
    [2008/05/23 05:22:18 | 003,596,288 | ---- | C] () -- C:\WINDOWS\System32\qt-dx331.dll
    [2008/05/23 05:19:46 | 000,000,416 | ---- | C] () -- C:\WINDOWS\System32\dtu100.dll.manifest
    [2008/05/16 14:50:56 | 000,000,160 | ---- | C] () -- C:\WINDOWS\MyDrivers.ini
    [2008/05/16 14:47:54 | 000,000,064 | -H-- | C] () -- C:\WINDOWS\system.sys
    [2008/03/12 03:47:24 | 000,884,736 | ---- | C] () -- C:\WINDOWS\System32\HDX4MediaConverter.dll
    [2008/02/29 05:30:08 | 000,008,784 | ---- | C] () -- C:\WINDOWS\System32\ractrlkeyhook.dll
    [2008/02/06 02:31:50 | 001,511,424 | ---- | C] () -- C:\WINDOWS\System32\HDX4MediaReveal.dll
    [2008/02/05 08:23:10 | 000,693,792 | ---- | C] () -- C:\WINDOWS\System32\OGACheckControl.DLL
    [2008/01/29 15:05:48 | 002,842,624 | ---- | C] () -- C:\WINDOWS\System32\btwicons.dll
    [2008/01/13 21:07:09 | 000,000,022 | ---- | C] () -- C:\WINDOWS\ShellIcon32.dll
    [2007/10/29 04:24:08 | 000,126,976 | ---- | C] () -- C:\WINDOWS\System32\pwlang.dll
    [2007/10/10 20:00:36 | 000,165,376 | ---- | C] () -- C:\WINDOWS\System32\chckshll.dll
    [2007/09/24 15:06:06 | 000,034,128 | ---- | C] () -- C:\WINDOWS\OEM_FLASHDRV.dll
    [2007/08/24 04:07:20 | 000,000,239 | ---- | C] () -- C:\WINDOWS\WINCMD.INI
    [2007/08/21 05:46:07 | 000,544,256 | ---- | C] () -- C:\WINDOWS\System32\janGraphics.dll
    [2007/08/20 01:50:48 | 000,000,918 | ---- | C] () -- C:\WINDOWS\BOC425.INI
    [2007/07/27 03:24:57 | 000,000,250 | ---- | C] () -- C:\WINDOWS\gmer.ini
    [2007/07/27 03:24:17 | 000,585,791 | ---- | C] () -- C:\WINDOWS\gmer.dll
    [2007/07/25 02:10:55 | 000,180,224 | ---- | C] () -- C:\WINDOWS\System32\OmniEOM.dll
    [2007/07/25 02:10:55 | 000,090,112 | ---- | C] () -- C:\WINDOWS\System32\nfsshare.dll
    [2007/06/21 17:32:49 | 000,000,008 | ---- | C] () -- C:\WINDOWS\System32\PROTOCOL.INI
    [2007/06/18 22:09:25 | 000,000,123 | ---- | C] () -- C:\WINDOWS\rootkitno.ini
    [2007/06/18 20:58:41 | 000,000,133 | R--- | C] () -- C:\WINDOWS\System32\ftdiun2k.ini
    [2007/06/08 20:46:39 | 000,000,077 | ---- | C] () -- C:\WINDOWS\lsoon.ini
    [2007/05/22 10:13:11 | 000,000,097 | ---- | C] () -- C:\WINDOWS\System32\PICSDK.ini
    [2007/05/22 10:10:26 | 000,000,084 | ---- | C] () -- C:\WINDOWS\EPSPRX580.ini
    [2007/05/18 19:51:54 | 000,002,828 | -HS- | C] () -- C:\WINDOWS\System32\KGyGaAvL.sys
    [2007/05/02 16:39:48 | 001,216,512 | ---- | C] () -- C:\WINDOWS\System32\xvidcore.dll
    [2007/05/02 16:39:48 | 000,237,568 | ---- | C] () -- C:\WINDOWS\System32\xvidvfw.dll
    [2007/04/21 03:29:02 | 000,413,696 | ---- | C] () -- C:\WINDOWS\System32\RTClientSDK70.dll
    [2007/03/30 14:00:40 | 000,203,264 | R--- | C] () -- C:\WINDOWS\System32\CddbCdda.dll
    [2007/03/21 17:18:47 | 000,000,026 | ---- | C] () -- C:\WINDOWS\dvdSanta.INI
    [2007/03/17 07:45:08 | 000,000,069 | ---- | C] () -- C:\WINDOWS\NeroDigital.ini
    [2007/03/07 08:54:55 | 000,077,824 | R--- | C] () -- C:\WINDOWS\System32\HPZIDS01.dll
    [2007/03/06 09:29:11 | 000,000,459 | ---- | C] () -- C:\WINDOWS\BRWMARK.INI
    [2007/03/06 09:29:11 | 000,000,027 | ---- | C] () -- C:\WINDOWS\BRPP2KA.INI
    [2007/03/06 09:28:26 | 000,000,887 | ---- | C] () -- C:\WINDOWS\Brpfx04a.ini
    [2007/03/06 09:28:26 | 000,000,153 | ---- | C] () -- C:\WINDOWS\brpcfx.ini
    [2007/03/06 09:27:16 | 000,106,496 | ---- | C] () -- C:\WINDOWS\System32\BrMuSNMP.dll
    [2007/02/27 02:59:14 | 000,000,026 | ---- | C] () -- C:\WINDOWS\FPKPMSV.INI
    [2007/02/26 23:45:39 | 000,005,248 | ---- | C] () -- C:\WINDOWS\System32\giveio.sys
    [2007/02/21 03:53:08 | 004,239,360 | ---- | C] () -- C:\WINDOWS\System32\qtp-mt334.dll
    [2007/02/12 00:49:20 | 000,000,201 | ---- | C] () -- C:\WINDOWS\AspellPlugin.INI
    [2006/12/29 21:08:34 | 000,000,317 | ---- | C] () -- C:\WINDOWS\LEXSTAT.INI
    [2006/12/07 21:59:00 | 000,400,896 | ---- | C] () -- C:\WINDOWS\stb_user.dll
    [2006/12/07 21:59:00 | 000,146,432 | ---- | C] () -- C:\WINDOWS\stb_struct.dll
    [2006/12/07 21:58:55 | 003,693,568 | ---- | C] () -- C:\WINDOWS\stb_prog.dll
