Resolved Srvr2003 - WindowsUpdate no longer works.
Discussion in 'Windows Server System' started by batsona, 2012/12/18.
  1. 2012/12/18
    batsona
    batsona Well-Known Member Thread Starter
    Greetings;
    I have a Server2003 system, 32-bit, using SP2. WindowsUpdate had worked ok in the past, but the first time we've run it since late-sept, yields errors. I compared a working system, to the system that's broken, and the part of windowsupdate.log that differs, is as follows:
    2012-12-10 13:19:13:124 760 f18 PT +++++++++++ PT: Synchronizing server updates +++++++++++
    2012-12-10 13:19:13:124 760 f18 PT + ServiceId = {7971F918-A847-4430-9279-4A52D1EFE18D}, Server URL = https://update.microsoft.com/v6/ClientWebService/client.asmx
    2012-12-10 13:19:13:124 760 f18 PT WARNING: Cached cookie has expired or new PID is available
    2012-12-10 13:19:18:421 760 f18 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80190194
    2012-12-10 13:19:18:421 760 f18 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80190194
    2012-12-10 13:19:18:421 760 f18 PT WARNING: ECP: Failed to download cab file from http://download.windowsupdate.com/m..._e6b146afc5238fed187ae64d600e15562bd63761.cab with error 0x80190194
    2012-12-10 13:19:18:421 760 f18 PT WARNING: ECP: This roundtrip contained some optimized updates which failed. New Update count = 21, Old Count = 30
    2012-12-10 13:19:22:280 760 f18 PT WARNING: Sync of Updates: 0x8024402f
    2012-12-10 13:19:22:280 760 f18 PT WARNING: SyncServerUpdatesInternal failed: 0x8024402f
    2012-12-10 13:19:22:280 760 f18 Agent * WARNING: Failed to synchronize, error = 0x8024402F
    2012-12-10 13:19:22:280 760 a6c AU Can not perform non-interactive scan if AU is interactive-only
    2012-12-10 13:19:22:515 760 f18 Agent * WARNING: Exit code = 0x8024402F
    2012-12-10 13:19:22:515 760 f18 Agent *********
    2012-12-10 13:19:22:515 760 f18 Agent ** END ** Agent: Finding updates [CallerId = MicrosoftUpdate]
    2012-12-10 13:19:22:515 760 f18 Agent *************
    2012-12-10 13:19:22:515 760 f18 Agent WARNING: WU client failed Searching for update with error 0x8024402f
    2012-12-10 13:19:22:530 5156 8e4 COMAPI >>-- RESUMED -- COMAPI: Search [ClientId = MicrosoftUpdate]
    2012-12-10 13:19:22:530 5156 8e4 COMAPI - Updates found = 0
    2012-12-10 13:19:22:530 5156 8e4 COMAPI - WARNING: Exit code = 0x00000000, Result code = 0x8024402F
    2012-12-10 13:19:22:530 5156 8e4 COMAPI ---------
    2012-12-10 13:19:22:530 5156 8e4 COMAPI -- END -- COMAPI: Search [ClientId = MicrosoftUpdate]
    2012-12-10 13:19:22:530 5156 8e4 COMAPI -------------
    2012-12-10 13:19:22:530 5156 114c COMAPI WARNING: Operation failed due to earlier error, hr=8024402F
    2012-12-10 13:19:22:530 5156 114c COMAPI FATAL: Unable to complete asynchronous search. (hr=8024402F)
    I've done lots of searching on the Internet, and lots of people have this problem, and 4-5 fixes are always indicated, all of which I've tried:
    1.) Refreshing proxy config using proxycfg
    2.) delete/rename of c:\windows\system32\softwaredistribution\
    3.) use the French version of the URL (using 'fr' rather than 'en' in the URL)
    4.) Bouncing WindowsUpdate Service as well as BITS, and re-registering some DLLs, the rebooting
    5.) Following websites are in IE's Trusted-Zone:
    ds.download.windowsupdwate.com
    www.update.microsoft.com
    schemas.microsoft.com
    stats1.update.microsoft.com
    Something new: The 'latest' version of Windows Update said that it's now set to only trust content that is signed by a new certificate. --If I'm missing a root-cert update, or other cert update, do you think this is the issue? Also, the 'SoftwareDistribution' directory is not automatically re-creating, now that I renamed it.
