[Stop 0x0000000a BSOD]
Discussion in 'Windows 7' started by AkWong, 2011/03/26.
  1. 2011/03/26
    AkWong
    AkWong Inactive Thread Starter
    Hello this is my situation,
    I was just on the internet watching movies and all of a sudden i get a bsod. Now when i boot up my computer it will start up normally then just crash after 10 seconds.
    The message i get on my bsod says driver Irql not_equal_or_less_than Stop 0x0000000a, I can't boot it in safe mode either. I am using a Hp g62 model
    Thank you all in advance for your help.
  2. 2011/03/26
    Follow these instructions to post a Dump Data Log.
    If you do not have a dump, ensure that your machine is configured to write out a dump by following the directions from microsoft
    Please note:
    AkWong
    it does have dump its just that i can't access my laptop at all since it crashes once its booted up and Thank you
  5. 2011/03/26
    When restarting, press the F8 key before Windows starts.
    Choose Last Known Good Configuration
    If that doesn't work, try Safe mode with networking
    AkWong
    I tried both and it wont work.
    Also it says storport.sys
  7. 2011/03/26
    Boot off the Windows 7 DVD and on the Install Now screen choose Repair your computer.
    I'd 1st try a Startup Repair, if that doesn't work try a System Restore.
  8. 2011/03/26
    That's not the only thing it says though... Full & precise error messages are helpful.
  9. 2011/03/26
  10. 2011/03/27
    AkWong
    When you say boot off the windows 7 dvd, i have the disk but when i start my laptop up it doesnt go to the install screen how can i access the disk?
  11. 2011/03/28
    You'll have to change the Boot order in your BIOS to boot off the DVD before checking the HDD.
    To access your BIOS, look at the manuals that come with your system (usually it is the F2 key you'll have to press when the computer is booting).