    [2006/12/07 21:58:53 | 001,199,616 | ---- | C] () -- C:\WINDOWS\stb_import.dll
    [2006/12/07 21:58:53 | 000,279,040 | ---- | C] () -- C:\WINDOWS\stb_dwobj.dll
    [2006/12/07 21:58:53 | 000,161,280 | ---- | C] () -- C:\WINDOWS\stb_func.dll
    [2006/12/07 21:58:52 | 000,688,640 | ---- | C] () -- C:\WINDOWS\stb_comm.dll
    [2006/12/07 21:58:51 | 000,376,832 | ---- | C] () -- C:\WINDOWS\Jpeg2Raw.dll
    [2006/12/07 21:58:51 | 000,282,624 | ---- | C] () -- C:\WINDOWS\MPEG_ENC_DLL.dll
    [2006/12/07 21:58:51 | 000,077,824 | ---- | C] () -- C:\WINDOWS\stb_Serial32.dll
    [2006/12/07 21:58:50 | 000,049,152 | ---- | C] () -- C:\WINDOWS\stb_EzInternet.dll
    [2006/12/07 21:58:50 | 000,032,768 | ---- | C] () -- C:\WINDOWS\stb_Compress.dll
    [2006/12/07 21:58:39 | 000,392,192 | ---- | C] () -- C:\WINDOWS\Libjcc.dll
    [2006/12/07 21:58:39 | 000,035,328 | ---- | C] () -- C:\WINDOWS\libjsybheap.dll
    [2006/10/13 06:08:43 | 000,000,002 | ---- | C] () -- C:\WINDOWS\msoffice.ini
    [2006/10/12 08:06:08 | 000,005,652 | ---- | C] () -- C:\WINDOWS\System32\drivers\bvrp_pci.sys
    [2006/10/05 11:01:45 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
    [2006/10/05 10:54:09 | 000,000,612 | ---- | C] () -- C:\WINDOWS\ODBC.INI
    [2006/10/05 10:44:36 | 000,712,704 | ---- | C] () -- C:\WINDOWS\System32\DellSystemRestore.dll
    [2006/10/05 10:42:22 | 000,000,138 | ---- | C] () -- C:\WINDOWS\wininit.ini
    [2006/10/05 10:07:52 | 000,016,480 | ---- | C] () -- C:\WINDOWS\System32\rixdicon.dll
    [2006/10/05 10:06:42 | 000,000,391 | ---- | C] () -- C:\WINDOWS\System32\OEMINFO.INI
    [2006/09/19 05:48:00 | 000,413,696 | ---- | C] () -- C:\WINDOWS\System32\RTClientSDK55.dll
    [2006/08/15 23:43:02 | 000,001,147 | ---- | C] () -- C:\WINDOWS\System32\IPCamera.ini
    [2006/03/07 15:22:04 | 004,014,080 | ---- | C] () -- C:\WINDOWS\System32\qt-mt335.dll
    [2006/03/07 15:22:04 | 000,057,344 | ---- | C] () -- C:\WINDOWS\System32\boost_thread-vc71-mt-1_32.dll
    [2006/01/26 19:51:57 | 000,647,168 | ---- | C] () -- C:\WINDOWS\System32\pqdvdb.dll
    [2006/01/26 19:51:56 | 000,110,080 | ---- | C] () -- C:\WINDOWS\System32\nlame.dll
    [2005/09/21 14:05:30 | 000,286,720 | ---- | C] () -- C:\WINDOWS\System32\GpsToolsXP.dll
    [2005/09/21 14:05:30 | 000,258,048 | ---- | C] () -- C:\WINDOWS\System32\GpsViewXP.dll
    [2005/09/21 14:05:30 | 000,253,952 | ---- | C] () -- C:\WINDOWS\System32\MapLibXP.dll
    [2005/09/21 14:05:28 | 000,135,168 | ---- | C] () -- C:\WINDOWS\System32\GpsShapeXP.dll
    [2005/09/01 01:43:32 | 000,098,304 | ---- | C] () -- C:\WINDOWS\System32\resourceGeneric.dll
    [2005/08/16 16:37:24 | 000,001,793 | ---- | C] () -- C:\WINDOWS\System32\fxsperf.ini
    [2005/08/06 02:01:54 | 000,235,008 | ---- | C] () -- C:\WINDOWS\System32\psisdecd.dll
    [2005/05/26 03:06:26 | 000,119,296 | ---- | C] () -- C:\WINDOWS\System32\WnASPI32.dll
    [2005/02/17 11:41:32 | 000,000,603 | ---- | C] () -- C:\WINDOWS\System32\BTNeighborhood.dll.manifest
    [2005/02/17 11:41:30 | 000,000,593 | ---- | C] () -- C:\WINDOWS\System32\btcss.dll.manifest
    [2003/08/29 16:23:49 | 000,094,274 | ---- | C] () -- C:\WINDOWS\System32\HPBHEALR.DLL
    [2003/03/09 21:31:04 | 000,561,152 | ---- | C] () -- C:\WINDOWS\System32\hpotscl.dll
    [2003/01/07 22:05:08 | 000,002,695 | ---- | C] () -- C:\WINDOWS\System32\OUTLPERF.INI
    [2002/03/21 15:39:02 | 000,073,728 | ---- | C] () -- C:\WINDOWS\System32\UNACEV2.DLL
    [2001/11/14 12:56:00 | 001,802,240 | ---- | C] () -- C:\WINDOWS\System32\lcppn21.dll
    [2001/07/07 18:00:00 | 000,003,399 | ---- | C] () -- C:\WINDOWS\System32\hptcpmon.ini
    [2000/09/19 11:16:56 | 000,003,584 | ---- | C] () -- C:\WINDOWS\System32\drivers\DLPORTIO.SYS
    [2000/07/28 16:15:00 | 000,000,001 | ---- | C] () -- C:\WINDOWS\System32\uuddc32.dll
    [2007/05/20 07:08:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\1.0.0.0
    [2008/05/31 14:29:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\ACD Systems
    [2009/02/16 05:34:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Acronis