    Any other ideas? Thanks!
  2. 2012/12/18
    Please do the following:
    • At the command prompt, type net stop wuauserv, then press Enter.
    • Next type cat /dev/null > %windir%\WindowsUpdate.log then press Enter (ignore the error that 'cat' isn't recognized... it still does what it is supposed to do).
    • Lastly type net start wuauserv, then press Enter
    • Now repeat the action that normally leads to the Windows Update error.
    • Once completed copy/paste the contents of the %windir%\WindowsUpdate.log file in your next post (at minimum 50-75 lines).
    If you want to keep a backup of your current WindowsUpdate.log file you can make a copy from the command prompt. Enter copy %windir%\WindowsUpdate.log %windir%\WindowsUpdate.log.old
    batsona
    Here's the WindowsUpdate.log file, with one single 'detect' in it.
    2012-12-18 16:33:36:796 768 fb4 Misc =========== Logging initialized (build: 7.6.7600.256, tz: -0500) ===========
    2012-12-18 16:33:36:796 768 fb4 Misc = Process: C:\WINDOWS\system32\svchost.exe
    2012-12-18 16:33:36:796 768 fb4 Misc = Module: C:\WINDOWS\system32\wuaueng.dll
    2012-12-18 16:33:36:796 768 fb4 Service *************
    2012-12-18 16:33:36:796 768 fb4 Service ** START ** Service: Service startup
    2012-12-18 16:33:36:796 768 fb4 Agent * WU client version 7.6.7600.256
    2012-12-18 16:33:36:796 768 fb4 Agent * Base directory: C:\WINDOWS\SoftwareDistribution
    2012-12-18 16:33:36:796 768 fb4 Agent * Access type: Named proxy
    2012-12-18 16:33:36:796 768 fb4 Agent * Default proxy: 172.29.9.14:443
    2012-12-18 16:33:36:796 768 fb4 Agent * Network state: Connected
    2012-12-18 16:33:49:015 768 c74 Agent *********** Agent: Initializing Windows Update Agent ***********
    2012-12-18 16:33:49:015 768 c74 Agent *********** Agent: Initializing global settings cache ***********
    2012-12-18 16:33:49:015 768 c74 Agent * WSUS server: <NULL>
    2012-12-18 16:33:49:015 768 c74 Agent * WSUS status server: <NULL>
    2012-12-18 16:33:49:015 768 c74 Agent * Target group: (Unassigned Computers)
    2012-12-18 16:33:49:015 768 c74 Agent * Windows Update access disabled: No
    2012-12-18 16:33:49:015 768 c74 DnldMgr Download manager restoring 0 downloads
    2012-12-18 16:33:49:109 768 fb4 Report *********** Report: Initializing static reporting data ***********
    2012-12-18 16:33:49:109 768 fb4 Report * OS Version = 5.2.3790.2.0.196880
    2012-12-18 16:33:49:218 768 fb4 Report * Computer Brand = Dell Inc.
