Resolved spinning circle follows curser
Discussion in 'Windows 7' started by cbumpkin, 2015/01/26.
  1. 2015/01/26
    cbumpkin
    cbumpkin Well-Known Member Thread Starter
    I have a spinning circle on the right side of the curser when I click on an icon. It continues to spin until I release the left mouse button. this happened after a power failure yesterday. No other problems that I can find.
  2. 2015/01/26
    Why do you hold the mouse button for? Click and release. Mine does the same thing while it loads the program. I just click and release and be done with it.
    cbumpkin
    I dont hold the mouse button. It spins as I drag the mouse across the desktop to get to the icon.
  5. 2015/02/15
    Hi cbumpkin,
    Surely an Icon on the Desktop is active and normally requires Double Left click to open?
    Unless you have set the mouse for 1 click operation.
    Do you mean that you are moving the cursor across the Desktop and a spinning circle is following the cursor?
    Or have you clicked on something which is trying to open?
    Please clarify. :confused: Neil.
  6. 2015/02/15
    cbumpkin
    spinning circle
    Yes neil the circle follows the curser when I drag to click the icon. my mouse is set to double left click to open.
    I have just opened screen saver and am going to the Icon. Y ou know I never have a simple problem.
  7. 2015/02/15
    cbumpkin
    Neal this is no big deal all functions are working properly. This spinning wheel just started a few days ago and I just wandered what might be causing it.
  8. 2015/02/16
    What is the cursor/pointer doing when it's in the middle of the screen (idle).
    Is there a spinning circle next to it? Neil.