    [2007/03/08 07:41:41 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Amazon
    [2009/11/24 17:14:29 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\AT&T
    [2006/10/17 06:47:46 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Basta Computing
    [2007/08/20 01:59:30 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\BOC425
    [2010/04/03 11:23:00 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Canneverbe Limited
    [2007/08/21 05:46:08 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\DreamboxManagerSuite
    [2010/02/28 18:35:13 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\DriverScanner
    [2006/10/16 10:59:47 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\eFax Messenger 4.2 Setup
    [2007/03/17 05:56:34 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Elaborate Bytes
    [2009/03/31 02:39:07 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\EPSON
    [2008/09/20 14:59:38 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\GARMIN
    [2008/10/28 16:55:37 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Geek Squad
    [2008/08/28 16:19:35 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\GoodSync
    [2009/11/10 01:30:36 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Innovative Solutions
    [2010/03/02 23:35:04 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Installations
    [2010/06/18 04:01:16 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\iolo
    [2008/08/23 17:12:55 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\LogMeIn
    [2009/02/20 13:21:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\MagneticOne Store Manager for osCommerce
    [2008/01/01 12:46:50 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\MailFrontier
    [2009/01/26 07:04:55 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Mixesoft
    [2007/03/19 18:07:46 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\MSScanAppDataDir
    [2007/12/08 01:35:33 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Nokia
    [2009/11/20 17:11:54 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\OnlineArmor
    [2006/10/13 05:38:15 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Otto
    [2007/12/08 01:15:47 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\PC Suite
    [2010/05/20 20:15:33 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\regid.1986-12.com.adobe
    [2008/07/15 00:00:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\RoboForm
    [2010/05/27 06:33:04 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\SecTaskMan
    [2007/03/17 05:04:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\SlySoft
    [2009/01/14 16:01:20 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\SuperEasy Software
    [2008/05/27 08:53:18 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\T-Mobile
    [2009/03/09 10:59:37 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\TelTel
    [2010/05/27 04:14:38 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\TEMP
    [2007/07/26 03:43:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\TuneUp Software
    [2008/12/08 15:55:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\VisualZone
    [2008/07/03 07:46:14 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\vsosdk
    [2007/12/25 02:06:19 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\VTSystems
    [2007/11/25 06:54:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Zfone
    [2008/12/27 09:19:24 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\{148D8B8A-8F96-4822-81EC-D510B626B7D5}
    [2009/03/22 19:52:18 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\{2840BBCB-9BEC-47F6-BA0F-10D3C34BF151}
    [2009/06/18 11:03:47 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\{299AD074-3B8B-4811-BF5C-E2EDBC6DEB23}
    [2009/06/18 11:03:44 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\{907A85CA-E023-4161-8F5C-E72C340031D2}
    [2008/02/06 04:38:48 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\{A25FEDC1-F6D7-440C-BCE2-B71F595F6646}