    2012-12-18 16:33:49:218 768 fb4 Report * Computer Model = PowerEdge 1950
    2012-12-18 16:33:49:218 768 fb4 Report * Bios Revision = 1.2.0
    2012-12-18 16:33:49:218 768 fb4 Report * Bios Name = Phoenix ROM BIOS PLUS Version 1.10 1.2.0
    2012-12-18 16:33:49:218 768 fb4 Report * Bios Release Date = 2006-10-18T00:00:00
    2012-12-18 16:33:49:218 768 fb4 Report * Locale ID = 1033
    2012-12-18 16:33:54:890 692 bfc Misc =========== Logging initialized (build: 7.6.7600.256, tz: -0500) ===========
    2012-12-18 16:33:54:890 692 bfc Misc = Process: C:\Program Files\Internet Explorer\IEXPLORE.EXE
    2012-12-18 16:33:54:890 692 bfc Misc = Module: C:\WINDOWS\system32\wuapi.dll
    2012-12-18 16:33:54:890 692 bfc COMAPI ----------- COMAPI: IUpdateServiceManager::AddService -----------
    2012-12-18 16:33:54:890 692 bfc COMAPI - ServiceId = {7971f918-a847-4430-9279-4a52d1efe18d}
    2012-12-18 16:33:54:890 692 bfc COMAPI - AuthorizationCabPath = C:\WINDOWS\SoftwareDistribution\AuthCabs\muauth.cab
    2012-12-18 16:33:54:906 768 c74 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\AuthCabs\Downloaded\7971f918-a847-4430-9279-4a52d1efe18d.auth.cab.temp\muauth.cab:
    2012-12-18 16:33:54:921 768 c74 Misc Microsoft signed: Yes
    2012-12-18 16:33:54:937 768 c74 DtaStor Update service properties: service registered with AU is {7971F918-A847-4430-9279-4A52D1EFE18D}
    2012-12-18 16:33:54:937 692 bfc COMAPI - Added service, URL = http://www.update.microsoft.com/microsoftupdate/
    2012-12-18 16:33:54:937 692 bfc COMAPI ----------- COMAPI: IUpdateServiceManager::RegisterServiceWithAU -----------
    2012-12-18 16:33:54:937 692 bfc COMAPI - ServiceId = {7971f918-a847-4430-9279-4a52d1efe18d}
    2012-12-18 16:33:54:968 692 bfc Misc =========== Logging initialized (build: 7.6.7600.257, tz: -0500) ===========
    2012-12-18 16:33:54:968 692 bfc Misc = Process: C:\Program Files\Internet Explorer\IEXPLORE.EXE
    2012-12-18 16:33:54:968 692 bfc Misc = Module: C:\WINDOWS\system32\muweb.dll
    2012-12-18 16:33:54:968 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
    2012-12-18 16:33:55:390 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:33:57:468 692 bfc Misc WARNING: DownloadFileInternal failed for http://download.windowsupdate.com/v9/1/windowsupdate/redir/muv4wuredir.cab: error 0x80190194
    2012-12-18 16:33:57:468 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
    2012-12-18 16:33:57:484 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:33:58:468 692 bfc Misc WARNING: DownloadFileInternal failed for http://download.microsoft.com/v9/1/windowsupdate/redir/muv4wuredir.cab: error 0x80190194
    2012-12-18 16:33:58:468 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
    2012-12-18 16:33:58:484 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:34:00:218 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
    2012-12-18 16:34:00:234 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:34:00:250 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WebSetup\wuident.cab:
    2012-12-18 16:34:00:265 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:34:00:703 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WebSetup\wuident.cab:
    2012-12-18 16:34:00:718 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:34:05:140 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WebSetup\wsus3setup.cab:
    2012-12-18 16:34:05:156 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:34:05:171 692 bfc Setup *********** Setup: Checking whether self-update is required ***********
    2012-12-18 16:34:05:171 692 bfc Setup * Inf file: C:\WINDOWS\SoftwareDistribution\WebSetup\wsus3setup.inf
