Resolved Startup Repair cannot fix this problem automatically
Discussion in 'Windows 7' started by Ratchet, 2011/05/13.
  1. 2011/05/17
    He'll need it to boot the installation media.
  2. 2011/05/17
    Clif, take a look at this page, How to Open a Command Prompt at Startup in Windows 7.
    Ratchet
    Ratchet Inactive Thread Starter
    I wanted to use the drive just once in hopes that the computer would turn on and work properly afteward.
  5. 2011/05/17
    Ratchet
    Once the prompt comes up to reinstall windows, are the directions fairly easy to follow?
  6. 2011/05/17
    Yes. If there are any steps that are confusing for you feel free to just ask.
  7. 2011/05/17
    savagcl Lifetime Subscription
    savagcl Geek Member
    Evan,
    I should know that! Guess I was to close to the forest to see the trees.
    Thanks.
    Sorry for butting in on this thread.... my bad.
    clif
  8. 2011/05/17
    IvanH
    IvanH Well-Known Member
    Exactly.
    In that situation I faced before, it kept on asking me for the Windows 7 Installation Disk every alternate boot. So, eventually, I gave it a clean installation and fixed the problem forever. Every other ways trying to fix the problem were interesting but only proofs of ineffective, and liked digging into the iceberg down from the tip and inviting more and more uncertainties and additional software tools which further complicated the problem. So, why not give it a clean start again? i.e. reinstall Windows.
    b.t.w. I strongly discourage you to put any browsers or applications at start up. Not even the sidebar gadgets. That will give you a better day.
  9. 2011/05/17
    Ratchet
    Okay thank you guys. If it all works out I should be reinstalling sometime later this week. I believe it will be fairly easy from here, but I will keep you posted.
    Thanks again. :)
  10. 2011/05/17
    Ratchet, I hope everything goes well and you will be able to get the computer back up and running. If you are going to reinstall Windows make sure you back up any important data on the harddrive before you format it.
    @ Clif, I am happy that I was able to provide some insight on your question that you had. If you have any other questions or concerns feel free to PM me.
  11. 2011/05/19
    Ratchet
    I've received my flash drive and will be using the instructions you gave me in the link.
    Thank you! :)
  12. 2011/05/19
    Alright cool. :)
  13. 2011/05/19
    Ratchet
    Thank you for your help you guys. It works.
  14. 2011/05/19
    IvanH
    There are many ways applicable in resolving a problem. No matter which way you choose, I wish you a success in restoring your computer and enjoy the process and outcome.:D
  15. 2011/05/19
    Great. So is it safe to say that this issue is now resolved?
  16. 2011/05/20
    Ratchet
    Yes, it is resolved.
  17. 2011/05/21
    Awesome. :)
    Since this issue is now resolved, please mark this thread as 'Resolved'.
  18. 2011/05/22
    Ratchet
    Using a USB flash drive to reinstall windows helped me solve this issue.