    [2009/03/22 19:40:49 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\{D994735B-8DC6-4AEE-B720-704A4EC0402E}
    [2006/10/16 11:00:04 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\.gaim
    [2008/10/30 14:28:19 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\.purple
    [2007/01/31 18:26:45 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\ACD Systems
    [2009/06/08 08:59:12 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\AT&T
    [2006/10/17 06:49:54 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Basta Computing
    [2009/01/01 13:28:07 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\BinaryMark
    [2010/06/07 17:29:46 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\BPFTP
    [2009/06/08 15:01:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Bytemobile
    [2010/04/03 11:23:02 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Canneverbe Limited
    [2009/11/08 15:39:20 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\CheckPoint
    [2008/10/22 03:19:06 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\ChemTable Software
    [2008/10/30 15:13:37 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\com.albelli.demo.XEditor.9662B72A69EC54AD83412D07E7CBBBB8B024DBAB.1
    [2007/05/18 19:51:47 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\CVS
    [2008/08/18 15:29:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\d
    [2009/06/08 08:59:17 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\DBUpdater
    [2010/06/19 12:55:53 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\DMCache
    [2007/02/27 02:55:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Downloaded Installations
    [2009/12/16 08:41:23 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\E-centives
    [2007/10/30 21:54:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Ectaco
    [2008/06/09 12:30:35 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Endicia
    [2007/05/22 12:52:30 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\EPSON
    [2007/06/28 21:16:12 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Fanix
    [2010/05/20 14:20:53 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\FileZilla
    [2009/03/29 14:36:27 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\GARMIN
    [2007/11/18 02:07:38 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\GetRightToGo
    [2007/05/21 19:51:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\GlarySoft
    [2010/05/12 22:47:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\GoodSync
    [2010/05/15 11:47:05 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\gtk-2.0
    [2010/05/29 17:31:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\IDM
    [2007/05/13 09:21:56 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\ieSpell
    [2008/09/28 11:58:12 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\ImgBurn
    [2006/10/16 11:00:04 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\InternetCalls
    [2010/06/18 04:01:10 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\iolo
    [2009/01/17 14:27:19 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\KeePass
    [2006/10/16 11:00:04 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Kerio
    [2007/02/27 02:59:13 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Kinko's
    [2007/05/22 10:18:18 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Leadertech
    [2008/07/04 06:23:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\magicJackOutlookAddIn
    [2007/07/14 01:44:48 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\mirkes.de
    [2010/06/21 12:16:08 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\mjusbsp
    [2010/04/08 00:59:46 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\mkvtoolnix
    [2010/04/13 02:14:21 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\MxBoost
    [2009/06/29 21:38:18 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Nokia
    [2008/10/15 19:16:27 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\OfficeUpdate12