    2012-12-18 16:34:05:171 692 bfc Setup Update NOT required for C:\WINDOWS\system32\wuweb.dll: target version = 7.6.7600.257, required version = 7.0.6000.381
    2012-12-18 16:34:05:171 692 bfc Setup * IsUpdateRequired = No
    2012-12-18 16:34:05:187 692 bfc Misc =========== Logging initialized (build: 7.6.7600.257, tz: -0500) ===========
    2012-12-18 16:34:05:187 692 bfc Misc = Process: C:\Program Files\Internet Explorer\IEXPLORE.EXE
    2012-12-18 16:34:05:187 692 bfc Misc = Module: C:\WINDOWS\system32\wuweb.dll
    2012-12-18 16:34:05:187 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
    2012-12-18 16:34:05:203 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:34:05:453 692 bfc Misc WARNING: DownloadFileInternal failed for http://download.windowsupdate.com/v9/1/windowsupdate/redir/muv4wuredir.cab: error 0x80190194
    2012-12-18 16:34:05:453 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
    2012-12-18 16:34:05:453 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:34:06:359 692 bfc Misc WARNING: DownloadFileInternal failed for http://download.microsoft.com/v9/1/windowsupdate/redir/muv4wuredir.cab: error 0x80190194
    2012-12-18 16:34:06:359 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
    2012-12-18 16:34:06:375 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:34:07:062 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
    2012-12-18 16:34:07:078 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:34:07:093 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WebSetup\wuident.cab:
    2012-12-18 16:34:07:093 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:34:07:531 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WebSetup\wuident.cab:
    2012-12-18 16:34:07:546 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:34:07:562 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WebSetup\wsus3setup.cab:
    2012-12-18 16:34:07:578 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:34:07:609 692 bfc Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WebSetup\wsus3setup.cab:
    2012-12-18 16:34:07:625 692 bfc Misc Microsoft signed: Yes
    2012-12-18 16:34:07:625 692 bfc Setup *********** Setup: Checking whether self-update is required ***********
    2012-12-18 16:34:07:625 692 bfc Setup * Inf file: C:\WINDOWS\SoftwareDistribution\WebSetup\wsus3setup.inf
    2012-12-18 16:34:07:640 692 bfc Setup Update NOT required for C:\WINDOWS\system32\cdm.dll: target version = 7.6.7600.256, required version = 7.6.7600.256
    2012-12-18 16:34:07:640 692 bfc Setup Update NOT required for C:\WINDOWS\system32\wuapi.dll: target version = 7.6.7600.256, required version = 7.6.7600.256
    2012-12-18 16:34:07:640 692 bfc Setup Update NOT required for C:\WINDOWS\system32\wuapi.dll.mui: target version = 7.6.7600.256, required version = 7.6.7600.256
    2012-12-18 16:34:07:640 692 bfc Setup Update NOT required for C:\WINDOWS\system32\wuauclt.exe: target version = 7.6.7600.256, required version = 7.6.7600.256
    2012-12-18 16:34:07:640 692 bfc Setup Update NOT required for C:\WINDOWS\system32\wuaucpl.cpl: target version = 7.6.7600.256, required version = 7.6.7600.256
    2012-12-18 16:34:07:640 692 bfc Setup Update NOT required for C:\WINDOWS\system32\wuaucpl.cpl.mui: target version = 7.6.7600.256, required version = 7.6.7600.256
    2012-12-18 16:34:07:640 692 bfc Setup Update NOT required for C:\WINDOWS\system32\wuaueng.dll: target version = 7.6.7600.256, required version = 7.6.7600.256
    2012-12-18 16:34:07:640 692 bfc Setup Update NOT required for C:\WINDOWS\system32\wuaueng.dll.mui: target version = 7.6.7600.256, required version = 7.6.7600.256