    [2009/11/20 18:05:15 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\OnlineArmor
    [2009/03/19 16:36:39 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\ooVoo Details
    [2006/10/13 05:38:15 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Otto
    [2009/06/29 20:15:41 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\PC Suite
    [2007/03/06 09:30:47 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\PC-FAX TX
    [2006/10/16 11:00:11 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\pe explorer
    [2008/01/21 18:21:50 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Powermarks
    [2010/05/21 19:55:54 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\ProcessLasso
    [2006/10/16 11:00:11 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Regrun
    [2010/02/03 04:28:42 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\RipIt4Me
    [2007/03/08 04:25:48 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\ScanSoft
    [2008/09/02 03:31:38 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Scooter Software
    [2010/05/01 01:30:11 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Serif
    [2008/08/18 15:30:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\ShareTV
    [2008/12/06 17:48:08 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Sharp World Clock
    [2009/06/08 08:47:35 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Sierra Wireless
    [2007/11/12 01:24:20 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\SimpLogs
    [2007/04/21 06:04:59 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\SlySoft
    [2007/05/31 04:57:34 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Snapfish
    [2007/09/19 15:04:51 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Sprite Software
    [2007/07/23 03:13:56 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Spycar
    [2007/06/06 11:26:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Stamps.com Internet Postage
    [2009/01/09 15:50:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\SuperEasy
    [2009/01/14 16:02:43 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\SuperEasy Software
    [2006/10/16 11:00:12 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Sync App Settings
    [2010/05/14 04:35:46 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\SystemRequirementsLab
    [2008/11/14 12:42:18 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Systweak
    [2007/05/26 18:36:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\T-Mobile
    [2008/07/01 13:57:08 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\TelTel
    [2008/02/15 21:01:35 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\TextPad
    [2008/09/28 11:26:57 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Thinstall
    [2009/12/22 15:52:00 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Trillian
    [2008/02/06 04:43:51 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\TrueCrypt
    [2008/10/30 14:59:21 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\TuneUp Software
    [2008/10/04 16:14:31 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Uniblue
    [2007/12/14 00:19:59 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\URSoft
    [2010/05/15 15:08:33 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\uTorrent
    [2007/06/05 01:16:31 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Viewpoint
    [2007/12/31 09:50:21 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\VisualZone
    [2009/03/29 15:34:11 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\VoiceEditor
    [2009/01/10 14:44:08 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Vso
    [2009/11/24 16:29:51 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\WinPatrol
    [2009/08/06 23:52:31 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\Wireshark
    [2008/01/26 06:33:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\WNR
    [2010/05/23 23:06:05 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\X-NetStat
    [2008/07/16 14:36:27 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jay\Application Data\zweitgeist
    [2010/06/21 12:41:32 | 000,032,554 | ---- | M] () -- C:\WINDOWS\Tasks\SCHEDLGU.TXT
    ========== Alternate Data Streams ==========
    @Alternate Data Stream - 88 bytes -> C:\WINDOWS\System32\net1.exe:SummaryInformation
    @Alternate Data Stream - 88 bytes -> C:\WINDOWS\System32\dllhost.exe:SummaryInformation
    @Alternate Data Stream - 88 bytes -> C:\WINDOWS\System32\ati2evxx.exe:SummaryInformation
    @Alternate Data Stream - 4752 bytes -> D:\My Documents\home.html:Q30lsldxJoudresxAaaqpcawXc
    < End of report >
  7. 2010/06/21
    Jayman007
    Jayman007 Inactive Thread Starter
    Just wanted to add that I no longer get the svchost error originally posted but I still get a BSOD every now and then when I try and shutdown. Doesn't happen every time and I'm not quite sure what sets it off. It's a Bad Pool Caller and I think it's a driver issue. Not 100% sure yet.
  8. 2010/06/21
    I'm glad to hear good news :)
    That may be not malware related. Please, remind me about the issue, when your computer is declared clean.
    1. Download Temp File Cleaner (TFC)
    2. Go to Kaspersky website and perform an online antivirus scan.
    1. Disable your active antivirus program.
    2. Read through the requirements and privacy statement and click on Accept button.
    3. It will start downloading and installing the scanner and virus definitions. You will be prompted to install an application from Kaspersky. Click Run.
    4. When the downloads have finished, click on Settings.
    5. Make sure these boxes are checked (ticked). If they are not, please tick them and click on the Save button:
      [*] Archives
      [*] Mail databases
    6. Click on My Computer under Scan.
    7. Once the scan is complete, it will display the results. Click on View Scan Report.
    8. You will see a list of infected items there. Click on Save Report As....
    9. Save this report to a convenient place. Change the Files of type to Text file (.txt) before clicking on the Save button. Then post it here.
  9. 2010/06/26
    Jayman007
    So.. seems like my issue has been fixed. No more errors or BSOD. All virus scans and malware scans pass.
    Maybe I should start another topic but there is one other thing that is bothering me. My computer always restarts when I shutdown/hibernate/standby. It completes the process without issue but laptop just doesn't poweroff. I have turned off the feature to restart on error but doesn't help. I don't have the roxio software installed which is known to cause such issues.
    I should add that this problem started several months ago when I switched out the motherboard on my laptop. I thought maybe it was a hardware issue up until I started this post during my recent woes. For some reason, the problem seemed to have gone away when I started having the svchost issue. But now that everything is fixed the poweroff issue is back. Now I know it can be fixed since I saw for several days it was working correctly.
    Any help would be greatly appreciated.
    And also let me add, thanks so much for helping me resolve the errors I was getting.
  10. 2010/06/26
    You're very welcome :)
    That would be the best idea to get more attention. The access to malware forum is very limited (just you and me).
    Now, last steps...
    OTL Clean-Up
    Clean up with OTL:
    * Double-click OTL.exe to start the program.
    * Close all other programs apart from OTL as this step will require a reboot
    * On the OTL main screen, press the CLEANUP button
    * Say Yes to the prompt and then allow the program to reboot your computer.
    Your computer is clean :)
    1. We need to reset system restore to prevent your computer from being accidentally reinfected by using some old restore point(s). We'll create fresh, clean restore point.
    Turn off System Restore:
    - Windows XP:
    1. Click Start.
    5. Click Apply.
    7. Click OK.
    - Windows Vista and 7:
    1. Click Start.
    8. Click OK
    2. Restart computer.
    3. Turn System Restore on.