    2012-12-18 16:34:07:640 692 bfc Setup Update NOT required for C:\WINDOWS\system32\wucltui.dll: target version = 7.6.7600.256, required version = 7.6.7600.256
    2012-12-18 16:34:07:640 692 bfc Setup Update NOT required for C:\WINDOWS\system32\wucltui.dll.mui: target version = 7.6.7600.256, required version = 7.6.7600.256
    2012-12-18 16:34:07:640 692 bfc Setup Update NOT required for C:\WINDOWS\system32\wups.dll: target version = 7.6.7600.256, required version = 7.6.7600.256
    2012-12-18 16:34:07:640 692 bfc Setup Update NOT required for C:\WINDOWS\system32\wups2.dll: target version = 7.6.7600.256, required version = 7.6.7600.256
    2012-12-18 16:34:07:640 692 bfc Setup * IsUpdateRequired = No
    2012-12-18 16:34:12:906 692 bfc COMAPI -------------
    2012-12-18 16:34:12:906 692 bfc COMAPI -- START -- COMAPI: Search [ClientId = MicrosoftUpdate]
    2012-12-18 16:34:12:921 768 c8 Agent *************
    2012-12-18 16:34:12:921 768 c8 Agent ** START ** Agent: Finding updates [CallerId = MicrosoftUpdate]
    2012-12-18 16:34:12:921 768 c8 Agent * Online = Yes; Ignore download priority = No
    2012-12-18 16:34:12:921 768 c8 Agent * Criteria = "IsInstalled=0 and IsHidden=0 "
    2012-12-18 16:34:12:921 768 c8 Agent * ServiceID = {7971F918-A847-4430-9279-4A52D1EFE18D} Third party service
    2012-12-18 16:34:12:921 768 c8 Agent * Search Scope = {Machine}
    2012-12-18 16:34:12:921 692 bfc COMAPI <<-- SUBMITTED -- COMAPI: Search [ClientId = MicrosoftUpdate]
    2012-12-18 16:34:12:937 768 c8 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
    2012-12-18 16:34:12:937 768 c8 Misc Microsoft signed: Yes
    2012-12-18 16:34:13:718 768 c8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80190194
    2012-12-18 16:34:13:718 768 c8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80190194
    2012-12-18 16:34:13:718 768 c8 Misc WARNING: DownloadFileInternal failed for http://download.windowsupdate.com/v9/1/windowsupdate/redir/muv4wuredir.cab: error 0x80190194
    2012-12-18 16:34:13:718 768 c8 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
    2012-12-18 16:34:13:734 768 c8 Misc Microsoft signed: Yes
    2012-12-18 16:34:14:312 768 c8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80190194
    2012-12-18 16:34:14:312 768 c8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80190194
    2012-12-18 16:34:14:312 768 c8 Misc WARNING: DownloadFileInternal failed for http://download.microsoft.com/v9/1/windowsupdate/redir/muv4wuredir.cab: error 0x80190194
    2012-12-18 16:34:14:312 768 c8 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
    2012-12-18 16:34:14:328 768 c8 Misc Microsoft signed: Yes
    2012-12-18 16:34:14:765 768 c8 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\9482F4B4-E343-43B6-B170-9A65BC822C77\muv4wuredir.cab:
    2012-12-18 16:34:14:781 768 c8 Misc Microsoft signed: Yes
    2012-12-18 16:34:14:796 768 c8 Agent Checking for updated auth cab for service 7971f918-a847-4430-9279-4a52d1efe18d at http://ds.download.windowsupdate.com/v10/1/microsoftupdate/redir/muauth.cab
    2012-12-18 16:34:14:796 768 c8 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\AuthCabs\authcab.cab:
    2012-12-18 16:34:14:812 768 c8 Misc Microsoft signed: Yes
    2012-12-18 16:34:15:546 768 c8 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\AuthCabs\authcab.cab:
    2012-12-18 16:34:15:562 768 c8 Misc Microsoft signed: Yes
    2012-12-18 16:34:15:562 768 c8 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\AuthCabs\authcab.cab:
    2012-12-18 16:34:15:578 768 c8 Misc Microsoft signed: Yes
    2012-12-18 16:34:15:578 768 c8 DtaStor Update service properties: service registered with AU is {7971F918-A847-4430-9279-4A52D1EFE18D}
    2012-12-18 16:34:17:921 768 c8 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\7971F918-A847-4430-9279-4A52D1EFE18D\muredir.cab:
    2012-12-18 16:34:17:937 768 c8 Misc Microsoft signed: Yes
    2012-12-18 16:34:18:234 768 c8 Misc Validating signature for C:\WINDOWS\SoftwareDistribution\WuRedir\7971F918-A847-4430-9279-4A52D1EFE18D\muredir.cab:
    2012-12-18 16:34:18:250 768 c8 Misc Microsoft signed: Yes
    2012-12-18 16:34:18:265 768 c8 PT +++++++++++ PT: Synchronizing server updates +++++++++++
    2012-12-18 16:34:18:265 768 c8 PT + ServiceId = {7971F918-A847-4430-9279-4A52D1EFE18D}, Server URL = https://update.microsoft.com/v6/ClientWebService/client.asmx
    2012-12-18 16:34:18:265 768 c8 PT WARNING: Cached cookie has expired or new PID is available
    2012-12-18 16:34:22:078 768 fb4 AU ########### AU: Initializing Automatic Updates ###########
    2012-12-18 16:34:22:078 768 fb4 AU AU setting next sqm report timeout to 2012-12-18 21:34:22
    2012-12-18 16:34:22:078 768 fb4 AU # AU disabled through User preference
    2012-12-18 16:34:22:078 768 fb4 AU Initializing featured updates
    2012-12-18 16:34:22:078 768 fb4 AU Found 0 cached featured updates
    2012-12-18 16:34:22:078 768 fb4 AU AU finished delayed initialization
    2012-12-18 16:34:23:203 768 c8 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x80190194
    2012-12-18 16:34:23:203 768 c8 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x80190194
    2012-12-18 16:34:23:203 768 c8 PT WARNING: ECP: Failed to download cab file from http://download.windowsupdate.com/m..._de58f5b3534cc07d753a850dae964f231ca18141.cab with error 0x80190194
    2012-12-18 16:34:23:203 768 c8 PT WARNING: ECP: This roundtrip contained some optimized updates which failed. New Update count = 17, Old Count = 30
    2012-12-18 16:34:24:437 768 c8 PT WARNING: Sync of Updates: 0x8024402f
    2012-12-18 16:34:24:437 768 c8 PT WARNING: SyncServerUpdatesInternal failed: 0x8024402f
    2012-12-18 16:34:24:437 768 c8 Agent * WARNING: Failed to synchronize, error = 0x8024402F
    2012-12-18 16:34:24:437 768 fb4 AU Can not perform non-interactive scan if AU is interactive-only
    2012-12-18 16:34:24:484 768 c8 Agent * WARNING: Exit code = 0x8024402F
    2012-12-18 16:34:24:484 768 c8 Agent *********
    2012-12-18 16:34:24:484 768 c8 Agent ** END ** Agent: Finding updates [CallerId = MicrosoftUpdate]
    2012-12-18 16:34:24:484 768 c8 Agent *************
    2012-12-18 16:34:24:484 768 c8 Agent WARNING: WU client failed Searching for update with error 0x8024402f
    2012-12-18 16:34:24:500 692 538 COMAPI >>-- RESUMED -- COMAPI: Search [ClientId = MicrosoftUpdate]
    2012-12-18 16:34:24:500 692 538 COMAPI - Updates found = 0
    2012-12-18 16:34:24:500 692 538 COMAPI - WARNING: Exit code = 0x00000000, Result code = 0x8024402F
    2012-12-18 16:34:24:500 692 538 COMAPI ---------
    2012-12-18 16:34:24:500 692 538 COMAPI -- END -- COMAPI: Search [ClientId = MicrosoftUpdate]
    2012-12-18 16:34:24:500 692 538 COMAPI -------------
    2012-12-18 16:34:24:500 692 bfc COMAPI WARNING: Operation failed due to earlier error, hr=8024402F
    2012-12-18 16:34:24:500 692 bfc COMAPI FATAL: Unable to complete asynchronous search. (hr=8024402F)
    2012-12-18 16:34:29:484 768 c8 Report REPORT EVENT: {8820EBFA-E289-4C14-ABC6-DCD32A951E3C} 2012-12-18 16:34:24:484-0500 1 148 101 {00000000-0000-0000-0000-000000000000} 0 8024402f MicrosoftUpdate Failure Software Synchronization Windows Update Client failed to detect with error 0x8024402f.
  5. 2012/12/19
    batsona
    Arie -- thanks! --This is an important system at work actually, and they won't let me run anything they think is 'smoke-and-mirrors' --the security people (and me), want to know what the 'fix-it' tool is doing up front, so we get the warm-n-fuzzy. We don't want to run anything where we can't see / don't know what it's doing in the background...
  7. 2012/12/19
    batsona
    Sorry -- I should have thought logically -- I can't break anything anymore than it is now.. So I ran it anyway... "Troubleshooting cannot continue" -- "Cannot contact the Server" Error Code=80072F8F
    The system proxy is set, and the proxy settings inside user 'joe' (let's say that's the username I was logged in as) are properly set. Now... The proxy I'm talking to, allows only 'business-related' sites, filtered by URL (like *.microsoft.com) etc etc.... Proxy is working, because IE can browse to these business-related sites just fine. The proxy won't be allowing facebook.com or "abc.troubleshoot-me.com "
    --This is why it's a good thing to run the checks manually, because I don't know that that fix-me app is trying to do....
    Thanks for the help though, it's appreciated!
  8. 2012/12/19
    Yea, right now I don't have any thing to add, the error you get is a HTTP 404 error.
    I see if I can think of something else.
  9. 2012/12/26
    Well, it looks like a proxy problem. Is the company running their own WSUS server by chance?
  10. 2013/01/01
    batsona
    If it means anything, we have some Server2008 machines that can use the same proxy & successfully do WindowsUpdate. I was contemplating moving the contents of c:\windows\system32\softwaredistribution\ on my windows XP machine, into the same location on the malfunctioning server2003. Ever since renaming that SoftwareDistribution directory, it has not re-appeared / been re-created. I actually have a guy at work who oversees some server2003 systems, and I can ask him if his WindowsUpdate on those systems is functioning. (his systems would use the same proxy as my broken system..)
  11. 2013/01/07
    batsona
    I replaced the c:\windows\SoftwareDistribution directory with one that was on my WinXP system, where WindowsUpdate is actually working. --Same error. I still need to get ahold of a logfile from a srvr 2003 system where WindowsUpdate is running, for an apples-to-apples comparison.
  12. 2013/01/08
    I don't expect a SoftwareDistribution folder from XP to work on a 2003 server.
    Disable your firewall& se if that works (don't forget the Windows Firewall).
    You could also try: How do I reset Windows Update components?
  13. 2013/01/08
    Did you stop the Windows Update service when you did the above?
  14. 2013/01/08
    batsona
    The link given in post #11 has alot more items in it to try, than other fixes I saw on the Internet, I'll give it a try. Otherwise, article 949104 doesn't have any info in it, about downloading & installing the newest Windows Update client... All it tells users, is how to punch WindowsUpdate thru a proxy. It's the chicken-or-the-egg.... I can't download the WindowsUpdate client using WindowsUpdate, because WindowsUpdate is broken. I was hoping for an EXE or an MSI that I could execute locally....
  15. 2013/01/09
    batsona
    Y'all are going to whip me... It turns out that all other Windows hosts that needed to run Windows Update, were moved to a different proxy about 2 months back, and they all started working fine. Apparently the problem does center around the particular proxy I'm using. I'll be switching to this new proxy within the next 10 days or so. Routing 'direct' to the Internet is not an option, I must use a proxy. SUch is life working in a large enterprise; -- this info just didn't reach me for 2 months!
  16. 2013/01/09
    Smack :D
    Well, at least we go where we needed t get...
